Seaton Sound SubMersive1 - Page 319 - AVS Forum | Home Theater Discussions And Reviews
 508Likes
Old 07-10-2014, 07:12 PM
jlpowell84's Avatar
Quoted: 1488 Post(s)
Liked: 661
Going absolutely brain dead. PGM 2 is with the button pushed in or left out?
FTW21 Ported Build
Volt 10 build
I miss Giants baseball!
jlpowell84 is offline
Old 07-10-2014, 07:29 PM
K1LL3M's Avatar
Out
Sent from my GT-N7105T using Tapatalk
jlpowell84 likes this.
K1LL3M is offline
Old 07-11-2014, 01:00 AM
Zzzzz...'s Avatar
Quoted: 97 Post(s)
Originally Posted by kbarnes701 View Post
Maybe we are using different meanings of 'vibration' here. I too can feel something through my palm when I lay it on top of my F2s and when really loud, really deep bass is playing. I'm not sure I'd call this 'vibration' in the sense that the cabinet itself is, well, 'vibrating'. Maybe we are experiencing the same thing but calling it something different?
It's quite possible I suspect.
Would be great if more F2 owners tried the coin experiment.
Not sure what you mean by "I possibly could have achieved a gain closer to 0 if I allowed the avr to have a positive gain". Do you mean the gain on the sub itself in the first mention of 'gain'? If so, as I say, it's not relevant anyway.
During Audyssey calibrations I could have chosen to reduce the F2 gain by turning the F2 gain knob one more click. Audyssey would then have compensated by increasing the sub gain in the avr. The resulting avr sub gain would then have been closer to 0 in absolute terms but would have been positive rather than negative.
Originally Posted by K1LL3M View Post
I doubt the OP has a cabinet problem, more likely a null as you suggested
Rather than taking up people's time with this its probably best to wait until I can get REW going and see what's what.
The cabinets more than tough enough not to "flex" and the drivers cancel any vibrations out. Google the it, coins glasses of water, still as.
As to the sub trim, thats what mine is on, and thats hot, though my trim is 0. The -4.5dB trim isnt bad. The question I have is if you turn it down 1 more click, whats the trim go up to. Not that it matters.
See my answer above (I can't remember the exact value).
I thought you were boosting you sub by 6-8dB though?
I did the boost the sub for War of the Worlds by +7 dB but I don't generally boost the sub by anything near that. For example, I didn't end up adding any boost to Oblivion. When I did try boosting the bass in Oblivion I found it just stood out too much. Having said that I was expecting the cable snap to be quite a bit more impactful than it was.
While I'm waiting for REW, is there anything I can try that might help with the rattles I'm hearing? As mentioned in my original post, it's really hard to work out what do about them - I suppose they're coming from the wall but I don't know what can be done. Would really like to hear some suggestions if people have them.
Zzzzz... is offline
Old 07-11-2014, 02:59 AM
kbarnes701's Avatar
Quoted: 6740 Post(s)
Liked: 5015
OK - gotcha. I always set up so that the initial Audyssey level reading is quite a bit higher than 75dB. This then means that Audyssey trims the bass down quite a lot, which leaves me headroom to boost it if I want to, while still remaining in negative trim territory.
Chasing down room resonances is really hard sometimes. I play a bass test tone, on repeat, quite loud and then go hunting. It's easy to fix rattling furniture or things on tables and so on. Even light fittings. The test tone will find them all. I use different frequencies too because some things resonate at different frequencies. Mine is a dedicated room so it doesn't have very much in it that isn't essential - eg no ornaments and so on. What is hard, or even impossible, is to track down resonances inside the walls. This can happen - there can be wires or debris left in there by builders and so on. In my case I have one resonance that so far I haven’t dealt with. It is caused by two central heating pipes which take the hot water to the upstairs floor of the house. At a certain frequency they vibrate. The only way to deal with it is to rip open the wall and fix the pipes down better but so far I haven't done this. It happens at just one very low frequency which doesn't seem to be in most movies, or not loud enough to cause the problem, so I am just living with it. The only time I really notice it is when the bass, at the right frequency, goes on for a long time - for example in the cave exit scene in Iron Man. Always something else to do with this hobby...
kbarnes701 is offline
Old 07-11-2014, 03:00 AM
kbarnes701's Avatar
Liked: 5015
Out
Yep. And, of course, it requires a power off/on cycle before it takes effect.
Old 07-11-2014, 06:59 AM
Skrill's Avatar
Quoted: 239 Post(s)
Liked: 72
Hello all ... so I pulled the trigger on a Seaton SubM HP+ and Slave combo.
Looking forward to hearing these in my room!
CT
Modicen and zdoggz like this.
Skrill is offline
Old 07-11-2014, 11:06 AM
Skrill's Avatar
Quoted: 239 Post(s)
Liked: 72
For the experienced SubM'ers, in antcicipation of the arrival of my SubM HP+ and slave, I wanted to get an understanding of the appropriate setup for everything. Here is my equipment:
Equipment: Speakers: B&W Nautilus 803 (R+L), B&W CDM-CNT (Center), Definitive Technologies BPX (surrounds), Definitive Technologies BP2X (rear surrounds)
Amp: Sherbourn PA 7-350 (350w RMS x 7 channels)
Sound Processer: Onkyo TX-SR805 (using pre-amp outs). I currently use the Audyssey MutiEQ XT and cross all speakers at 80hz.
Bass Management: Velodyne SMS-1 (this is a “new to me” addition to the system). I bought it to help manage and better integrate my subs (at least until I upgrade my processor to something with Audyssey MultiEQ XT32 and SubEQ).
Projector System: Sony VPL-HW55ES, VAPEX 120” fixed frame 1.1 gain screen.
Video Processors: DVDO Edge Green, and Darbee Darblet
Here is the process that I gleaned from some other posts in this thread (and the Audyssey thread).
  1. Hook up SubM's and set volume on amp to -13db ish (between Mark's recommended -10 and -16db)
  2. Disable existing Audyssey setup on Onkyo and return all channel trims to 0db (??? --- or perhaps some other number).
  3. Level match front L/R and Subs at 75 to 80 db from the MLP. I have a Radio Shack digital SPL meter for this.
  4. Run my Velodyne SMS-1 (using Volume @ 15 on the SMS-1) to get sub as flat as possible.
  5. Run my Onkyo's Audyssey MultiEQ XT. (If XT cuts LFE by more than -12db pull back the trim on the plate amp - and then run again till less than -12 db right?)
  6. So far everything has been in PGM1 -- now I set to PGM2 and power-cycle the SubM amp.
  7. Crack a beer and fire up Gravity
Sound about right? Any feedback would be very much appreciated.
I know I should upgrade to a receiver with XT32 -- but the 805 is working great right now, and I plan to make the switch to an XT32-enabled unit once 4K HDMI, HDCP and Atmos are more settled.
Thanks!! I am really excited to get the SubMs.
CT
Skrill is offline
Old 07-11-2014, 11:40 AM
kbarnes701's Avatar
Liked: 5015
CT
There are some useful Qs in the Audyssey FAQ that might help you:
b)6. Does it matter how I set the controls on my AVR when running Audyssey?
f)3. How do I set the controls on my subwoofer before running MultEQ?
f)9. What's the best way to set up Audyssey when also using Velodyne's SMS-1 room EQ system?
f)4. If I want to run my subs a little 'hot' where should I make the changes?
f)8. How does Audyssey handle complex multiple subwoofer setups?
That should keep you busy for a while
Old 07-11-2014, 11:56 AM
Skrill's Avatar
Quoted: 239 Post(s)
Liked: 72
I feel a bit silly now -- but thank you.
So it seems that I should run Audyssey first then make any adjustments with the SMS-1.
Skrill is offline
Old 07-11-2014, 01:30 PM
jlpowell84's Avatar
Liked: 661
Yea I am very familiar with the process as I have done tons of measuring and my EQ process. The good ol, Measure raw, implement mini dsp cuts, measure again, then run Audyssey and measure again, then implement PGM 2 and measure again. I have done this countless times as changes have occurred as I pieced my current system together over this last year. But last night I stopped and genuinely forgot if PGM 2 was out or in!!!! I ran XT32 with them out!!! UGHGHGHH!!! Well my wife doesn't get home until 745 tonight so...
FTW21 Ported Build
Volt 10 build
Old 07-11-2014, 01:33 PM
kbarnes701's Avatar
Liked: 5015
You’re welcome. No reason to feel silly IMO.
Just follow the FAQ - the SMS info was from a very experienced member who has first hand knowledge and experience.
If you run SMS first, Audyssey will just try to 'undo' what it has done as it attempts to hit the Audyssey target curve.
Old 07-11-2014, 01:35 PM
kbarnes701's Avatar
Liked: 5015
Funnily enough, I did the same last week. It's been a while since I needed to recalibrate (just moved my surrounds to 110 degrees to get ready for Atmos) and I had to look up which Pgm was which, in or out.
Skrill and jlpowell84 like this.
Old 07-11-2014, 02:48 PM
AVS Club Gold
craig john's Avatar
Quoted: 510 Post(s)
Liked: 701
CT
I don't suggest you follow the above process. Here's post I made from a number of years ago about the SMS-1 and Audyssey XT32. Your process will be different because you're using a Master/Slave, which means you only set the levels from the Master. There is no separate level or distance setting for your Slave. The first step is also important for finding the best placements for your subs.
First, the SMS-1 is a great device for helping to optimize subwoofer placement in the room prior to any EQ or calibration. To use it for this, just turn off the speakers and play only the sub. Disable all EQ in the SMS-1 and set everything else to baseline. Then place the mic at the primary LP and move the subwoofer around room while watching the FR on the OSD. Place the sub in the spot that measures the flattest without any EQ. This will make it much easier to EQ the system later, as you will need less cuts or boost to get a perfectly flat response.
Second, when setting levels, there are 4 different level settings that need to be accounted for:
1. Master Volume Control
2. Subwoofer and Speaker Trims
3. SMS-1 Level
4. Subwoofer Level
These will all interact and they all need to be taken into account prior to doing any calibrations or EQ. To set the levels, and then EQ the system with the SMS-1, I suggest the following progression:
1. Start by setting all trims in the receiver to 0. (We'll come back later and re-set these for calibration purposes, but for now, set them to 0.)
2. Set ALL speakers to Small AND all crossover frequencies to 80 Hz.
Reasons:
The SMS-1 expects the use of Bass Management, which is what you engage when you set the speakers to Small. Therefore, to get proper results from the SMS-1, you need to set the speakers to "Small" and engage BM.
The SMS-1 can *only* EQ the subwoofer channel. It can NOT EQ the speakers. This is very important to realize. Any filters set above the crossover point will have little effect on the subwoofer output and minimal effect on the overall response. Limiting the range of the subwoofer channel by using a low crossover point, limits the range available for the SMS-1 to EQ. IOW, if you set a 60 Hz crossover, the SMS-1's EQ will only be effective to 60 Hz. Therefore, set the crossover as high as possible without localization of the subwoofer, which is almost always 80 Hz.
Page 42 of your manual, (see below), describes the Bass Management scenarios for your receiver. You can either use a "global" crossover for all "Small" speakers and the sub, or your receiver allows for different crossover frequency settings for the subwoofer and the speakers. The subwoofer crossover is really just an LPF, whereas the global crossover is an LPF and an HPF at the same frequency. IMO, you should use the same frequency for the HPF on the speakers and the LPF on the sub. Therefore, I recommend you use the global crossover setting of 80 Hz, for all speakers and the subwoofer. Also, set the "Stereo" mode to "Speakers = Small". This will engage Bass Management for 2-channel sources and make your subwoofer active for 2-channel content. This is *very* important for optimal EQ with the SMS-1, as described below.
The Phase Control on the SMS-1 is centered at 80 Hz. While it is better to use the receiver's distance setting to effect the response around the crossover point, if you do want to use the SMS-1's Phase Control, it will only be effective with an 80 Hz crossover.
3. Next, on the SMS-1, select Preset: Setup and set all EQ bands to 0. (A default reset is the easiest way to do this. See Page 41 of the SMS-1 User Manual, linked below.)
4. Set the SMS-1 Level to +15.
Reason:
This is the setting for "Unity Gain" in the SMS-1. The SMS-1 is not an amplifier. You don't want to use the SMS-1 to add gain to the signal. You want it to add or reduce the gain of various frequencies *relative* to the average level, but you don't want it to increase the overall average level. "Unity Gain" means that there is no gain across the device, and the output signal is the same level as the input signal.)
5. Set the Subwoofer Gain Level at it's lowest setting. (We'll turn it up later.)
6. Turn on the left front speaker test tone. Adjust the receiver's MVC so the left front speaker reads 75 dB* at the primary LP. This MVC setting will be the "Reference Level" setting from this point forward.** Remember it.
7. Without changing the MVC setting, shut off the left front speaker and turn on the subwoofer test tone. Turn up the gain on the subwoofer until the SPL meter at the primary LP reads 75 dB. The SMS-1 should also read an "average" level of about 75 dB. (Once you've set this, you should never need to adjust the subwoofer's gain setting again, unless you move the sub.)
8. Now, go back and calibrate all of the speakers to 75 dB at the primary LP. Use the receiver's trim controls as described on Page 43 & 44 of the manual. Once you've done this, your system is fully calibrated for levels, and all of the settings are optimized in each device.
9. Proceed with manual EQ with the SMS-1. Put the receiver into "Stereo" mode. EQ the sub in isolation, (with the speakers off or disconnected), getting it as flat as possible up to the rolloff point of the speaker/subwoofer crossover you set in the receiver.
(Remember that in Step 2 above, we set the "Stereo" output to engage Bass Management. Even though the speakers are off here, the bass from the L/R channels will still be re-directed to the sub.)
(Remember also that any slider bands set above the crossover point will be wasted, so move them all over into the range below the crossover point.)
10. Once the subwoofer is EQ'd, turn the subwoofer test tone back on and reset the level to 75 dB. However, this time use the SMS-1's level control to adjust the volume to 75 dB. This will reset the SMS-1 for exact Unity Gain.
11. Finally, turn the speakers back on and evaluate the response around crossover point. Adjust the subwoofer distance setting in the receiver to optimize the response around the crossover point.
12. Re-check the full system calibration to ensure all speakers and the sub are at 75 dB.
Once you've done the entire process above, you'll have a fully calibrated system with optimized frequency response of the subwoofer. I suggest you try to live with that system for a few days or weeks. Some people are so used to a bloated or "hot" subwoofer level that they feel the bass is "missing" with a true "calibrated" and Eq'd level. Nonetheless, once they re-acclimate themselves to "flat" bass response, they begin to hear detail and articulation in the bass that was previously overwhelmed by bass bloat and boom.
Having said that, some people just don't "like" a flat FR of the subwoofer, and they prefer a rising LF response. There is nothing wrong with that, and everyone is allowed their own preference. If you're one of those people, you have a few options. The first option is to just raise the MVC. This will raise the overall system output, but you should also get closer to the bass response you are looking for. (This also assumes that the rest of your system is up to the task. If it's not, don't try to get bass response at the expense of your speakers! )
If that is still not enough, and you want to raise the subwoofer's output above the rest of the system, I suggest you initiate the Submersive's DSP Program 2. This adds a rise in the response below about 40 Hz, with 3 dB added at about 20 Hz. This should add the feel and kick you are looking for. You can view the effect of Program 2 by watching the response on the SMS-1. It should look like a rising response above about 40 Hz.
If that's *still* not enough, the third option is to raise the SMS-1's level. This will take you above "Unity Gain" on the SMS-1, but *judicious* use of the control should not be problematic. 3 to 6 dB of level increase should be taken in stride by the Submersive.
If the above suggestions don't get you were you want to be, then the only hope for you is another Submersive or 2 or 3.
Craig
Footnotes from #6 above:
*The Rotel uses -30 dBFS for it's test tones, so the test tones should read 75 dB on the SPL meter, ("Slow" setting and C-weighting.)
**The Rotel appears to be a "relative" MVC, (it goes from 0, (Off), to positive numbers), as opposed to an "absolute" MVC, which sets Reference Level at 0, and negative level settings indicate the dB below Reference Level.
Manuals:
http://velodyne.com/pdf/sms-1/sms-1_manual_english.pdf
http://www.rotel.com/content/manuals/rsp1570.pdf
Skrill and sevenz like this.
Lombardi said it:
Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
Old 07-11-2014, 07:29 PM
Skrill's Avatar
Quoted: 239 Post(s)
Liked: 72
Thanks Craig -- your post is really helpful. But it seems to reference a method of calibration for a Rotel (without the benefit of Audyssey). My Onkyo SR805 has MultiEQ XT. I was planning to follow the process in the Audyssey thread (which I believe was also authored by you and Mark). It seems like the process in the Audyssey thread would be the appropriate process in this case.
Please let me know if I am incorrect.
CT
Skrill is offline
Old 07-11-2014, 09:32 PM
Zzzzz...'s Avatar
Quoted: 97 Post(s)
Thank you for the excellent suggestion - certainly beats manually restarting film sections over and over again. I suspect REW has a tone generator so I'll use that. The other side of the wall in question is the kitchen with a built-in cabinet full of plates etc. Hopefully the sounds are coming from there rather than inside the wall itself, which I believe should only contain electrical cabling. Like you I'm not that keen to start breaking open walls :|
By the way, did you end up re-trying the coin experiment at a high sub level?
Zzzzz... is offline
Old 07-11-2014, 11:10 PM
jlpowell84's Avatar
Liked: 661
Well I have watched the first three transformers in prep to go see the 4th in imax tomm. Lets just say these movies are full of subtle to medium heavy bass effects of so many kinds. None of the three are known for the mega bass hit scenes but a couple especially in the third are intense. But like I said just filled with so many effects. I was just thinking I have absolutely ZERO regrets going the route of these two HP's! Absolutely nothing lacking! #noraegrets !
FTW21 Ported Build
Volt 10 build
Old 07-12-2014, 02:26 AM
kbarnes701's Avatar
Liked: 5015
I did. And guess what?
Spoiler!
Old 07-12-2014, 03:49 AM
Zzzzz...'s Avatar
Quoted: 97 Post(s)
Spoiler!
Zzzzz... is offline
Old 07-12-2014, 05:22 AM
AVS Club Gold
craig john's Avatar
Quoted: 510 Post(s)
Liked: 701
CT
Yes, the Audyssey process would be more applicable. Good luck.
Craig
Skrill likes this.
Lombardi said it:
My System
Old 07-12-2014, 11:07 AM
Mark Seaton's Avatar
Quoted: 418 Post(s)
Liked: 1029
Spoiler!
As I expect it to. The F2 is braced heavily so there is no significant flexing of the cabinet, but 2 big 15" woofers on the face do create some reaction forces. If you hold a 15" driver on its own in the air and pump a 10Hz signal in at a higher excursion, you and your hands will be shaken fore-aft pretty significantly. If you wanted to secure pieces of granite adding another 100-200 lbs of weight with rigid, spiked feet, you would mostly eliminate this reaction force, but fortunately this force does not directly create any audible sound, unlike panel flexing. This is where the dual-opposed configuration is mechanically and structurally a more elegant solution, but placed on a concrete slab floor, there's no audible difference.
Interestingly when we tested the vertical stack of F2's prior to Axpona 2014 (and used again at THE Show Newport), we found there was much less rocking action in the cabinet than I had anticipated. We found that with either the rubber feet or a natural rubber pad like we use on our speaker stands, there was no issue with the upper sub moving or walking. Examining the situation further I found that the key here was having 2 drivers tall on the face vs. a single...
With a single driver creating a reaction force with the bottom stuck in place by the feet, there is a clear fulcrum and force that creates rocking on the feet. Once the 2nd driver is added higher on the box, the 2 drivers push from different points and in effect push the entire face forward and back horizontally, with much less rocking force. There is still fore-aft shaking, but less tendency to rock on the feet vs just push forward and back. With 2 stacked and functioning F2's, the forces on both cabinets are largely the same with the dominant action fore-aft, so they stay together very nicely. At both shows we had no visible movement of the upper F2 over the course of the weekends where the subs were given a serious breaking in and stretching of their legs a few times.
Mark Seaton
Seaton Sound, Inc.
"Make no little plans; they have no magic to stir men's blood..." Daniel H. Burnham
Mark Seaton is offline
Old 07-12-2014, 12:58 PM
kbarnes701's Avatar
Liked: 5015
Hi Mark! Thanks for that. Flexing - that is the word I was after. There is no flexing. Like I said, I feel something through the cabinet but I wouldn't call it 'vibration'. For that, read 'flexing'. The main thing is there is no audible degradation. I’d have gone for the HPs but for the fact that I need the smaller footprint of the F2s (mainly because they work out cheaper but also for the greater elegance of the design).
But the most important part of SubMersive ownership for me is this: every time I watch a movie, my face lights up into a big, wide grin. Every time, at some point in the movie. And not just action movies, but quieter movies too. There is always at least one point where I congratulate myself on my decision to 'go Submersive'. I have had my subs for some time now, as you know. But I don't think I will ever get over this 'grin' thing.
Old 07-12-2014, 01:09 PM
calentz's Avatar
Quoted: 39 Post(s)
Liked: 29
My Seaton "System" is musical!
I listen to more music than movies, but I am happy in both cases.
--Carl
calentz is offline
Old 07-15-2014, 10:24 AM
Skrill's Avatar
Quoted: 239 Post(s)
Liked: 72
A follow up -- I had some good luck on Craigslist and sold my old Onkyo TX-SR805. My new Denon X4000 will be arriving tomorrow, and my SubM's next week.
So now I have a question. With Audyssey XT32 -- should I still attempt to further EQ the sub using my Velodyne SMS-1. From earlier posts, I know that many members jettisoned their dedicated Sub EQs (AntiMode, SMS-1, AS-EQ1) once they got a receiver/processor with XT32. I think the SMS-1s still fetch a nice penny on the used market, but before I sell it -- I wanted to get the opinions of some of the other SubM'ers. Does XT32 (when properly setup per the Audyssey guide) render my SMS-1 obsolete or unnecessary?
One thing I kind of like about the SMS-1 is the ability from my Harmony Ultimate to turn down the sub, uses different presets, or engage the adjustable "night mode" (which I have set at 60%) when I am watch movies in my theater is my wife is asleep upstairs. Although I have a dedicated theater that is mostly sound proofed -- some low frequency hum still escapes the room and travels through the house framing to the bedroom two floors up. It comes through as a low hum, but my wife finds it a bit annoying. I know that most receivers have a night mode -- but my experience is that it is not usually adjustable and grossly attenuates the bass such that the enjoyable experience is lost.
For background -- information on my theater room and equipment is a few posts up (and a page back).
Thank you!
CT
Skrill is offline
Old 07-16-2014, 06:27 AM
MIkeDuke's Avatar
Quoted: 420 Post(s)
Liked: 165
In my case, with the standard SubMersive HP, we(Craig and Dennis) ran XT32 first then we used a SMS-1 to tame a monster peak I had in my room that is room related. The combo of the two resulted in a great response and the sub sounds really good in my small room. I have been extremely pleased with the performance I have gotten with my SubMersive over the years. But I have not tried the coin trick .
It ain't easy being green.
My System
MIkeDuke is offline
Old 07-16-2014, 06:40 AM
Skrill's Avatar
Quoted: 239 Post(s)
Liked: 72
Thanks Mike.
I spoke to Mark. He felt that most likely I would no longer need the SMS-1 since I will have XT32. That said, since I have it (and I have no other measuring equipment), he suggested taking a look at the FR graph pre-Audyssey -- looking for any huge peaks (i.e. +10db) that XT32 would have a hard time taming (which could result in Audyssey attenuating bass across the board to bring the peak down to the level of the rest of the speakers). If there are no massive peaks, run Audyssey (with no EQ from the SMS-1 - i.e., preset 6). Then look at the result using the SMS-1 and see if there is anything that I might need SMS-1 to adjust. But he also said that in his experience -- it would be uncommon that SMS-1 can really do much to improve a post XT32 room calibration. Most importantly (and wisely) he said to listen and see if it sounds good (i.e., I probably should not get too hung up on graphs and such and just watch a movie). :-)
Of course -- there are rare cases like yours.
My room is pretty simple sealed rectangle (23' long x 19' wide x 8'8" tall). Hopefully nothing that XT32 can't handle.
Skrill is offline
Old 07-16-2014, 07:09 AM
MIkeDuke's Avatar
Quoted: 420 Post(s)
Liked: 165
My peak was at least 10db, maybe more. So I needed both. I don't want to cross link here but I will say it took a lot of work and 3 filters on the SMS-1 to take of my issue. But I believe I am the exception, not the rule. With a room that size, I don't think you should run into many issues that XT32 can't handle on it's own. I know that when Craig got a preamp with xt32 he stopped using the SMS-1. That is why I bought his. But you never know so measuring is the best thing to do.
First picture is before any EQ and the second picture (Green line) is full EQ.
ID:	164225   Click image for larger version
My System
MIkeDuke is offline
Old 07-16-2014, 02:09 PM
Skrill's Avatar
Quoted: 239 Post(s)
Liked: 72
My SubM Master and Slave combo has shipped ... WooT!.
Ediddy likes this.
Skrill is offline
Old 07-17-2014, 04:24 AM
MIkeDuke's Avatar
Quoted: 420 Post(s)
Liked: 165
Nice. Have fun setting them up.
My System
MIkeDuke is offline
Old 07-17-2014, 01:31 PM
Wraith2's Avatar
Quoted: 73 Post(s)
My Master arrived yesterday, just waiting on the slave to be built. Keep us posted on your setup.
Wraith2 is offline
Old 07-18-2014, 12:32 PM
Skrill's Avatar
Quoted: 239 Post(s)
Liked: 72
They're here .......!!
Skrill is offline
Seaton Sound , Velodyne Dd 15 Digital Drive Subwoofer 15 Inch Gloss Black , Velodyne , Speaker Systems , New Pac Sni 1 Ground Loop Signal Isolator
