Official SVS Owners/Support Thread. - Page 853 - AVS Forum | Home Theater Discussions And Reviews
 4151Likes
Old 01-21-2017, 08:47 PM
mthomas47's Avatar
Quoted: 2994 Post(s)
Liked: 4095
Originally Posted by twodollarcuts View Post
Anyone have suggestions for rocker switch repair? I bought a PB10 ISD about ten years ago and today when turning it off the rocker switch pops out. I'm quite sure I can repair it myself, but don't know where to buy the switch from or even if I did, the amps or voltage I need. Any help would be appreciated. Thanks.
Hi,
I would just contact SVS. They should be able to provide you with any information you need, and may even have a replacement part that will fit your sub.
Mike
Matt2026 likes this.
mthomas47 is online now
Old 01-22-2017, 04:09 PM
drunkpenguin's Avatar
Quoted: 1331 Post(s)
Liked: 1333
Dumb quetion:
I need an extension cord for a PC13 Ultra. I need about 15'. What gauge I should aim for?
Just 'cause you're right doesn't mean I'm wrong
drunkpenguin is offline
Old 01-23-2017, 01:28 AM
Quoted: 58 Post(s)
Liked: 6
Originally Posted by George Spyros View Post
Hi again fellow bass-heads!
A few pages back, i was contemplating the upgrade from pb-1000 to pb-2000.
So i did, i took the step... off went the pb-1000, here comes my brand new pb-2000.
Yeahhhhh -not so fast-... .
LED indicator is not working!
I cannot see it go blue-or orange (stand by).
The sub seems to work fine otherwise. More tests to follow...
what i havent confirmed yet is if it goes to stand-by mode (orange), since... no led. I will need a wattage meter, to monitor that.
For a brand new 900euro sub, of course this is not very good!
I will contact SVS of course, but i would hate to send it back. It will cost a lot and will take a long (i am in Greece, and i bought it from europe, it is a 40kilo huge package!)
Just wanted to share it and to see if anyone had any similar experience.
I fixed-it .
It was a loose wire for the LED. PB-2000 rocks.
As an upgrade from pb-1000, the difference is obvious especially in movies.
For example the Prometheus movie, in the start, when the spaceship hovers above, (it needs to be run too hot to see the difference, as much as +10db), the pb-1000 would max-out without really shaking the room. After a certain point of trying to turn up sub volume even more, you could see/hear that there was nothing more it could give to you. It was already maxed out.
You could of course listen to new things with pb-1000 -not hearable with ordinary speakers- you could feel a slight rambling, but not to the point you could say it is enough. Something was just missing, just before when you were about to reach climax... you wouldnt. Almost TOO close. Perhaps in a smaller room, or a different position, or lower listening volumes would reach absolute climax. But not my case.
With pb-2000 it just didnt couldn't be maxed out. As i said i did a +10 adj just for testing the sub (gonna leave it in +3 after i play a while), and i just felt no need to test it further. I was not maxed-out, plenty of headroom left, and i felt that it was more than enough, deep and loud, and i got the feeling that i was after. It was the "one".
If you are a movie guy, and not in a very small room (like a 14sq meters), i strongly suggest going for the PB-2000 instead . However notice that it is also substantially larger from pb-1000, the grill ads 5cm in front of it. I like it thought.
Any other questions, if i can answer, free to ask.
George Spyros is offline
Old 01-23-2017, 01:43 AM
Quoted: 58 Post(s)
Liked: 6
Is there any Poll, regarding how "HOT" people run their subs after Audyssey-YPAO ?
For example, in calibrated range (up to +1,5db)
Just a tad (up to 3-4db)
O decent boost (up to 6-7db)
Never satisfied (even more)?
Just to see how weird i am.
I've seen numerous posts with people tuning subwoofers up, even +10db, but it would be nice if we could make a proper statistic out of it.
Old 01-23-2017, 06:58 AM
Methodical_1's Avatar
Quoted: 347 Post(s)
Liked: 142
I go crazy when the wife is not home. Even when I don't I get the light flash from top of the basement steps to turn it down. She says it's rattling the house.
It will get worse as I am going to order up a 2nd subwoofer soon. I've always love lots of bass ever since installing the 2 Bazookas in my car, but I must have the other speakers to even things out, so you can imagine it gets really loud some times.
HT Configuration: 7.2.4 l Panasonic Plasma (65") l Denon X4300H l Mono 7 amp l Behringer FBQ3102 EQ l Polk RTi10s l Polk CSI-5 l Polk FXi-30 (x4) l Infinity ERS-610 (x4) - Atmos l SVS PB-2000 l Polk PSW 505 (temp) l Oppo BD-93 l Denon CD player/Turntable 1 Cassette Deck l
Subwoofer Trim and Audyssey EQ setup guide
Methodical_1 is online now
Old 01-23-2017, 07:08 AM
mthomas47's Avatar
Liked: 4095
Originally Posted by drunkpenguin View Post
Dumb quetion:
Hi,
A 14 gauge power cord is a good standard to use. If I were you, I would just buy a longer replacement power cord, if they come in the specific length you need, rather than connecting the existing power cord to an extension cord. This is a power cord that I am using for a PB16. Prior to that, it powered a PB13 in the same spot.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Mike
TomC1315 likes this.
Old 01-23-2017, 07:22 AM
mthomas47's Avatar
Liked: 4095
I fixed-it .
Congratulations on your new PB2000! The part about not being able to quite reach climax before sounds disappointing.
Let me answer two questions in one post. First, most people do add a sub boost, post-calibration. How much they add depends a lot on the master volume level. For Audyssey users, with DEQ (which has its own bass boost) engaged, the average boost is about +3 to +6. Without DEQ, most people would add an even larger sub boost.
But, how you add the boost, is important in order to keep your sub from distorting in the process. And, it doesn't sound as if you are adding the boost with the sub gain. It sounds as if you are just adding it with the AVR trim, which is not the best way to do it. Please read the lengthy post in my signature: "Subwoofer Trim and Audyssey EQ". The information on gain/trim protocols applies equally well to any system of automated, or manual calibration. If you have YPAO, or some other automated system, just pay attention to what your minimum trim level settings are, when you apply the advice in the post.
Mike
Old 01-23-2017, 07:25 AM
Liked: 1333
Originally Posted by mthomas47 View Post
Hi,
Mike
Excellent idea, thank you!
mthomas47 likes this.
Old 01-23-2017, 07:28 AM
Quoted: 58 Post(s)
Liked: 6
hey thanx for you input. im familiar with how to add boost, i've spend hours reading through all these forums. i am just, reducing the trim levels of audyssey settings. instead of -10, i go to -6 for example.
Old 01-23-2017, 07:36 AM
mthomas47's Avatar
Liked: 4095
You are very welcome! Since you do have Audyssey, you still might find that post an interesting read.
Old 01-23-2017, 11:04 AM
headshrinker2's Avatar
Quoted: 58 Post(s)
SB-2000: Thumbs up
For anybody looking for a sub that does excellent double duty for music and movies,
I would strongly recommend the SVS SB-2000. I'm a music first, movies second kind-of-guy. I'm really pleased with the performance of the SB-2000 in both settings. Clean, deep and fast with music. Plenty of fun for the movies- I don't need for the low frequencies to shake the house or knock me off my chair. I was worried the SB-2000 might excel on music, but leave me wanting more for movies. At least to my ears, not the case!
gnk1 and TomC1315 like this.
headshrinker2 is offline
Old 01-23-2017, 12:36 PM
garnuts's Avatar
Quoted: 83 Post(s)
Liked: 60
See this thread:
Do you run your sub "hot"???
Living Room: Denon X4000, XPA-5, Polk RTiA9, CSiA6, RTiA3-wides, FXiA4, OWM3, SVS PC12+, 4 Shakers, Epson 5030, VApex 92”, Sony XBR9 52”, PS3, Xbox 360, Darbee, Harmony 1.
Bedroom: Denon X2000, Polk: RTiA3, CSiA4, RTiA1, OWM3, SVS SB12-NSD, Sony XBR-55X850B, Sony BPD-S590, Xbox 360, RPi2-RasPlex, Darbee, Harmony 510.
Home Office: Onkyo 707, Polk: LSiM 703, LSiM 704, Monitor 70, Yamaha SW315 x 2, Turntable, Triple Monitors, Harmony 610.
garnuts is offline
Old 01-23-2017, 12:49 PM
AllenA07's Avatar
Quoted: 684 Post(s)
Liked: 557
For me about a 6db boost is the sweet spot, however that is going to depend on a lot of factors that are going to be specific to you. Room acoustics, the capability of the subs, and personal preference are all going to come into play.
My Theater: The Ugly Theater
AllenA07 is offline
Old 01-23-2017, 12:55 PM
Liked: 1333
I run mine a few db hot also. I was a kid in the 90's when everyones car went BOOM BOOM! You just never outgrow that.
Old 01-23-2017, 02:07 PM
saprano's Avatar
Quoted: 542 Post(s)
Liked: 537
Got the new amp in Saturday and everything is working as it should. No volume drop outs when adjusting. I noticed the gain is much higher too. Before i had to set it to the 2 o' clock position to get 78db, now it's around 11 to 12.
I think it's an understatement when i say i'm glad all this is finally done.
home theater addict
saprano is offline
Old 01-23-2017, 07:01 PM
ceh383's Avatar
Quoted: 421 Post(s)
Liked: 2719
I like to run my subs a little hot. Running Dirac allows me to save different house curves and switch on the fly. I currently have two curves, 1 for movies which is 4db hot, 1 for music that is 6db hot. This works best for me in my room.
Yamaha RX-A2020 | Outlaw M-2200 (x5) | Oppo BDP-103 | Sony CDP-CE500 | Dish VIP622
Definitive Technology BP-8060ST : CS-8060HD : PM-1000 | SVS PC12 Plus | PSA S1500
Sharp LC-70C6400U | miniDSP DDRC-88BM | Belkin PureAV (x2)
ceh383 is offline
Old 01-23-2017, 08:09 PM
saprano's Avatar
Quoted: 542 Post(s)
Liked: 537
Wanted to add that SVS has been great trough this whole 2 weeks (wow). Was very frustraded in the beginning and they amply helped to solve my issues. CS is one the best i've experienced.
Thanks again, Ed, for the SoundPaths.
Alan P, fredxr2d2 and Matt2026 like this.
home theater addict
saprano is offline
Old 01-23-2017, 08:33 PM
januza's Avatar
Quoted: 279 Post(s)
Liked: 150
I run my 3 Ultras +10 db... nothing less. Its only after I added a 3rd ultra I feel im really pressurizing my room like I can in my car..
januza is offline
Old 01-24-2017, 08:18 AM
cchunter's Avatar
Quoted: 520 Post(s)
Liked: 810
I run my SB13 Ultra 3dbs hot for music and 6dbs hot for movies.
5.2 Livingroom
Sony 65XBR850D 4K
Marantz SR7011
Klipsch RB-75's Cherry, RC-64II, RS-52's Cherry
SVS Dual SB13 Ultra's
Oppo UDP-203 Sony PS4 Panamax 5300PM
cchunter is offline
Old 01-24-2017, 11:19 AM
twodollarcuts's Avatar
Hi,
Mike
I tried and they said to just contact an electronics repair service here in Houston. They didn't have one to recommend, nor did they have any information regarding the type of switch. I'd happily take it to a service place, but I have the feeling that I could do it provided I knew the correct part. Is there a place that has this information that you might know about? Thanks for the reply.
twodollarcuts is offline
Old 01-24-2017, 12:25 PM
mthomas47's Avatar
Liked: 4095
No, I don't know where else to inquire. I will say, though, that the advice you can get on the phone sometimes depends on who you are talking to there. If I were you, I would take a photo of that switch and attach it in an email to Ed Mullen directly. I would be surprised if someone in their engineering department couldn't help.
On second thought, another source you could try is Tom Vodhanel, of PSA Speakers. He was one of the founders of SVS, and I have seen him help people with questions on some of the older SVS subs, before. Tom is a nice guy.
Mike
Old 01-24-2017, 04:20 PM
Ed Mullen's Avatar
Quoted: 111 Post(s)
Liked: 307
Mike
Once a power switch breaks, it can't easily be repaired and should be replaced. Sourcing a switch isn't too hard - there are a few on Parts Express which would work.
But actually replacing the power switch on the older BASH amps is fairly involved surgery. The switch is glued to the plate and the switch and all of the AC connections are covered in black liquid RTV. The AC wires need to be cut, the switch needs to be hogged out of the plate, the AC wires need to be spliced back into the new switch along with fresh spades, and then adhesive and RTV needs to be re-applied to seal off the plate and secure the switch.
Unless the owner is experienced and qualified to perform this type of electrical work, it's best to take the amp to an electronics repair facility and have the switch replaced by a professional. That way you'll have peace of mind and know it's done right.
Ed Mullen
Director - Technology and Customer Service
SVS
"What We Do In Life, Echoes In Eternity"
Ed Mullen is offline
Old 01-24-2017, 04:27 PM
mthomas47's Avatar
Liked: 4095
Thanks, Ed! That certainly doesn't sound like something I would want to try, particularly considering my track record with amp replacement.
Mike
Old 01-26-2017, 07:53 PM
bern43's Avatar
I've decided to go with the "downsizing" strategy and just ordered the SB16. I'm still within my return window for the PB-2000 so that will likely be going back assuming the SB16 performs like I think it will. Based on everything I've read, it sounds like I won't be losing too much if any low end making the switch. I'll post up some first impressions once I get everything set up.
bern43 is offline
Old 01-27-2017, 10:22 AM
ClydeOberholt's Avatar
Quoted: 14 Post(s)
Liked: 36
I think you're going to be pleasantly surprised at what the SB16 is going to do. Of every sub SVS has designed, the SB13 and SB16 are my personal favourites!
ClydeOberholt is offline
Old 01-27-2017, 08:41 PM
EricST's Avatar
Quoted: 104 Post(s)
Liked: 51
Do I need a new sub?
I have a Bic America F-12 and it serves its purpose. I kinda want a new one to go with my new PSB X2 series and I like either the PB 1000 or 2000. Question is am I taking a big enough step up to justify the $500/ $800?
60" Samsung KS-8000
Oppo 203 UHBD
Denon X6300H eceiver
PSB X series 7.2.4
SVS Dual PB-1000
SVS Prime Elevation
EricST is offline
Old 01-27-2017, 09:52 PM
flamjam's Avatar
Quoted: 67 Post(s)
I look forward to your thoughts on the SB16. I am trying to decide whether I should run 2 x PB2000's or 1 x SB16. By the looks of the specs, the SB appears to reach pretty low for a sealed.
flamjam is offline
Old 01-27-2017, 09:53 PM
aKa DaShiznit's Avatar
Quoted: 213 Post(s)
Liked: 141
Absolutely!! I replaced Dual BIC F12's with Dual SB12NSD's and those were much better but it wasn't long before I jumped to the Dual PC-2000's. I can go as far to say just one of my PC-2000's would be better than the 2 F12's so going to 1 PB-2000 should be a pretty big upgrade for you. Even the PB-1000 would be an upgrade. IMHO either are worth the extra money easily.
Samsung UN65KS8000/Samsung UBD-M9500/Denon AVR-x6200w/Emotiva XPA-3 Gen 1
DefTech StudioMonitor 65 x3(L/C/R),ProMonitor 1000 x4(Surround),DI5.5R x4(Atmos/DTS X)
SVS PC-2000 x2(Subs)/PS4 Pro/Xbox One S/APC H15/Logitech Harmony Elite
aKa DaShiznit is offline
Old 01-29-2017, 10:09 AM
Quoted: 125 Post(s)
Liked: 70
I run maybe 5 dB hot, though on movies that I know have a lot of LFE and the kids aren't asleep I've been known to bump the sub gain 2 clicks :-)
HT: OLED65E6P, STR-DN1050, UBP-X800, Take Classics, Dual SB2000's
LR: 47LW5600
Internet limited to 3MB DSL, so no HD / UHD streaming for me :(
Long live physical media!
Magellan55 is online now
Old 01-29-2017, 05:10 PM
Liked: 1333
Question, I'm ordering a 2nd PC13 Ultra after have one for many years. Time to go dual for the first time! Anything I should know? I've been using my existing sub without using any of the foam plugs, but I'm wondering if there is any advantage to using 1 sub with no plugs and 1 sub with some plugs to get different types of base out of each one. Is there any science to using dual PC13's or should I just experiment to see what I like.
Speaker Systems , Svs , svs pb-2000 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Pb13 Ultra , Svs Pc12 Nsd 12 Inch 400 Watt Powered Cylinder Subwoofer , Svs Pc12 Ultra , Svs Sb1000 12 Inch 300 Watt Powered Subwoofer , Svs Sb12 Nsd Charcoal Black Vinyl 12 Inch 400 Watt Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Svs Sb2000
