New <$300 sub choices from Elemental Designs... - Page 16 - AVS Forum | Home Theater Discussions And Reviews
post #451 of 1007 Old 12-15-2006, 06:15 AM
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
Originally Posted by micah3sixty View Post
I believe these drivers have a breather whole through the center of the voice coil. If this whole doesn't have a screen to keep it clear/clean, something could have fallen in there and could be bouncing against the dust cover. Even just a tiny piece of wood may be enough to make the muffled sound you hear. If that's the cause, eD would probably need to either replace the driver (preferred) or at least repair it for free.
That's an excellent point. There may have been wood particles still in the cabinet and entered the driver.
If the driver is disconnected, and shaken with the breather hole facing down, maybe the possible debris will fall out?
Panasonic AE-2000, Carada BW 120", Paradigm Studio 40v3 x 2, Paradigm 690v4, Paradigm ADP 470v3 (rears), Micca M-8C x 4, Volt 6 x 2 (SR), SI DS4-18 in 12cuft X 2, Marantz 7702MKII, OPPO 103D, Emotiva XPA-3,
vitod is offline
post #452 of 1007 Old 12-15-2006, 06:57 AM
Subliminal's Avatar
Also, try holding the driver while it's thumping, out of the box, turn it on it's side and then try turning it on the other sides.
Ok, that sounded stupid. basically, what I'm getting at is the vc might not be aligned right, and turning it on its side might clear up the noise.
If it does, I'd guess the driver needs to be replaced. Luckily eD is really good about their warranty policy...although it sucks to have problems with a brand new sub, I'll admit.
Subliminal is offline
post #453 of 1007 Old 12-15-2006, 07:05 AM
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
Yeah, nothings perfect. It may be defective.
vitod is offline
post #454 of 1007 Old 12-15-2006, 08:16 AM
icehawk_OS's Avatar
That finish looks ugly - more pro audio than home audio IMO. I agree with others here that a normal painted finish or optional veneer would be better.
Is it me or does the inside have a ton of overspray???
I have sound equipment.
icehawk_OS is offline
post #455 of 1007 Old 12-15-2006, 08:36 AM
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
It's an aquired taste. Not as bad as you think. Different. I got used to it.
As long the over spray doesn't effect performance, I don't care.
vitod is offline
post #456 of 1007 Old 12-15-2006, 09:01 AM
micah3sixty's Avatar
I am still surprised that they don't have any filler/dampening material. Usually a must to keep subs from sounding boomy and distorted. My SVS PB10 is probably 1/3 full of what looks like house insulation. Any other thoughts on this?
Micah
micah3sixty is offline
post #457 of 1007 Old 12-15-2006, 09:24 AM
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
It's debateable. Some use them and some don't. The A2-300 doesn't sound boomy at all. But since you brought it up, I may experiment. I'll line the walls with some house insulation and hear the results. It's not going to happen anytime soon, so be patient.
vitod is offline
post #458 of 1007 Old 12-15-2006, 11:21 AM
Dom C's Avatar
Be careful when you do that, you may end up with a fiberglass insulation canon
Dom C is offline
post #459 of 1007 Old 12-15-2006, 11:38 AM
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
Yes, your right. Might go with polyfill instead.
vitod is offline
post #460 of 1007 Old 12-15-2006, 12:12 PM
OvalNut's Avatar
You will want to line the interior walls with about 2" thick fiberglass batting rather than using any type of fill material for a ported sub.
All you're trying to do in this case is knock down any higher frequency mechanical rattles or box resonances, not affect the perfomance of the driver/port combination.
Tim
He drove a black and white pirate ship at 190 mph.
- Dale in the #3 will never be forgotten. Thanks for the memories.
OvalNut is offline
post #461 of 1007 Old 12-15-2006, 12:48 PM - Thread Starter
Willd's Avatar
No.
Willd is offline
post #462 of 1007 Old 12-15-2006, 02:48 PM
Lol, I added fiberglass insulation to a yamaha subwoofer and that's what I got! Luckily, the speaker grill/cover also covered the port opening and kept the flying glass at bay. I'm letting my dad use that sub in his HT.
Micah
post #463 of 1007 Old 12-15-2006, 02:53 PM
Dom C's Avatar
Originally Posted by Willd View Post
No.
Yes, I've had it come apart over time and shoot out the port. I use foam now instead.
Dom C is offline
post #464 of 1007 Old 12-15-2006, 06:46 PM
h1tman's Avatar
Looks like there are some new finish options on the way! Looks like ED is trying to respond to the market feedback. Read more on thier Blog
h1tman is offline
post #465 of 1007 Old 12-15-2006, 06:46 PM
Peppery John's Avatar
Really p***ed off.
Took delivery of the A2-250 on Wednesday and it was working ok until this evening. I switched it on this evening and nothing unless I turn the volume up to maximum and then just a sort of muffled crackle. All the connections are ok and the green light is on, the only other thing I can think of is a problem with my AV receiver. Anyone got any ideas please?
Peppery John is offline
post #466 of 1007 Old 12-15-2006, 06:54 PM
h1tman's Avatar
Originally Posted by Peppery John View Post
Really p***ed off.
John,
Try plugging the some cables straight from the source (IE dvd player or ipod) into your sub. This will gaurantee that there is a signal reaching the sub. IF it still does not work then you probably have a problem. A muffled crackle could be a blown Voice Coil (At least in my limited expierence).
Contact ED immediately. You are under warranty, they may be able to drop ship you a new sub quickly if the sub is the problem. Give them a chance to respond.
h1tman is offline
post #467 of 1007 Old 12-15-2006, 08:46 PM
Thanks, I've tried putting putting the coax connection from the DVD directly to the sub, no signal getting through to the sub. I don't see how that would work without any amplification?
post #468 of 1007 Old 12-15-2006, 08:51 PM
mikeinnj's Avatar
I think you're putting the DIGITAL output of the DVD player into the sub. That means you were sending it 1's and 0's. You gotta use one of the analog audio outputs on the DVD player (Red or White RCA Jack) to get any kind of a signal through. And as for amplification, all the amplification is done by the amp inside of the subwoofer.
mikeinnj is offline
post #469 of 1007 Old 12-15-2006, 08:53 PM
h1tman's Avatar
I don't think the coax connection would work since it sends a digital signal. Connect the red and white rca's on the back of the dvd and plug them into the l and r connections on the amp. There should ve plenty of signal from the dvd player
h1tman is offline
post #470 of 1007 Old 12-15-2006, 09:07 PM
Lol, the penny's dropped.
I'll try it with an analog signal in the morning now, it's too late to start messing on now and the wife's in bed . I'll get back later, thanks for the help so far.
post #471 of 1007 Old 12-16-2006, 06:50 AM
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
Any news?
vitod is offline
post #472 of 1007 Old 12-16-2006, 08:08 AM
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
UPDATE on eD.
http://edesignaudio.com/edv2/ednews/home/blog.php?id=51
vitod is offline
post #473 of 1007 Old 12-16-2006, 09:20 AM
Any news?
Yes, tried it this morning with a direct connection from my DVD and it's making a loud thumping noise with a muffled crackle. I've rang eD and was lucky enough to catch somebody in. He thinks that it's probably the amp at fault or possibly the speaker, there nothing that can be done 'till Monday anyway, but whichever part is faulty they are going to ship one out to me. Meanwhile I'm going to have a look inside and check for loose connections.
post #474 of 1007 Old 12-16-2006, 10:20 AM
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
You mean a whole new sub or parts?
vitod is offline
post #475 of 1007 Old 12-16-2006, 11:02 AM
Parts and fit myself.
Actually he would've sent me an amp out but as they can't send one out until Monday anyway and he hasn't really decided whether it's the amp or speaker that's at fault, I said we'll leave it over the weekend and phone first thing Monday.
I've checked it direct from DVD with an analog signal and the speaker is pumping well, the only way I can describe it is as a thumping crackly tick.
Set up in the normal manner it won't seem to accept a digital signal unless the volume is at maximum and then it's not very loud at all.
The last test which eD suggested, was to directly connect the speaker wires from my receiver to the inline of the sub, which produced nothing apart from one pump of the speaker when I switched it on and one pump when I switched it off.
Lastly I took the back off to look for loose connections and there were none.
post #476 of 1007 Old 12-17-2006, 07:59 AM
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
Keep us updated.
vitod is offline
post #477 of 1007 Old 12-17-2006, 08:10 AM
Darin's Avatar
That narrows it down.
My dual Rythmik Servo sub project (actually quad now, need to update page)
HDM format neutral thanks to the pricing wars of the '07 xmas shopping season :)
Darin is offline
post #478 of 1007 Old 12-18-2006, 08:36 AM
cdub998's Avatar
Well I am taking the plunge as of today. I just put in my order for the a2-300. Now I have to go find a 50ft coaxial to run it to the back of my room.
Xbox 360 gamertag: Cdub998
PSN: cdub998
cdub998 is offline
post #479 of 1007 Old 12-18-2006, 08:55 AM
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
Get ready to wait for a while. My order was put in 12/05/06 and it's still in 'box construction".
vitod is offline
post #480 of 1007 Old 12-18-2006, 09:18 AM
XylerB's Avatar
My order was placed on 11/28 and I was told last monday that he thought it was going to paint... Still shows "in woodshop" as of today. On another note, im picking up a Denon 3806 this week! Im currently running 5 of the eD MTM's, going to order a set of towers and another sub to finish off the system.
XylerB is offline
