I've listened, THIS BETTER WORK - AVS Forum | Home Theater Discussions And Reviews
post #1 of 26 Old 11-03-2006, 08:12 AM - Thread Starter
swgiust's Avatar
Quoted: 26 Post(s)
OK, so I have a room null at about 63hz. Been messing with my SMS-1 and my
PB12/Ultra-2. Can only get it smoothed out with major boost in the EQ. +6 on
three bands. (not good)
So, I've been debating the best way to fix things. Option 1 add another subwoofer. Which by far is the most fun option (and the most exspensive) or
option 2 invest in some good room treatments.
I had seen GIK acoustics had a special listed here a while ago and when I
contacted them, they gave me the same deal. I purchased 4 Tri-Traps and
6 242 acoustic panels. Bright red (Go Huskers!).
My hope is that by treating the room I can smooth out my bass response. As
well as treating some first level reflections. Giving me an overall better sound.
I do have some homade tube traps and some panels. I will find some secondary
locations for them.
So, opinions, did I do the right thing? Thoughts? Suggestions? Ideas?
swgiust is offline
post #2 of 26 Old 11-03-2006, 08:17 AM
Liaury's Avatar
I can't wait for your opinions, thoughts, suggestions, and ideas.
Liaury is offline
post #3 of 26 Old 11-03-2006, 09:14 AM
ThomasV555's Avatar
Can you move the sub?
This bloody Redcoat said I was a terrorist.
Somewhere along the way I become an Elitist who looks down on the
cheap bastards who call themselves my AV Hobbyist peers.
I am not prepared.
ThomasV555 is offline
post #4 of 26 Old 11-03-2006, 09:40 AM
Jesse S's Avatar
A null cannot be corrected with any amount of eq boost. So it's not a null. Just move the sub somewhere else.
Jesse S is offline
post #5 of 26 Old 11-03-2006, 09:48 AM - Thread Starter
swgiust's Avatar
Quoted: 26 Post(s)
I have had the sub in 4 locations. Front left corner, Rear right corner,
1/2 down left wall and current position 1/3 down the right wall. My room
is perfectly square. So I guess I felt room treatments were the best option.
I know you can over treat a room, but I feel I am far, far away from that.
Room is 18' x 18'. Has a vaulted ceiling 13' high. Peak runs from left to right.
Left wall is solid with a door, right wall is entirely glass. Lower windows are
covered with heavy curtains. Front wall is solid. Back wall has a set of glass
dutch doors going outside. Also covered with curtains.
So if you look at all the wrong things a room can have, I have most of them!
swgiust is offline
post #6 of 26 Old 11-03-2006, 02:18 PM
Nick250's Avatar
Just wait for the treatments. It was a night and day experience for me.
Nick
Nick250 is offline
post #7 of 26 Old 11-03-2006, 02:48 PM
cyberbri's Avatar
Liked: 54
Once you get the treatments in the room, you'll notice a big difference. But if the dip (as opposed to a null) is still there, you can add an eq like the BFD ($100) or the more expensive SMS-1.
I got traps (a little less than you) and treatments, and it improved the sound quality but I still had a number of dips/peaks.
Here's after traps + before BFD, and after adding the BFD:
That's done at 1/6 octave. Actual response is within a 2-2.5dB range for most of the 35-90Hz range, with a rise below that.
cyberbri is offline
post #8 of 26 Old 11-04-2006, 12:37 AM
hifisponge's Avatar
I don't mean to be a pesimest, and I may be wrong (as I'm not familiar with the GIK bass traps) but most bass traps have to be huge to do any effective absorbsion of low bass frequencies. Even the largest ASC Tube Traps (20" in diameter) are most effective at around 250Hz. The fact is that low bass frequencies have huge wave lengths and it typically takes an equally large (deep) absorber to make any difference in standing waves. Even though GIK claims on their website that their traps work down to 50Hz, I would imagine that it isn't doing much down that low.
Again, I may be wrong, and I hope I am. I look forward to hearing your results.
PS - You may need more than four of the traps if you hope to make difference. Measure the results and if you see a slight improvement in your dip, get more of them to stack on top of one another.
Edit: I stand somewhat corrected. The Tri-Traps appear to be more effective at low frequency than a the largest tube traps, though they are still most effective at around 125 - 250Hz, as I suspected.
hifisponge is offline
post #9 of 26 Old 11-04-2006, 01:08 AM
armystud0911's Avatar
So what is it in their design that makes them so effective? Is there a way to make a DIY version that replicates these properties?
armystud0911 is offline
post #10 of 26 Old 11-04-2006, 04:43 AM
craig john's Avatar
Quoted: 554 Post(s)
Liked: 798
http://forum.studiotips.com/viewtopic.php?t=535
http://forum.studiotips.com/viewtopic.php?t=536
Craig
Lombardi said it:
"Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #11 of 26 Old 11-04-2006, 07:58 AM
Ethan Winer's Avatar
Quoted: 267 Post(s)
Liked: 363
Yes and no. You don't need 100 percent or even 50 percent absorption to make a real improvement in peaks and nulls and ringing. For example, if a room boundary reflects perfectly and creates an infinitely deep null, adding absorption that is 25 percent effective raises that null from infinitely deep to less than 15 dB deep. The demo video on my company's site shows a real improvement in the response of a small room all the way down the the 40 Hz lower limit we tested. So it's definitely possible to make a real improvement at low frequencies with good bass traps, even if they're not hugely thick.
--Ethan
Ethan Winer is offline
post #12 of 26 Old 11-06-2006, 05:19 AM
myfipie's Avatar
Quoted: 71 Post(s)
Liked: 72
Oh yes you are correct they do EXTREMELY well at 125 to 250HZ, but at 60HZ you are STILL looking at 8.93 Sabins and 6.53 at 50HZ. If you where to translate that to a absorption coefficient that would be 1.12 at 60HZ and .82 at 50HZ. I dare you to find any bass trap that touches that number. Heck there are products on the market that brag the same 8.93 at only 250 Hz.
note: absorption coefficient numbers are for "A" and "E" mount testing and I am only showing this because some people understand that number better. NO FLAMING ME.
Glenn
Glenn Kuras
GIK Acoustics
http://www.gikacoustics.com
myfipie is offline
post #13 of 26 Old 11-06-2006, 06:23 AM
kgveteran's Avatar
Quoted: 487 Post(s)
Liked: 178
I built two (18"x48").They work great.Biggest effect is the reduction in overhang or ringing.Seems to make the bass sound a bit quicker.http://www.geocities.com/jonrisch/basstrap.htm
Cost was 175.00 for two.
KG
kgveteran is offline
post #14 of 26 Old 11-06-2006, 09:35 AM
Nick250's Avatar
And just to add to the confusion, my setup is in a large living room, dining room and entryway combined . There is just one ninety degree corner anywhere close to sub and speakers. I ordered four Tri Traps. It turns out I only needed one of them! The bass went from somewhat boomy to tight and musical. It was one of those night and day things. I was amazed.
Nick
Nick250 is offline
post #15 of 26 Old 11-07-2006, 04:24 PM
mcallister's Avatar
Quoted: 118 Post(s)
Liked: 41
so any update on how these are doing in your room?
mcallister is offline
post #16 of 26 Old 11-09-2006, 07:43 AM - Thread Starter
swgiust's Avatar
Quoted: 26 Post(s)
They come today. I will be messing around this weekend and will give a full
report asap.
swgiust is offline
post #17 of 26 Old 11-09-2006, 11:19 AM
mcallister's Avatar
Quoted: 118 Post(s)
Liked: 41
awesome!!! I'm about to pull the trigger on some tri traps but am waiting to see your review. I have a nasty null between 60-80Hz.
post #18 of 26 Old 11-09-2006, 11:57 AM - Thread Starter
swgiust's Avatar
Quoted: 26 Post(s)
FedEx delivered my 6 panels and 2 of the 4 Tri traps I ordered...
I'll be setting them up tonight, but can't really do any serious tuning untill
the other traps come
swgiust is offline
post #19 of 26 Old 11-09-2006, 12:07 PM
Tim916's Avatar
Quoted: 12 Post(s)
Liked: 26
You will not regret your decision. Not only do bass traps help smooth the bass at the primary listening position, they smooth the resonse at all listening positions - something that the standard sms-1 does not do.
Tim916 is offline
post #20 of 26 Old 11-11-2006, 07:21 AM - Thread Starter
swgiust's Avatar
Quoted: 26 Post(s)
OK FedEx finally delivered my last two TriTraps. Have them installed in my front two corners (2 in each corner). I ordered them in red, it's a Husker thing, and they are quite the sight to be seen! I also ordered 6 of the panels. I have 1 behind each of my front speakers, 1 below each of my surround back speakers, and 2 on my left wall. The other wall is mostly glass, I installed 3 of my homade panels along that wall behind a heavey curtain, which is closed 99% of the time. I have 2 homeade tube traps in the rear corners.
I have not spent alot of time messing with things yet, but after I had all in place,
I ran my SMS-1. Ruler flat from 200hz down to 40hz. We're talking 2db +- max.
I have a slight hump at 40hz. About 6 db and then it gently rolls off below that.
I have not adjusted much for the 40hz hump, but I will play around today and
see if I can smooth it out.
So remember, I had a 9-10db dip at 63hz which is now gone. Pretty impressive.
I will try to take a picture of the screen so you can see the bass curve display.
Right out of the box I would recommend these traps. They did what they were supposed to do. I am going to play around with them all weekend and I will post my results on Monday.
swgiust is offline
post #21 of 26 Old 11-11-2006, 07:32 AM
billybob_jcv's Avatar
Sounds like the title of this thread should be changed to "I've listened, IT WORKS!"
If you think this post was dumb, you really should read my blog=> http://bumpedhishead.blogspot.com/
billybob_jcv is offline
post #22 of 26 Old 11-13-2006, 05:33 AM
myfipie's Avatar
Quoted: 71 Post(s)
Liked: 72
HECK YES!!!!!!!!! Thank you very much for the report back. When you get a moment please send me a couple pictures if you would. My guys here love to see them.
Glenn
Glenn Kuras
GIK Acoustics
myfipie is offline
post #23 of 26 Old 11-17-2006, 02:06 PM
mcallister's Avatar
Quoted: 118 Post(s)
Liked: 41
so how are things going swgiust? I ordered 4 tri traps today. Anxious to see if they will help my enormous null between 60 and 80 Hz.
post #24 of 26 Old 02-06-2007, 09:38 AM
Rupert's Avatar
breedingamies,
Did your 4 tri traps help?
Rupert is offline
post #25 of 26 Old 02-06-2007, 08:36 PM
cyberbri's Avatar
Liked: 54
Is it a null, or are there two peaks, maybe modal, at 55 and 85Hz? A null won't increase in volume at the same level of the increase overall. If you turn up the volume 3dB, and the "dip" goes up 3dB as well, it's not a null. More likely you just have some peaks.
The tri-traps will help a bit with fr, mainly the ringing and boominess, but to really flatten it you'll need an eq.
Here's my room, before (red) and with 2x "244" panels in each front corner (blue). One Tri-trap is about equal to two of the 244s. Note that this is both sub and mains, with no eq. Peaks at 45Hz and 75Hz, which I brought down with an eq.
15-500Hz
Here's after eqing, combined sub and mains response:
15-200Hz
cyberbri is offline
post #26 of 26 Old 02-06-2007, 09:00 PM
ribbit's Avatar
get the second sub just because it's fun
then get the room treatments.
if you get the room treatments FIRST, there might not be any reason to buy a second sub
Mike C
MKC International
SVSound Philippine Dealer
ribbit is offline
