***Official HSU owners/support thread!*** - Page 217 - AVS Forum
 43Likes
post #6481 of 6497 Old 09-28-2014, 12:44 PM
gadgtfreek's Avatar
Quoted: 133 Post(s)
Liked: 325
65" VT50 / BDP-S7200
Denon AVR-4520CI
Klipsch RF82 II and RC62 II / Hsu VTF-15H (2)
Directv HR44-200 / HR24-500
gadgtfreek is offline
post #6482 of 6497 Old 09-28-2014, 09:31 PM
Gmash's Avatar
Quoted: 97 Post(s)
Liked: 96
The VTF-3.5 looks sweet. I always thought the side firing design looked weird.
It's surprising how easily even knowledgeable people fall for the gimmicks some of the other companies use. I prefer the straightforward approach Hsu employs.
How about some pictures of the new drivers? Show off those cast baskets!
BigDonk and gadgtfreek like this.
Gmash is online now
post #6483 of 6497 Old 10-02-2014, 05:10 PM
HsuKevin's Avatar
Liked: 27
Hi there,
Just a friendly reminder, for all of you around the Denver area, that we will be at Rocky Mountain Audio Fest 2014 showcasing our new subs. We would love to see some of you folks there. Don't worry, I didn't forget about the driver pics.
Sincerely,
Kevin
shadyJ, BornSlippyZ and gadgtfreek like this.
HsuKevin is offline
post #6484 of 6497 Old 10-02-2014, 05:54 PM
gadgtfreek's Avatar
Quoted: 133 Post(s)
Liked: 325
Well, my bud wil be ready to buy one of mt VTF15's in Dec/Jan now that he is settling into his new house. I figure Ill sell my newest VTF15 to him and then buy a VTF15 MK2.
BornSlippyZ likes this.
Denon AVR-4520CI
post #6485 of 6497 Old 10-03-2014, 05:48 AM
BornSlippyZ's Avatar
Quoted: 163 Post(s)
Liked: 288
If any one here is so inclined to hear some wonderful BASS from a Horror movie (it is OCT!) Frankenstein's Army has a ton of it!
I realized I should have posted this in the VTF thread, but I am sure anyone with any HSU sub would notice this flick.
October HorrorFest Participant
BornSlippyZ is offline
post #6486 of 6497 Old 10-03-2014, 07:11 AM
troyh4's Avatar
Hey everyone,
How many of you have the pinpoint speaker wall mounts p/n AM40 you're using to wall mount your HB-1 MK2's ?
Does this wall mount do a very good job of supporting this bookshelf?
I like what I've read online for these speakers and all of your comments just make it that much confident of a decision to buy them. And to augment the bottom end with these, I'm hoping to go with 1 or 2 SVS
SB-2000's. Should be very nice.
troyh4 is offline
post #6487 of 6497 Old 10-03-2014, 10:35 AM
shadyJ's Avatar
Quoted: 311 Post(s)
Liked: 578
The AM40s work very well to hold the HB-1s, I have used them. The Videosecu side-clamping mounts are essentially the same mounts but less expensive. I have used them also.
shadyJ is online now
post #6488 of 6497 Old 10-03-2014, 01:11 PM
HsuKevin's Avatar
Liked: 27
One thing you can do, if you're afraid of them slipping out of the grip, is use some double sided adhesive foam to better secure the speaker to the mount. We use duck brand double-sided adhesive foam in our demo room and it works well. It survived through a few California earthquakes. One thing to note is that stuff is very strong, so if you're going to use it, make sure that you aren't planning on moving the speaker for a good long while and note that the foam might ruin the speaker finish it's stuck to, if you attempt to remove the foam.
BigDonk likes this.
HsuKevin is offline
post #6489 of 6497 Old 10-03-2014, 07:52 PM
WhskyTangoFoxtrt's Avatar
Quoted: 22 Post(s)
Liked: 37
Blu-tack is another option. Works great and won't harm the finish on speakers.
WhskyTangoFoxtrt is offline
post #6490 of 6497 Old 10-03-2014, 08:09 PM
gadgtfreek's Avatar
Quoted: 133 Post(s)
Liked: 325
+1
Denon AVR-4520CI
post #6491 of 6497 Old 10-03-2014, 10:36 PM
HsuKevin's Avatar
Liked: 27
Awesome! We should try that out.
HsuKevin is offline
post #6492 of 6497 Old 10-07-2014, 10:41 AM
mnc
mnc's Avatar
Quoted: 52 Post(s)
Liked: 67
Originally Posted by gadgtfreek View Post
Just looking at both those 15" results, what is the point of getting a VTF15 MK2 over a VTF3 MK5 15"? CEA are so close and it is $100 less.
On the website it appears the vtf15mk2 has a lower 1 port tuning than the vtf3 mk5, 16hz vs 18hz.
NHT speakers, Denon 4520, 65VT50
mnc is offline
post #6493 of 6497 Old 10-08-2014, 07:22 AM
Quoted: 22 Post(s)
Liked: 37
Hey gang: If you haven't seen it already, AVS Senior Writer imagic has offered his opinion in a story he posted on his experience at The New York Audio Show 2014.
A Nice Radio Station with Great Music. For Those That Like That Sort of Thing: RadioParadise.com
post #6494 of 6497 Old 10-08-2014, 07:53 AM
saldog78's Avatar
Quoted: 17 Post(s)
According to Kevin, on the vtf3mk5, you can plug either the 3" port (18hz tune), or the 4" port (16hz tune). I don't believe they've shown us a FR for the 16hz tune yet, though.
My Basement Build Thread
Paradigm Studio 60v3, Studio 570v3, Studio 20v5, Onkyo TX-NR808, PS3, Chromecast, Acer H6510BD
saldog78 is offline
post #6495 of 6497 Old 10-08-2014, 09:43 AM
HsuKevin's Avatar
Liked: 27
Hi there,
The 4" port is tuned to 18 Hz and the 3" port is tuned to 16 Hz. You can certainly run the sub with either port open. However we would usually recommend just running with 4" port open for max extension mode as that will have less port noise than if you were to run the sub with the 3" port open. So for the VTF-15H Mk2, it has 16 Hz tuning in max extension mode and it utilizes 4.5" triangular ports so it will be able to give you the 16" Hz extension and play significantly cleaner than the VTF-3 Mk5 HP.
HsuKevin is offline
post #6496 of 6497 Old 10-13-2014, 01:34 PM
shadyJ's Avatar
Quoted: 311 Post(s)
Liked: 578
Hey Kevin, about the roll off of the VTF3 mk4, does it roll down at a 24 dB octave slope or 48 dB?
post #6497 of 6497 Old 10-14-2014, 12:52 PM
HsuKevin's Avatar
Liked: 27
Hi ShadyJ,
In sealed, it would be 24 dB/oct (4th order). In ported mode, it would be 36 db/oct (6th order).
HsuKevin is offline
Hsu Research , Hsu Vtf3 Mk4 , Hsu Vtf2 Mk4 , Hsu Research Hb1 Mk2 , Hsu Research Vtf 2mk3 , Hsu Research Hc 1 Mk2 , Hsu Vtf 15h Subwoofer , Hsu Research Uls 15 Subwoofer , Hsu Research Stf 1 Subwoofer 150 Watt
User Tag List
