OFFICIAL Hsu MBM-12 thread - Page 14 - AVS Forum | Home Theater Discussions And Reviews
 20Likes
Old 02-01-2011, 01:07 AM
stewdawg's Avatar
Gentlemen i have a Integra 7.2 rec, what is the best way to hook up 2 MBM's and 1 true sub? I would assume to use 1 of the rec. sub outs with a y splitter for the MBM's and just straight out for the true sub, am i correct?..please help.
stewdawg is offline
Old 02-01-2011, 06:47 AM
WhskyTangoFoxtrt's Avatar
Quoted: 76 Post(s)
Liked: 58
That connection will work.
A Nice Radio Station with Great Music. For Those That Like That Sort of Thing: RadioParadise.com
WhskyTangoFoxtrt is offline
Old 02-01-2011, 08:22 AM
Jrunr's Avatar
Quoted: 43 Post(s)
Hey guys, I am down-sizing a bit and have two MBM-12's for sale. If anyone is interested, please PM me.
Jrunr is offline
Old 02-01-2011, 08:32 AM
skypop's Avatar
Quoted: 176 Post(s)
Liked: 87
I sent you a PM
2 Channel: Fi 2A3 mono's,Hovland HP100 W/MM Phono Stage,Technics SP10MK2/SME/Benz,Medallion Cabinets With Fostex 206EN Drivers,Peerless Subs....HT:126" Seymour AT Screen,JBL Studio 590's LCR,JBL 8340a Surround,JBL HT5 Fr Heights, and JBL SCS8 Back Surrounds,2 Epik Empire Subs,HSU Midbass Sub,Marantz 7702MK2,Outlaw 7125,Marantz Ma500's,Panasonic UB900,Toshiba HD35,JVC RS400. Black Velvet.
skypop is offline
Old 02-01-2011, 10:38 AM
moehop's Avatar
you have pm
moehop is offline
Old 02-01-2011, 10:55 AM
monomer's Avatar
Ported, sealed, or Mk2... Which version?
"For deep bass, the listener is not really listening to the speaker, but rather, is listening to the room as it is being played by the speaker."
Juicy
Doggie Jabber
monomer is offline
Old 02-26-2011, 07:12 AM
RobZ's Avatar
Quoted: 110 Post(s)
Liked: 41
Anyone have advice on calibrating the MBM with a receiver (Onkyo 3008) that has dual sub outputs and Audyssey MultEQ XT32? I have a PB13 Ultra as the true sub and the MBM nearfield.
My Theater Room JVC RS4910, Panamorph UH480, 148 in. 2.40:1 Dalite HD Pro 1.3, Klipsch THX Ultra II's x 7, Quad JTR Captivator S1 subs
My Previous Non-Dedicated space
RobZ is offline
Old 02-26-2011, 10:33 AM
ndskurfer's Avatar
Quoted: 43 Post(s)
Liked: 52
I'm posting in the MBM-12 forum as I believe this is the right audience for what I'm trying to address. I'm looking for any comments on my room situation. Room pic below:
SVS PC13U in back corner
http://i704.photobucket.com/albums/w...r/IMG_3125.jpg
Seating area
http://i704.photobucket.com/albums/w...r/IMG_3126.jpg
My issue:
I currently do not have the "punch" from the SVS, but I do have great deep bass. Using REW, my frequency response is very good, almost flat. But, I do not have the punch from gun shots, etc.
Solutions I have been thinking of:
* Placing dual MBM-12's on either side of the couch
- Placement 1: back wall next to couch about 4 feet from Ultra (this is where I sit)
- Placement 2: side wall at end of couch
- I would split the frequency at 50hz with the Ultra on the first sub (will eventually have an Audyssey XT32 Pre/Pro to EQ the Ultra/MBM & the second MBM indepentantly)
* Add Dual Epik Empires (same placement as the proposed MBM's)
* Single Epik Empire (placement 2)
* Room treatment - I'm not excited about adding panels to the walls/ceiling... Front wall is an option, but back and side walls fail WAF
* I will be replacing current Onkyo receiver (NR807) with an Audyssey XT32 pre/pro (not sure how much improvement this will provide?)
The reason on why I have been looking at the Epik Empire and MBM is because of the reviews I have read on their "punch". Would the Epik's best the MBM's for this purpose (still retaining the SVS)? I'm fine in the low low end. I would prefer not to add 2 Epiks as that is more than I want to spend right now. Would 2 MBM's = 1 Empire (please consider the Empire would be in Placement 2, not nearfield to my seat)? I'm thinking nearfield placement would help with room mode issues while adding impact?
What I have tried:
* Moving the sub - The current location is best (I didn't try along side walls - side wall along couch blocks tv view because of the height of the PC13 & and other side wall fails WAF)
* Moving couch forward and placing behind couch - not much improvement
* EQ - Currently have Onkyo NR807 with Audyssey (REW confirmed flat results)
* SVS's built-in sub EQ (prior to owning the Onkyo)
* Second sub - It isn't another Ultra, rather an Outlaw LFM-1 borrowed from my brother. I have it currently situated in "Placement 2" (gain matched with the Ultra) - not much improvement
Thoughts?
ndskurfer is online now
Old 02-26-2011, 11:00 AM
skypop's Avatar
Quoted: 176 Post(s)
Liked: 87
Seating area
My issue:
What I have tried:
Thoughts?
I would say to add 1 MBM. If you can pull the couch off the wall just enough to place the MBM behind it, centered of your couch, if you like the sound and want a little more punch than get a second MBM and try both of them behind the couch and also one one each side of the couch. The other subs you mentioned don't have high pass filtering I don't think so it's not the same as adding a MBM
skypop is offline
Old 02-26-2011, 11:23 AM
ndskurfer's Avatar
Quoted: 43 Post(s)
Liked: 52
Thanks for your quick response -
I would have to get creative with the high pass filtering if I were to cut the frequencies on the Empires. I was thinking full range sub on those since they are capable, plus have the benefit of the punch.
Unfortunately, I can't pull the couch out. While it would open up placement options, The needs to be to the back wall as it really does impose on the rest of the room (comfort).
The con of 1 MBM, it would be close to the Ultra if I wanted nearfield, which would increase localization.
Old 02-26-2011, 12:30 PM
skypop's Avatar
Quoted: 176 Post(s)
Liked: 87
It's all about the Setup, mine is sitting Right Against the back of my couch with the Port facing Sideways. No Localization for me.
skypop is offline
Old 02-26-2011, 02:35 PM
bsoko2's Avatar
Quoted: 71 Post(s)
Liked: 78
There is only one way to peoperly calibrate a true sub and a MBM. Go to http://forum.hsuresearch.com/showpos...9&postcount=33
scottnv likes this.
bsoko2 is offline
Old 03-05-2011, 08:34 PM
lefthandluke's Avatar
Quoted: 137 Post(s)
Liked: 266
i'm currently experimenting running dual mbm's, one original version (ported) and one mk2 (sealed). while i have to admit they sound great, i'm wondering if there would be any sonic improvement to be had by running dual mk2's.
anyone had experience with both setups?
at the zenith of his nadir...
lefthandluke is offline
Old 03-06-2011, 05:39 AM
Kimwyn's Avatar
I was here thinking and I have come up with a question which I know has probably been asked but I can't find the answer.
Is it possible, if running dual MBMs to connect the MBMs straight to the left and right main speakers instead of running them through the receiver's crossover and just let the true subwoofers be the only ones to implement the bass management from the receiver?
Kimwyn is offline
Old 03-06-2011, 01:09 PM
bsoko2's Avatar
Quoted: 71 Post(s)
Liked: 78
Yes, I have done it in the past when I had dual MBM's with dual 3.3's.
bsoko2 is offline
Old 03-06-2011, 01:27 PM
Kimwyn's Avatar
So you are saying that I don't have to run the MBMs through the receiver right? I think another member was saying that the MBM does not have speaker line levels.
Kimwyn is offline
Old 03-06-2011, 04:13 PM
monomer's Avatar
Well then he was wrong. I have both versions (original and Mk2) of MBM's and they both indeed do have high level inputs with speaker outs. I don't use 'em but they've got 'em.
Juicy
Doggie Jabber
monomer is offline
Old 03-07-2011, 08:10 AM
Kimwyn's Avatar
i guess this question is for Bill, as he has done what i would like to do already. If the MBMs are connected directly to the speakers via speaker wire, do both the MBM and the speaker act as ONE TOTAL speaker? By this i mean, would the bass that was going to the speaker initially, now go to the MBM and they all blend as one?
What i am trying to do, is improve my mid bass response without having to crossover at 80Hz. I would like for the MBM and speaker to act as one total full range speaker and have the punch in the 60-90Hz range coming from the MBM rather than the speaker. Is this possible and is it a good thing to do?
Kimwyn is offline
Old 03-07-2011, 08:14 AM
cacihome's Avatar
Quoted: 37 Post(s)
^The subsonic filter on the MBM will always rolloff freqs from about 50hz down...
Cacimar Hernandez
cacihome is offline
Old 03-07-2011, 08:39 AM
Kimwyn's Avatar
thats not what i was asking but thanks for the reply. I will be using the crossover in the AVR to then send the frequencies below 50Hz to the ULS dual drive.
I jus want to know how does the system know what do to (i.e send it to the speaker or the MBM) when it sends out signals to the speaker and the MBM? how does it differentiate between what the MBM will play and what the speaker will play? do i have to bridge it or anything special or do i just hook the MBM to the speaker via speaker levels and it just does its thing.
Because if so, why dont person just hook their subwoofers up to their speakers and run them full range?
Kimwyn is offline
Old 03-07-2011, 09:53 AM
cacihome's Avatar
Quoted: 37 Post(s)
You control the MBM upper range with your AVR or pre-pro. Then you turn ON the main subwoofer internal xover, and you set the internal x-over dial to about 45-47hz...
Cacimar Hernandez
cacihome is offline
Old 03-07-2011, 04:25 PM
ralfale's Avatar
Am I right to say there is already some predefined xover in mbm itself. Even if we set the knob at the amp plate to be OUT.
So my question is which is better? Set to OUT let it auto roll off at 50hz or set to IN and set knob to roll at 50hz?
ralfale is offline
Old 03-07-2011, 05:26 PM
Quoted: 76 Post(s)
Liked: 58
The MBM-12 rolls off naturally at 50 Hz. Its frequency response is 50 - 150 Hz +/- 2 dB with a low pass crossover that can be adjusted to 150 Hz.
Old 03-08-2011, 04:06 PM
cacihome's Avatar
Quoted: 37 Post(s)
^Exactly. It has always a ~50hz xover to filter out the deeper bass.
Cacimar Hernandez
cacihome is offline
Old 03-08-2011, 08:22 PM
otk
otk's Avatar
you wont be getting much out of your MBM if you do that
All this noise about noise.
Finding the acoustic sweet spot.
otk is offline
Old 03-09-2011, 06:56 AM
Kimwyn's Avatar
^^^why is that? would the MBMs not be getting everything above 50Hz up until approx 150Hz?
Kimwyn is offline
Old 03-09-2011, 07:50 AM
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
If you set the Xover on the receiver to 50hz, the receiver will only send 50hz to the subs. Meaning, the subs will handle anything from 50hz and lower. Since the Xover on the MBM is set at 50hz at it's lowest, the MBM is pretty much useless because the receiver is not sending anything over 50hz for it to work with. Now, if you set the receiver to 80hz, THEN the MBM has something to play with from 80hz-50hz.
Panasonic AE-2000, Carada BW 120", Paradigm Studio 40v3 x 2, Paradigm 690v4, Paradigm ADP 470v3 (rears), Micca M-8C x 4, Volt 6 x 2 (SR), SI DS4-18 in 12cuft X 2, Marantz 7702MKII, OPPO 103D, Emotiva XPA-3,
vitod is offline
Old 03-09-2011, 08:18 AM
Quoted: 76 Post(s)
Liked: 58
I believe Kimwyn wants to insert Stereo MBMs via Speaker-level inputs. The MBM-12 would not receive an LFE signal and would be a part of a bi-amped, self-powered L/R speaker.
Old 03-09-2011, 08:46 AM
vitod's Avatar
Quoted: 267 Post(s)
Liked: 140
Ah, thanks for clarifying. In that case, then it can be done.
vitod is offline
Old 03-09-2011, 09:24 AM
Kimwyn's Avatar
hey WTF, what is your take on what I am trying to achieve?
Kimwyn is offline
Hsu Vtf3 Mk4 , Hsu Research Hc 1 Mk2 , Hsu Research Uls 15 Subwoofer
