Seaton Sound SubMersive1 - Page 232 - AVS Forum | Home Theater Discussions And Reviews
 724Likes
post #6931 of 10603 Old 07-04-2012, 02:32 PM
ccotenj's Avatar
Liked: 101
lol... biggrin.gif yea, true dat... never ceases to amaze me what some will "believe", even though it's completely irrational...
those of us on the lunatic fringe of subwoofage*, otoh, are entirely rational... tongue.gif
* and heck, i'm not really even there with my measly dual hp's... although my friends seem to think i am... smile.gif
- chris
ccotenj is offline
post #6932 of 10603 Old 07-06-2012, 06:26 PM
loopaddiction's Avatar
So for those running more than 1 of a SubMersive HP, Captivator or similar high-powered subwoofer/amp combo...
I think it's safe to presume that you all have fully fleshed out home theater set-ups. Is it common knowledge/sense to have separate 20A circuits installed? I'm planning on running 2 SubMersive HPs, a 5-channel 400WPC power amplifier + 5 speakers, receiver, LCD TV, etc... and i'm guessing at the minimum, I should have two independent 20a circuits -- 1 for each socket of an outlet. I'm planning on having the power amp on one circuit, and the 2 SubM's and all other electronics on another circuit. I listen typically at -15 on the receiver and all the way down to -8, and I run my subs about 10dB hot. Does this seem like a safe bet?
Also, i'm just not sure whether i'm getting a good deal on the installation. I invited an electrician over to scope it out and the lines would have to be run through a conduit outside of the house all the way to the circuit box, which is about a 100 ft. distance and so 500 ft. of wire, so he says. For 2 circuits, I was quoted at about around $700. The guy seemed pretty honest and even suggested getting quotes from other electricians, or even buying and providing the wire myself to save a little money. Does this quote seem fair?
Not really willing to DIY because the thought of tearing up drywall frightens me. Opinions and personal experiences please?
loopaddiction is offline
post #6933 of 10603 Old 07-06-2012, 06:56 PM
edoggrc51's Avatar
Quoted: 57 Post(s)
Liked: 69
I have 3 20amp circuits. One for each of my sub amps and the other powers everything else (4311ci, Cinenova Grande, SMS-1, etc). I've never had any problems tripping breakers even at reference levels. cool.gif
edoggrc51 is offline
post #6934 of 10603 Old 07-06-2012, 08:45 PM
bsoko2's Avatar
Quoted: 75 Post(s)
Liked: 79
I'm using 2, 20 amp plugins for my room.
bsoko2 is offline
post #6935 of 10603 Old 07-06-2012, 09:20 PM
calentz's Avatar
Quoted: 83 Post(s)
Liked: 52
I am using three 120V 20 Amp & one 240V 45 Amp circuits in my temp HT.
--Carl
calentz is offline
post #6936 of 10603 Old 07-06-2012, 09:32 PM
carp's Avatar
Quoted: 2784 Post(s)
Liked: 2097
When I had my dual Captivators I was using a ep4000 to power them both, and just had a 15 amp line shared with a small freezer and dorm fridge, lights in a utility room, and I never once tripped the breaker. Currently I have a Submersive on that same line and the other Submersive on a 30 amp line that is shared with a ton of things, seemingly most of the rooms above me. I haven't tripped them with the Submersives either.
Keep in mind I have had these subs at insanely loud levels too. I don't understand it, I think I have some kind of breaker magic going on down here.
carp is offline
post #6937 of 10603 Old 07-08-2012, 06:32 AM
Larry M's Avatar
Quoted: 29 Post(s)
Liked: 46
Sounds like about $250 in material if you were buying on your own. I'm sure he gest a better price.
In the LA area I would assume electricians charge $75 - $100 an hour? Seems like a fair deal but hard to tell
Larry M is offline
post #6938 of 10603 Old 07-09-2012, 01:59 PM
bsoko2's Avatar
Quoted: 75 Post(s)
Liked: 79
Has anyone tried their Submersive(s) in a down and up firing postition?
bsoko2 is offline
post #6939 of 10603 Old 07-09-2012, 02:09 PM
spyboy's Avatar
Liked: 48
Sure thing Bill. I get my wife and kids to each hold a Submersive 2 feet off the floor. It has done wonders for their upper body strength biggrin.gif
Seriously, how do you propose to hold the Submersives down and up firing? That woud probably create a much shorter distance to the bottom boundary (floor), and the top boundary (ceiling).
I know you have a method in mind and it will be good to hear some discussion of such placement. smile.gif
tanbyte likes this.
spyboy is offline
post #6940 of 10603 Old 07-11-2012, 05:32 PM
Reefdvr27's Avatar
Quoted: 1578 Post(s)
Liked: 1062
I presently have a Outlaw plus and EX. I have been planing on eventually buying a pair of seaton subs. My question is, would one sub be better than my pair of outlaws?
Reefdvr27 is offline
post #6941 of 10603 Old 07-11-2012, 05:47 PM
craig john's Avatar
Quoted: 530 Post(s)
Liked: 751
One SubM HP will have more output and deeper extension than your Outlaws. However, it may not sound "better." With two subs, you can place them to even out the response over more seats. If you've done this, and you can't find a single placement for the SubM that has equivalent response, it may not sound as good as the two Outlaws. Some of that can be addressed with room correction/EQ, but placement of the sub and the listening position will be the first things to address.
Craig
Lombardi said it:
"Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #6942 of 10603 Old 07-11-2012, 06:01 PM
Reefdvr27's Avatar
Liked: 1062
Craig
Thanks, the placement would be near placement. What if I was to keep the EX and add a subm hp? Would they play well together?
post #6943 of 10603 Old 07-11-2012, 06:07 PM
craig john's Avatar
Quoted: 530 Post(s)
Liked: 751
It would be a chore to integrate them. The SubM has much deeper extension than the ported Outlaw. The Outlaw would just hold the SubM back. I would probably not even bother.
Craig
Lombardi said it:
My System
post #6944 of 10603 Old 07-11-2012, 06:47 PM
dominguez1's Avatar
Quoted: 1108 Post(s)
Liked: 953
Craig
I currently have 2 FTW21in drivers powered by 2 EP4000 bridged integrated with a pair of EX's. They sound incredible together in my room, and the outlaws don't run out of steam they way I have them setup.
It can be done, but you need the right equipment to dial them in. However, I probably wouldn't recommend 1 SubM and 1 EX. That would be more difficult to get right since you would essentially want to level match them to get a smooth FR...the EX would definitely run out of steam. However, 2 SubMs to get a smooth FR, and then add in the EX nearfield would definitely be an option. You wouldn't have to run the EX as loud, and just use it for the tactile shaking.
dominguez1 is online now
post #6945 of 10603 Old 07-12-2012, 02:24 AM
Dustcap's Avatar
One question regarding placement of the SubM: Did you experience any differences in the SubM's sound between side firing placement and front firing? In other words: Does it make a difference between one driver facing towards the listening position and both drivers facing sideways?
Dustcap is offline
post #6946 of 10603 Old 07-13-2012, 04:14 PM
Mark Seaton's Avatar
Quoted: 648 Post(s)
Liked: 1749
With the pair of opposed drivers, the virtual or effective acoustic location of the subwoofer is in the center of the box between the two woofers. As such, rotating the 17.5" x 23" footprint makes a very minor change in effective position. So long as you leave ~3" in front of the driver or grill, you can orient the SubMersive any way you like in a corner. With frequencies below 80Hz, there really isn't much of a front or rear projection of sound for conventional subwoofers. The bass radiates in all directions equally from a driver (or port at the frequencies the port operates).
Mark Seaton
Seaton Sound, Inc.
"Make no little plans; they have no magic to stir men's blood..." Daniel H. Burnham
Mark Seaton is online now
post #6947 of 10603 Old 07-27-2012, 10:37 AM
GPBURNS's Avatar
Quoted: 136 Post(s)
Liked: 310
not sure if you guys check out Mark's site but he posted some pics of submersives added to a full
Rockport speaker system set-up -
that is some heavy artililery
http://www.seaton-sound-forum.com/post/Rockport-speaker-system-with-3-SubMersive-HPs-5947063
15400 Watts of Seaton Power -Quad SubMersived
GPBURNS is offline
post #6948 of 10603 Old 07-27-2012, 12:08 PM
MIkeDuke's Avatar
Quoted: 512 Post(s)
Liked: 202
Yep saw that. It is one top notch system with some really high end gear.
It ain't easy being green.
My System
MIkeDuke is offline
post #6949 of 10603 Old 07-28-2012, 07:48 PM
logicators's Avatar
Liked: 26
Hi Guys,
I am thinking of buying a submersive HP. The sub needs to fit under my wall-mounted TV and I need to put my center channel speaker on it (a def tech CLR-3000).
The official forum provides the dimensions as 24.25" W x 17.5" D x 25.5" H (including feet & grills) but I have about 23.5" (or maybe 24") space available (plus space for my center channel). Can someone please measure the sub without the feet and let me know the height? The sub will be on a carpet so it shouldn't be an issue to use it without the feet (if it shouldn't be used without the feet for some technical reason please do let me know!).
Also, do you think I can safely put a 45-50 lbs center channel speaker on top of it?
Thanks in advance for your help
logicators is offline
post #6950 of 10603 Old 07-28-2012, 08:29 PM
carp's Avatar
Liked: 2097
Mark posted awhile back that the feet need to stay on to keep the sub sealed, I was going to take the feet off too until I read that. Mine is 25 1/16" inches tall with the feet on, on carpet.
carp is offline
post #6951 of 10603 Old 07-28-2012, 08:32 PM
templemaners's Avatar
Originally Posted by logicators View Post
Hi Guys,
I measured mine just now on the woofer side from top to bottom - it came out to 24.75" tall.
And I think it should be just fine with a 45-50 lb center channel on it - it's pretty solidly built. biggrin.gif
templemaners is offline
post #6952 of 10603 Old 07-28-2012, 09:04 PM
calentz's Avatar
Quoted: 83 Post(s)
Liked: 52
Hi Guys,
In my case, I have the 1st gen SubM's & the feet are attached differently; however I think that the Dims are the same (24 3/4in) without the feet. I am using them with my Cat 12C on top of them. (>100 lbs)
If I was you, I would turn the sub on it's side (17.5) and space your CLR-3000 up high enough to clear the PowerCon & the XLR audio input connectors. You could place something in the space between
the two speakers to hide the cables from view. Due to the speakers design, there is no vibration & the speaker is built like a tank, so no problem with weight.
--Carl
calentz is offline
post #6953 of 10603 Old 07-28-2012, 11:09 PM
Bunga99's Avatar
Quoted: 12 Post(s)
Liked: 40
Logicator,
You may also want to consider the newer SubMersive F2 design. It's 20'' in height when laying on its side.
Here's a quote from Mark that may be useful:
Originally Posted by Mark_Seaton
the walls are all very well braced, and they should be fine to place a speaker on with an appropriate rubber pad under them similar to what I use on the top of the stands. We can cut and supply a suitable pad if desired. Had the samples been done in time, a pair would have served as the stands for the rear CAT-8C's at our demo in Indy a few weeks ago.
With a 20" or 35.75" height, suitability as a stand will depend on the specific room and seating, but rear surrounds certainly make sense in balancing and distributing subs in the room as I've repeatedly found general front and rear locations to be very workable and useful at efficiently covering the entire subwoofer range.
Bunga99 is offline
post #6954 of 10603 Old 07-28-2012, 11:47 PM
logicators's Avatar
Liked: 26
Thanks for your quick responses!
I checked the wall-mount I used for my TV (monoprice 4174: http://www.monoprice.com/products/product.asp?c_id=108&cp_id=10828&cs_id=1082801&p_id=4174&seq=1&format=2) and I might be able to adjust the rails screwed on the back of the TV by a couple of inches. Not guaranteed to work (since the instructions recommend placing them towards the center of the TV), but worth a try smile.gif
post #6955 of 10603 Old 07-29-2012, 05:05 AM
ccotenj's Avatar
Liked: 101
Hi Guys,
others have commented on the rest, but i'll add that you could likely put a 500 pound center channel on top of the subm without issue... smile.gif
remains to be seen what the response will be put in the center of the wall though...
- chris
ccotenj is offline
post #6956 of 10603 Old 07-29-2012, 05:57 AM
logicators's Avatar
Liked: 26
I sent you a PM.
post #6957 of 10603 Old 07-30-2012, 05:11 AM
Larry M's Avatar
Quoted: 29 Post(s)
Liked: 46
Instead of messing around with the height adjustment why not mount the entire Monoprice mount a little higher. Once the TV is off the mount the hard work is done smile.gif
Larry M is offline
post #6958 of 10603 Old 07-30-2012, 09:53 AM
Quoted: 648 Post(s)
Liked: 1749
Emphatically seconded. The simple options are either to use a SubMersive F2 on side, or to use a standard SubMersive HP and raise the TV Mount. Assuming it's mounted into wood studs, shifting 4 lag bolts up makes for an easy option. There's no need for others to measure for you though, as you can check the exact dimension drawings here. The only issue with the F2 is that the flat surface on the side is limited to 9.75" flat depth due to the front and rear chamfers on the 15" enclosure depth. With the bracing and construction of the two enclosures, there is no concern for the weight of any speaker you are likely to place on top.
Mark Seaton
Seaton Sound, Inc.
post #6959 of 10603 Old 08-01-2012, 01:12 PM
logicators's Avatar
Liked: 26
Thanks Mark. Makes perfect sense.
I don't see F2's pricing and availability on your forum?
post #6960 of 10603 Old 08-01-2012, 01:35 PM
Quoted: 648 Post(s)
Liked: 1749
We finally received the custom packing materials allowing for safe and cost effective shipping individual F2s. F2's are actually a few $ less to ship than an original due to the longer narrower package which help offset the premium. Pricing and availability will be added to the main thread on our forum in the next few days. If you find the F2 thread on our forum, I answered some related questions in post #23.
Mark Seaton
Seaton Sound, Inc.
Seaton Sound , Velodyne Dd 15 Digital Drive Subwoofer 15 Inch Gloss Black , Velodyne , Speaker Systems , New Pac Sni 1 Ground Loop Signal Isolator
