Seaton Sound SubMersive1 - Page 353 - AVS Forum | Home Theater Discussions And Reviews
 704Likes
post #10561 of 10578 Old 06-15-2017, 09:20 AM
kbarnes701's Avatar
Quoted: 6798 Post(s)
Liked: 5192
Originally Posted by imureh View Post
Good suggestion. Is a RCA/XLR connector being used?
Yes - it is the adapter Mark supplies with the sub. Checks out fine with my meter.
kbarnes701 is offline
post #10562 of 10578 Old 06-15-2017, 09:28 AM
Mark Seaton's Avatar
Quoted: 619 Post(s)
Liked: 1655
Originally Posted by kbarnes701 View Post
Thanks. Have disconnected slave - no different. The amp may have failed in some way but it would be real strange because it was working fine a few days ago and has just been standing by on idle since. And the amp shows no signs of any problems when I removed it to check. It is really weird. The strangest thing seems to be that the signal light is flickering when it receives the test tone from the AVR (and goes out if I stop the test tone) which would suggest that the signal is getting to the sub just fine, but then no sound is coming from the amp. It's exactly like the gain was zeroed or the mute button was out.
Hi Keith,
I just responded to your e-mail from this morning with a few more suggestions to try, and an option for warranty service if required.
kbarnes701 likes this.
Mark Seaton
Seaton Sound, Inc.
"Make no little plans; they have no magic to stir men's blood..." Daniel H. Burnham
Mark Seaton is offline
post #10563 of 10578 Old 06-15-2017, 10:06 AM
kbarnes701's Avatar
Liked: 5192
Thanks to Mark for instantly replying to me via email. Mark has suggested there may be an issue with the DSP loading (or not loading). Mark is sending me a warranty replacement amp out asap. When I have received and installed it I will update the thread.
Thanks to everyone who replied and to Mark for his unrivalled customer service.
I can’t be without Submersive pleasure for long, so I will be counting the days until Fedex knock on my door
It's a strange fault to develop for sure but I am confident the replacement amp will fix it.
post #10564 of 10578 Old 06-16-2017, 06:29 AM
kbarnes701's Avatar
Liked: 5192
post #10565 of 10578 Old 06-16-2017, 06:57 AM
bscool's Avatar
Quoted: 292 Post(s)
Liked: 150
Mark despatched my replacement amp yesterday (great same-day service - thanks Mark) and it is scheduled to get to me here in the UK by Wednesday next week.
That is crazy how stuff can just go out. I know though from messing around with computers and electronics you never know what to expect. If you think you have everything figured eventually something will throw you for a loop and make you want to pull your hair out
HTPC, Sony 40es, Marantz 7702mkii, Sunfire Cinema Grand 225w x 5, JBL 590, JBL 520
PSA XS30, Seaton Submersive, 2 Um-18 8cf sealed, Outlaw Ultra x 12, Kappa Pro 18LF, BFM Tuba 60 horn, B&C 18TBW100 6cf 41hz, 34hz, 28hz tune
iNuke 3000 & 6000 DSP's, Crowson Motion Actuator
bscool is offline
post #10566 of 10578 Old 06-16-2017, 07:15 AM
kbarnes701's Avatar
Liked: 5192
Yep - all fine one day, left alone, nothing touched and dead the next day. Really strange.
post #10567 of 10578 Old 06-16-2017, 04:43 PM
imureh's Avatar
Quoted: 434 Post(s)
Liked: 228
Those with Submersive HP, just got duals. Have a question please. I have going to place in what I think is best location. However I would like to understand whether the PGM button should be in or out when running REW and Audyssey XT32? I was thinking of running REW with and without Audyssey but not sure about the PGM whether it should be in or out.
imureh is online now
post #10568 of 10578 Old 06-16-2017, 05:05 PM
zdoggz's Avatar
Quoted: 118 Post(s)
Liked: 47
You want to run audyssey with it pushed in (program 1) or else audyssey will try to flatten out the elevated ~3.5dB that program 2 provides below 20hz. Once you run audyssey, then you can use rew to check your response and you will see the elevated ~3.5dB below 20hz when running program 2 compared to program 1.
Refer to this posting if you want to read a bit more about the two settings.
http://www.seaton-sound-forum.com/po...-hp-f2-5999706
zdoggz is offline
post #10569 of 10578 Old 06-16-2017, 05:19 PM
imureh's Avatar
Quoted: 434 Post(s)
Liked: 228
Thanks will do.
post #10570 of 10578 Old 06-19-2017, 03:48 PM
kbarnes701's Avatar
Liked: 5192
Update.
The warranty replacement amp for my F2 Master/Slave subs arrived this afternoon and I am delighted to report that I have regained my woofage!
Contacted Mark 1730 Thursday, UK time, had replacement amp in my hands 1500 today (UK time) Monday. How's that for service - thanks Mark (and Fedex).
Seems Mark's diagnosis was correct - the DSP in the amp has somehow failed. All is well again.
bscool likes this.
post #10571 of 10578 Old 06-19-2017, 03:56 PM
Gary J's Avatar
Quoted: 417 Post(s)
Liked: 221
The long international nightmare is over.
Gary J is online now
post #10572 of 10578 Old 06-19-2017, 06:13 PM
buddhamus's Avatar
Quoted: 115 Post(s)
Liked: 91
Congratulations Kbarnes on your amp making it back home. One of my 1000w amps just blew yesterday during a movie with a funny burning smell and now it doesn't turn on. Emailed Mark yesterday and got a very quick reply.... So we are sorting out if I can upgrade all four of my Submersive amps to the 2.4kw amps or the Hpi master/slave amps.....lol. Just waiting on Mark to get back to me now and see which way I can go. I live in Australia so I feel the same as you when you had to wait for the amp to arrive Hahaha. Love my Seatons
Sent from my SM-G900I using Tapatalk
buddhamus is offline
post #10573 of 10578 Old 06-20-2017, 06:07 AM
kbarnes701's Avatar
Liked: 5192
post #10574 of 10578 Old 06-21-2017, 02:44 PM
Quoted: 22 Post(s)
Liked: 4
I just got a used F2 locally. The seller still has 2 normal Submersive he is keeping. : )
I am using it mostly for music. I understand that each room is different, but I am curious about how others with single F2 is doing placement wise.
The room I am in is about 13.5' x 23' x 18' (w, l, h), with openings to upstairs and to back half of the house. I am using the front half of the room. The left side of the front has additional 3' x 7' square of floor space. Thus the room is not symmetry.
I sit about 9' from the front wall.
A single 12" sub placed higher up (woofer about 3' up from the ground), between front middle wall and right corner, have been working well for me. Placing the F2 at the same place (about 8' from mlp) is not optimum for me so far. I can feel the air pressure out of the F2, thus make it localized.
I will have to try more locations tonight.
For single F2 owners, where do you ended placing your sub and what crossover point do you use for music?
pdxaudio is offline
post #10575 of 10578 Old 06-21-2017, 10:05 PM
bscool's Avatar
Quoted: 292 Post(s)
Liked: 150
Placement will depend on each room. I would look at crossover point first if you can localize the sub. 80hz is a good starting point. And go up or down from there. I like higher crossover points like 120hz but you will have to have things setup correctly to do that and not have localization issues.
Did you run room correction or do any distance setting? Any kind of measuring equipment? Without measuring it is a shot in the dark.
The $80 I spent for a Umik 1 was the best money I have spent on audio equipment. It shows you so much you otherwise have no way of seeing or knowing what is going on with the sound in your room.
https://www.amazon.com/miniDSP-UMIK-.../dp/B00N4Q25R8
Marc Alexander likes this.
bscool is offline
post #10576 of 10578 Old 06-21-2017, 10:28 PM
Quoted: 22 Post(s)
Liked: 4
Thanks! Yeah, I do have omni mic I used with REW a few years ago in a closet somewhere. I was hoping my AV receiver would help in that regard. My crossover is at 80 Hz.
I moved the F2 to the middle of the front wall and reran the MCACC of my Pioneer SC-95. The sub now blends very well when playing bass heavy music. It is not perfect, but definitely is the best I have heard in my house. It is cleaner and hits harder than all the other smaller subs (several 12" and one 10") I got.
bscool likes this.
pdxaudio is offline
post #10577 of 10578 Old Today, 04:01 AM
Marc Alexander's Avatar
Quoted: 1997 Post(s)
Liked: 1726
Whenever someone asks Mark about the Submersive vs F18+ the answer is more above 40Hz for the Submersive and more below for the F18+. Here are some measurements which back that up. These numbers are somewhere between 4-7dB low (I did not properly set the SPL offset) and the 20Hz and under measurements are unreliable due to the frequency response and noise floor of the Dayton EMM-6. I will be correcting the SPL offsets within the next few days. Hopefully this data is helpful to those shopping (I went F18+ as I chase single digits). I can likely test the F18+ at 1m instead of 2m to gain some mic headroom down low, but this doesn't help measure the DO Submersive.
See attached PDF as well as the link for more data.
SoCal/LAAVA.org Spring 2017 Subwoofer meet
Marc Alexander is online now
post #10578 of 10578 Old Today, 04:54 AM
DRC3's Avatar
Quoted: 115 Post(s)
Liked: 112
Marc- Thanks so much for taking the time to measure and compile your results. I have blended both models and have measured with REW...I was hoping to take advantage of each model's strengths. Shared my graphs with Mark S and they seem to be working well together. They sound phenomenal and both have killer good looks.....
DRC3 is online now
Seaton Sound , Velodyne Dd 15 Digital Drive Subwoofer 15 Inch Gloss Black , Velodyne , Speaker Systems , New Pac Sni 1 Ground Loop Signal Isolator
