OFFICIAL Hsu MBM-12 thread - Page 18 - AVS | Home Theater Discussions And Reviews
 8Likes
post #511 of 524 Old 03-17-2015, 12:04 PM
shadyJ's Avatar
Quoted: 746 Post(s)
Liked: 807
Why do you think the MBM-12 is discontinued? Is that what they told you?
As for the filters, do not use those passive in-line filters. Supposedly they change the resistance and mess with the frequency response beyond the stated filtering. An active filter like the Hsu is the correct way to deal with that.
shadyJ is offline
post #512 of 524 Old 03-17-2015, 12:07 PM
RobZ's Avatar
Quoted: 16 Post(s)
Yes. I emailed to find out when they would be in stock and received reply:
"Hi Robert,
We are discontinuing the MBM-12 series.
Sincerely,
The Hsu Research Sales Team"
Also, thanks for the info regarding the passive filters. I was unaware.
RobZ is online now
post #513 of 524 Old 03-17-2015, 04:35 PM
shadyJ's Avatar
Quoted: 746 Post(s)
Liked: 807
Huh, that is a shame. However, with the massive mid bass that the VTF3 mk5 and VTF15h mk2 provides, I suppose it really isn't needed anymore. Anyway thanks for the heads up.
shadyJ is offline
post #514 of 524 Old 03-17-2015, 05:12 PM
HsuKevin's Avatar
Quoted: 28 Post(s)
Liked: 51
It's still a great concept and is very effective once integrated correctly. You'll probably see this concept show up at some point down the road. As for the MBM-12 series, yes we are phasing them out.
Kevin W.
Hsu Research
Sales and Marketing Representative
HsuKevin is online now
post #515 of 524 Old 03-17-2015, 05:56 PM
basshead81's Avatar
Quoted: 66 Post(s)
Liked: 2039
I can see why HSU is phasing them out...they probably do not sell many of them. How many out there would actually take the time to integrate them properly? Most are not willing to measure the in room response to set up multiple Sub's let alone integrating 2 or more subs with vastly differing responses. The concept is solid and I understand why it is there but it is not very practical for most peoples needs.
Getting Started with REW: A Step by Step Guide --> http://www.mediafire.com/view/aolmz2..._101_v3.92.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #516 of 524 Old 03-18-2015, 12:40 PM
ChromeJob's Avatar
Quoted: 61 Post(s)
Originally Posted by RobZ View Post
So it appears that Hsu has discontinued the mid bass module. I'm surprised. ...
I am, too. It's still on their site, and I was tempted to get one with a VTF-1, but opted for a VTF-2 instead. Still interested in one if I could have it handle 300Hz - 50Hz and let the VTF handle 80Hz - 16Hz.
http://www.hsuresearch.com/products/mbm-12mk2.html
Modest "theater": Samsung UN40ES6150, Panasonic BDT210, Yamaha RXV775. Bose 401 mains, 301 Series III surrounds, Yamaha NS-C444 center, Hsu VTF-2 Mk4.
ChromeJob is online now
post #517 of 524 Unread Today, 06:57 AM
Liked: 5
I have a pair of HSU ULS-15's and a pair of MBM-12 MK2 Mid-Bass Module's in a 2-channel music system that also serves for HT use. IMO HSU needlessly made Mid Bass Module implementation Way To Complicated by refusing to consider and or recommend anything other than Near Field Placement. Near Field Placement has potential phasing & localization issues.
If you do as I did and simply place your Mid Bass Module anywhere between the left & right main you can set the MBM crossover at 150hz (Max) and you will have NO phasing and or localization issues. Furthermore just run your mains full range, adjust the Mid Bass Module volume to suite your room & taste and it will integrate seamlessly. Basically the Mid Bass Module reinforces the mains, this is very simple and works.
For the most seamless integration between Mid Bass Module and Mains use Speaker Level Connections into the Mid Bass Module and or Sub. HSU unfortunately discourages speaker level connections (boggles my mind). Go here and REL will tell you why they recommend speaker level as their first choice.
http://rel.net/support/faq/
HSU makes a great product but they really Blew It with the Mid Bass Module. I never understood how HSU could be so clueless about how easy it is to integrate a product that they manufacture???? It is a shame to see the Mid Bass Module go like this. If anyone is interested I explain here how I set up the Mid Bass Module in my system:
http://www.decware.com/cgi-bin/yabb2...m=1360355711/0
RobZ likes this.
D-Shark is offline
post #518 of 524 Unread Today, 07:26 AM
RobZ's Avatar
Quoted: 16 Post(s)
Very good point. Another use that some may find value in the MBM and the original reason for me purchasing one years ago is the ability to experience tactile midbass or punch without having to listen anywhere near reference level. When I purchased mine, I had a PB13 in the system and experienced plenty of tactile feel in mid bass but only at high volume. At the time I had a newborn in the house and our room was open to the rest of the house. Using the MBM nearfield worked very well though I know many here on avs will say I should have just put subdudes under the baby's crib and give him a pair of ear plugs
RobZ is online now
post #519 of 524 Unread Today, 07:32 AM
ChromeJob's Avatar
Quoted: 61 Post(s)
[corrected, thanks]
// Posted from Tapatalk 3.2.1 for iOS - later versions are pfft //
post #520 of 524 Unread Today, 07:58 AM
RobZ's Avatar
Quoted: 16 Post(s)
Originally Posted by ChromeJob View Post
I'm still not sure why any of you think the MBM is being phased out...? The sale price? What am I missing here?
If they mark them down further, I'll buy one. I've found that with my AVR cross over set higher, the VTF-2 provides enough bass that I can turn off any tone controls in my AVR. With an MBM, I could do that but have the VTF cross over a wee bit lower (which I don't need, at my volume levels the thing isnt even breaking a sweat).
They are discontinued (see 514 above). They no longer have black.
ChromeJob likes this.
RobZ is online now
post #521 of 524 Unread Today, 07:58 AM
WhskyTangoFoxtrt's Avatar
Quoted: 48 Post(s)
Liked: 48
Roll back 7 posts.
http://www.avsforum.com/forum/113-subwoofers-bass-transducers/799936-official-hsu-mbm-12-thread-6.html#post32705121
A Nice Radio Station with Great Music. For Those That Like That Sort of Thing: RadioParadise.com
WhskyTangoFoxtrt is offline
post #522 of 524 Unread Today, 08:10 AM
RobZ's Avatar
Quoted: 16 Post(s)
Speaking of MBM, I watched Whiplash last night with my wife and kids. They don't like the system at high levels so we had the Onkyo down to -15. The nearfield MBM really brought extra punch to the movie even though I would have preferred listening closer to -5 on my system.
RobZ is online now
post #523 of 524 Unread Today, 08:12 AM
basshead81's Avatar
Quoted: 66 Post(s)
Liked: 2039
Perhaps you missed it due to iOS failure? Time for a Android...
post #524 of 524 Unread Today, 10:16 AM
ChromeJob's Avatar
Quoted: 61 Post(s)
Oops, yeah I missed posts 512 and 514. My bad.
... More like Tapatalk, or more likely high impedance between seat and keyboard. I use it on iOS and Android (currently mobile arsenal stocked with Nexus 4, Nexus 7 '12, Nexus 7, iPod Touch, iPad Mini 2).
Hsu Vtf3 Mk4 , Hsu Research Hc 1 Mk2 , Hsu Research Uls 15 Subwoofer
