***Official HSU owners/support thread!*** - Page 214 - AVS Forum | Home Theater Discussions And Reviews
 496Likes
post #6391 of 7457 Old 09-02-2014, 11:37 AM
BigDonk's Avatar
Originally Posted by gadgtfreek View Post
Not sure what you mean.
It can have content up to 120hz that is meant for the sub only, and should, so the rule is to keep your LFE channel at 120hz so you arent clipping anything meant for the sub.
I never know where my subs are, but I sure know they are doing something.
That's new to me, thanks for clarifying. I always understood the crossover as frequency across all 6 channels in a 5.1 setup (at least this is how it was explained to me). Perhaps I am missing out on keeping my sub at 80hz but I just notice the sub being much more localized and slightly boomy when crossed at 120hz. However if a movie's LFE track is designed to play as high as 120hz then perhaps I'll cross differently in the future.
Thanks for the information
BigDonk is offline
post #6392 of 7457 Old 09-02-2014, 05:35 PM
WhskyTangoFoxtrt's Avatar
Quoted: 76 Post(s)
Liked: 58
The LPF (low pass filter) for LFE (.1) is not a crossover. It is a low-pass filter that is usually recommended to be set at its highest level, which is probably 120Hz.
A Nice Radio Station with Great Music. For Those That Like That Sort of Thing: RadioParadise.com
WhskyTangoFoxtrt is offline
post #6393 of 7457 Old 09-02-2014, 06:46 PM
derrickdj1's Avatar
Quoted: 913 Post(s)
Liked: 622
Boomy sub is due to placement or improper calibration.
derrickdj1 is offline
post #6394 of 7457 Old 09-03-2014, 06:35 AM
BigDonk's Avatar
It's not calibrated incorrectly but it's also not in the best spot either... Due the shape of my room and limited areas for placement of this massive sub there are only two spots for it and it comes down to (for me) which is the better of the two. After mucking with with it at 120hz last night it's too boomy and very localized in it's location. I may be clipping that channel, per what I have learned here, but I am going to keep at 80hz for the time being.
BigDonk is offline
post #6395 of 7457 Old 09-03-2014, 12:45 PM
HsuKevin's Avatar
Quoted: 94 Post(s)
Liked: 151
Hi there,
Not sure if this was mentioned already, but if you feel it's too boomy in that region, you can try setting the crossover to in on the subwoofer and the crossover knob to max. Set the LFE channel crossover back to 120 Hz. It may not make much of a difference, but it's worth giving a shot. Ultimately, it's whatever sounds best to you. Using the dBSPL meter with the test cd, would help in determining why it sounds boomy to you.
Sincerely,
Kevin
BigDonk likes this.
HsuKevin is offline
post #6396 of 7457 Old 09-03-2014, 10:00 PM
BigDonk's Avatar
Originally Posted by HsuKevin View Post
Hi there,
Sincerely,
Kevin
I'll give that a shot, thanks
BigDonk is offline
post #6397 of 7457 Old 09-03-2014, 11:24 PM
derrickdj1's Avatar
Quoted: 913 Post(s)
Liked: 622
You can also set the sub xo to 80 Hz. Only about 5% of the LFE will be cut out. You most likely will not notice it.
post #6398 of 7457 Old 09-04-2014, 05:12 AM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3322
In my room we had to set the VTF15's to xover IN and 90hz (max) to fix an issue and get audyssey to create a flat response. I surely do not notice anything lacking
gadgtfreek is offline
post #6399 of 7457 Old 09-07-2014, 07:43 PM
PcGeek626's Avatar
Help.
I was watching some movies this weekend and I notice during some kick drums on the sound track I will hear a faint popping noise. First I thought it came from the one of my hsu speakers. I checked the subwoofer cone and there is a small crack just below the surround. What the heck. I'm one of those people who tries to take care of their speakers. The subwoofer is Only a year old never pushed to its limit just recently happen. How much is it to replace a woofer cone?.
Hsu Research HB-1 MK2
Hsu Research Hc-1 MK2
Hsu Research VTF3 mk4 12" subwoofer
PcGeek626 is offline
post #6400 of 7457 Old 09-07-2014, 08:11 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
It won't cost you anything. Just let Hsu know, because you are covered under warranty.
PcGeek626 likes this.
shadyJ is offline
post #6401 of 7457 Old 09-07-2014, 08:44 PM
PcGeek626's Avatar
Hey shadyj, I was really bummed.I mean I hardly use the sound system,mostly for movies.
But I guess things will fail at some point. Sighs
post #6402 of 7457 Old 09-07-2014, 10:39 PM
shadyJ's Avatar
Liked: 1350
Could just be a hidden defect that didn't manifest itself until now. I wouldn't worry about it, Hsu will take care of you. I have had two VTF3s for years now, never a problem. One of them is over 5 years old and the other over 7 years old, both still works like a charm, despite my continuous abuse.
shadyJ is offline
post #6403 of 7457 Old 09-08-2014, 08:09 AM
ClawAndTalon's Avatar
Quoted: 378 Post(s)
Liked: 260
Originally Posted by Invader3 View Post
That is nice, but I'd really rather have the down firing model though.
Why?
ClawAndTalon is offline
post #6404 of 7457 Old 09-08-2014, 09:44 AM
Invader3's Avatar
Quoted: 45 Post(s)
Originally Posted by ClawAndTalon View Post
Why?
I just like the effectiveness and sound of down firing subs better. Personal preference.
Invader3 is offline
post #6405 of 7457 Old 09-08-2014, 10:39 AM
Quoted: 378 Post(s)
Liked: 260
There's no difference. Low frequencies behave in such a way that it doesn't matter. That doesn't mean to say that you haven't heard front firings that sounded bad, or only bottom firings have sounded good but trust me, it was only by chance that the down firings have sounded better. If that's the case at all.
Too many great sub designers make front firing for there be a definitive advantage with down firing. HSU, SVS, JL Audio. HSU even does both, and for their flagship model it's front firing.
Again, it doesn't matter.
post #6406 of 7457 Old 09-08-2014, 11:00 AM
ambesolman's Avatar
Quoted: 1083 Post(s)
Liked: 911
There's no difference. Low frequencies behave in such a way that it doesn't matter. That doesn't mean to say that you have heard subs but trust me, it was only by chance that the down firings have sounded better.
+1 it's like when I was in high school and tried weed a few times and it didn't work. Just so happened that the first time I smoked a joint it affected me. Thought that was how I had to do it to work... until I found out that wasn't the case. Just coincidence. Ahh high school
Sent using Tapatalk since the mobile version is still
ambesolman is online now
post #6407 of 7457 Old 09-08-2014, 11:40 AM
Invader3's Avatar
Quoted: 45 Post(s)
Maybe you guys are right. Heck, you probably are. I just always figured that a downsizing sub had an advantage of working with the floor or the room more directly. I guess this is incorrect?
Invader3 is offline
post #6408 of 7457 Old 09-08-2014, 08:35 PM
shadyJ's Avatar
Liked: 1350
Yeah, it doesn't work with the room like that. The only potential advantage that down-firing might have is, since the woofer is facing away from the listener, some higher order harmonic distortion may get masked. Outside of that, I can think of no advantage of down-firing from the perspective of sound quality.
shadyJ is offline
post #6409 of 7457 Old 09-17-2014, 08:33 AM
Jay.Windmill's Avatar
I've had an STF-2 in my 2.1 setup, and just recently got VTF-2 for my 5.1 setup. I've messed around with the different port configurations and the Q control, but I haven't had time to really listen to the various possibilities back to back. I've read through this thread looking for some discussion, but haven't come across any yet. I'm curious how people are setting up their VTF subs. I currently have both ports open and q control dial at 12:00 and curious if and when a different configuration would be better.
Jay.Windmill is offline
post #6410 of 7457 Old 09-17-2014, 09:03 AM
SirDracula's Avatar
Quoted: 172 Post(s)
New owner of a HSU STF-2 that I got on the secondary market. Receiver is a Denon S900W, speakers EMP Tek E55Ti towers. I like the bass that this sub puts out, it really helps these speakers.
My receiver has a setting "LPF for LFE" with a range 80-250Hz (default 120Hz). I understand this only applies to the true LFE channel for 5.1 material for example, not stereo music and it also has nothing to do with the crossover setting which can be set in a different menu.
What would be a good setting for the STF-2 for "LPF for LFE"? Does it really matter or should I just leave it at the max 250Hz? Not sure what freq range we really see in practice for the LFE channel.
SirDracula is offline
post #6411 of 7457 Old 09-17-2014, 09:35 AM
Vacation's Avatar
It's a matter of personal preference. I have a VTF-15H that I run with two ports open per Dr. Hsu's, recommendation, EQ2, with Q=0.3. From my understanding this gives the best mid bass headroom and punch.
Vacation is offline
post #6412 of 7457 Old 09-17-2014, 09:42 AM
Vacation's Avatar
Leave the LPF for LFE at 120 Hz.
Also, you may want to set your speakers to "small" and crossover to the sub at 80 Hz if you haven't done so already.
Vacation is offline
post #6413 of 7457 Old 09-17-2014, 10:04 AM
raistline's Avatar
Quoted: 37 Post(s)
Liked: 25
Additionally, unless you like with to destroy your houses foundation you may want to dial back form 12 O' clock to around 9 or 10.
raistline is offline
post #6414 of 7457 Old 09-17-2014, 10:31 AM
SirDracula's Avatar
Quoted: 172 Post(s)
Yes, that's where I have the knob, I tried it in the middle and it was too much. I do not like loud bass that shakes the couch, just tight and clean to help my speakers.
I have the speakers set to small and crossed at 80Hz. The sub specs say:
Frequency Response 25 - 100 Hz, +/- 2 dB
Crossover 30 - 90 Hz, Bypassable
(from http://www.hsuresearch.com/products/stf-2.html)
I also see 90Hz as a magic number mentioned a lot in the manual. Would it make more sense to cross the speakers at 90Hz in the AVR and also set the LPF for LFE to 90Hz just to keep it all simple and easy to remember?
I do have the sub switch set to Out which bypasses the internal crossover and lets the AVR do it.
post #6415 of 7457 Old 09-17-2014, 12:41 PM
wlhungdude's Avatar
Quoted: 181 Post(s)
Liked: 227
leave the LPF of LFE at 120.
mods, can we have a 'dislike' button ?
wlhungdude is offline
post #6416 of 7457 Old 09-18-2014, 02:20 PM
SirDracula's Avatar
Quoted: 172 Post(s)
[Cross posted from the Denon thread]
Anyone using the STF-2 with a 2014 model Denon AVR (mine is the S900W)?
I have the sub set to Auto which is supposed to turn the sub on when the receiver sends anything to it. Except that it doesn't seem to do the trick. While the sub is in standby, I tried playing the AVR test tones via the setup menus. With the sub level set to 0dB nothing was playing because the sub was not turning on. I have to bump up the sub volume to sometimes +4.5dB other times +6dB for the sub to come alive. Any thoughts? The sub manual says that I can also leave the sub ON at all times and it won't use more power or affect its reliability, but Auto sounds more appealing. Perhaps an Audyssey calibration would take care of it if the sub level is indeed deemed too low at 0dB.
post #6417 of 7457 Old 09-18-2014, 02:37 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3322
Almost sounds like something is wrong with the sub out on the AVR. It has some voltage on it and if it isnt working right, it won't turn the sub on.
Does the sub perform fine otherwise if set to on instead of Auto? I leave mine on On all the time, but that doesnt take away from the fact something in your setup seems to have an issue.
post #6418 of 7457 Old 09-18-2014, 02:43 PM
SirDracula's Avatar
Quoted: 172 Post(s)
It seems to work if I have it manually set to ON, whether it performs fine, not sure how to tell. I can tell the difference between the sub on and off and I like it on, does that count?
post #6419 of 7457 Old 09-18-2014, 02:46 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3322
Someone may have a better idea, but it either sounds like the output voltage on the AVR isn't right, or the auto sense on the amp is not working correctly. I'd lean toward the amp since you get boom with it set to On. That tells me output voltage on the AVR should be OK, because if it wasn't you would not get much or any output from the sub regardless of Auto or On.
Maybe Hsu can help you reign it in. If your trim level in the AVR is set to 0.0, the sub should turn on just fine with volume.
post #6420 of 7457 Old 09-19-2014, 07:45 AM
I have a 2312ci that turns on an STF-2 with no problems, and an X2000 that turns on a VTF-2 with no issues. As you mentioned, the Hsu manual says that if auto on doesn't work, leaving it set to 'on' is not an issue. I'd be a little frustrated by auto on not working, but it's probably not worth worrying about.
Hsu Research , Hsu Vtf3 Mk4 , Hsu Vtf2 Mk4 , Hsu Research Hb1 Mk2 , Hsu Research Vtf 2mk3 , Hsu Research Hc 1 Mk2 , Hsu Vtf 15h Subwoofer , Hsu Research Uls 15 Subwoofer , Hsu Research Stf 1 Subwoofer 150 Watt
