Seaton Sound SubMersive1 - Page 347 - AVS Forum | Home Theater Discussions And Reviews
 536Likes
post #10381 of 10405 Old 09-01-2016, 01:22 PM
jjackkrash's Avatar
Quoted: 849 Post(s)
Liked: 705
Thanks Mark!
I'll give you a ring when the room is finished. Right now I am putzing around with HVAC options and power, which are way less fun to think about than your equipment.
jjackkrash is online now
post #10382 of 10405 Old 09-06-2016, 06:28 AM
djreef's Avatar
Quoted: 75 Post(s)
Liked: 68
Hey Mark,
Sent you an e-mail (actually a response to a previous e-mail).
DJ
Overkill IS my middle name.
djreef is offline
post #10383 of 10405 Old 09-08-2016, 05:56 AM
djreef's Avatar
Quoted: 75 Post(s)
Liked: 68
Hey Mark,
Replied to your response e-mail.
DJ
djreef is offline
post #10384 of 10405 Old 09-08-2016, 07:36 AM
rgiorgio's Avatar
Quoted: 47 Post(s)
Liked: 39
Without having to look through all 347 pages on this thread, can someone point in the direction for eliminating the hum from my F2's. I drastically reduced it by plugging into a Richard Gray 1200, but its big and in the way of updated setup.
My setup is a pair of F2's, one in each corner about 10-15 ft away from AVR, each
7.2 with Thiel Power Points, twin Seaton Submersive F2's in Espresso. D-Sonic Amp, Marantz Pre-Pro, Richard Grey Power, Control 4 Home Automation, lots of Blue Jean Cables, Oppo 103D, QNAP 423, Roku, Darbee, Samsung Plasma 64" 8500 all in a Salamander Synergy 247 in Walnut.
rgiorgio is offline
post #10385 of 10405 Old 09-08-2016, 07:57 AM
jjackkrash's Avatar
Quoted: 849 Post(s)
Liked: 705
Here is a link to blue jeans cable's advice on subwoofer hum.
https://www.bluejeanscable.com/artic...woofer-hum.htm
post #10386 of 10405 Old 09-08-2016, 08:34 AM
madhuski's Avatar
Quoted: 452 Post(s)
Liked: 236
madhuski is online now
post #10387 of 10405 Old 09-08-2016, 01:49 PM
rgiorgio's Avatar
Quoted: 47 Post(s)
Liked: 39
Well, i discovered today my main cable for Direct Tv runs straight from the dish to the receiver with no ground. Direct Tv is sending someone Tuesday to ground the system. Could this be the cause of the hum?
rgiorgio is offline
post #10388 of 10405 Old 09-08-2016, 02:12 PM
thxman's Avatar
Quoted: 401 Post(s)
Liked: 436
No, that ground is for other things like lightning. Can you try different outlets (AC power)?
thxman is online now
post #10389 of 10405 Old 09-08-2016, 02:15 PM
Gary J's Avatar
Quoted: 384 Post(s)
Liked: 195
huh? nothing cause hum more often than TV cables.
Gary J is offline
post #10390 of 10405 Old 09-08-2016, 02:51 PM
thxman's Avatar
Quoted: 401 Post(s)
Liked: 436
He said the cable from his dish (LNB) to his receiver. Grounding this connection helps with static build up, etc.
http://www.sadoun.com/Sat/Installation/Grounding.htm
The reason I said AC outlet is that signals (electricity) take the path of least resistance. Sometimes that path is through your equipment vs. the indented ground causing hum. AC outlets in homes tend to be "daisy chained " to a circuit and sometimes using a different outlet shortens the ground and fixes hums.
http://www.techhive.com/article/3063...o-systems.html
Can you please provide details on how subwoofer hum is introduced via a non-grounded satellite dish connection?
post #10391 of 10405 Old 09-08-2016, 05:00 PM
mmiles's Avatar
Quoted: 286 Post(s)
Liked: 111
Try a $2 cheater plug from the local hardware store.
Mike Miles
mmiles is offline
post #10392 of 10405 Old 09-08-2016, 05:04 PM
mmiles's Avatar
Quoted: 286 Post(s)
Liked: 111
I have had HUM from cable boxes due to the coax from the outside box to the STB not being grounded. The noise is in the signal path of that device.
Not sure about from the LNB on a dish.
I use to have a LNA on my 10' BUD back in 1982...
thxman likes this.
Mike Miles
mmiles is offline
post #10393 of 10405 Old 09-08-2016, 06:05 PM
rgiorgio's Avatar
Quoted: 47 Post(s)
Liked: 39
I have replaced all the outlets with Shuyanta outlets and Shuyanta plug in suppressors. Had the electrician here and isolated outlets used for home theater. Says there is nothing else he can do.
I will be replacing my Marantz with rca sub outs with Anthem AVM60 with XLR sub outs. Hope this will help.
Changed outlets, grounding Direct Tv, changing AVR and what works best is the Richard Gray 1200. Eliminates about 50% of the hum. Trying to get rid of the other 40%-50%
Thinking about running speaker wire or small guage wire from ground on AVR to somewhere on subs, really want to avoid that
rgiorgio is offline
post #10394 of 10405 Old 09-08-2016, 09:46 PM
djreef's Avatar
Quoted: 75 Post(s)
Liked: 68
Ground it yourself. Drill a hole through the wall and run 10, or 12ga OFC wire to a grounding rod outside pushed into the ground. Seal the wire hole up with silicone ( that matches the decore, of course). Really, people make such a big deal out of this stuff, and really it isn't.
DJ
HTPCat likes this.
djreef is offline
post #10395 of 10405 Old 09-08-2016, 11:08 PM
Roger Dressler's Avatar
Quoted: 1483 Post(s)
Liked: 685
In case you have not done some basic sleuthing, here's some ideas to help isolate the cause:
1) Try the ground lift plug if you have not already done so. Is the hum gone?
If so, you're done.
If not, 2) disconnect the sub's input cable from the preamp output. Is the hum gone? If not, go to step 4).
If so, 3) touch only the ground/shield side of the cable to the jack's ground. Does the hum return? If so, there's a ground or power circuit war to investigate. Let's talk about this later if needed.
4) Disconnect the cable where it enters the sub's amp. Is the hum gone? If not, go to step 6).
If so, it appears the hum is induced from something nearby.
5) Move the audio cable to a different location, or use a different cable taking a different path (even if just temporary) to see if it affects the result. Or maybe there's some other equipment nearby that can be turned off temporarily.
6) Apply a short across the input jack of the sub's amp. Can also be done for XLR inputs but there you have to jump both signal pins 2 & 3 to ground. Is the hum gone?
If not, the unit appears either defective or entirely unhappy in its environment.
If so, it proves the sub's internals are not the source of the hum.
Happy humting
djreef likes this.
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is offline
post #10396 of 10405 Old 09-08-2016, 11:10 PM
HTPCat's Avatar
Quoted: 301 Post(s)
Liked: 198
It is best to try to isolate the item introducing the hum. Perhaps you could just hook up source dvd to AVR to monitor and speakers including subs. If no hum add back one device at a time to see if it introduces hum, etc.
HTPCat
"I have a need to feed the hole with more Audio & Video toys"
HTPCat is offline
post #10397 of 10405 Old 09-09-2016, 07:31 AM
djreef's Avatar
Quoted: 75 Post(s)
Liked: 68
Has anyone heard from Mark? I hope he's not trapped under a large appliance.
I've sent him e-mails and no response. How is he going to fill orders with a looming deadline if he's out of pocket?
DJ
djreef is offline
post #10398 of 10405 Old 09-09-2016, 07:40 AM
thxman's Avatar
Quoted: 401 Post(s)
Liked: 436
DJ
You may want to call him. Lots of folks getting ready for CEDIA EXPO next week and Mark has stated he would be attending.
post #10399 of 10405 Old 09-09-2016, 08:57 AM
myav6000's Avatar
Try contact Mark via facebook messaging.
Usually he'll notice that faster than other means except calling
myav6000 is offline
post #10400 of 10405 Old 09-09-2016, 08:47 PM
djreef's Avatar
Quoted: 75 Post(s)
Liked: 68
I don't have Facebook.
The problem is that there's info in the e-mail that he needs to review.
DJ
djreef is offline
post #10401 of 10405 Old 09-11-2016, 01:54 PM
Gary J's Avatar
Quoted: 384 Post(s)
Liked: 195
DJ
his FB not yours.
Gary J is offline
post #10402 of 10405 Old 09-11-2016, 01:56 PM
sandbagger's Avatar
Quoted: 16 Post(s)
Liked: 32
FB is never a good way to contact anyone regarding business.
Call and if he does not answer, leave a message about emailing him.
Kevin
Motor City Custom Audio
Bringing you Custom subwoofer kits, with flames if you want
Onix and Melody Valve Hi Fi Audio Dealer serving the Midwest and Canada
sandbagger is offline
post #10403 of 10405 Old 09-15-2016, 05:20 AM
larry7995's Avatar
Quoted: 25 Post(s)
Liked: 26
I saw Seaton Subs in the list of exhibitors at RMAF, I am going this year. Will definitely stop by his room.
sandbagger likes this.
larry7995 is offline
post #10404 of 10405 Old Yesterday, 05:28 AM
madhuski's Avatar
Quoted: 452 Post(s)
Liked: 236
Hey Mark- shot you an email!
post #10405 of 10405 Old Today, 09:45 AM
Liked: 0
So, Mark has a sale going for pre-owned amps usable internationally($700 off). I call him from India and he spends 30 mins talking to me, patiently answering all my questions.
After a bit of back and forth, I decide on the HPi+ in black maple. I call him to make the payment, and ask him about the warranty on the pre-owned amp. His response: I see we have a new amp on the shelf from last year and I am going to send you that one instead of a pre-owned. For the sale price, no less.
There was no real business reason for Mark to do this. I would've been none the wiser if he hadn't told me and he could've sold that amp for the regular price.
You know what though? I'll remember this gesture forever. It's the little things like these that really, really count. Not to mention fantastic product quality. Thank you Mark!
I await the shipping notice later today and look forward to being absolutely blown away when I receive my Submersive.
liverpool_for_life is online now
Seaton Sound , Velodyne Dd 15 Digital Drive Subwoofer 15 Inch Gloss Black , Velodyne , Speaker Systems , New Pac Sni 1 Ground Loop Signal Isolator
