***Official HSU owners/support thread!*** - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 384Likes
Old 12-20-2007, 10:44 PM
bori's Avatar
Quoted: 187 Post(s)
Liked: 125
Originally Posted by Kevin12586 View Post
Maybe someone else can better explain it than me, but unless I am mistaken even with dual subs, you still want your subs signal to be 75bd or else it will overpower the rest of your speakers.
Peter, is this true?
Yes, I understand what you are saying but, should I be worried about damaging anything. I calibrated each one seperatly to 75dbs so I am not running them hot.
bori is offline
Old 12-21-2007, 12:17 PM
Pete_Hsu's Avatar
Peter, can you take a look at my attached FR, can you think of why I have such a dip after 80Hz?
My crossover is set at 80Hz on my receiver.
Kevin, do you mind posting a rough sketch of your room, including current speaker/sub positions?
Pete - Hsu Research
Pete_Hsu is offline
Old 12-21-2007, 12:19 PM
Pete_Hsu's Avatar
bori, when you say damaging something, may i ask in what context?
I agree that it is not necessary to run the subs hot when using two vs one subwoofer. The advantage of two subwoofers would be in effectively cutting distortion in half for a given listening level, and in significantly boosting headroom and maximum output capability.
Pete - Hsu Research
Pete_Hsu is offline
Old 12-21-2007, 02:22 PM
bori's Avatar
Quoted: 187 Post(s)
Liked: 125
Do I need to worry about damaging the subwoofers? If I calibrated each one separetly to 75dbs would there be a problem?
bori is offline
Old 12-21-2007, 03:46 PM
Pete_Hsu's Avatar
The two subwoofers should be calibrated together. If you calibrate them separately, then your LFE will be +6db hot! Some people do like to run it a bit hot (+2 or +3db). That's ok to do as long as one notices no offensive noises.
Sincerely,
Pete - Hsu Research
Pete_Hsu is offline
Old 12-21-2007, 10:38 PM
bori's Avatar
Quoted: 187 Post(s)
Liked: 125
Sincerely,
Thanks Pete!
bori is offline
Old 12-22-2007, 04:41 AM
audio-newbie's Avatar
I recently purchased STF-2, and I have a question on placement. Please be patient w/ me as I am a newbie.
currently, I have my sub placed in a corner of HT room but away from listening position but on the side of the TV and receiver. how close should the sub to the wall? right now, it is only 6" away from (basically very close) or should it be maybe 12" away? especially on the ported side, should it have a "breathing" room or closer to the wall the better?
Also, what if i position the sub away from the corner but next to the TV. again, how far from the wall?
The question maybe ridiculous, but again I am a complete newbie.
Appreciate the inputs. thanks.
audio-newbie is offline
Old 12-24-2007, 02:37 PM
Pete_Hsu's Avatar
Hi audio_newbie!
6" of spacing is just fine between the port and the back wall. Corner placement is just fine.
Would it be possible for you to post a sketch of your room here?
Sincerely,
Pete - Hsu Research
Pete_Hsu is offline
Old 12-24-2007, 03:41 PM
Kevin12586's Avatar
Pete, did you miss my question above?
Kevin12586 is offline
Old 12-24-2007, 05:01 PM
darkninja67's Avatar
are there any Hsu owners pairing the sub with Monitor Audio speakers and if so how is the synergy? Thanks in advance
darkninja67 is offline
Old 12-25-2007, 05:33 PM
ezkcdude's Avatar
Can someone explain the sonic differences b/w the STF-2 and the VTF-1? I had a Dayton Titanic 10", but it's not working now (one too many turn-on thumps from my DAC). So, I'm looking for a new sub, and these two Hsu subs seem to be closest to what the Dayton could produce. My room is a medium-sized bedroom (~12' x 15' x 10').
ezkcdude is offline
Old 12-25-2007, 07:15 PM
ezkcdude's Avatar
Well, I ordered the VTF-1. I hope it works out.
ezkcdude is offline
Old 12-25-2007, 07:46 PM
vardo's Avatar
Quoted: 41 Post(s)
Liked: 130
ezkcdude, I think you made the right choise w/the VTF-1.
The VTF-1 is very similar to the original box sub from HSU,
the VTF-2. Same spec's, except the VTF-2 had a 150w amp,
and the present VTF-1 has a 200w amp.
I've owned two VTF-2's (would of bought a VTF-3, but it was
unavailable back then). I've also have two Dayton 10" Titanic
MKIII subs, which I use in a second (smaller) home theater.
They are good sub(s), but the VTF-1 will dig down to 25HZ
(max extention) and 32HZ (max output).
The Dayton Titanic subs are great for the money. But the 10"
will go down to 30HZ and that's about it. Pretty musical though.
If the amp in your Dayton 10" sub is bad you can replace it
from ordering it from Parts Express for about $100 w/ $50 off
of shipping......link:
http://www.partsexpress.com/pe/pshow...number=300-804
or if it's the driver:
http://www.partsexpress.com/pe/pshow...number=295-414
But I think you made the right decision with ordering the VTF-1,
good luck...vardo
vardo is offline
Old 12-25-2007, 07:52 PM
ezkcdude's Avatar
Thanks! I don't really have time to diagnose and treat my Dayton amp, so that's why I'm going for a new one. Also, I think they changed the amp on it since I bought mine, over a year ago. From what I read about the VTF-1, mostly comments similar to yours, I think I did the right thing. This sub will be paired my bookshelf speakers, and solely used for music - not home theater. I will probably tune it for maximum extension, not output, and 25 Hz seems pretty good. I also like the look of the maple veneer.
ezkcdude is offline
Old 12-26-2007, 12:14 PM
Pete_Hsu's Avatar
Kevin, I posted a response in post #633. I was trying to get a better sense of room dimensions and placement position.
Pete - Hsu Research
Pete_Hsu is offline
Old 12-27-2007, 11:24 AM
Kevin12586's Avatar
Sorry, I missed that. I'll post a sketch in a little while
Old 12-27-2007, 11:27 PM
bori's Avatar
Quoted: 187 Post(s)
Liked: 125
Just wanted to let you know that I calibrated both of my 3.3 subs the way you instructed and now they sound great. Thanks for your patience and help.
bori is offline
Old 12-28-2007, 03:22 PM
Kevin12586's Avatar
Glad everything worked out
Old 12-29-2007, 10:56 PM
Shift's Avatar
Quoted: 94 Post(s)
Liked: 65
Originally Posted by Pharcyde23 View Post
Finally pulled the trigger on a VTF 2.3, after much comparison between SVS, eD, and Def Tech I decided that this was the one for me.
I'm looking for any settings/setup suggestions before this thing arrives. The rest of my 5.1 system is Def Tech with bipolar towers in the front w/built in 8" subs, powered by an Onkyo 805. The HSU will be replacing a Mirage Omni S8 which currently sits behind the couch. My x-over settings right now are 60hz for the fronts and 80hz for the sub, will I need to change these up with the HSU? Also what about the sub placement, any specific recommendations? The room is 15x15x7. Thanks guys!
Congrats being a owner of a HSU! So what was it that pulled you towards an HSU sub over an eD sub?
The reason why I ask and if anyone else here would opt your opinion please do so.
-But I am looking at either the HSU's VTF-2 MK 3 Subwoofer or the eD A2 - 300 Subwoofer.
Which between these two would be the better beast in the theater room?
Preponderance
1: a superiority in weight, power, importance, or strength
2a : a superiority or excess in number or quantity
2b : majority
Shift is offline
Old 12-30-2007, 08:24 AM
Pharcyde23's Avatar
Thank you. I've had this beast for about 3 weeks now and couldnt be happier. It goes plenty deep and plenty loud for my room. I havent taken this thing above -3db on the receiver and above 30% gain on the sub.
I went with the VTF over eD simply because of the wait time. I'm in AZ and had the VTF arrive just 2 days after I ordered it. I've never heard an eD HT sub but from everything I've read they are very similar in performance. Some people say the eD might go lower but to me the difference between 17hz and 18hz wasnt worth the 6 week wait.
Pharcyde23 is offline
Old 12-30-2007, 09:33 AM
nixul's Avatar
Anyone can enlighten me the difference between them? I am using it for movie.
Front: 2xKlipsch RF 7 II Center: Klipsch RC 64 II Surround: 2xKlipsch RS 62II Sub: SVS PB2000
Receiver: Yamaha CX-A5100 Amplifier: NAD M25 7-Channel 160W
Video Player: Sony BDPS3500
nixul is offline
Old 12-31-2007, 12:23 AM
HDMom's Avatar
Just want to say I'm absolutely blown away by the VTF-2 MK-3 I picked up on Friday. I haven't had time to properly calibrate my system yet but will definitely get to it over the coming days. Unfortunately my lack of technical knowledge doesn't allow me to make any helpful comments other than to say that I love what I hear! This is my first sub and to say that I'm blown away is an understatement. The only drawback is that I live in a smallish apartment and I don't think my neighbor would appreciate her china getting rattled around when my boys play Halo - looks like we'll be moving sooner than I thought.
HDMom is offline
Old 12-31-2007, 12:29 AM
Jakeman02's Avatar
Originally Posted by nixul View Post
old VTF-2 vs the MK3
Quote from the HSU website
"The new VTF-2 MK3 is basically a slightly less powerful version of the VTF-3 Mk 2, and just like the VTF-3, with 250W, a 12 inch woofer, and maximum extension down to 18 Hz. It gives you unprecedented value for your money - VTF-3 performance for a VTF-2 price!"
Jakeman02 is offline
Old 12-31-2007, 07:46 AM
Shift's Avatar
Quoted: 94 Post(s)
Liked: 65
Pete,
Do you have a picture that you can post of the VTF-2 MK3 or the STF-2 Driver it self? I would like to see it if you can share that. Thanks
Preponderance
2b : majority
Shift is offline
Old 12-31-2007, 08:08 AM
handyjr's Avatar
Happy New Year, members. I've been tracking this thread for awhile to ensure that most Hsu sub owners are happy, so your many positive comments have swayed me into buying one - my first new sub in over a decade! I bought the VTF-3 MK3 after helpful correspondence with Dr. Hsu on both the best model for my HT and placement considerations. It should arrive later this week, and I'll let you know how it sounds (and probably be asking for your help, too!).
Other subs considered: JBL Fathom; Martin Logan Depth; SVS, Velodyne
I'll post some links to some pics and a diagram of my HT later. Here's my rig:
Speakers: Meadowlark Audio Kestrel 2 (LCR), Owl (Surround), Swift (Surround Back)
Sub: DefTech Pro Cinema 100 sub (for a few more days!)
Receiver: Denon 3805
Projector: Sony VPL VW10HT
Screen: Draper (110")
Sources: Sony PS3, Dish ViP 622 HD PVR
handyjr is offline
Old 12-31-2007, 10:03 AM
mitchlewis's Avatar
Quoted: 32 Post(s)
We purchased a new VTF-3 MK-3 a few weeks ago and over all we're very happy with it. But we have never "calibrated" the unit although we did use the Denon Audessy auto setup microphone built-in to our new Denon AVR-3808CI receiver. We also cannot move the sub around to find the ideal position due to space constraints. I did check the levels of all the speakers including the sub with pink noise and a Radio Shack SPL meter.
With all that in mind, we do have one "problem". It seems like the sub is MUCH louder on some material than others. For example, we watched Planet Earth and the first disc (Pole to Pole) the bass sounded a little weak. But on the third disc (Rivers) during the salamander segment the bass is HUGE, so much so that we had to turn the sub channel level all the way down (-12db).
So here's my question....
Could we have some HUGE frequency spikes at certain frequencies and dips at other frequencies to make it seem like the sub is louder on some material. In other words, one movie might put out a rumble at 80Hz and another movie might put out a rumble at 140Hz. If our sub isn't calibrated (I really don't understand how I could calibrate it without some kind of multi-band EQ), then it might have a HUGE spike at 140Hz and a dip at 80Hz yielding a large difference between the two movies.
The temporary "solution" has been to use the Denon remote to raise/lower the sub channel volume. Or is that what everyone on this thread is doing as a "solution"?
mitchlewis is offline
Old 01-01-2008, 09:00 AM
handyjr's Avatar
Originally Posted by mitchlewis View Post
We purchased a new VTF-3 MK-3 ... But we have never "calibrated" the unit although we did use the Denon Audessy auto setup microphone built-in to our new Denon AVR-3808CI receiver ... I did check the levels of all the speakers including the sub with pink noise and a Radio Shack SPL meter.
With all that in mind, we do have one "problem". It seems like the sub is MUCH louder on some material than others ...
Mitch: My first thought is that the work you did with your Denon Audessy and RadioShack SPL meter qualifies as calibration - its at least as much as 90% of people do. So pat yourself on the back for that!
I suspect that you are on the right track with your ideas about the source of your problem - it's probably related to room conditions and the normal peaks and valleys in low frequency sound waves. At certain frequencies, you're sitting in a "peak" at your listening position, while at other frequencies you're sitting in a valley (null). One easy test for this is to change your location while listening to the same source material. If you hear an appreciable difference in bass output, then you know it's a room response/location issue.
My understanding of the Denon auto-calibration software (and most others) is that they can reduce peaks, but they can't fill in valleys (nulls). I think your solutions will involve moving the location of your sub, or perhaps adding another one, to achieve a more uniform frequency response at your primary listening position.
Hopefully some of our more experienced members can offer more specific advice.
Cheers!
handyjr is offline
Old 01-01-2008, 03:32 PM
Major Nelson's Avatar
pulled the trigger yesterday on the 3.3. From all my research an everything I read hear on the site was a great help. Can't wait to get it in and setup now. I have to pick up my speakers this week as well...I'm either goinng with the B&W 600 series for the 5 speakers or possibly the CM's for the L/R/C speaker. Any input on which ones would match up better with the HSU? I'm leaning towards the CM's.
Major Nelson is offline
Old 01-02-2008, 02:24 PM
bori's Avatar
Quoted: 187 Post(s)
Liked: 125
Hello Kevin,
I see you have dual HSU with MBM-12. I just ordered the MBM-12 and would like to know how to intergrate this smoothly with my two 3.3 subs. I have each 3.3 on opposite corners in the front of the room. I plan to put the MBM-12 nearfield. What are the steps I need to go through to get everything working correctly?
bori is offline
Old 01-02-2008, 07:46 PM
Kevin12586's Avatar
Simple answer, do what you did to calibrate 2 subs, only it is now 3 subs you are calibrating. Set the MBM to handle 50-80Hz and the 3.3's to handle everything below 50Hz.
If you have a laptop, I recommend you download a program called Room Eq wizard from hometheathershack.com. This will help to see how all three of your subs are interacting with each other. One thing I have found from my own personal experience is the more subs you add the harder it is to calibrate the system, but the benefits are worth it once you have finished calibrating
Good luck
Hsu Research , Hsu Vtf3 Mk4 , Hsu Vtf2 Mk4 , Hsu Research Hb1 Mk2 , Hsu Research Vtf 2mk3 , Hsu Research Hc 1 Mk2 , Hsu Vtf 15h Subwoofer , Hsu Research Uls 15 Subwoofer , Hsu Research Stf 1 Subwoofer 150 Watt
