Seaton Sound SubMersive1 - Page 323 - AVS Forum | Home Theater Discussions And Reviews
 585Likes
post #9661 of 10443 Old 09-24-2014, 01:44 AM
Zzzzz...'s Avatar
Quoted: 152 Post(s)
Liked: 48
A while back I posted some initial impression of my F2 (which I really love) and mentioned how great I thought War of the Worlds sounded. My preferred way to watch this film is with the sub 7 dB hot. While to me this sounds just right, I thought this was a quite a large boost and other people here agreed and mentioned that I might be compensating for a room null.
At the time I didn't have any measuring gear. Since then I've had the opportunity to run REW and would be keen to know what people think (please see the attached frequency responses) as I'm still not really sure that the plots explain the large sub boost I feel is needed.
Note: for most films I don't run the F2 hot, and if I do, its usually just 2-3 dB at most. Also, for most music, I don't run the sub hot either and find that everything sounds very balanced. It is only with music with quite low bass, like that in first 10 minutes of The Art of Flight, that some parts of the bass sound/feel a little weak - I suppose this is a result of the dips between 40-50 Hz?
Anyway, l would very much appreciate some feedback. Here are some extra details on how I normally watch War of the Worlds:
Volume: -10 dB from reference
Sub trim: +7 dB hot
Dynamic EQ: On (with a 0 dB offset)
Crossover: 80 Hz
Pgm 2 (both before and after Audyssey XT32 calibration)
Not sure if it relevant but my room is rather small: 3.7m(L) x 3.3m (W) x 2.6m (H). It does however have an opening in the back wall (double sliding doors that are usually left open). The room thru the opening is roughly twice the size of the AV room. (Together the two rectangular rooms form an "L" shape)
Zzzzz... is offline
post #9662 of 10443 Old 09-24-2014, 05:44 AM
kbarnes701's Avatar
Quoted: 6740 Post(s)
Liked: 5071
Sub trim: +7 dB hot
Crossover: 80 Hz
Is that REW chart with the sub 7dB hot or flat? We need to see it flat. Also, could you go back into REW and remake the chart with a 10-200Hz window as that is more like the 'normal' chart used for these things. The overall level is quite low too - what SPL do you use for the sweeps? You may need to run the sweep again using something like 90dB.
kbarnes701 is offline
post #9663 of 10443 Old 09-24-2014, 08:23 AM
Skrill's Avatar
Quoted: 246 Post(s)
Liked: 73
KBarnes -- what db scale do you like to see on the Y axis?
EDIT: Saw your link -- nevermind.
Skrill is offline
post #9664 of 10443 Old 09-24-2014, 04:09 PM
Zzzzz...'s Avatar
Quoted: 152 Post(s)
Liked: 48
Hi, thanks for the reply.
The sub is no longer in the position used to create these plots (it was done a while back and since then I have been testing different sub placements). If a chart with higher SPL is crucial, I could certainly create such a plot but I would not be able to do so soon (need to have my avr repaired). I have included same chart but changed the axis to 10-200 Hz as requested. The chart does NOT include the 7 dB sub increase I use for War of the Worlds, nor does it have DEQ on (which I always have on except for when measuring).
Note: in the attached chart I was trying to capture solely the sub response. The responses shown are of the left speaker and the sub combined but with the crossover set to 250 Hz. In normal use, the crossover is set to 80 Hz.
Zzzzz... is offline
post #9665 of 10443 Old 09-25-2014, 04:53 AM
kbarnes701's Avatar
Liked: 5071
The response looks fairly good other than the region between 40 and 50Hz which merits some attention. (I am ignoring the chart above 90Hz as the mains will be kicking in by then.
The general advice is to run the sweep as loud as you dare (with the brave going for 100dB). I generally go for about 90dB. Apparently the result is more reliable/accurate if you do this. IDK if it would affect your result much though.
In REW you can run a sub-only sweep by selecting Ch4 (I am assuming here that you use the latest version of REW which is HDMI/USB mic).
You may be boosting by 7dB just as preference for more bass. I boost my dual F2s by 3dB usually for example. And remember that Audyssey aims to give a flat curve at Reference Level - many people find this anemic. I assume you use Dynamic EQ when listening (you are right to disengage it when measuring).
I don't really see a null in your graph in the 10-90Hz range. Nulls usually are very deep and go to a 'point' at the bottom of the inverse spike (more like what you can see at just over 100Hz) - what you have at 40-50Hz just seems to be a dip. You might be able to change that by moving the sub to a different location and measuring again.
Incidentally, what many of us do is calibrate in Pgm 1 and then switch to Pgm 2 afterwards to get that extra oomph at the very bottom end. If you calibrate in Pgm 2 and run in Pgm 2, Audyssey will just EQ out the low-end boost.
post #9666 of 10443 Old 09-25-2014, 05:15 AM
GPBURNS's Avatar
Quoted: 123 Post(s)
Liked: 277
the louder the better to check for compression issues - just disconnect speakers when running sweep - subs at 100+ Db is not bad
15400 Watts of Seaton Power -Quad SubMersived
GPBURNS is offline
post #9667 of 10443 Old 09-25-2014, 05:41 AM
Zzzzz...'s Avatar
Quoted: 152 Post(s)
Liked: 48
This is exactly what I thought. Hence I was a little stumped why I felt the need to boost the sub so much for War of the Worlds. While its good with just a +4 dB boost, its just perfect with +7 (I can really feel the lightning strikes, the earth cracking open, etc)
I've been trying other positions for the sub but the options are pretty limited. The only other position I really have for the sub has a better response in the 40-50 Hz range, but is worse at higher frequencies, in particular, the dip around 60 Hz is much deeper and wider.
I'll give this a try in the future and test if the responses match (aside from a uniform SPL bump).
Thanks for that - I'm currently using an analog connection from my computer to the avr. Will try HDMI eventually.
Could it been that my sub 10 Hz response is too low? Yes, aside from when measuring, I always have DEQ on.
Yes - I will try this eventually. Currently I'm still in the process of trying to settle on a good location. It sort of looks like I may have to get some bass traps.
I suppose the conclusion is that I just like it playing the film that way I suppose others would watch this film at reference (I only watch at -10 dB from reference) and hence their experience of the bass would be similar to mine. Maybe having a small, untreated room makes the higher frequencies a bit much while for others with larger, treated room its not so much of an issue. Anyway, that's pretty much all I can think of...
Zzzzz... is offline
post #9668 of 10443 Old 09-25-2014, 05:44 AM
Zzzzz...'s Avatar
Quoted: 152 Post(s)
Liked: 48
Yes that makes sense. I will investigate. Thanks.
Zzzzz... is offline
post #9669 of 10443 Old 09-25-2014, 05:48 AM
3ll3d00d's Avatar
Quoted: 1566 Post(s)
Liked: 542
a 75dB sweep is perfectly fine for frequency response, you only need more for compression testing.
3ll3d00d is online now
post #9670 of 10443 Old 09-25-2014, 03:48 PM
madhuski's Avatar
Quoted: 553 Post(s)
Liked: 289
What is the benfit of the 2400 watt amp over the 1kw ICE amp?
Is it purely how many db's you can hit, or are there any other differrences?
Selling in the Classifieds
Wyred4Sound MC7150 seven channel amp - $899
madhuski is offline
post #9671 of 10443 Old 09-25-2014, 04:12 PM
Skrill's Avatar
Quoted: 246 Post(s)
Liked: 73
There are two types of 2400W amps. The HP and the HP+ -- both are 2400W @4 ohm amps made by SpeakerPower. Setting aside other potential improvements of the SpeakerPower amps, the HP+ also drives a 2 ohm load to 4000W and allows you to drive a passive slave unit along with your powered unit. A master/slave combo puts out nearly as much output as two 2400W units.
It's a great unit -- and the master/slave allows you to get dual SubMs at a relatively economical price.
More info on HP+ is here:
http://www.seaton-sound-forum.com/po...3864?&trail=20
kbarnes701 and Modicen like this.
Skrill is offline
post #9672 of 10443 Old 09-25-2014, 06:20 PM
madhuski's Avatar
Quoted: 553 Post(s)
Liked: 289
Yup - I knew about the HP+. Unfortunately duals are never going to be an option due to WAF.
What im wondering is would there be a benefit to upgrading from the 1kw and to the 2400hp?
madhuski is offline
post #9673 of 10443 Old 09-27-2014, 04:07 AM
djbluemax1's Avatar
Quoted: 54 Post(s)
Liked: 300
Db's and a little more headroom, especially for the lowest octaves which suck up a lot of power.
Max
djbluemax1 is offline
post #9674 of 10443 Old 09-28-2014, 04:31 AM
kbarnes701's Avatar
Liked: 5071
Max
Yup. In the UK with our beefier mains voltage, the amp in my master/slave pair of F2s puts out 6,000 watts, equivalent to 3,000 watts per sub.
This is how it drives those lowest, power-sucking octaves... note the start frequency of the graph...
Graph is unsmoothed, Audyssey XT32 on, Dynamic EQ off, calibrated with subs in Pgm1 then switched to Pgm2 for normal use. Crossovers are 90Hz.
post #9675 of 10443 Old 09-28-2014, 06:46 AM
Quoted: 1393 Post(s)
Liked: 587
KBarnes,
That looks great.
Did you go from the regular submersives to the F2's and if so, what did you find as the difference?
JimP is offline
post #9676 of 10443 Old 09-28-2014, 07:10 AM
kbarnes701's Avatar
Liked: 5071
Originally Posted by JimP View Post
KBarnes,
That looks great.
I went from dual F2s with the original smaller international version amps to the master/slave with the huge amp. The difference is what Max said - more grunt at the very bottom end and what feels like limitless headroom.
post #9677 of 10443 Old 10-08-2014, 11:47 AM
Wraith2's Avatar
Quoted: 76 Post(s)
If you haven't had a chance to experience it do yourself a favor and checkout the first minute of Edge of Tomorrow. I thought I knew what my Submersive(s) could do..., when all hell broke loose last night I realized I was sadly mistaken.
Modicen and jlpowell84 like this.
Wraith2 is offline
post #9678 of 10443 Old 10-18-2014, 07:37 AM
Ediddy's Avatar
Quoted: 71 Post(s)
Liked: 67
I'll pick it up this weekend
Ediddy is offline
post #9679 of 10443 Old 10-18-2014, 07:42 AM
kbarnes701's Avatar
Liked: 5071
Too right. Warning: you can easily dislodge loose items. Even if they are in another room. Or in your neighbor's house.
Modicen likes this.
post #9680 of 10443 Old 10-18-2014, 11:48 PM
NextLevel217's Avatar
Quoted: 76 Post(s)
Liked: 34
I haven't watched the whole movie yet. But was curious as to what everyone was talking about. WOW!! Craziest thing I heard yet!! Had me smiling for days.
NextLevel217 is offline
post #9681 of 10443 Old 10-19-2014, 06:02 AM
morrischestnut60's Avatar
Quoted: 63 Post(s)
Liked: 86
Easy to get excited about that scene but it was actually friggin scary . For old heads like myself watch out for vertigo.
Politics is like religion. You never know who you serve.
morrischestnut60 is offline
post #9682 of 10443 Old 10-19-2014, 06:35 AM
kbarnes701's Avatar
Liked: 5071
Also, watch out for falling masonry, pictures, ornaments...
post #9683 of 10443 Old 10-19-2014, 04:02 PM
bsoko2's Avatar
Quoted: 71 Post(s)
Liked: 78
and take a whiz before Submersives kick in, as it produces too much pressure on the bladder.
bsoko2 is offline
post #9684 of 10443 Old 10-26-2014, 09:02 AM
yosh7's Avatar
Quoted: 121 Post(s)
Liked: 160
I have been excited about the prospects of a Submersive XL for quite awhile. From what I have picked up it appears to be the same design as a Submersive except it will have dual opposed 18 inchers. I thought you would all be interested to see this was just posted on the official SubMersive XL/2 Forum over at Seaton Sound....
Posted 10/23 #233
Moving along nicely, and will be happening, but we are not taking any orders or deposits until they are ready to ship. Feel free to e-mail us at sales@seatonsound.net asking to be put on an e-mail notify list to be notified first when they are available for order.
__________________
Mark Seaton
Seaton Sound, Inc.
773-290-8436
Now this should not keep you from getting a normal HP+ if you are waiting for the XL/2 as this post could mean they are coming next week, next year, next couple of years - who knows. I don't mind this as I know Mr. Seaton is taking his time to make sure he gets it right the first time. Just FYI.
audioguy and cgrfce like this.
yosh7 is online now
post #9685 of 10443 Old 10-26-2014, 10:04 AM
rangers's Avatar
Quoted: 65 Post(s)
Liked: 51
Can't wait to see the XL. I think it will be a good move by Mark, with 18" and larger drivers all the rage these days.
A SubMersive on steroids, now that is something to get excited about!
JTR Noesis 212HTR (LR)JTR 228 (Center and Surrounds)Seaton SubMersive HP Plus and Minus (Subs)Denon 3312 (Receiver)Sherbourn PA 7-350 (Amp)Oppo BDP-103 (BluRay Player) and Sharp 80" TV
rangers is offline
post #9686 of 10443 Old 11-13-2014, 06:33 PM
Nabs17's Avatar
Quoted: 891 Post(s)
Liked: 488
Same here .....can't wait. I did get myself added to the notify list so I'll know as soon as it's ready.
Nabs17
Nabs17 is offline
post #9687 of 10443 Old 11-14-2014, 01:44 AM
Blackdevil77's Avatar
Quoted: 229 Post(s)
Liked: 118
I'm excited as well. I already have 2 Submersive HP's and don't really NEED them, but if they fit in my space, sound just as good, tight and punchy as my HP's, and have significantly more output, I'd be very tempted. I wonder if you can mix them with the regular HP's in a room and have them play nice with each other.
Blackdevil77 is online now
post #9688 of 10443 Old 11-14-2014, 05:02 AM
rangers's Avatar
Quoted: 65 Post(s)
Liked: 51
Mark says you can. I asked him about this.
rangers is offline
post #9689 of 10443 Old 11-14-2014, 02:35 PM
jlpowell84's Avatar
Quoted: 1613 Post(s)
Liked: 712
About to start hosting friends for movie nights. The dual Submersive HP's are soon to be showcased
Gonna watch the new Xmen movie tonight.
audiofan1 likes this.
jlpowell84 is offline
post #9690 of 10443 Old 11-15-2014, 08:16 AM
audioguy's Avatar
Quoted: 1917 Post(s)
Liked: 1240
"NEED"? That's blasphemy!! No one NEEDS the kind of subs Mark builds. I have a friend who just added two Terraform XL's to his dual HP's! Did he need them? Nope. Can he get the smile off his face? NOPE!
If I were not on a second floor, I would get some Terraforms and add them to my 4 HP's. There is no such thing as too much woofage!!
audioguy is offline
Seaton Sound , Velodyne Dd 15 Digital Drive Subwoofer 15 Inch Gloss Black , Velodyne , Speaker Systems , New Pac Sni 1 Ground Loop Signal Isolator
