AV 12 sub- car to home theatre - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-01-2007, 09:35 AM - Thread Starter
jacbri's Avatar
I am planning on taking my Acoustic elegance AV12 from the car and putting it in the house for HT. Does anyone know if their are any box kits/amps for this particular sub that has worked well. Preferably something that looks good.
Yamaha RX-V667
Sherwood A965 (x2)
JBL L890 (x5)
JBL LC2 (x1)
JBL L820 (x4)
jacbri is offline
post #2 of 3 Old 01-02-2007, 12:15 PM
stockmonkey2000's Avatar
Liked: 30
I have 2 of the AV15 in my home theater. I built custom boxes for them. You will get the best results if you design something specifically for them. I was powering them with 2 NHT SA-3 amplifiers, 350 watts into 4 ohms, but am now using the amplifier that comes with the buttkicker tactile transducer. It puts out 2100 into 2 ohms. It can drive both with no problems.
stockmonkey2000 is offline
post #3 of 3 Old 11-22-2007, 11:32 PM - Thread Starter
jacbri's Avatar
I was told with the AV12 to put it in a sealed 3 cubic foot box with a dayton 500 watt amp, this sound reasonable? I want to reach at a clean 22hz
Yamaha RX-V667
Sherwood A965 (x2)
JBL L890 (x5)
JBL LC2 (x1)
JBL L820 (x4)
jacbri is offline
