Seaton Sound SubMersive1 - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 703Likes
post #31 of 10576 Old 11-30-2006, 11:21 AM
crackyflipside's Avatar
So.... Where are the specs for this sub, a DIY guy loves reading numbers!
crackyflipside is offline
post #32 of 10576 Old 11-30-2006, 12:05 PM
MIkeDuke's Avatar
Quoted: 501 Post(s)
Liked: 194
Flip, check your PM
It ain't easy being green.
My System
MIkeDuke is offline
post #33 of 10576 Old 11-30-2006, 12:15 PM
Mark Seaton's Avatar
Quoted: 619 Post(s)
Liked: 1647
While I need to do another set of more ideal measurements, preliminary ground plane response of the SubMersive is +/-3dB 20-200Hz, +/-12dB extends down to 14Hz, and 10Hz is -12dB the 20Hz level.
Here's a link to an earlier response measurement with zero smoothing (2Hz resolution) and with a few reflections making for some wiggle at higher frequencies. 1m frequency response - 100dB @ 20Hz
Below 20Hz there is 6-8dB more output capability beyond this measurement, and a LOT more available higher in frequency.
Final dimensions are 17.5" x 23.25" x 24.75" tall plus 3/4" feet. The feet usually translate to ~25" of height on carpet or 25.5" on a hardwood floor.
Mark Seaton
Seaton Sound, Inc.
"Make no little plans; they have no magic to stir men's blood..." Daniel H. Burnham
Mark Seaton is offline
post #34 of 10576 Old 11-30-2006, 12:33 PM
thebland's Avatar
Quoted: 1549 Post(s)
Liked: 902
Congratulations Mark! This product is a major ball buster from what I have heard and you deserve all the success coming your way!
Goodbye to a great audio and video genius and writer... JOHN GANNON. I enjoyed your friendship, wit and a nice long run we took around Indianapolis at CEDIA years back... and for buying my Runco 980 Ultra years back... you saved my ass! Rest in peace.
thebland is offline
post #35 of 10576 Old 11-30-2006, 12:40 PM
johnlarsen's Avatar
So you opted NOT to use LINEAR moto tech in your drivers. i wonder why. JL AUDIO, TC SOUNDS, and HSU are using it
johnlarsen is offline
post #36 of 10576 Old 11-30-2006, 01:03 PM
Quoted: 619 Post(s)
Liked: 1647
Hi John,
All motors are linear over some range.
When you have a pair of large 15" cones and aren't loosing significant surface area to 2" wide surrounds, linearity can be quite good as the cones don't have to move very far for very prodigious output. By optimizing the driver parameters for sufficient sensitivity at low frequencies, I am able to employ two 15" drivers, in an inert enclosure with two 3" voice coils. This results in less need for huge excursion, and less need to get around the inherent hurdles of designing such drivers. Through the development process I have not yet found reliable and viable options in the so-called linear motor designs that were suiltable or preferrable for the performance and value of the SubMersive. I am always working with different suppliers for continued improvement in the future, and I may incorportate such motor designs at some point in the future. That said, solid subwoofer performance requires a lot more than just using an alledgedly "linear motor." There is a lot more to execution of a design, and it is more about selecting parts that predominantly operate within their operating limits to achieve the desired goals.
Mark Seaton
Seaton Sound, Inc.
post #37 of 10576 Old 11-30-2006, 01:11 PM
wje
wje's Avatar
Originally Posted by MIkeDuke View Post
"This has resulted in a Huge mess.... My projector completely came unaligned, one of the HVAC vents in the wall opposite the subs came out about 1" from the wall (it is an old house and a bad HVAC install), I dislodged an electrical outlet cover that wasn't secured, and dislodged one of my DVI plugs (not screwed in) coming into my computer on the 2nd floor."
WOW I haven't heard many other subs really causing physical damage to a room. We have all heard the "It shook my room like nothing else" but this is actual proof
Sounds like a wonderful product endorsement.
wje is offline
post #38 of 10576 Old 11-30-2006, 01:15 PM
TheEAR's Avatar
Mark S.,
Where do I sign up for your Submersive subs? Where is the web page,where is the shopping basket.I want a SubMersive. Serious buyer here.
Ask yourself mortal , do you have as much displacement as me ? The answer is no unless you have a Windmere fan sub.
TheEAR is offline
post #39 of 10576 Old 11-30-2006, 01:37 PM - Thread Starter
WarrenBuffett's Avatar
Update.... Just watched Batman Begins... The scene when the water mains explode caused my PJ to go way out of alignment again. I think i'm going to have to get better Projector Mount or tighten the screws a lot more. All other rattling and assorted problems have been fixed (i hope).
Bad Wallet! Bad Bad Wallet!
WarrenBuffett is offline
post #40 of 10576 Old 11-30-2006, 01:45 PM
DrewB's Avatar
Quoted: 123 Post(s)
Liked: 108
You're running those bad boys off hardwood floors - that's probably why everything is jumping around. May want to look into one or two subdudes.
DrewB is offline
post #41 of 10576 Old 11-30-2006, 01:49 PM
johnlarsen's Avatar
Hi John,
this be correct, Mark^2 the benefit though of the linear motor is the distortion lower, but u know that
do ya place any stock on ThD distortions for subs?
woulud be reallllllyyyyyyy interesting to see craig shootout of Sub1 and f113!!!!!! it be a good fight me thinks
post #42 of 10576 Old 11-30-2006, 01:53 PM
TheEAR's Avatar
I think you are holding a baseball bat and taking swings at your projector.
At least say pictures fell of the walls!
TheEAR is offline
post #43 of 10576 Old 11-30-2006, 02:29 PM
Quoted: 619 Post(s)
Liked: 1647
Hi Drew,
The subdudes would have zero effect. The opposed mounting of the drivers results in a entirely inert enclosure, even at the highest drive levels. The SubMersive enclosures are probably the most stable things in the room.
I also believe that the hardwood floor you see is on slab, at most there is a crawl space, but I don't believe so. All vibrations noted are acoustically induced.
Mark Seaton
Seaton Sound, Inc.
post #44 of 10576 Old 11-30-2006, 03:10 PM
bossobass's Avatar
Quoted: 78 Post(s)
Liked: 668
The initial reviews from some guys over here in HEMI are extremely positive.
Art
Art,
I just finished checking out your site. The theater and the latest G2G you hosted just blew me away. You are indeed one classy guy, and the attendees have something to remember, IMHO.
A very respectful tip o' the hat. Very cool stuff.
Bosso
bossobass is offline
post #45 of 10576 Old 11-30-2006, 03:49 PM
Ettepet's Avatar
Warren, could you show us a picture of the amp section?
Ettepet is offline
post #46 of 10576 Old 11-30-2006, 04:16 PM - Thread Starter
Submersive does not move. not one bit. Even when we were running really high DB's they didn't move. The house has no basement and AFAIK no crawl space. it was built back in 1890 i believe and has been poorly renovated (its a rental property). All of my issues are from my neglect to tighten screws (why my projector keeps moving during heavy LFE scenes), and poor construction of the house.
I do not have an ideal room and the SubMersives easily handle it.
Also I apologize for my fanboy attitude as this has definately been the biggest transformation in my theater since i went to a front projection setup.
Anyone in the Chicago area can PM me if they want to stop by and see what these bad boys can do.
post #47 of 10576 Old 11-30-2006, 04:28 PM - Thread Starter
Pod Emergence -5 volume..... video with 2 coins on top of submersive
SubMersive Coins
post #48 of 10576 Old 11-30-2006, 04:49 PM
CollinViegas's Avatar
Are us Canadians going to be able to order the Submersive 1 up here o the North?
CollinViegas is offline
post #49 of 10576 Old 11-30-2006, 05:01 PM
TheEAR's Avatar
WarrenB.,
May impress the masses,problem is...
This is a sub using two identical woofers that are opposed. You should see almost no movement even full tilt blasting til your eardrums give.
A single woofer sub like the JL f112/113 may shake like this from the massive strokes of the cpiston at deafening SPL.
hmmm
TheEAR is offline
post #50 of 10576 Old 11-30-2006, 05:02 PM
TheEAR's Avatar
Exactly my question,I did send a PM to Mark Seaton today. lets wait and see.
TheEAR is offline
post #51 of 10576 Old 11-30-2006, 11:23 PM
CSEmoses's Avatar
ok, i have headphones on, lol, but that pod emergence scene sounds really fricken deep those coins didnt move even a tiny bit!
.... and yeah, i'd also sure like to know if we Canadians are going to be able to order one of those Submersives. What is the final weight of the unit?
CSEmoses is offline
post #52 of 10576 Old 11-30-2006, 11:26 PM
Quoted: 619 Post(s)
Liked: 1647
I see no reason why the SubMersive won't make it across the border just like any other subwoofer from a US manufacturer. I don't have any plans for a Canadian distributor if that's what you were indirectly asking, but aside from the costs involved, shipping to Canada shouldn't be a problem.
Mark Seaton
Seaton Sound, Inc.
post #53 of 10576 Old 11-30-2006, 11:30 PM
Quoted: 619 Post(s)
Liked: 1647
It's more impressive when the coins are ballanced on end.
I should have exact shipping weight confirmed next week as I recently changed some packing details. The subwoofer itself is about 100 lbs.
Mark Seaton
Seaton Sound, Inc.
post #54 of 10576 Old 12-01-2006, 05:50 AM
Need4spdnb's Avatar
Hey Mark,
I shot ya an email and PM, but your probably a tad busy these days.
I would love to pick up one of these submersives. If you could shoot me a PM letting me know how to do so, it would be greatly appreciated. Thanks.
Theater design at Audio Video Interiors of Chicago, Inc.
Right across from the Oakbrook Center Mall.
Noah B.
Need4spdnb is offline
post #55 of 10576 Old 12-01-2006, 06:45 AM
craig john's Avatar
Quoted: 517 Post(s)
Liked: 718
Just had Mark Seaton over to install my 2 SubMersives, it being late and all I will keep my initial post on this MONSTER of a sub short.
I don't mean this in any negative way, but I think it's important to note that Mark Seaton actually installed these subs himself. I have read more than one thread where MS has been hired to optimize an HT. In addition to being an expert at sub installation, his expertise has been utilized to do more than just install the subwoofer. He can, by all accounts, optimize the speakers by adjusting placement, toe-in, etc., optimize the bass management, the phase, any and all peripheral EQ systems, and tweak the overall system to sound better.
Mark, could you describe the installation you performed for WarrenBuffett? Also, will your installation services be included with some or all of these systems, or do you charge an installation fee?
Craig
Lombardi said it:
Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #56 of 10576 Old 12-01-2006, 07:46 AM
MIkeDuke's Avatar
Quoted: 501 Post(s)
Liked: 194
Mark,
I sent you a PM and email
Mike
My System
MIkeDuke is offline
post #57 of 10576 Old 12-01-2006, 10:25 AM
Jack Gilvey's Avatar
Quoted: 37 Post(s)
Liked: 45
Looking good...a $2000 sub that might actually be worth it. Interesting to see how it does against the Fathom thingie...be nice if someone the calibre of Mullen got his hands on one or both.
Jack Gilvey
SVS Customer Service
Jack Gilvey is offline
post #58 of 10576 Old 12-01-2006, 10:48 AM
wje
wje's Avatar
If you catch the other thread, you'll see that Mr. Ed now works for SVS.
wje is offline
post #59 of 10576 Old 12-01-2006, 11:15 AM
johnlarsen's Avatar
finally cat is let out of bag about *that*, i was saying that one year ago even told Mark^2 (and big kahuna Mark^1) about that, now he knows i am and was right.
post #60 of 10576 Old 12-01-2006, 05:25 PM
GaryMB's Avatar
Hi, Mark. It's obviously early in the game, but is a smaller version of the SubMersive, perhaps using 12" drivers, a realistic possibility at some point?
GaryMB is offline
Seaton Sound , Velodyne Dd 15 Digital Drive Subwoofer 15 Inch Gloss Black , Velodyne , Speaker Systems , New Pac Sni 1 Ground Loop Signal Isolator
