The Master List of DVD, HD-DVD & Blu-ray Movies with BASS Thread...With WaterFalls - Page 112 - AVS Forum | Home Theater Discussions And Reviews
post #3331 of 5744 Old 06-22-2009, 01:50 PM
Darin's Avatar
Yes, I agree that 0 should be 0 but my system can not be played at 0 because I have too much power and very sensitive speakers and sub system.
Not to get too far OT, but if it's calibrated, the power and efficiency shouldn't matter. That would affect your ability to reach (or even exceed) "reference" levels (which, IIRC, is 105db peaks at the seats from the satellite channels, and 115db from the LFE channel), but the reference is still the reference. If you calibrate a -30d test tone to 75db, then set the MV reference to 0, that should eliminate the variables of speaker efficiency, amp gain, the room, etc. Of course, it's not perfect, because some systems may have some compression (or just plain inability) that prevents perfect scaling to 105db, but at least you know contented encoded for 75db is 75db @ 0MV, and things should scale from there within your system's limit.
My dual Rythmik Servo sub project (actually quad now, need to update page)
HDM format neutral thanks to the pricing wars of the '07 xmas shopping season :)
Darin is offline
post #3332 of 5744 Old 06-22-2009, 01:57 PM
MKtheater's Avatar
Quoted: 1735 Post(s)
Liked: 1304
That is exactly what I did was turn the test tones down. MV at 0 is still over 105 db's peak, well over actually. It was supposed to be 0 for reference but it did not work I guess. When I get out the spl meter 105 db's peak are at around -15 MV on some movies and -13 MV on others. It should be 0.
Marantz 7702 Atmos
Outlaw 7140 and 5000
Speakers- DIY mini arrays all channels.
subs 2 XXX ported SLLT.
MKtheater is online now
post #3333 of 5744 Old 06-22-2009, 02:26 PM
Kain's Avatar
Quoted: 1499 Post(s)
Liked: 437
You could lower the trim levels for each channel so 0 dB becomes reference. However, this way you will lose maximum potential volume headroom. On my home theater, -5 dB is reference.
Kain is offline
post #3334 of 5744 Old 06-22-2009, 02:33 PM
MKtheater's Avatar
Liked: 1304
All my channels are set at 75 db's and 0 MV is past 105 db's peak, more like 120 db's. The trim goes to -20 db's on all channels and I am there.
Marantz 7702 Atmos
post #3335 of 5744 Old 06-22-2009, 03:02 PM
jaejw1's Avatar
it seems that u guys are playing with numbers to get ur reference at "0" MV
arent u supposed to have all speaker levels set at 0dB when you first run your test tone and then you add/subtract to get all speakers matched at 75dB via splmeter.....
I enjoy my movies also at high volumes.... but movies like Mr.and Mrs. Smith I cant even attempt to watch at close to reference... I have to watch it at -40dB MV without be annoying to neighbors.....
my reference is at -16dB MV...
I did play WAR OF THE WROLDS at almost reference level and both neighbors came outside wondering what was going on
jaejw1 is offline
post #3336 of 5744 Old 06-22-2009, 04:32 PM
lalakersfan34's Avatar
Liked: 25
Not necessarily. The "MV" level at which Dolby Reference Level is attained can vary because different receivers, speakers, and rooms all have an effect. Different receivers use different "MV" scales (some go from -80 to +16 or so, others go from 0 to 70 or 0 to 100 etc). Speaker sensitivity can impact how hard an amp needs to work to achieve a given output level, which also affects what receiver MV setting will be needed to achieve reference level. Finally, a larger room will require more output and more power to reach the same levels as in a much smaller room, against skewing the "MV" setting needed on a receiver to achieve reference level.
I used AVIA so I calibrated to 85dB instead of 75dB, but yes, I set speaker levels to 0, raised the MV until I reached 85dB ("reference level" according to AVIA's test tones),then level matched via SPL meter so all speakers read 85dB. This ends up being about -2dB or -3dB on my receiver's scale of -80 to +16.
Assuming your reference level really is -16MV, you watched Mr. and Mrs. Smith at -24dB from reference. Most people here would classify that as quite modest. I usually listen to movies at somewhere between -8dB and -3dB from reference level. Of course I don't worry too much about neighbors either because they can't hear my HT very easily . I don't know what I'd do if I lived in an apartment...
Any idea what kind of peak bass levels you were reaching there? WOTW DTS is recorded a good 5-6dB HOTTER than normal for reference level, so if you watched it at reference you'd probably have LFE peaks of 120-125dB (assuming your subs are calibrated flat - if they're hot it would be even louder). Very few forum members have subwoofer systems that can easily deliver 125dB peaks in LFE - most of those bass nuts are in the DIY forum
lalakersfan34 is offline
post #3337 of 5744 Old 06-22-2009, 05:30 PM
jaejw1's Avatar
i did test it out and obtained a peak of 98db at the seating area from the lightning that happened just before they ran into the house.. but this was recorded using a dgital splmeter and the MV was at -30db 14db below reference.. i know i posted it here somewhere.. i just did it last weekend..
jaejw1 is offline
post #3338 of 5744 Old 06-29-2009, 08:00 AM
vivid's Avatar
forgive me for such a noob question... but does the format make a huge difference? I ask because I recently set up two ULS-15 and have been trying to find some test material...
I have not bought any BRs, I usually just rent them, but I do have a fair DVD collection but waterfalls that I have tried, (LOTR Two Towers, Matrix, Sum of all Fears, T2, T3, Unbreakable etc) are really lack luster. I had a friend who came over with Transformers on BR and the flip scene was just insane. So does the format DVD, BR, HDDVD make a huge difference, or is the flip scene just that insane that it put other waterfalls to shame?
vivid is offline
post #3339 of 5744 Old 06-29-2009, 09:24 AM
otk
otk's Avatar
as far as format, some will say it makes a big difference and some will not think it's a giant difference
some movies you might want to try are war of the worlds (the one with tom cruise) and cloverfield (and some others, scan the thread and the forum). the newer movies definitely make a big difference no matter which format. they keep raising the bar on the LFE channel
All this noise about noise.
Finding the acoustic sweet spot.
otk is offline
post #3340 of 5744 Old 06-29-2009, 02:41 PM
lfe man's Avatar
Liked: 41
Originally Posted by Kain View Post
Anyone have a waterfall of the first bang during U-571's depth charge scene? I am talking about when you see the depth charge fall into the water, then silence as it submerges deeper and deeper into the water, and then BANG!
Something like this.
chap15 (1:17:15)dts
http://i294.photobucket.com/albums/m...1511715dts.jpg
lfe man is offline
post #3341 of 5744 Old 07-01-2009, 06:20 PM
bori's Avatar
Quoted: 194 Post(s)
Liked: 126
For all u bass lovers check out the movie street fighter on BD.
bori is offline
post #3342 of 5744 Old 07-03-2009, 05:03 AM
mcjasonb's Avatar
Liked: 113
try Cloverfield on BR and Master and Commander on BR. both awesome for bass.
Nearfield rig: Laptop -> JDS Labs ODAC -> Emotiva Mini-X -> Pioneer SP-BS22-LR & SW8-mk2Headphone rig: laptop -> JDS Labs ODAC -> Emotiva Mini-X speaker taps -> modded AKG Q701H.T.: PS3 - Yamaha RX-V2500 - Infinity Alpha 50's - Alpha center - Harmon Kardon HKB6 rears, Epik SentinelMy last.fm profile
mcjasonb is offline
post #3343 of 5744 Old 07-04-2009, 07:39 PM
fj6474's Avatar
I am calling it now, The Unborn movie that comes out next week has a few LFE suprises. It might give WOTW a run.
fj6474 is offline
post #3344 of 5744 Old 07-04-2009, 08:51 PM
Helmutz88's Avatar
Totally one of the best chapter's in HT. The lightning hit 116 db's for me at 14 feet. At -8.
Def Tech BP 2000's
Def Tech BPVX Surrounds
Polk Monitor 70's Wired Together Center Channel
Dual Elemental Design A5-350 Subs
Epson 2030 Projector
Screen Goo Self 120 Inch Screen
Sony Blu Ray
Carver Sunfire TGIII Receiver
Helmutz88 is offline
post #3345 of 5744 Old 07-08-2009, 05:29 PM
Helmutz88's Avatar
I didn't see this movie on the ratings page. But, if you haven't watched 28 Days Later on Blu Ray...your missing out. This movie totally, completely hammered from start to finish. I would score this at least 4.5...
Def Tech BP 2000's
Sony Blu Ray
post #3346 of 5744 Old 07-08-2009, 07:47 PM
SbWillie's Avatar
Anyone seen KNOWING or Push on BR yet??
SbWillie is offline
post #3347 of 5744 Old 07-08-2009, 07:54 PM
MKtheater's Avatar
Liked: 1304
The knowing has some big bass moments for sure. My wife just smiled at me. I will rewatch it at reference tomorrow.
Marantz 7702 Atmos
post #3348 of 5744 Old 07-09-2009, 05:49 AM
SbWillie's Avatar
The last 12 or so minutes of KNOWing for sure!
SbWillie is offline
post #3349 of 5744 Old 07-09-2009, 04:03 PM
kirbybreezy's Avatar
Who put The Hurt Locker up in the OP? It hasn't even released yet....
Jamal Shareef
THX® Certified Video Calibrator
Seattle, WA
kirbybreezy is offline
post #3350 of 5744 Old 07-09-2009, 05:17 PM
OvalNut's Avatar
I just saw the trailer for The Hurt Locker last night.
Oh yeah baby! When the movie's plot revolves around experiencing large explosions at extreme close range, and the trailer shows clips of the gound heaving, ... you just might have a BASS winner.
Tim
He drove a black and white pirate ship at 190 mph.
- Dale in the #3 will never be forgotten. Thanks for the memories.
OvalNut is offline
post #3351 of 5744 Old 07-09-2009, 05:39 PM
vivid's Avatar
yea there were three scenes that I recall have great low end... the plane crash, when the son was told to look out of his window and the ending.
vivid is offline
post #3352 of 5744 Old 07-09-2009, 06:06 PM
merzbow's Avatar
If the new Roland Emmerich movie "2012" doesn't break all LFE records, I don't know what will. The trailer will make you weep for joy...
merzbow is offline
post #3353 of 5744 Old 07-09-2009, 06:15 PM
MKtheater's Avatar
Liked: 1304
There were at least 4 extended bass scenes in the Knowing. The biggest bass was when the blonde guy opened his mouth and the light came out. That was intense. Every catastrophe, that open mouth scene, and when the boy looked out the window.
Marantz 7702 Atmos
post #3354 of 5744 Old 07-09-2009, 07:19 PM
bori's Avatar
Quoted: 194 Post(s)
Liked: 126
I was not too impressed with the bass in 12 rounds.
bori is offline
post #3355 of 5744 Old 07-10-2009, 07:00 AM
SbWillie's Avatar
I don't think it was all that DEEP but
Spoiler
the spaceship arriving and leaving earth
had the loudest bass -probably ref. level.....overall I didn't like the movie THAT much but my girls loved it!
SbWillie is offline
post #3356 of 5744 Old 07-10-2009, 07:11 AM
MKtheater's Avatar
Liked: 1304
I still think the biggest wow factor in The Knowing is when that guy opens his mouth and the light comes out. That had everyone's hair standing up and pants flapping from 18 feet away. It was not expected.
Marantz 7702 Atmos
post #3357 of 5744 Old 07-10-2009, 11:01 PM
OvalNut's Avatar
I agree with MK. I just finished watching The Knowing, and when the blonde guy opened his mouth, the result had me screaming Oh My Gosh, laughing, and applauding the BASS. Fantastic.
Tim
OvalNut is offline
post #3358 of 5744 Old 07-11-2009, 03:57 PM
SbWillie's Avatar
sooo anyone gonna post some charts on it? (Vista=no charts here)
SbWillie is offline
post #3359 of 5744 Old 07-11-2009, 07:09 PM
lfe man's Avatar
Liked: 41
guess i could do them, but i need still adjust my sound card settings. it was nice find that now i can make charts without long cables and loud noises.
edit:SbWillie, latest spectrumlab should work on vista.
lfe man is offline
post #3360 of 5744 Old 07-11-2009, 09:10 PM
SbWillie's Avatar
thx, but I promised my wife and daughter I wouldn't DL that on HER (daughter's) laptop...oh well.
SbWillie is offline
Blu Ray Players , Subwoofers
