Seaton Sound SubMersive1 - Page 337 - AVS Forum | Home Theater Discussions And Reviews
 216Likes
post #10081 of 10096 Old 08-04-2015, 11:57 AM
Stereodude's Avatar
Quoted: 1967 Post(s)
Liked: 1256
Originally Posted by Mark Seaton View Post
With the 4x #11 wire we use for the slave cables we sell and make in house, you have to get into a rather long length before there is any measurable difference.
You put two 11ga conductors in parallel for the + and -? That's equivalent to 8ga I think.
I was only thinking to use a 2 conductor 12ga SOOW for my slave sub.
Stereodude is online now
post #10082 of 10096 Old 08-04-2015, 01:19 PM
Mark Seaton's Avatar
Quoted: 249 Post(s)
Liked: 629
Correct, that's comparable to a pair of 8AWG wires, but the 4x cables are more common, and the jacket is more round and terminates more easily. Since the internally powered sub only has ~2' of wire, it's good measure and allows longer runs. The 4x12 in-wall wiring has a much thinner jacket if the diameter of the wire is a problem for any reason or if you need a white or grey jacket.
All 4 pins of the SpeakON are connected with +1/+2 in parallel along with -1/-2, so just use 4x 12AWG. While for 70% of the range it doesn't matter much, remember the lower the minimum impedance, the more the wire size can matter. For the small cost difference going to heavier copper, it's silly to waste power in a speaker cable.
Mark Seaton
Seaton Sound, Inc.
"Make no little plans; they have no magic to stir men's blood..." Daniel H. Burnham
Mark Seaton is online now
post #10083 of 10096 Old 08-04-2015, 02:07 PM
Stereodude's Avatar
Liked: 1256
Thanks for the reply. I didn't realize the SpeakON on the SP1-4000 had all 4 terminals connected. I figured it would require paralleling up the conductors in the connectors. That certainly makes things easier. I did notice the warning about using class 1 wiring. I didn't find any class 1 speaker wire. Hence my looking to SOOW or SJOOW. FWIW, I'm not sure how far apart my two subs will end up. It might only be a few feet.
post #10084 of 10096 Old 08-04-2015, 08:13 PM
Tnedator's Avatar
Quoted: 251 Post(s)
Liked: 89
That's pretty close correlation between measurements considering you have both subs running in-room an acoustically small room vs. the bass wavelengths involved.
You can see the main low pass or LFE channel low pass in the measurement and still see a bump or 2 in the 9-16Hz range vs the outdoor response.
The + and slave units do perform identically as they receive the identical signal. With the 4x #11 wire we use for the slave cables we sell and make in house, you have to get into a rather long length before there is any measurable difference. Remember the + & slave unit function just like you connected 2 subs off the same binding posts on an amplifier.
Mark, I had you make a 16' cable, and in reality, 7-8' is all I need. When you are talking about long length before measurable difference, is 16' "long" or is there no difference between 8' and 16'? I was wondering if I should shorten it to the minimum required or just coil up and leave the extra?
I'll never use it in a different location that requires more length, since this is behind a 10.5' screen in an Erskine theater, but Adam Pelz the calibrator wants the levels on each sub as close as possible.
Tnedator is offline
post #10085 of 10096 Old 08-05-2015, 06:07 AM
Pontifus Maximus
DaveyMac's Avatar
Quoted: 431 Post(s)
Liked: 71
We also have an upcoming shallow depth, single 15" module intended to fit in places where an HP or F2 can't. It is 16" x 30" on the face, and only 11" deep.
Wow! My whole challenge right now is that I have to put my two subs in opposite corners of room for flat response. But I really want a sub near field for the extra punch. I want to upgrade my exiting two subs badly, but I don't want to buy 3 subs. This sounds like the ticket!
I could put a HP+ behind my couch and then a F15s in opposite corners of room (two corners).
How would the cords flow on a HP+ and two F15s? I have to run cords around my walls. How would you actually hook these three subs together - can you run a seperate cord from HP+ to each F15s? Since HP+ is in middle of two F15s, this would be ideal.
Or do you need to run a cord from HP+ to one F15s, and then from that F15s to the other one? I could do this but room opens into dining room, so to avoid running cords across that opening.. It would take nearly a 50 foot cord to get from one F15s to the other.
DaveyMac is offline
post #10086 of 10096 Old 08-05-2015, 09:19 AM
Quoted: 249 Post(s)
Liked: 629
It's not hard to re-terminate the cable shorter, but at 16' long there is no concern. I generally consider anything under 20' as "short" when using the cable we offer. I only start questioning customers to confirm the length is necessary when we get past about 30'. Within 35-50' the differences are still extremely small and not audible. For some perspective, when looking at 35-75' lengths you have 2-4x the effect that a 16' cable might have. Note that for thebland's monster system we used two 75' runs from the rack mounted amplifier at the rear of the room to the front wall to power 2 SubMersives from each line and things worked wonderfully.
Mark Seaton
Seaton Sound, Inc.
post #10087 of 10096 Old Yesterday, 12:30 PM
3ll3d00d's Avatar
Quoted: 753 Post(s)
Liked: 234
Interesting to see a formal review of a seaton sub published - http://www.hometheaterhifi.com/subwo...all-pages.html - that is a first isn't it?
audiofan1, Magibeg, DRC3 and 1 others like this.
3ll3d00d is online now
post #10088 of 10096 Old Yesterday, 01:10 PM
audiofan1's Avatar
Quoted: 762 Post(s)
Liked: 949
Great review ! Congrats Mark
Mark Seaton and Magibeg like this.
audiofan1 is online now
post #10089 of 10096 Old Yesterday, 01:44 PM
jlpowell84's Avatar
Quoted: 1035 Post(s)
Liked: 395
Quote from review
"There are two programs that can be set. Program 1 delivers 19 Hz - 200 Hz, ± 3 dB, and Program 2 gives 15 Hz - 200 Hz ± 3 dB. I went with the default factory setting, which was Program 1. There is also a limiter dial that you can set to keep the amplifier from clipping. Again, I went with the factory default. I did this as I suspect most consumers will not want to fuss with the program or the clipping protection."
I thought the two different PGM settings were simply add a 3db bump below around 45hz or leave it flatter. Kind of like adding a little shelf filter. Measurements of each have shown identical responses but just a small rise down lower. I didn't realize one was for 15hz and one was for 19hz?
Also what is the limiter dial? Is he talking about the gain?
I agree nice to see this review Are the newer HPi models still using Speaker Power amps? If so I was surprised they didn't mention that as SP amps are known to be better than run of the mill amps.
For Sale: Ben Q W7000 Projector http://www.avsforum.com/forum/218-di...l#post36918978
DIY Sound Group Volt 10 surround speaker build
http://www.avsforum.com/t/1531107/di...axial-speakers
jlpowell84 is online now
post #10090 of 10096 Old Yesterday, 02:06 PM
Quoted: 249 Post(s)
Liked: 629
Originally Posted by jlpowell84 View Post
Quote from review
I believe there was some confusion on the "limiter". I thought I caught any technical details but I'll mention it. The limiting/protection of the amplifier remains the same for both response programs and any volume/level setting.
Also realize that Secrets' writes to a wider audience which would consider the SubMersive to be a rather massive subwoofer rather than the "just right" or "very reasonable" size most consider it in the context of the AVS subwoofer addiction.
Magibeg likes this.
Mark Seaton
Seaton Sound, Inc.
post #10091 of 10096 Old Yesterday, 02:12 PM
Skrill's Avatar
Quoted: 205 Post(s)
Liked: 63
Mark --
Is the reviewer also mistaken in his belief that the HPi+ (on a 220V main) is capable of putting out more output than the regular HP+? I gathered from your site - that the 2400/4000W HP+ and the 6000W HPi+ put out the approximately the same output (assuming a strong mainline voltage in the 120V circuit -- I have dedicated 20amp lines in my case). Which is correct?
Skrill is online now
post #10092 of 10096 Old Yesterday, 04:24 PM
Quoted: 249 Post(s)
Liked: 629
Originally Posted by Skrill View Post
Mark --
The HP+ & HPi+ have the same maximum output capabilities.
If you really push the SubMersive hard with big dynamics you will see the "clip" LED on HP+ flicker a bit, where you would see less flickering on the HPi+ running on 230-240V (more running at 120V). With the way we use the amplifiers in the SubMersive HP/F2 models you won't hear any difference so long as the 120V line isn't significantly sagging.
This type of sagging of the power line can only happen with extended duration content below ~25Hz, and most home systems will show a bigger difference in Voltage measured mid day vs evening. Available power is a detail I am always very conscious of. The SubMersive is quite power efficient over it's operating range such that the maximum amplifier is largely kept in reserve for big dynamics and the less efficient VLF reproduction. You will find many customers have no issue at all powering 4 SubMersive cabinets from two of our "+" model amplifiers (4000W each) on a single 20A, 120V circuit/line.
Mark Seaton
Seaton Sound, Inc.
post #10093 of 10096 Old Yesterday, 05:55 PM
atabea's Avatar
Quoted: 76 Post(s)
Liked: 83
I can never quite get the hang of interpreting charts but, from what I think the text is saying, distortion from 15hz on up is incredibly low!. Looking at Data-bass, I can't find anything that approaches the low overall THD measured. Perhaps this is why so many of the folks who have attended the GTGs rave about the clean, articulate sound of the Submersives. Very impressive indeed, Mr. Seaton!!!
atabea is online now
post #10094 of 10096 Unread Today, 09:05 AM
Quoted: 249 Post(s)
Liked: 629
Thank you for taking a close look at all the info in the review, you are definitely correct.
I would caution against too much comparison of John Johnson's test data vs those done by others like the more rigorous testing at Data-Bass, especially with regards to output capability. I will double check with him, but I believe the measurements were all taken in the middle of his room or off the midpoint of a wall. Much more useful comparisons can be had by looking at his past history of reviews. You will see the SubMersive is similarly low in distortion with more headroom beyond his 100dB spot-check or exceeds many well known subwoofers he has tested.
A quick scan of the subwoofer reviews under the "AUDIO" section found these past reviews for some comparison. The first 2 show how well the SubMersive has strengths over even the servo-feedback designs like the $9k Paradigm Sub2, and Velodyne DD-18+, while also showing much lower distortion, more output and deeper extension than well reviewed subs like the JL F113 and Ken Kreisel DXD-12012. Do take note a few older reviews measured at 1 foot rather than 2m or the 18" distance he used for the frequency response he saw in his room.
Direct links to Secrets' subwoofer reviews by John Johnson - "On the bench"
SubMersive HPi+
Paradigm Sub 2
Velodyne DD-18+
JL Audio F113
KEN KREISEL DXD-12012
JL Audio F212
Sunfire SDS-10
Earthquake MiniMe P10
Earthquake Supernova MKV15
Poking through the above, here's a fun quote from the earlier review of the Paradigm Sub2:
At 15 Hz and 100 dB output, with the microphone 2 meters away, distortion was less than 2%. That is a landmark result. But it gets better. At all measurements up to 50 Hz, 100 dB output, and the microphone 2 meters away, distortion never rose above 2% except at 25 Hz, where it was still only at 2.3%. I am speechless about these results, except for the word "Astonishing".
Having some fun with some admitted cherry-picking...
15Hz 100dB - Sub2 vs SubMersive:
20Hz 100dB - Sub2 vs SubMersive:
25Hz 100dB - Sub2 vs SubMersive:
And then in the very important upper octave... 50Hz 100dB - Sub2 vs SubMersive:
Happy reading.
Magibeg likes this.
Mark Seaton
Seaton Sound, Inc.
post #10095 of 10096 Unread Today, 09:41 AM
MIkeDuke's Avatar
Quoted: 241 Post(s)
Liked: 120
As I said on your forum Mark, congrats on a great review. I didn't need measurements to buy it or to prove to me that it sounds and performs great , but it's good to see a formal review of it.
It ain't easy being green.
My System
MIkeDuke is online now
post #10096 of 10096 Unread Today, 12:19 PM
audiofan1's Avatar
Quoted: 762 Post(s)
Liked: 949
SubMersive HPi+
Paradigm Sub 2
Velodyne DD-18+
JL Audio F113
JL Audio F212
Sunfire SDS-10
Happy reading.
That's the million $ question for me Mark and curious as to why he omitted it from the review if he did adhere to his normal practice of pulling the sub measured out from the adjacent walls (by how many feet etc..) then the results are simply incredible for distortion levels and output but do to the distortion levels alone (Its what we here that matters most) I may have just found a new contender for the sub in the rear of my room
This is only cherry picking of course
Seaton Sound , Velodyne Dd 15 Digital Drive Subwoofer 15 Inch Gloss Black , Velodyne , Speaker Systems , New Pac Sni 1 Ground Loop Signal Isolator
