SVS AS-EQ1 Thoughts... - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 6298 Old 02-18-2008, 10:44 AM
CFoote's Avatar
Just thought I would 'bump' this to the top....hoepfully the AS-EQ1 is still going to be produced...
My HT: 60" Pioneer Elite PRO-151FD (calibration soon), Krell electronics, B&W N802s.
CFoote is offline
post #122 of 6298 Old 02-18-2008, 11:09 AM
Wireless member
pepar's Avatar
Quoted: 1055 Post(s)
Liked: 546
It is.
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is offline
post #123 of 6298 Old 02-18-2008, 12:07 PM
Ed Mullen's Avatar
Quoted: 122 Post(s)
Liked: 332
I have the latest hardware/software at my place for evals and independent confirmation of correction performance. We're still not ready for external beta testers (we've had dozens of volunteers though), but things are moving quickly as of recent.
Ed Mullen
Director - Technology and Customer Service
SVS
"What We Do In Life, Echoes In Eternity"
Ed Mullen is offline
post #124 of 6298 Old 02-18-2008, 03:11 PM
Wireless member
pepar's Avatar
Liked: 546
Is it still too soon for you to compare this with the Audyssey in the Integra 9.8?
pepar is offline
post #125 of 6298 Old 02-18-2008, 04:50 PM
allredp's Avatar
Add me to the list of those beta tester-wanna-be's
creative>energy
allredp is offline
post #126 of 6298 Old 02-20-2008, 09:11 AM
Ed Mullen's Avatar
Quoted: 122 Post(s)
Liked: 332
This version has proprietary algorithms/sampling rate and can handle dual subs independently. We are designing the product to interface seamlessly with any consumer AVR which is equipped with Audy MultEQ.
Ed Mullen
SVS
post #127 of 6298 Old 02-20-2008, 09:26 AM
Wireless member
pepar's Avatar
Liked: 546
Cool! Can't wait!!
pepar is offline
post #128 of 6298 Old 02-20-2008, 08:28 PM
skriefal's Avatar
Quoted: 97 Post(s)
Liked: 79
I'd love to be placed on a notification or pre-order list, if any such thing exists yet.
skriefal is offline
post #129 of 6298 Old 03-20-2008, 08:35 AM
CFoote's Avatar
Just thought I'd check in and see if there are any updates...
CFoote is offline
post #130 of 6298 Old 03-20-2008, 08:46 AM
jonnyozero3's Avatar
Hey, while you're at it, can you design it to interface seamlessly with MCACC too?
- Jon
"010 Meh"
jonnyozero3 is offline
post #131 of 6298 Old 04-24-2008, 07:11 AM
CFoote's Avatar
Ed, how goes the testing of the AS-EQ1?
Chris
CFoote is offline
post #132 of 6298 Old 04-24-2008, 10:31 AM
Ed Mullen's Avatar
Quoted: 122 Post(s)
Liked: 332
Yes, it will also interface with Pio AVRs equipped with MCACC. The interface is genius - one of those "why didn't I think of that" type designs.
After extensive test/review, we are waiting on the next hardware/software version from Audyssey. There's not much more to report, actually.
I really like this product; it's quite powerful - a PC/laptop is needed for all measurement data crunching, correction algorithms, and filter building. After set-up, the unit operates discretely with no user interface. It's definitely not for the tweaker crowd - it's for the enthusiast who wants a flat/accurate FR from the subwoofer(s) with a minimum of fuss, user interface, or learning curve. It's literally a 'set-it and forget it' piece of equipment, much like modern AVR auto-set-up routines.
Ed Mullen
SVS
post #133 of 6298 Old 04-24-2008, 10:41 AM
spyboy's Avatar
Liked: 48
Are you saying that a computer is needed for proper set-up of the AS EQ-1? Also, more and more people are using house curves. Are you going to craft the software so that it is easy to include a house curve, not just a flat FR from the sub(s)?
Thanks In Advance
spyboy is offline
post #134 of 6298 Old 04-24-2008, 10:42 AM
pbc
pbc's Avatar
Quoted: 414 Post(s)
Liked: 214
Can't recall, has a price point been discussed on this unit yet?
My DIY Subs ... http://www.avsforum.com/avs-vb/showthread.php?t=1233892
J Dunlavy:.. if you stop to think about it, no loudspeaker can sound more accurate than it measures.
pbc is offline
post #135 of 6298 Old 04-24-2008, 10:47 AM
Macfan424's Avatar
...a PC/laptop is needed for all measurement data crunching, correction algorithms, and filter building...
Hopefully you will port the software to Macs, as well.
Macfan424 is offline
post #136 of 6298 Old 04-24-2008, 10:59 AM
Ed Mullen's Avatar
Quoted: 122 Post(s)
Liked: 332
Thanks In Advance
Yes, a computer is needed to set-up the AS-EQ1, just like the Audyssey Pro software. The calculations would take an inordinate amount of time with an on-board processor.
We will not be building a house curve or any adjustability into the unit. We discussed this extensively both internally and with our target demographic/customer base. The more we listened and measured and compared, the more we preferred the sound of a flat FR, and the less we preferred any DSP type EQ curves or various house curves.
If you want to tweak or build a house curve (and that's perfectly fine), then use REW and a Behringer PEQ - something I frequently recommend to our tweaker customers and will continue to do so. But the vast majority of our customer base are not tweakers and definitely want a 'set-it and forget-it' accurate bass solution with a minimum of user interface. For example, our polls indicated very few users actually manually override the MCACC, YPAO, or MultEQ XT EQ settings after auto-set-up.
Ed Mullen
SVS
post #137 of 6298 Old 04-24-2008, 11:17 AM
Wireless member
pepar's Avatar
Liked: 546
Acquiring an appreciation for truly flat bass is sometimes like acquiring a taste for fine red wine. When I started with both wine and audio, I liked Boone's Farm and fat bass. I found that, with both, I needed to educate myself and taste/listen extensively to come to like the best.
Want fatter, non-flat bass? Crank the tone control.
pepar is offline
post #138 of 6298 Old 04-24-2008, 11:23 AM
ManicMiner's Avatar
Hi Ed, thanks for dropping by : )
If you choose to do so at a later point in time, will it be possible to add a house curve and/or manual tweaking in the software running on the PC, or would it require soft and/or hardware modifications in the EQ-1?
And feel free to add me to the list of beta testers ; ) Maybe it's just that I'm getting old, but fiddling around with the BFD isn't as fun as it used to be : )
Thomas
Thomas. Rated R for non-stop dumbness, language and some nudity
ManicMiner is offline
post #139 of 6298 Old 04-24-2008, 11:27 AM
lalakersfan34's Avatar
Liked: 25
That, or sit against a wall or in a corner
lalakersfan34 is offline
post #140 of 6298 Old 04-24-2008, 11:37 AM - Thread Starter
Warpdrv's Avatar
Hey Ed... Please correct me if I'm wrong here... this is an Auto EQ, but will it have adjustable Highpass feature like the SMS-1, and will it have the ability for adjustable EQ settings... The way I am reading it here it does everything for you and you have no control to tweak things after its done its thing... I would like to think one could adjust some EQ a bit here and there...
Appreciate you stopping in here as well, people have been patiently waiting your results.
Warp
Warpdrv is offline
post #141 of 6298 Old 04-24-2008, 11:49 AM
Ed Mullen's Avatar
Quoted: 122 Post(s)
Liked: 332
While I don't see him much on this side of the forum anymore, it was bossobass who first opined that our relative insensitivity to the deepest bass frequencies is already compensated for in HT source material by the mastering/mix engineers. They mix the audio track so infrasonic (or near infrasonic) content is a level which sounds flat/level/even to our ears, and additional correction/compensation is therefore unnecessary.
The key limitation to the above is that the bass will only sound balanced at a given playback level (typically fairly loud) and won't sound that way at lower volumes, which was the basis for the house curve concept. The problem with a fixed house curve is that it will also only sound correct at a given playback volume.
This limitation of the fixed house curve ultimately spawned the development and release of Audyssey Dynamic EQ, which (as the name implies) has an EQ curve which changes with playback level. Dynamic EQ is very well conceived and works extraordinarily well in actual use; the house curve is always perfect, no matter what the playback level.
So I definitely recognize the need for a house curve as Spyboy suggests, but I eventually found the limitation of a fixed house curve to outweigh its usefulness. Now with Dynamic EQ, consumers can enjoy the benefits of a flat subwoofer response at higher playback levels, and then also enjoy the benefits of a customized dynamic house curve which works equally well at all lower playback levels.
Ed Mullen
SVS
post #142 of 6298 Old 04-24-2008, 12:01 PM
Ed Mullen's Avatar
Quoted: 122 Post(s)
Liked: 332
Originally Posted by Warpdrv View Post
Hey Ed... Please correct me if I'm wrong here... this is an Auto EQ, but will it have adjustable Hipass feature like the SMS-1, and will it have the ability for adjustable EQ settings... The way I am reading it here it does everything for you and you have no control to tweak things after its done its thing... I would like to think one could adjust some EQ a bit here and there...
Warp
Hi Warp:
It will not have any adjustable EQ settings. The unit will be flashable, so the potential does exist for future tweaks/features to be added, but they will not be present in this release, and honestly we don't feel they are needed for this type of product (for the above-discussed reasons).
It also does not have user adjustable high pass filters (nor are they needed). The unit does have a sophisticated roll-off sensing algorithm (for lack of better words) which actually senses the roll-off frequency of the subwoofer and will not attempt to boost below that frequency, but will EQ flat down to the corner frequency of the subwoofer. I've tried to trip-up this algorithm and it refuses to be fooled.
Ed Mullen
SVS
post #143 of 6298 Old 04-24-2008, 12:05 PM
Wireless member
pepar's Avatar
Liked: 546
Ummm, yeah, that's where I used to sit with the Boone's Farm.
pepar is offline
post #144 of 6298 Old 04-24-2008, 12:07 PM
Wireless member
pepar's Avatar
Liked: 546
The PDF linked in the first post says approx $750.
pepar is offline
post #145 of 6298 Old 04-24-2008, 12:15 PM - Thread Starter
Warpdrv's Avatar
Hi Warp:
Well it sounds like a pretty powerful unit, and I appreciate your feedback here.
I guess that with all the auto setup and the Audyssey Dynamic EQ feature, that it probably goes without saying that it will also take care of Phase for multiple subs as well....
Also couldn't remember if it was stated as having Balanced outputs...
Warpdrv is offline
post #146 of 6298 Old 05-14-2008, 09:27 AM
04FLHRCI's Avatar
Bump for update per XLR I/O?
Larry
04FLHRCI is offline
post #147 of 6298 Old 05-18-2008, 09:32 AM - Thread Starter
Warpdrv's Avatar
Larry
I would think that with the Balanced inputs and outputs on the Ultra13, they are adding them to the EQ as well... It just makes sense.....
SVS is a sensible company right...
Warpdrv is offline
post #148 of 6298 Old 05-18-2008, 04:47 PM
MUCHO's Avatar
Hey Ed -
After it took me about 5 hours to get my subwoofers calibrated with Room EQ and a Behringer only to discover the two adjoining seats were completely screwed I decided I will only sit in the sweet spot.
Add another hash mark for me in the enthusiast who doesn't want to be a tweaker crowd.
MUCHO is offline
post #149 of 6298 Old 05-18-2008, 05:21 PM
Wireless member
pepar's Avatar
Liked: 546
There are no balanced ins/outs on this piece.
pepar is offline
post #150 of 6298 Old 05-19-2008, 04:44 AM
Ed Mullen's Avatar
Quoted: 122 Post(s)
Liked: 332
Originally Posted by MUCHO View Post
Hey Ed -
Yep, there's something to be said for plug-n-play ease of set-up. You could have set-up the AS-EQ1 and watched two movies in that time frame and had decent bass at all three seats.
Ed Mullen
SVS
