SVS AS-EQ1 Thoughts... - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 6298 Old 05-22-2008, 06:20 PM - Thread Starter
Warpdrv's Avatar
Originally Posted by 04FLHRCI View Post
WOW; a couple hundred - how is this determined? That's 2/3 the price of an ep2500. XLR is implemented on too much gear for this to be so; I'm not buying this...
I had high hopes here too.
Larry
reguardless, I will not be poo pooing this device just because it doesn't have xlr.... It would be nice, but not a do or die for me....
Warpdrv is offline
post #182 of 6298 Old 05-22-2008, 06:36 PM
Wireless member
pepar's Avatar
Quoted: 910 Post(s)
Liked: 502
well said, no poo pooing here folks!
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is online now
post #183 of 6298 Old 05-22-2008, 07:30 PM
Static Wick's Avatar
Larry
I still have high hopes for this unit and I will buy one.
Static Wick is offline
post #184 of 6298 Old 05-22-2008, 07:32 PM
04FLHRCI's Avatar
No poo poo here guys; merely a 'realistic' and simple challenge as to the proposed cost of implementing XLR - $200 on top of a $700 device?
Larry
04FLHRCI is offline
post #185 of 6298 Old 05-22-2008, 07:35 PM
04FLHRCI's Avatar
As you should - my reference to 'high hopes' was pertaining to XLR - I'm sure this is going to be a great device; likewise meeting 'everyone's' expectations is unrealistic.
04FLHRCI is offline
post #186 of 6298 Old 05-22-2008, 07:51 PM
04FLHRCI's Avatar
I'll likely pick one up too - nothing wrong with using adapters on the back of the device!
Oh great, now you have me quoting myself
Larry
04FLHRCI is offline
post #187 of 6298 Old 05-23-2008, 07:28 AM
Wireless member
pepar's Avatar
Quoted: 910 Post(s)
Liked: 502
Larry, it's not just the cost of adding a male and female chassis mount XLRs. Unless the EQ1's circuitry is balanced, baluns transformers would need to be added. It is that part that could add ~$200. You can google Jensen baluns or Rane BB22 to do some of your own research.
- Jeff
pepar is online now
post #188 of 6298 Old 05-23-2008, 07:34 AM
Wireless member
pepar's Avatar
Quoted: 910 Post(s)
Liked: 502
No balanced in/out is far from a deal breaker for me. My present sub "group" (dual Hsu TN-1220 HO) is in the front of my room driven by my "head-end" in the room's "rear end." I am adding a second identical setup in the rear close to the rack. I will use an external baluns for the run to the room front, but will use the SE direct to my rear group.
Just my $.02.
- Jeff
pepar is online now
post #189 of 6298 Old 05-23-2008, 08:06 AM
04FLHRCI's Avatar
Hi Jeff,
Not doubting your position here; however, does cause one to wonder how other organizations are able to street balanced devices for < $500. Like I said, I'm not knocking the device (I'll likely pick one up); merely an enthusiast sharing my thoughts.
Larry
- Jeff
04FLHRCI is offline
post #190 of 6298 Old 05-23-2008, 08:26 AM
04FLHRCI's Avatar
Hi Jeff,
My install sounds similar in approach as yours; multiple subs distributed around the listening environment, with the source electronics located in the rear of the room. I've gone overboard on my pursuit of the last' octave (I blame Arthur TheEar' here); my install will consist of 4 18 Maelstrom-X's, 2 18" LMS Ultras and one of the 21" units Haskins' is developing. I'll follow the Harmon 'white paper' per the install, so I currently don't view auto-calibration as a must-have for me. In the interim I'll use a Marchand Bassis with the XLR I/O upgrade.
My intent was NOT to belittle SVS's product; I only desired the unit to be balanced is all - merely personal preference. I will most certainly be looking forward to user feedback.
Larry
Just my $.02.
- Jeff
04FLHRCI is offline
post #191 of 6298 Old 05-23-2008, 08:49 AM
Wireless member
pepar's Avatar
Quoted: 910 Post(s)
Liked: 502
Hi Jeff,
Larry
Larry,
"Position" connotes, to me, an argument or at least a debate. I really don't think that is the case, but *that* would be a position.
When I referred to Jensen baluns and Rane BB22, I went straight to audiophile/pro level gear. Many of us are audiophiles with a sizable chunk o' money in our systems. There are lesser expensive transformers, but they fall below my threshold of acceptability. Perhaps that is what the devices you cite are using?
- Jeff
pepar is online now
post #192 of 6298 Old 05-23-2008, 08:54 AM
04FLHRCI's Avatar
Hey Jeff,
I certainly don't want to sidetrack the thread any further (my apologies to all here); however, I like the Rane device; particularly the BB44 - this guy is expandable to 8x8...
Have a great day!
Larry
Larry,
- Jeff
04FLHRCI is offline
post #193 of 6298 Old 05-23-2008, 09:07 AM
Wireless member
pepar's Avatar
Quoted: 910 Post(s)
Liked: 502
Hi Jeff,
My install sounds similar in approach as yours; multiple subs distributed around the listening environment, with the source electronics located in the rear of the room. I’ve gone overboard on my pursuit of the ‘last’ octave (I blame Arthur ‘TheEar’ here); my install will consist of 4 18” Maelstrom-X's, 2 18" LMS Ultras and one of the 21" units Haskins' is developing. I'll follow the Harmon 'white paper' per the install, so I currently don’t view auto-calibration as a must-have for me. In the interim I'll use a Marchand Bassis with the XLR I/O upgrade.
If your room has all 90° angles and straight, flat walls and ceiling, the method discussed in the Harmon paper will indeed minimize the interference that causes peaks and nulls. Where possible/practical, I am a big fan of "speaker placement" as a way to smooth out the bottom end. I'd imagine that, with your apparent level of commitment (read: $$$ invested), you have acoustical treatments, i.e. bass traps, installed? On my list, that is right after speaker position and just before electronic correction.
For me, subwoofer position is dictated by other factors and my room has no parallel surfaces. 'Harmon" can't be employed in my room and wouldn't work if it could. I do have a good amount of Studiotips SuperChunk corner bass traps, and now I need an AS-EQ1 to take my system the rest of the way to being all it can be.
- Jeff
pepar is online now
post #194 of 6298 Old 06-22-2008, 05:58 PM - Thread Starter
Warpdrv's Avatar
Well just got the new SVS newsletter....
Here it is, if anyone is interested in reading it... a little talk about the new EQ
Hopefully more info to come soon...
http://www.svsound.com/Newsletter/20...wsletter08.pdf
Warpdrv is offline
post #195 of 6298 Old 06-22-2008, 06:47 PM
Wireless member
pepar's Avatar
Quoted: 910 Post(s)
Liked: 502
pepar is online now
post #196 of 6298 Old 06-22-2008, 07:03 PM
OvalNut's Avatar
Which would be the recommended download format for the HDTracks CD mentioned in the newsletter, AIFF or FLAC ?
Tim
He drove a black and white pirate ship at 190 mph.
- Dale in the #3 will never be forgotten. Thanks for the memories.
OvalNut is offline
post #197 of 6298 Old 06-22-2008, 07:55 PM - Thread Starter
Warpdrv's Avatar
Tim
Both are great formats... I would shoot for FLAC myself, but either are very good quality...
Warpdrv is offline
post #198 of 6298 Old 07-08-2008, 10:39 AM
bsoko2's Avatar
Quoted: 71 Post(s)
Liked: 78
Originally Posted by ransac View Post
It looks like the Audyssey is an AutoEq device, but it will smooth response for multiple locations and multiple subs. It also looks like you need to be trained/certified to purchase the Pro software to be able to tweak it beyond the auto setup function.
I'm not a skeptic of what appears to be new technologies, but I never jump on board until others prove it will float.
The Anti Mode 8033 is fully automatic and can handle all the subs you want as long as they are after the unit on the sub cable.
Bill
bsoko2 is offline
post #199 of 6298 Old 07-08-2008, 10:46 AM
Wireless member
pepar's Avatar
Quoted: 910 Post(s)
Liked: 502
Bill
What is the Anti Mode 8033?
pepar is online now
post #200 of 6298 Old 07-08-2008, 10:46 AM
pbc
pbc's Avatar
Quoted: 347 Post(s)
Liked: 206
Check out the "Best EQ under $400 thread" on this forum.
I'm hoping the SVS EQ will do whatever the 8033 does and more given it will be twice the cost ...
My DIY Subs ... http://www.avsforum.com/avs-vb/showthread.php?t=1233892
J Dunlavy:.. if you stop to think about it, no loudspeaker can sound more accurate than it measures.
pbc is offline
post #201 of 6298 Old 07-08-2008, 10:49 AM
Kal Rubinson's Avatar
Quoted: 672 Post(s)
Liked: 457
See this thread: http://www.avsforum.com/avs-vb/showt...highlight=8033
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #202 of 6298 Old 07-08-2008, 11:11 AM
Wireless member
pepar's Avatar
Quoted: 910 Post(s)
Liked: 502
Thanks. This device is for one sub only, isn't it?
pepar is online now
post #203 of 6298 Old 07-08-2008, 04:10 PM - Thread Starter
Warpdrv's Avatar
Appreciate the thoughts of the Anti mode 8033, it looks like a promising unit, but lets keep this thread dedicated to the SVS AS-EQ1.
SVS, any new updates for us...?
Warpdrv is offline
post #204 of 6298 Old 07-08-2008, 04:59 PM
Wireless member
pepar's Avatar
Quoted: 910 Post(s)
Liked: 502
Agreed. Last paragraph.
pepar is online now
post #205 of 6298 Old 07-08-2008, 06:47 PM
jonnyozero3's Avatar
Not to play devil's advocate for the hell of it - but I'd be interested in learning what the differences are between the 8033 and the AS-EQ1, as we know so far. I think that is kind of relevant.
- Jon
"010 Meh"
jonnyozero3 is offline
post #206 of 6298 Old 07-08-2008, 07:07 PM
Wireless member
pepar's Avatar
Quoted: 910 Post(s)
Liked: 502
I suggest that you go to Audyssey's site and read about their technology. If regular equalizers are checkers, the 8033 may be chess, but Audyssey is 3D chess.
pepar is online now
post #207 of 6298 Old 07-08-2008, 07:12 PM
Cough.
- Jon
"010 Meh"
post #208 of 6298 Old 07-08-2008, 08:30 PM - Thread Starter
Warpdrv's Avatar
Excellent analogy...
Warpdrv is offline
post #209 of 6298 Old 07-08-2008, 08:55 PM
Wireless member
pepar's Avatar
Quoted: 910 Post(s)
Liked: 502
Cough.
Bad batch of Kool-Aid?
pepar is online now
post #210 of 6298 Old 07-08-2008, 08:57 PM
- Jon
"010 Meh"
