Official SVS Owners/Support Thread. - Page 871 - AVS Forum | Home Theater Discussions And Reviews
 4109Likes
post #26101 of 26116 Old 04-27-2017, 11:13 AM
mthomas47's Avatar
Quoted: 2899 Post(s)
Liked: 3899
Originally Posted by Ed Mullen View Post
Right - the SB-2000 has on average 3-3.5 dB higher max output across the entire pass band (so call it 1.5X stronger on average). The 2000 driver is more robust (even though they look similar) with respect to power handling, and the Sledge 500 has considerably more real world power than the 100W difference in power ratings would otherwise suggest.
Thanks, Ed! Does the same thing hold true for the difference between the PB12 (or PC) NSD and the newer ported 2000 models? This kind of question comes up fairly frequently on various threads, and I had it wrong.
Mike
mthomas47 is online now
post #26102 of 26116 Old 04-27-2017, 12:44 PM
Ed Mullen's Avatar
Quoted: 107 Post(s)
Liked: 300
Mike
They are close at 16/20 Hz (mostly port and box size), and above that (25-80 Hz) the PB/PC-2000 has about +3 dB over the NSD.
mthomas47 likes this.
Ed Mullen
Director - Technology and Customer Service
SVS
"What We Do In Life, Echoes In Eternity"
Ed Mullen is offline
post #26103 of 26116 Old 04-27-2017, 12:59 PM
mthomas47's Avatar
Liked: 3899
Thank you again!
post #26104 of 26116 Old 04-27-2017, 06:46 PM
Quoted: 99 Post(s)
Liked: 92
The SB12-NSD isn't quite the bargain it was just 3 days ago. Apparently Huppins/Onecall realized they are the only internet seller that still has them in stock, and brought the price up $50. I would suspect that means they are low stock, and selling reasonably well, probably partially due to all the recommendations on AVS.
Denon AVR-4520CI
Emotiva XPA Gen3 3 channel
Klipsch Reference II, auditioning Klipsch RP
SVS SB12-NSD x4
OPPO UDP-203
TiVo Roamio, sometimes buzzy Samsung Plasma
drh3b is offline
post #26105 of 26116 Old 04-27-2017, 08:53 PM
gene4ht's Avatar
Quoted: 852 Post(s)
Liked: 896
Just wanted to jump in with a brief subjective PB 2000 comment...
We periodically encounter posts requesting comparisons/opinions between various ID subs within the PB-2000's value range. Databass, test report, and various anecdotal GTG information will surface supporting the prowess of one sub over the other. Although the numbers do tell a story, they do not tell how a sub sounds. And most of us understand that a room's physical and acoustic properties, sub location(s), and proper set up all influence a sub's performance. Having said this and as a previous owner of dual PB-2000's, I still hold them in high regard relative to FR and in particular sound signature and sound quality in medium sized and even some large rooms for both movies and music. To put this in perspective, I've auditioned in my home comparable and larger products from PSA and JTR. Also, as you're both aware, I've recently owned PB-13 Ultras and currently own the PB-16's. Some subs may/will outperform the PB-2000's in terms of output. However, IMO few have better sound quality. YMMV
jamiebosco, stikle and mthomas47 like this.
Epson: 5040UB | Elite: 115" Fixed Frame CinemaScope (2.35:1) | Onkyo: TX-NR636 (5.2.2) | Klipsch: RF-7 II's, RC-64 II, RS-62 II, RB-61 II MICCA: M-8C (Atmos) x 6 | SVS: PB16-Ultra x 2 | Philips: BDP7501 Oppo: UDP-203
gene4ht is offline
post #26106 of 26116 Old 04-28-2017, 06:34 AM
mthomas47's Avatar
Liked: 3899
Ed,
When you get a chance, would you please explain the Room Gain Compensation feature of the PB16? The Owner's Manual doesn't provide much information on what it actually does, or how to employ it. Does it boost the selected frequency by some fixed amount, or does it cut the selected frequency? It sounds more like attenuation to me, but I don't remember seeing an explanation of it. I am also not clear on what the RGC slope of 6db or 12db does in this context.
Thanks for the help!
Mike
gene4ht likes this.
post #26107 of 26116 Old 04-28-2017, 08:15 AM
jamiebosco's Avatar
Quoted: 27 Post(s)
Liked: 39
Mike
Not meaning to step on Ed's toes but thought I'd throw my 2c in as I had one of each (PB12-NSD & PB-2000) and ran them together for several months. Whilst the PB-2000 definitely had a bit more impact in the mid-bass range , I noticed the difference waaaayyy more down low. In my room the NSD had very little output under 17-18hz. The PB-2000 on the other hand still has noticeable output around the 15hz range . The Edge of Tomorrow intro would show this off very easily, with the NSD only playing the first 3 tones (30,25,20) and only some minimal cone movement on the 15hz tone. The PB-2000 shakes the house on the 15hz tone. The WWZ hand grenade scene is another where the NSD would drop off about half way through the sweep, whereas the PB-2000 does this scene very well.
gene4ht and mthomas47 like this.
Display: Panasonic P65ST60 65" Plasma
AVR: Denon X-1000
Speakers: PSA MTM-210C ( C ) , PSA MT-110 (L+R) , James Loudspeakers S-62 (Surrounds)
Subwoofers: SVS PB-2000 x 4
jamiebosco is offline
post #26108 of 26116 Old 04-28-2017, 08:53 AM
gene4ht's Avatar
Quoted: 852 Post(s)
Liked: 896
I concur...had the same experience with the same scenes. Not only does the PB-2000's response go that low but it sounds good doing it. Other subs seem to "rumble" while the PB-2000 for lack of better descriptors plays...tight, smooth, clean, and clear.
jamiebosco likes this.
gene4ht is offline
post #26109 of 26116 Old 04-28-2017, 10:25 AM
stikle's Avatar
Quoted: 683 Post(s)
Liked: 708
I recently relocated an old rarely used PB10-NSD to my theater room to see what would happen. I've got it behind my MLP for nearfield impact. Wow. Aside from throwing my back out lifting it improperly, I'm starting to get used to it. I actually had to turn the gain down a little bit as it was a little overwhelming and threw off the balance in the room.
I'm still playing with it, but so far...yeah. PB10 + 2x PB-2000 is pretty awesome so far. That's a lot of bass for my little theater.
gene4ht and jamiebosco like this.
Seth-o-Plex featuring Atmos/DTS:X 7.3.4 & 4K! - Vizio | Denon | Oppo | Onkyo | SVS | Mirage
stikle is offline
post #26110 of 26116 Old 04-28-2017, 11:50 AM
Liked: 0
SALE OR TRADE my SVS PC-2000: Hi SVS people - I'm in the NYC area and would love to trade my like new PC-2000 for a PB-2000 on the off chance that fits anyone's needs. My place is just too small for the PC-2000, so going back to a cube works for us. If anyone's interested in just buying it, I'll do $675.
P.S. My apologies if I've posted this in the wrong place - kind of new here.
jeremyjava is offline
post #26111 of 26116 Old 04-28-2017, 12:09 PM
Pogre's Avatar
Quoted: 41 Post(s)
Liked: 42
Ed,
Mike
I found this digging around their site.
"ROOM GAIN COMPENSATION
This menu option compensates for excessive amounts of ‘room gain’ (a rising low-end bass response most common in smaller listening rooms). Excessive room gain can create a bloated or bottom-heavy sound from the subwoofer.
The acoustic roll-of slope of the SB13-Ultra is designed to complement available room gain in most listening spaces, so this menu control is rarely used with the SB13-Ultra. It is more commonly used with the SVS variable tune models (PB12-Plus, PC12-Plus, PB13-Ultra, PC13-Ultra).
The room gain compensation control is adjustable for frequency (40 Hz, 31.5 Hz, 25 Hz) and slope (6 dB/octave and 12 dB/octave). When enabled, this control will reduce the output of the subwoofer below the selected frequency. The steeper the selected slope, the more aggressive the effect. The factory default setting is Disabled.
AVR: If the A/V receiver set-up function equalizes the subwoofer channel (such as Audyssey MultEQ XT or XT32), the room gain compensation control is not required. If the A/V receiver set-up function does not equalize the subwoofer channel, the room gain compensation may be beneficial to reduce excessive amounts of low-frequency energy in smaller listening rooms to help restore a more balanced presentation.
2-CH: If excessive amounts of low-frequency energy are present in smaller listening spaces and the presentation seems bloated or bottom-heavy, the room gain compensation may be beneficial to help restore a more balanced sound."
Clicky
Dunno if that answers your question, but I'm guessing it's more descriptive than the manual.
Pogre is online now
post #26112 of 26116 Old 04-28-2017, 12:53 PM
mthomas47's Avatar
Liked: 3899
Clicky
Thank you very much! That's exactly the kind of description I was looking for. I assumed that the RGC attenuated only, rather than boosting, but the question came up in another thread, and I wanted to be sure.
Mike
post #26113 of 26116 Old 04-28-2017, 02:01 PM
Ed Mullen's Avatar
Quoted: 107 Post(s)
Liked: 300
Mike
The RGC is essentially an adjustable high pass filter. It attenuates output below the selected frequency. The rate of attenuation is defined by the slope (6 dB/octave or 12 dB/octave).
Ed Mullen
SVS
post #26114 of 26116 Old 04-28-2017, 02:23 PM
mthomas47's Avatar
Liked: 3899
Thanks, Ed! I appreciate the additional clarification.
post #26115 of 26116 Old Yesterday, 07:07 PM
retro124's Avatar
Quoted: 1155 Post(s)
Liked: 896
Hey guys, one of our AVS family member needs help so please take a look and if you can pick up some movies for youself.
Robert had over 1000 movies and now he is 1/2 sold out. I personally picked up a lot of movies I need to count it but ot is close to 200 what Robert said.
Anyway thanks all for help !!!!
Entire 1000 Blu-Ray Collection Part Out Due to Health Reasons-Look Here 4K/3D/BluRay!
Denon X6200W
Klipsch RF-7II's, RC-64II, RB-81II's, RS-62II's
SVS 2x PC12-Pluses
Sony XBR65X850B, Oppo 203
Emotiva XPA-200
Apple Mac mini, Sony PS3,
retro124 is online now
post #26116 of 26116 Old Today, 07:51 AM
EricST's Avatar
Quoted: 95 Post(s)
Liked: 46
Can I get away with adding two Evaluation Atmos in the rear of my HT if I already have a pair of PSB XA in the front?
60" Samsung KS-8000
Oppo 203 UHBD
Denon 2200X receiver
PSB X series 5.2.2
SVS Dual PB-1000
The Force will be with you ...always.
EricST is online now
Speaker Systems , Svs , svs pb-2000 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Pb13 Ultra , Svs Pc12 Nsd 12 Inch 400 Watt Powered Cylinder Subwoofer , Svs Pc12 Ultra , Svs Sb1000 12 Inch 300 Watt Powered Subwoofer , Svs Sb12 Nsd Charcoal Black Vinyl 12 Inch 400 Watt Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Svs Sb2000
