***Official HSU owners/support thread!*** - Page 218 - AVS | Home Theater Discussions And Reviews
 50Likes
post #6511 of 6522 Old 12-01-2014, 01:12 PM
Reepp's Avatar
Has anyone ever lost the feet to the sub? Well I moved and for whatever reason didn't put them in the box....I did talk to HSU and they were very helpful but replacement feet run $30. The rep did say that they use M6 X 1.0 screw for the feet, which is easy to find just need to find either spikes or feet, and idea's? Thanks in Advance.
PS: The sub is a VTF-2/MK3 if it matters
Reepp is offline
post #6512 of 6522 Old 12-01-2014, 01:13 PM
Reepp's Avatar
Reepp is offline
post #6513 of 6522 Old 12-06-2014, 07:13 PM
dan webster's Avatar
Quoted: 61 Post(s)
Liked: 32
I am looking for a good budget sub for my son for christmas. I know all the usual subs under $300 . I found a used hsu VTF-2 MK3 subwoofer. on craigs list for $275 The owner says it is like new. I am an hour away so i could easily pick it up. Any thoughts on this sub for this price. His basement theater is 14 x 24 with 7ft ceilings. He currently has a dayton 1200 sub. The dayton blends nicely with the ascend acoustic speakers however it does not extend nearly low enough.
Dolby Atmos 9.2.4 Marantz 7009 Gemstone 200x7 Emotiva upa-500 amps
Oppo 103 bluray player Jvc 4910 projector Benq 1070 projector
Carada 110"BW screen Monster HTS 5100 MK11 power conditioner
Golden Ear Triton 7 L&R &super center XL Emotiva erm 6.2 sides ert 8.3 rear s
Emotiva erd-1 front wides 4 erd-1 on ceiling SVS PB2-plus sub Outlaw LFM-1-plus sub
dan webster is offline
post #6514 of 6522 Old 12-06-2014, 07:16 PM
raistline's Avatar
At 275 that thing is a steal. I payed 549 for mine just two years ago and it is a beast. Make sure you hear it first but if you can get that sub that cheap go for it. You will not find better for that price.
ambesolman likes this.
raistline is offline
post #6515 of 6522 Old 12-07-2014, 08:28 AM
Quoted: 61 Post(s)
Liked: 32
Thanks i will go look at it and post back.
post #6516 of 6522 Old 12-10-2014, 02:35 PM
Quoted: 61 Post(s)
Liked: 32
My son and i picked up the used sub monday and set it up that night. We moved his Dayton 1200 to the rear of his room. We experimented with the ports and decided it sounded best with both plugs out . It really sounds wonderful. He has a yamaha RX-A 3000 receiver so there is no equalizing on the subs. The dayton did a nice job of complimenting the Hsu without drawing any attention to itself. We used the Skidoosh scene from Kung Fu Panda to make the adjustments and it really shook the room. For 275 i am very satisfied and glad i drove 2 hours to get it.
post #6517 of 6522 Old 01-19-2015, 07:30 PM
Liked: 0
Hi everyone, I am new to this forum and have a question. I have an HSU STF-2 and I want to get a pair Vanatoo Transparent One active monitors to hook up to it. My only concern is that the built-in crossover in the Vanatoos is 120Hz, and I want to be sure that the STF-2 will sound good at frequencies that high (especially since it's own crossover stops at 90Hz). Does anyone have experience listening to the STF-2 at 120Hz (or even higher)?
jb3030 is offline
post #6518 of 6522 Old 01-19-2015, 09:40 PM
shadyJ's Avatar
Quoted: 566 Post(s)
Liked: 699
It looks like the Vanatoo automatically shoots out a low passed 120 hz signal to the sub, so bass management (such as it is) should be very easy. Just shoot the cable out from the Vanatoo to the subwoofer, and turn the sub's internal crossover off. The STF2 has an upper +/- 2 dB point of 100 Hz, so it shouldn't be terrible at 120, if not quite as loud as 50 - 80 Hz.
shadyJ is online now
post #6519 of 6522 Old 01-19-2015, 10:00 PM
Liked: 0
Thanks Shady J. Someone from Vanatoo support also just replied to me and said that the STF-2 is "reasonably flat" beyond 125Hz so it should sound fine at those frequencies. If anyone has personal experience running the STF-2 at frequencies above 90Hz I'd love to hear opinions. Thanks.
jb3030 is offline
post #6520 of 6522 Unread Today, 12:34 PM
NismoZ's Avatar
I have been searching for a sub to replace my JBL PB12, 250RMS, Downfiring 12 inch. (back in 2001, this was a $400 retail sub). I still think it sounds great for music.
I have a large room to fill, opening to a kitchen. This sub will only be used for 2.1 music. I have decided against sealed subs, because I don't think they'll have the output I need for a large room that I want in my music: Rock, Dub, Funk, Nine Inch Nails, Metallica, etc...
What I am wanting is a sub that hits well on kick drums for Rock and something the will step down to low music notes as well, but still be controlled and musical. The VTF-2 Mk4 seems like my best bet with both ports open, is this the case? And have you all enjoyed this sub for music reproduction?
NismoZ is online now
post #6521 of 6522 Unread Today, 12:57 PM
dr_hsu's Avatar
Liked: 33
What I am wanting is a sub that hits well on kick drums for Rock and something the will step down to low music notes as well, but still be controlled and musical. The VTF-2 Mk4 seems like my best bet, is this the case? And have you all enjoyed this sub for music reproduction?
How large is your room? Where do you sit in your room? Do post a detailed sketch including the kitchen. Sounds like a VTF-3 MK5 HP with both ports open, EQ2 Q 0.3 should be more like what you need. Will give placement recommendations after seeing your room details.
dr_hsu is online now
post #6522 of 6522 Unread Today, 01:21 PM
NismoZ's Avatar
Thanks for the reply! I don't sit in a stationary position in this room for listening. I am usually all over the house (open floor plan). When I am in the room, I am either in the actual family room part or the kitchen. The Family room is connected to the kitchen without any openings, it's one large rectangle. I'd say about 35 long x 18 wide x 9 high, with openings to other rooms. The sub is about 3 ft away from a corner and about .8 ft from the wall (one of the 18ft walls). I have found that this position sounds great with the JBL sub I have.
I am not sure I want to get up into the VTF-3 price point. And, I am not sure I need something with much more output than the JBL sub I already have listed. I just want something with the same or above output, and to be good at music production, listening to the music I listed above.
I'd also like to hear from others in this thread who have the VTF-2 Mk4, how they like this sub with music reproduction.
Hsu Research , Hsu Vtf3 Mk4 , Hsu Vtf2 Mk4 , Hsu Research Hb1 Mk2 , Hsu Research Vtf 2mk3 , Hsu Research Hc 1 Mk2 , Hsu Vtf 15h Subwoofer , Hsu Research Uls 15 Subwoofer , Hsu Research Stf 1 Subwoofer 150 Watt
