Official SVS Owners/Support Thread. - Page 880 - AVS Forum | Home Theater Discussions And Reviews
 4303Likes
post #26371 of 26378 Old Today, 09:48 AM
Alan P's Avatar
Quoted: 5032 Post(s)
Liked: 3709
If you are going to upgrade to an AVR with SubEQ HT, then it is less likely that you will need a MiniDSP. That being said, there are plenty of folks around here with both.
Alan P is online now
post #26372 of 26378 Old Today, 10:34 AM
Darth Omi's Avatar
Quoted: 31 Post(s)
That is what I was thinking. Have the two PB2000's in the front connected to one of the sub outputs, treated as one (they will be equidistant to MLP) and have the PC2000 behind the couch to be connected to the second sub output.
Darth Omi is offline
post #26373 of 26378 Old Today, 10:53 AM
jnelson2000's Avatar
Quoted: 280 Post(s)
Liked: 308
Originally Posted by guller View Post
SVS Ultra SB16 digital screen.
Does anyone else's screen turn on for no reason? I have it set to timeout in 10 seconds (which doesn't work) and it just stays on all the time until I manually toggle it off in the app. Then a few hours later it pops back on. Is there a way to update the software?
Quick tip. Set the Sub Display to Off in system settings. And leave timeout for 10 seconds. Not real intuitive but it will stay off doing that.
Sony XBR-55A1E, LG OLED 65G6P, LG 55EF9500
Anthem AVM 60, Anthem MRX720
Oppo UDP-203, Sony UBP-X800
Dynaudio Focus 210C/260, Dynaudio DM Center/2/6, Dynaudio IC17, Dynaudio Contour SR
AT 44-DA
SVS SB16-Ultra
jnelson2000 is online now
post #26374 of 26378 Old Today, 10:57 AM
Quoted: 12 Post(s)
Liked: 3
Originally Posted by cchunter View Post
Have you ever tried a sealed sub? I always owned ported subs then went to an SB13 because I hated the port chuffing when playing at loud volumes. I will never own another ported sub after going sealed. I listen 50/50 music and movies and I listen at very loud levels at times. 0 to -15 dependng on the source. I've never heard any unusual noises come from either of my dual 13's. Just a thought.
I haven't tried one mostly because i get little room gain in my fairly large room and i wasn't willing to give up the low end. I may have to just give it a shot though.
DarkEnigma is online now
post #26375 of 26378 Old Today, 11:38 AM
mthomas47's Avatar
Quoted: 3243 Post(s)
Liked: 4567
Originally Posted by DarkEnigma View Post
Hey guys,
I made a post earlier in this thread about my pb12 plus potentially bottoming out during movies and making a sort of knocking noise. I was told to contact SVS, which i did, although they told me it was difficult to tell what was happening based on the videos i sent. I was told the issue would be escalated and i should expect a response by email, which I never received. I didn't feel like bothering SVS over what seemed to be an issue in only one movie so i let it be. But i watched WarCraft yesterday, since the ultimate list of bass movies thread here recommended it and again while most of the movie sounded great, I could hear some distracting "flapping" coming from the driver cone area occasionally. I replayed the scene to confirm that it wasn't chuffing that i was hearing. I ran a pb2000 along side it, which was actually chuffing a bit, but not enough to be audible over everything else playing in that scene, where as the flapping from the pb12 plus was (-10.0 MV on the AVR, -5.0db on subwoofer channel in the avr and -5.0db on the pb12plus itself).
I've also noticed this at high music playback (i play in the -5.0db to 0.0db range, since i like it loud sometimes and i only use 2 channels for music). The pb12 plus will (depending on the song of course) make a flapping noise that is audible over the music. It sounds kind of like a "poof" sound where you'd expect a lot of air to be coming out of the ports but their isn't. From the research I've done, it seems like the 12 plus is hitting it's excursion limits. But why is the pb2000, which seems to have a lot more driver movement than the 12 plus, not making these noises loud enough to be distracting and the 12 plus is?
I'm still within the 45 day trial period so i was honestly considering just returning it, but before i bothered SVS again i figured i'd try here one more time to see if i could get any advice. Faulty sub, or is this something expected when high powered subs are driven hard? I'm a bit of a newbie so i don't know if these are acceptable high drive artifacts from a sub or not (considering the fact that the pb2000, a lesser sub, doesn't do this audibly at my MLP).
The quality of the bass doesn't seem to suffer too much, there just seems to be an annoying "flapping" artifact.
Thanks .
**I should add that turning down the gain on the amp to -8.0db gets rid of the flapping in both the music and WarCraft but does not get rid of the knocking in the old post i made.
Hi,
Perhaps Ed will read your post and offer some insight into this, but I'm not too sure about the Plus. In theory, it's a more powerful sub than the PB (or PC2000). It's certainly more expensive. But, the 2000 series is a newer design, and it has the advantage of just having the single port tune. The Plus is an older model and is also the lowest model in the SVS food chain to offer variable tuning. And, it seems as if I hear more complaints about that model making bad noises than I do about lower or higher models.
At one time, I had three Pluses in my 6000^3 room, on a concrete slab. (The floor material makes a difference in the amount of tactile response we feel from our subs. Sealed subs are often able to provide perfectly adequate TR on suspended wood floors. Ported subs may be much more helpful for concrete floors.) I had two PC12 Pluses and one PB12 Plus. When I pushed them hard, I could hear them making bad noises. I upgraded to three 13 Ultras, in the same cabinet models, and had no more bad sounds.
I think that you can have ported subs, and enjoy the much more significant low bass and TR they can provide in a large room. But, the ported subs have to be powerful enough to handle what you are asking them to do. My Pluses weren't. My 13 Ultras were.
I would consider one of several options. First, you could return the Plus and get another PB2000. That seems counterintuitive since the Plus should be a better sub. But, as noted above, I'm not entirely sure it is. Second, you could return the Plus and get two PB2000's. Third, you could return the Plus and upgrade the 2000, for dual PB (or PC) 13 Ultra's. I actually like this last solution best, if you are also getting some occasional port chuffing from the 2000. Dual 13 Ultras would take your bass to a different level.
All but the first option involves some additional expense, but that sort of brings us back to the original proposition that ported subs are great as long as you have sufficiently powerful subs for what you are asking them to do. Sealed subs don't generally make any bad noises when they run out of gas, they just stop playing any louder. However, they run out of gas much sooner, below about 50Hz, than ported subs do. And, that is particularly the case if we have large rooms and if we want to hear and feel significant low bass.
Typically, it takes at least two sealed subs, of an equivalent model, to produce as much SPL below about 35Hz as a single ported sub. And, the <35Hz content in movies is what we pay extra for with our subs. So, if you want a lot of low bass, you can have more sealed subs, or fewer ported subs. But, in either case, your subs will have to be powerful enough to satisfy your specific listening objectives without prematurely running out of gas, or making any unpleasant noises.
I hope this helps!
Mike
mthomas47 is online now
post #26376 of 26378 Old Today, 11:58 AM
MATT J's Avatar
Quoted: 111 Post(s)
Liked: 48
??? I have 2 SB-1000s. I love bass. My main use is movies, but I do play a lot of video games and listen to some rock music (Metallica)some bass hip hop and some rap. Would it be more beneficial to get the PB-1000s, or keep what I have?? Which ones will make me really feel the bass, but clean powerful bass?
Thank You!
MATT J is offline
post #26377 of 26378 Old Today, 01:01 PM
mthomas47's Avatar
Liked: 4567
Thank You!
Hi Matt,
I didn't mean to create any controversy, or to make anyone rethink his subs. I was just responding to that poster's specific situation. Some people prefer sealed subs for music, or for their smaller form factor. And, ported subs can chuff if they are pushed too hard with low frequencies. On the other hand, ported subs are also typically able to deliver more SPL below about 50 or 60Hz, and a lot more below about 35Hz than comparable sealed subs. So, a lot depends on your individual preferences and on your specific room, listening distances, etc.
Here is some information which will let you compare earlier SVS sealed and ported subs of the same model. The difference in output at various frequencies should be roughly comparable to the difference in output between SB1000's and PB1000's. You can compare the difference in output between the PB12-NSD and the SB12-NSD and draw your own conclusions as to which you might prefer. Essentially, the ported subs will produce much louder bass below about 35Hz. http://www.data-bass.com/systems
Here is something to think about, though. If you are happy now with your sealed subs, you might not want to become unhappy just because ported subs would give you more clean bass. Ported subs are larger and more expensive to make. But, they can deliver more SPL in the low bass range, and they can provide more tactile response than equivalent model sealed subs. Some people will prefer those attributes and some won't.
Mike
post #26378 of 26378 Old Today, 02:04 PM
Quoted: 12 Post(s)
Liked: 3
Originally Posted by mthomas47 View Post
Hi,
I hope this helps!
Mike
Thanks for the advice. At the moment my room needs duals, and getting dual 13's would considerably increase my budget over the dual 12s so i wouldn't be able to take that on right now. I was considering keeping the 12 plus(even with the artifacts the extra output down low is considerable) and just saving up for about a year and purchasing dual 16s (at once). Or i could trade in the 12 plus for a 13 and add another 13 down the road.
Which option do you think is preferable? The 13s would save me quite a bit of money and i can't seem to tell if the 16s are really worth the extra cash.
Speaker Systems , Svs , svs pb-2000 , Svs Pb1000 10 Inch 300 Watt Powered Subwoofer , Svs Pb12 Nsd Black Vinyl 12 Inch Powered Subwoofer , Svs Pb13 Ultra , Svs Pc12 Nsd 12 Inch 400 Watt Powered Cylinder Subwoofer , Svs Pc12 Ultra , Svs Sb1000 12 Inch 300 Watt Powered Subwoofer , Svs Sb12 Nsd Charcoal Black Vinyl 12 Inch 400 Watt Powered Subwoofer , Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer , Svs Sb2000
