***Official HSU owners/support thread!*** - Page 176 - AVS Forum | Home Theater Discussions And Reviews
 585Likes
post #5251 of 7617 Old 05-05-2012, 08:47 PM
dr_hsu's Avatar
Quoted: 25 Post(s)
Liked: 73
Originally Posted by rwe416 View Post
Just watched Iron Man, for the first time, and my house is still shaking. My VTF-15H never skipped a beat. Had it set at EQ2, Q2 and two ports open. WOW this sub is amazing. I recommend it to any anyone that is thinking about buying one. I have not heard any of the other ID subs but I feel as though I have made the right choice. Wife wants to order another in a couple of weeks.
Cool!
dr_hsu is offline
post #5252 of 7617 Old 05-05-2012, 09:18 PM
EJ
EJ's Avatar
I have 2 Hsu subs, a VTF-3R, and a first gen VTF-3. Both have the switch for auto<->off
with no option for "always on". I was having the problem of the subs not kicking in at lower volumes. I did what I thought to be the logical thing, and turned the volume of the sub down, while increasing the signal from the receiver.
Is there a setting on the sub that's "too low" and the subwoofer's performance is compromised in some way? I have it set at about 25% now, and it has corrected most issues. I guess I'm wondering how low can I go.
Former USSB uplink operator.
EJ is offline
post #5253 of 7617 Old 05-06-2012, 10:28 AM
dr_hsu's Avatar
Quoted: 25 Post(s)
Liked: 73
There is no limit as far as the sub goes. It's more a matter of whether your source (I assume a sub out) will start clipping if it's level is raised too high.
dr_hsu is offline
post #5254 of 7617 Old 05-06-2012, 11:52 AM
rhinomike's Avatar
Quoted: 34 Post(s)
Originally Posted by dr_hsu View Post
Volume is way too high - almost 12 o'clock! Also, crossover should be set to 'out'. EQ should be set to EQ2 (down). Open both ports (you did not take a photo of the ports). Follow the instructions above and see if it's better.
First off thank u for all of the help. It is greatly apreciated
I did what u said. Turned the volume down to about 11 o'clock turned eq and crossover like u said. Both ports were already open. No more popping. But there is not nearly as much bass now. I guess I was pushing the sub too hard. If I want more bass I better add another sub.
rhinomike is offline
post #5255 of 7617 Old 05-06-2012, 12:53 PM
dr_hsu's Avatar
Quoted: 25 Post(s)
Liked: 73
No wonder it was popping! Your installer should be responsible for any damage to the sub. It is stated clearly in the manual that you should NEVER operate the sub with both ports open and EQ1.
Did you re-run Audyssey auto calibration? Remember to set the sub to one port open, EQ1, Q=0.7 for the Audyssey calibration. After calibration, set to two port open, EQ2, Q=0.3. Bass level should be correct after Audyssey recalibration.
A VTF-15H would be more appropriate for that space. Another option for you is to add another VTF-3 MK4. You can put the second one on the other end of that row of seats. If it's not practical to put it there, you can put it where you marked 'table' for the row behind you.
dr_hsu is offline
post #5256 of 7617 Old 05-06-2012, 08:37 PM
rhinomike's Avatar
Quoted: 34 Post(s)
I was just watching Mission Impossible Ghost Protocol and the sub popped again a few times. I turned the volume down to about the 10 o'clock position and it stopped popping. I have never ran the Audessey but I will try to figure it out tomorrow. Thanks again for all f your help.
post #5257 of 7617 Old 05-06-2012, 09:17 PM
intoflatlines's Avatar
Depends on the sub out level as well. We built a lot of gain into the amp so folks with two channel stereo and efficient speakers (Klipschorns, for example, 104 dB/W) will not have trouble matching. If your main speakers are very efficient, and the sub out level on your receiver is not high, you are fine. Also, if you have the sub set to two ports open, EQ2, Q 0.3, the sub can handle higher levels safely.
What about with both ports open and turbo mounted on a VTF3.3?
intoflatlines is offline
post #5258 of 7617 Old 05-06-2012, 09:55 PM
dr_hsu's Avatar
Quoted: 25 Post(s)
Liked: 73
The woofer may have been damaged by two ports open, EQ1, and 12 o'clock volume. Anyway, try re-running Audyssey tomorrow and see what happens.
dr_hsu is offline
post #5259 of 7617 Old 05-07-2012, 07:22 AM
rhinomike's Avatar
Quoted: 34 Post(s)
Ok I will try to do the Audyssey today. After that where about should the volume be set?
post #5260 of 7617 Old 05-07-2012, 09:08 AM
dr_hsu's Avatar
Quoted: 25 Post(s)
Liked: 73
Remember, set the sub to one port open, EQ1, Q=0.7, volume 9 o'clock, phase 0, crossover out. Run Audyssey auto calibration with mike at your listening position. After calibration, check receiver's crossover frequency and sub out level. If crossover is not 80 Hz, set them manually to 80 Hz. If sub out level is not between +3 and -3, adjust the subwoofer's volume control and re-run. e.g., if sub out is at -10, you adjust the subwoofer's volume control down a bit. If it's at +10, turn up the subwoofer's volume to 10 o'clock and re-calibrate.
Once the crossover is at 80 Hz and sub out level on receiver is between +3 and -3, set the subwoofer to two ports open, EQ2, Q=0.3. The subwoofer should be at the correct level (accurate bass - if a movie sounds bass shy, it's because the recording has not much bass). You should not need to do anymore volume adjustments on the subwoofer.
If you want to adjust for more output, do it with the receiver's sub out level control. that way, you can easily set it back to the accurate position. Just remember where Audyssey set it to.
How high did you usually set the volume on the receiver when watching your movies - like Avatar, Ghost Protocol? Which scene on the Ghost Protocol did you get popping?
dr_hsu is offline
post #5261 of 7617 Old 05-07-2012, 09:13 AM
dr_hsu's Avatar
Quoted: 25 Post(s)
Liked: 73
Both ports open with turbo is the same as the one port open mode - 16 Hz tuning. It does require more woofer excursion within the operating range of the sub (16 Hz and up), but should be OK for the woofer. It's the stuff below 16 Hz at too high a level that can damage the woofer.
dr_hsu is offline
post #5262 of 7617 Old 05-07-2012, 09:24 AM
rhinomike's Avatar
Quoted: 34 Post(s)
I had it on 76 for the volume..... I am not sure what scenes it popped on....
post #5263 of 7617 Old 05-07-2012, 09:26 AM
rhinomike's Avatar
Quoted: 34 Post(s)
When you say "set the sub to one port open".... Do you mean to close it with the foam stopper provided? Sorry if that is a dumb question but I want to be sure. Thank You.
post #5264 of 7617 Old 05-07-2012, 09:50 AM
oztech's Avatar
Liked: 101
^^^^ Yes
oztech is offline
post #5265 of 7617 Old 05-08-2012, 07:12 AM
newfmp3's Avatar
Quoted: 286 Post(s)
Liked: 261
Is there no Canadian dealer for HSU anymore?
What a shame.
newfmp3 is offline
post #5266 of 7617 Old 05-08-2012, 08:42 AM
Stylz25's Avatar
What a shame.
Nope and I know! Want the VTF-15H's so bad!!
Stylz25 is offline
post #5267 of 7617 Old 05-08-2012, 10:06 AM
newfmp3's Avatar
Quoted: 286 Post(s)
Liked: 261
have you tried getting a quote for shipping? Just curious as to how bad it was. I noticed they use FedEx - which is horrible for duties from my experience. As bad as UPS.
USPS is the way to go.
I got my last HSU fom a Canadian retailer. Too bad they aren't around now.
newfmp3 is offline
post #5268 of 7617 Old 05-08-2012, 10:49 AM
Stylz25's Avatar
Yeah the quote for 1 VTF-15H shipped to me in Alberta was just shy of $300!! Total cost was going to be around $1350! But could be more if there is additional charges and duties is more!
Stylz25 is offline
post #5269 of 7617 Old 05-08-2012, 10:52 AM
newfmp3's Avatar
Quoted: 286 Post(s)
Liked: 261
ouch. That rules that out.
newfmp3 is offline
post #5270 of 7617 Old 05-08-2012, 10:58 AM
lrtrees's Avatar
Do the HSU's ever go on sale. Specificallhy the VTF-3 MK4? I am not usre how that model has been out.
I have spent some time on here and have been helped by some of the good folk here
My HT area is just under 10,000^3 and I am now thinking about two of the VTF-3 MK4's or a VTF-15H. I can more easily afford the one 15" vs the two 12"s.
lrtrees is offline
post #5271 of 7617 Old 05-08-2012, 11:09 AM
sputter1's Avatar
Liked: 42
Try two 15H's lol, that's a lot of space.
sputter1 is offline
post #5272 of 7617 Old 05-08-2012, 11:25 AM
lrtrees's Avatar
I certainly would if I could afford it.
lrtrees is offline
post #5273 of 7617 Old 05-08-2012, 01:33 PM
dr_hsu's Avatar
Quoted: 25 Post(s)
Liked: 73
Unfortunately USPS do not handle large packages like the VTF-15H or VTF-3 MK4. May be worthwhile to have it ship to someone on this side of the border and drive over and pick it up.
dr_hsu is offline
post #5274 of 7617 Old 05-08-2012, 01:36 PM
dr_hsu's Avatar
Quoted: 25 Post(s)
Liked: 73
Do the HSU's ever go on sale. Specifically the VTF-3 MK4? I am not sure how that model has been out.
Please post your room layout, including adjoining rooms if linked via permanently open doorways. If the room layout is right, and you have the sub close to you, you might be able to get away with one 15H.
dr_hsu is offline
post #5275 of 7617 Old 05-08-2012, 02:07 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1351
The VTF3 is on sale right now, regularly it is $699. That is a big space though, no matter what sub you get, placement will be crucial in getting some decent bass on your listening position.
shadyJ is offline
post #5276 of 7617 Old 05-08-2012, 02:35 PM
raistline's Avatar
Quoted: 53 Post(s)
Liked: 31
If you Canucks don't mind driving to the Twin Cities (st.paul), I would be happy to store them at my house for nominal storage fee. You would have to arrange a Saturday Delivery though as I am never home on weekdays when the UPS driver arrives. While you are in town I could even demo my VTF-2 MK3 for ya.
PM me if you want to work something out.
raistline is offline
post #5277 of 7617 Old 05-08-2012, 03:12 PM
lrtrees's Avatar
dr hsu, I sent a rough layout of my room last Thursday or Friday. Last name Trees. You responded and I appreciate it. You mentioned the corner placement of my current sub would likely work for the 15H, but that I would probly be missing out on some low frequencies because the seating area is pretty close to right under the peak of our vaulted ceiling. I was just wondering if two VTF-3 MK4 might work any better.
I know it is an extremely large area. I am just looking for decent performance with what I have.
lrtrees is offline
post #5278 of 7617 Old 05-09-2012, 09:49 AM
dr_hsu's Avatar
Quoted: 25 Post(s)
Liked: 73
dr hsu, I sent a rough layout of my room last Thursday or Friday. Last name Trees. You responded and I appreciate it. You mentioned the corner placement of my current sub would likely work for the 15H, but that I would probably be missing out on some low frequencies because the seating area is pretty close to right under the peak of our vaulted ceiling. I was just wondering if two VTF-3 MK4 might work any better.
Sitting in the middle of the length of your room is where the deep bass null is. That is irrespective of which subwoofer you get, or how many subs you get. It is the room acoustics. More subwoofer will let you get higher output than one sub, but all the subs will still be fighting the room acoustics.
Now, if you can move your entertainment center to the right wall (the wall furthest from where your sub is currently) and have your sofa as the primary seating position, you will dramatically improve the bass. You will have strong 20 and 16 Hz room reinforcement.
dr_hsu is offline
post #5279 of 7617 Old 05-09-2012, 10:19 AM
patchwrk's Avatar
Hello,
I just purchased the VTF-2 for my HT. I've attached a drawing of the family room where it is going to be (sorry for the poor quality) and would like to get some advice about placement. I went to the Hsu forum looking for help, but my requests have been ignored. Hoping the good people here on AVS will give me a helping hand.
Equipment:
I have a 65" LG tv mounted on the wall (top of picture). Under the set is a tv stand that holds my Klipsch RC-62. On each side of the tv stand I have Klipsch Bookshelf speakers RB-61. And two ceiling speakers above the couch to complete my 5.1. Have a Denon 2112 A/V receiver.
The family room dimensions are 15'x25'. It opens out to the kitchen (15'x15'). The two vertical blue lines are sliding glass doors. The short blue horizontal line is a window. The two brown vertical lines are open doorways going to the living room and dining room.
Currently I have the sub placed at position #1 in the corner of the family room. But from what I've read on other posts, it seems you recommend placing the sub more often behind the couch (#2), or besides it (#3). My wife thinks it would looks prohibitively out of place at position #2, and there isn't much space at position #3.
I'm also guessing that the VTF-2 will likely not be big enough for the room. If I keep it in position #1, I can upgrade it to a VTF-3. But if I need to place it in position #2 or #3, I doubt that my wife will allow anything bigger than the VTF-2.
Thanks for the help.
patchwrk is offline
post #5280 of 7617 Old 05-09-2012, 10:23 AM
Wassup Doc's Avatar
Does anyone have the instructions on removing the amplifier from a VTF-3 as I like to see what fried? It fried when I plugged it in after being stored away for 1.5 years. First thought it was just the fuse but after multiple fuse blows and a little bit of googling, it looks like my amp is done. Barely even used it as it was only used sparingly in the 5 yrs I had it as I used to lived in a condo. Disappointed at the quality of the electronics as I didn't expect solid state parts to go so easily. My car's amp take way more abuse and they still are going strong.
Wassup Doc is offline
Hsu Research , Hsu Vtf3 Mk4 , Hsu Vtf2 Mk4 , Hsu Research Hb1 Mk2 , Hsu Research Vtf 2mk3 , Hsu Research Hc 1 Mk2 , Hsu Vtf 15h Subwoofer , Hsu Research Uls 15 Subwoofer , Hsu Research Stf 1 Subwoofer 150 Watt
