Seaton Sound SubMersive1 - Page 320 - AVS Forum | Home Theater Discussions And Reviews
 619Likes
post #9571 of 10469 Old 07-18-2014, 10:08 PM
Skrill's Avatar
Quoted: 247 Post(s)
Liked: 76
Quick question -- I did a search and have seen a few posts, everyone seems to say its fine to leave it on. But ... is it OK to leave my SubM on 24/7? Is it preferable? Mine actually has an audible pop from the woofers when I switch it off (not crazy loud -- but definitely there). Is that normal?
Skrill is offline
post #9572 of 10469 Old 07-19-2014, 02:45 AM
K1LL3M's Avatar
Yep, pop is not uncommon and Mark had always said it will not hurt the sub.
There is also no problems running it 24/7 as far as the sub goes. Power wise I have read it draws about 10w idling.
K1LL3M is offline
post #9573 of 10469 Old 07-19-2014, 05:06 AM
INDY27's Avatar
Quoted: 52 Post(s)
Have any of you gone from a pair of JL F113's to a Submersive master/slave combo?
INDY27 is offline
post #9574 of 10469 Old 07-19-2014, 11:23 PM
jlpowell84's Avatar
Quoted: 1745 Post(s)
Liked: 750
Thanks Mike.
I spoke to Mark. He felt that most likely I would no longer need the SMS-1 since I will have XT32. That said, since I have it (and I have no other measuring equipment), he suggested taking a look at the FR graph pre-Audyssey -- looking for any huge peaks (i.e. +10db) that XT32 would have a hard time taming (which could result in Audyssey attenuating bass across the board to bring the peak down to the level of the rest of the speakers). If there are no massive peaks, run Audyssey (with no EQ from the SMS-1 - i.e., preset 6). Then look at the result using the SMS-1 and see if there is anything that I might need SMS-1 to adjust. But he also said that in his experience -- it would be uncommon that SMS-1 can really do much to improve a post XT32 room calibration. Most importantly (and wisely) he said to listen and see if it sounds good (i.e., I probably should not get too hung up on graphs and such and just watch a movie). :-)
Of course -- there are rare cases like yours.
My room is pretty simple sealed rectangle (23' long x 19' wide x 8'8" tall). Hopefully nothing that XT32 can't handle.
I use a mini dsp unit PRE AUDYSSEY to tame peaks and hand the baton off to XT32 with a better response to work with. Great team IMO to use anything to tame peaks PRE AUDYSSEY. I found the end result ALWAYS better than just giving Ausyysey my raw response to do all the work. Even if you don't have a 10db boost still try it out and see how you like it
jlpowell84 is offline
post #9575 of 10469 Old 07-20-2014, 06:25 AM
Skrill's Avatar
Quoted: 247 Post(s)
Liked: 76
So I followed Mark's process - looked at SMS, saw nothing crazy, ran XT32, after that it looked pretty flat. But then I tweaked with SMS and got it pretty flat from 15hz through 80hz.
I get a dip in the 80 to 90 hz range which seems to be caused when I add 3db to the LFE channel.
I tried to smooth a couple of dips, one at around 18hz and another around 70. Both required about 3db boost. The rest of the EQ required cuts, some bigger ones to tame a peak around 35ish hz.
I am running the Audyssey (non-flat) curve with Dynamic EQ active with 0db offset. I listen mostly between -25 to -15db - so the Dynamic EQ seems to work nicely.
Here is my SMS result - I will take another pic tonight with the SMS EQ off to show the before. As I am still learning - would love some comments.
I am running PGM2, but calibrated Audyssey in PGM1. Although I did not see a dramatic difference in the two on the SMS readout (and I did power cycle the SubMs).
Skrill is offline
post #9576 of 10469 Old 07-20-2014, 07:32 AM
basshead81's Avatar
Quoted: 212 Post(s)
Liked: 5785
That looks nice, there appears to be a lot of cutting and boosting to get the response flat. I am betting you reduced the overall headroom of the subs by 3-6db. Have you experimented with different placement for a smoother response with no eq?
basshead81 is offline
post #9577 of 10469 Old 07-20-2014, 07:39 AM
Skrill's Avatar
Quoted: 247 Post(s)
Liked: 76
Here is the measurement with XT32, but with the SMS EQ defeated.
With Audyssey also defeated it's kind of a mess -especially in the upper bass and above the crossover - but I didn't get a picture of it.
Skrill is offline
post #9578 of 10469 Old 07-20-2014, 07:46 AM
Skrill's Avatar
Quoted: 247 Post(s)
Liked: 76
I am constrained in placement due to room setup, wiring and aesthetics - these where purchased specifically because of the ability to work well in rear corners. I do plan to that the room.
In terms of headroom - playing the pod scene yesterday at -20db on the main volume resulted in a plenty loud and very imersive experience. If I am losing some headroom - I don't think it will be missed.
Alternatively I could just run with without the SMS since the Audyssey result by itself is not horrid.
Right now the master and slave are symmetrically placed in the rear corners firing in a north / south orientation (i.e firing into the back wall and out to the room). They are 8" from the side walls and 8" from back wall. I could move them a few inches forward or backward or sideways - but that is all I have to work with in terms of placement.
I could try turning the so they angle into the corners - but I think that will certainly look strange.
Skrill is offline
post #9579 of 10469 Old 07-20-2014, 09:20 AM
basshead81's Avatar
Quoted: 212 Post(s)
Liked: 5785
Well long as you do not run out of headroom then I would leave it. Just remember you have some headroom left on the table with the current tune up if you ever get to the point where the volume levels start increasing.
post #9580 of 10469 Old 07-20-2014, 12:08 PM
craig john's Avatar
Quoted: 514 Post(s)
Liked: 718
That's a nice result. Is that with Dynamic EQ on or off? (XT32 defaults to On, so it's likely with it on.) If so, MVC setting were you at when you took the measurements?
That little dip at 80 Hz may be able to be tweaked by adjusting the subwoofer Distance setting in the AVR. Try adding a foot or 2 of distance and see if you can raise that little dip.
Otherwise, it looks great and should sound great as well.
Craig
Lombardi said it:
Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #9581 of 10469 Old 07-20-2014, 12:15 PM
craig john's Avatar
Quoted: 514 Post(s)
Liked: 718
If you look cloesely, it's almost all cuts. The only boosts look to be at about 18 Hz and 63 Hz, and they loom like just 3 dB. The rest are all 6 to 8 dB cuts. Overall, he's probably reduced the "average" level by 3 to 4 dB. Since the SMS Volume setting is still at 15, (Unity Gain for the device), I would expect that he'll actually see an *increase* in his overall headroom with the EQ settings of the SMS-1.
Craig
Lombardi said it:
My System
post #9582 of 10469 Old 07-20-2014, 12:57 PM
Skrill's Avatar
Quoted: 247 Post(s)
Liked: 76
Craig
Craig -- thanks for the kinds words and the tip. I will try that with the distance setting.
Dynamic EQ is on (I hope that is ok). I left it on because most of my watching and listening if pretty far from reference (-25 to -15 db on the main volume). I am not sure what you mean by "MVC" -- but I left Dynamic EQ on the default (movie - 0db offset) setting.
You are correct -- I have two boosts (both 3db - I tried to avoid boosts as per advice I had read when reading about the SMS) one at 18hz and the other around 68-ish (I can check for the exact number). The later boost helps a lot with a the dip around 80hz -- without that boost, it has double-dip drop like the grand canyon starting around 75 hz.
I will let you know that results I get when I play with the distance. Once thing I love about this Denon X4000 is how I overlay it's setup menu right on top of the SMS -- so I can make changes, and see the immediate results in the graphing. Pretty slick.
Skrill is offline
post #9583 of 10469 Old 07-20-2014, 02:08 PM
craig john's Avatar
Quoted: 514 Post(s)
Liked: 718
Sorry, MVC = Master Volume Control. Dynamic EQ's effect on the bass is tied to the MVC setting.
A couple of 3 dB boosts shouldn't hurt anything, especially if they're not wide Q boosts. With all the other cuts you've implemented, you've easily offset them, and you should not have any headroom issues, (at least none you wouldn't have had without the SMS-1.)
The most important question: How does it sound?
Craig
Skrill likes this.
Lombardi said it:
My System
post #9584 of 10469 Old 07-20-2014, 02:18 PM
basshead81's Avatar
Quoted: 212 Post(s)
Liked: 5785
Craig
A 3db boost @ 18hz will effectively reduce amplifier power 50%. So that 2400watt amp is now 1200watts for all frequencies above the boost. If he is not reaching the subs limits with the current config then it is all good. I was just pointing this out for future reference if he finds the limits of those subs.
post #9585 of 10469 Old 07-20-2014, 02:52 PM
Skrill's Avatar
Quoted: 247 Post(s)
Liked: 76
Craig
You raise a great point - I have been doing more tweaking than enjoying. But I did run the pod scene from WOTW at -20db on the main volume and it was incredible.
BTW - changing the distance settings seemed to make the dip at 80hz worse. Audyssey shows 18.2' which is probably 4 to 5' longer than actual. But I think that just accounts for the SMS's processing delay.
What about phase adjustment - could that help with the dip?
Skrill is offline
post #9586 of 10469 Old 07-20-2014, 03:40 PM
craig john's Avatar
Quoted: 514 Post(s)
Liked: 718
Yeah, but that's only important when all he's playing is an 18 Hz test tone. Whenever he's playing real content, there will be signal at lots of other frequencies at the same time there is signal at 18 Hz. All those 6 - 8 dB cuts at other frequencies more than offset the one boost at 18. For example, say he has a signal at 18 Hz with harmonics at 36 Hz. He's boosted 18 Hz by 3 dB and cut 36 Hz by 6 dB, (1/3 octave filters at 32 and 40 Hz will overlap at 36 Hz and cut that frequency virtually equally.) The net effect of a 3 dB boost at 18 Hz and a 6 dB cut at 32 Hz is zero increase in amplifier demands across the bandwidth.
Craig
Lombardi said it:
My System
post #9587 of 10469 Old 07-20-2014, 06:47 PM
Skrill's Avatar
Quoted: 247 Post(s)
Liked: 76
Craig
So I was concerned about adding a boost that far down -- should I remove it? Sounds like I am fine. Keep in mind -- I also am using SW2 -- which I think means that the DSP is also adding a +3db down low.
Also Craig -- I figured the Dynamic EQ was MVC dependent, so I EQ'ed at -15 db on the Denon MVC (my house reference -- as I find that pretty darn loud with most content). I also added +3db to the Subwoofer level via the Denon. I did this to bring the lows in line with the 80hz+ stuff after adding all the cuts.
One other note Craig -- and I think this is not big deal -- but I wanted to ask about it. When I ran XT32 on my X4000 -- I originally had the SubM's trim at -10db as the starting point. The test tone register in the 110 db range and Audyssey said it was too high. It then played a tone and I adjusted the trim downward until I get a green light at about 77db. Oddly that required me to take the trim down to what is its absolute lowest limit (-36db -- I suppose the math works). I saw on Mark's setup guide that it is fine and totally does not impact overall output to have the trim so low, and that some systems will require a setting of -36db and some will require 0db (mine is the former). But since we were taking about headroom -- does that fact that my trim is set so low impact (positively or negatively) dynamic range or headroom?
CT
Skrill is offline
post #9588 of 10469 Old 07-21-2014, 05:01 AM
kbarnes701's Avatar
Quoted: 6740 Post(s)
Liked: 5083
Mine have been on 24.7 since I got them quite some time ago. No issues.
kbarnes701 is offline
post #9589 of 10469 Old 07-21-2014, 07:55 AM
Tnedator's Avatar
Quoted: 347 Post(s)
Liked: 127
Ok, this is more a curiosity thing than anything.
So, the HP+ amp is a 2,400 watt amp at 4 ohms, which is what it runs at with a single HP+. However, if you connect a slave cabinet, then it is capable of producing 4000 watts at 2 ohms, essentially doubling the output and driving the slave sub at the same (or close to the same) level as the single sub.
My question is about the 4 ohms vs. 2 ohms. Does this happen because when the slave unit is hooked up that essentially the speakers are now wired in parallel, which drops the resistance to 2 ohms?
Is that essentially what's going on and how the resistance is dropped and the amplifier output is increased?
Tnedator is offline
post #9590 of 10469 Old 07-21-2014, 08:15 AM
MIkeDuke's Avatar
Quoted: 474 Post(s)
Liked: 190
There here .......!!
Sweet. Have fun. Looking forward to your thoughts on them. Did you post how you are going to place them in your room? Or do you still have to figure out the best spot for each one.
Skrill, I will also add that when Craig setup my sub, he had to set the SubMersive level control to as low as it would go(I think we were still in the low 80's with that) and it really hasn't had a bad impact, so to speak. It still sounds fantastic.
It ain't easy being green.
My System
MIkeDuke is offline
post #9591 of 10469 Old 07-21-2014, 01:06 PM
QuadMersed in bass!
giomania's Avatar
Quoted: 14 Post(s)
Liked: 35
I went from a pair of Velodyne DD-15's and a pair of JL Audio f113's to four SubMersive HP's; this was a couple of years ago, so the master/slave setup was not a product. If you are worried about making the switch, I would say to go for it.
Mark
INDY27 likes this.
giomania is offline
post #9592 of 10469 Old 07-21-2014, 06:49 PM
INDY27's Avatar
Quoted: 52 Post(s)
Mark
Did you ever have the JL's hit the limiters? Mine have a few times on movies with extended lows...they sound great but have their limitations.
INDY27 is offline
post #9593 of 10469 Old 07-22-2014, 08:03 AM
Mark Seaton's Avatar
Quoted: 563 Post(s)
Liked: 1478
When JL users ask me about upgrading, I often ask if they've ever gotten into the limits of the sub, as doing so shows there can be significant benefit in an upgrade, along with the extension and sound character differences. The SubMersive never makes a hard overload noise, freeing you from that concern in listening.
Mark Seaton
Seaton Sound, Inc.
"Make no little plans; they have no magic to stir men's blood..." Daniel H. Burnham
Mark Seaton is online now
post #9594 of 10469 Old 07-22-2014, 02:32 PM
QuadMersed in bass!
giomania's Avatar
Quoted: 14 Post(s)
Liked: 35
Yes, I did.
Mark
giomania is offline
post #9595 of 10469 Old 07-23-2014, 06:59 AM
Skrill's Avatar
Quoted: 247 Post(s)
Liked: 76
Gents (and ladies),
Is there an optimal distance from corner walls in order to enhance room gain and low frequency extension in our SubMs? I currently have my master and slave in the rear corners of the room (the only real available placement in my theater due to furniture, layout and wiring constraints). They are currently firing in a north/south orientation (i.e., into the back wall and forward into the room). Each is symmetrically placed 8" from the side wall and 8" from the rear wall. I read somewhere that Mark said that these can be placed as close as 4" to the walls. Will moving the rear facing driver to 4" from rear wall boost low frequency gain? Is there an optimal placement for corner loading -- or is that entirely room dependent?
CT
Skrill is offline
post #9596 of 10469 Old 07-23-2014, 08:43 AM
Wraith2's Avatar
Quoted: 77 Post(s)
Liked: 24
Not to derail the thread but does anyone find their service to be slow and inconsistent? I have trouble reaching them for updates to my order as my emails go UN-returned. When I do have their attention things go smoothly and I'm very satisfied but then I seem to drop through the cracks and disappear off their radar. Am I alone here or is this just par for the course with a small company? I'm getting frustrated with delays and wondering if I shouldn't have gone with JL instead.
Wraith2 is offline
post #9597 of 10469 Old 07-23-2014, 08:49 AM
kbarnes701's Avatar
Liked: 5083
I know just what you mean.
Mark can be 'distracted' sometimes. Just keep plugging away. Seaton Sound is a small company and doesn’t have an army of administrators and staff, which is probably reflected in the great value for money of the subs. Once you get your Submersive(s) any irritation at slow email responses will fade into nothing, trust me. Try sending copies of your emails to Kelly as well.
post #9598 of 10469 Old 07-23-2014, 08:52 AM
Skrill's Avatar
Quoted: 247 Post(s)
Liked: 76
That is very unfortunate to hear. I did have to send a few emails and call couple of times to grab the attention of Mark, but once I got - the order process was smooth. That may have been because I was buying in-stock product (b-stock black oak SubM master/slave combo).
Sorry to hear of your trouble. I can tell you -- by all accounts, these products outclass JLs by a wide margin.
jlpowell84 likes this.
Skrill is offline
post #9599 of 10469 Old 07-23-2014, 09:44 AM
Wraith2's Avatar
Quoted: 77 Post(s)
Liked: 24
Thanks guys. I have my HP+, which is beautiful, but I haven't turned it, or the rest of my new system, on yet as I'm waiting for the Slave unit. I was told 2 weeks ago that it was being built and it would ship today. I sent a few emails requesting updates and didn't hear back so I resorted to phone calls. When I did eventually reach them yesterday I was told that not only was it never built but that it may be late August before it is. My frustration is compounded by the fact that these aren't exactly cheap and that all the other pieces are in place. I really want to have AHHHH moment when I turn everything on for the first time but right now my parade is getting rained on.
Thanks for letting me vent.
Wraith2 is offline
post #9600 of 10469 Old 07-23-2014, 10:07 AM
Skrill's Avatar
Quoted: 247 Post(s)
Liked: 76
If I was you -- would fire up what you have with the HP+ Master -- have you ahh your moment, and then when the slave gets there ... have an ahh+ moment.
Question: Seems like I ordered after you and got mine last week. Did order a custom finish (i.e., something not black oak)?
Skrill is offline
Seaton Sound , Velodyne Dd 15 Digital Drive Subwoofer 15 Inch Gloss Black , Velodyne , Speaker Systems , New Pac Sni 1 Ground Loop Signal Isolator
