***Official HSU owners/support thread!*** - Page 221 - AVS | Home Theater Discussions And Reviews
 66Likes
post #6601 of 6628 Old 03-07-2015, 11:10 PM
shadyJ's Avatar
Quoted: 763 Post(s)
Liked: 818
If the size doesn't bother you, I would go for the VTF3 mk5. The ULS is a great sub, but it is more expensive and it does not offer as much output. It's for situations where there is a real WAF and you don't need extreme loudness levels.
galonzo likes this.
shadyJ is online now
post #6602 of 6628 Old 03-08-2015, 08:23 AM
Quoted: 44 Post(s)
Originally Posted by galonzo View Post
So here's a crude drawing of my current layout; of course, my only concern is the "theater area" in the upper-right (so approximately 11'x18'), but I know the full, open-area size will play a part. The dashed line is a beam, held up by the pillar (black square), and my rear surrounds are ceiling mounted directly in front of the door to the unfinished space. All windows have the blackout honeycomb type shades. Only the bottom few stairs are open to the staircase, so not totally walled off. 8.5' ceiling.
My sub placement options are numbered in order of preference, with my current sub at the #1 position. I believe I can squeeze the mk5hp in the same spot, or will the ULS-15 give me what I'm looking for (for now)? Like I said, I will most likely add in a second of whatever I go with in the future. Any insight would be greatly appreciated!
If you can put an mk5hp in spot by the couch you'd have chest thumping bass. It'd be unreal. Spots by the tv would still be excellent.
boosted330 is offline
post #6603 of 6628 Old 03-08-2015, 09:24 AM
WhskyTangoFoxtrt's Avatar
Quoted: 50 Post(s)
Liked: 49
Thanks, I was actually leaning toward the VTF-3 MK5 HP because of the smaller footprint and possible upgrade to a 2nd to eventually end up better than one VTF15.2 (from what I gather from reading here), until I saw the chart comparisons between the ULS-15 and VTF15.2; I'm upgrading from a Klipsch RW10-D (we'll typically watch a movie a few Db lower than reference level), and am basically just looking to get the full spectrum of ULF that I'm starting to notice I'm missing in some movies. I'll see if I can draw up a sketch of our layout to illustrate my placement options.
The ULS-15 will extend a little deeper and is pretty linear. You will need 2+ for large rooms.
A Nice Radio Station with Great Music. For Those That Like That Sort of Thing: RadioParadise.com
WhskyTangoFoxtrt is online now
post #6604 of 6628 Old 03-08-2015, 02:11 PM
bear123's Avatar
Quoted: 614 Post(s)
Liked: 1101
For music listening only, I think the ULS-15 would be nearly as good and about the same price, yet smaller. If you plan on watching movies and want solid output without compression, again, it would take FOUR ULS-15's to match the output of ONE VTF15.2 at 20Hz. I know what I would go with.
bear123 is offline
post #6605 of 6628 Old 03-08-2015, 04:31 PM
galonzo's Avatar
Quoted: 33 Post(s)
Thanks everyone, I'm going to try the VTF-3 MK5 HP for now; unfortunately, the VTF15.2 is just too beastly for this space, no matter the placement. I suspect I'll be blown away by the difference, even though I was able to get my rw10d dialed in to the "t" for this space. I'll be sure to post back my impressions
Onkyo TX-NR616 (7.1; HSU VTF-3 Mk 5, Klipsch R-3650-WIIs, RC-10, R-2650-Cs, Polk RC80is) || Sammy UN78HU9000FXZA || Panny DMP-BD60 || Sony PS3 || AppleTV
galonzo is offline
post #6606 of 6628 Old 03-08-2015, 08:42 PM
bears t2's Avatar
Quoted: 13 Post(s)
I just ordered a VTF-3 Mk5 HP last week and from what I can see, I'm gonna like it. I also was going to order the pb-2000 but after looking at everything I said, lets just get the best we can and I did. No looking back now. You made a good decision on it.
LG 55LW5600 / Roku3 / Logitech 520
Onkyo TX-NR818
Sony BDP-S570 Blu-Ray, Toshiba HD-D3KU HD-DVD
Bowers & Wilkins 683B (mains), HTM61 (center)
Polk F/XiA4 (Surrounds), Paradigm Titan v3 (Back Surrounds)
HSU VTF-3 MK5 HP
bears t2 is offline
post #6607 of 6628 Old 03-09-2015, 10:33 AM
Viche's Avatar
Quoted: 22 Post(s)
Liked: 31
Originally Posted by bear123 View Post
It's because the VTF15.2 will have more than double the output in the low bass region for movies. In fact, it would likely take four ULS-15's to match the 20 Hz output of one VTF-15.2
Newb question, how can the VTF15.2 output have so much more output at 20Hz, when the chart for it shows 89-93 dBSPL at 20 Hz and the ULS15 shows 90-94 sBSPL at the same frequency?
Viche is offline
post #6608 of 6628 Old 03-09-2015, 01:47 PM
shadyJ's Avatar
Quoted: 763 Post(s)
Liked: 818
The chart isn't showing maximum output sweeps, it is only showing the basic response. If you want to know how loud these subs get, you should be looking at the CEA 2010 measurements. At 20 Hz, the VTF15h mk2 has an almost 10 dB advantage over the ULS-15. This is slightly more than 3x as powerful.
post #6609 of 6628 Old 03-10-2015, 10:07 AM
Viche's Avatar
Quoted: 22 Post(s)
Liked: 31
Ahhh...I see that now. Thanks!
Viche is offline
post #6610 of 6628 Old 03-11-2015, 12:35 PM
bears t2's Avatar
Quoted: 13 Post(s)
Just got my HSU!! W O W it's HUGE!!! But I love it so far, although I've only had it a couple of hours. I set it up and played the demo disc they packed with it and the very 1st song I knew I had something special. Felt it through the couch LOL... I'm going to try to put it in front of the room and see how that goes.
ID:	597209   Click image for larger version
ID:	597217   Click image for larger version
Name:	Inside the Box.jpg
ID:	597225   Click image for larger version
Name:	After placement.jpg
Onkyo TX-NR818
HSU VTF-3 MK5 HP
bears t2 is offline
post #6611 of 6628 Old 03-11-2015, 02:58 PM
GJG
GJG's Avatar
Originally Posted by bears t2 View Post
Just got my HSU!! W O W it's HUGE!!!.
I got mine last months and was home when UPS arrived. The delivery guy brought it up my driveway on one shoulder. I almost had a heart attack! But he didn't drop it.
GJG is offline
post #6612 of 6628 Old 03-11-2015, 03:17 PM
ambesolman's Avatar
Quoted: 616 Post(s)
Liked: 545
Sent using Tapatalk since the mobile version is still
ambesolman is offline
post #6613 of 6628 Old 03-17-2015, 01:40 PM
sinisanav's Avatar
Quoted: 13 Post(s)
Hello HSU owners, as I am close to finishing my small HT ( 1500 cubic ft space) I have a a subwoofer dilemma. If you check my setup( link in the signature below),you will see I have no separate subs except for built in Supercube1's in the Def Tech BP7001 towers. I have just installed back wall bass trap and some other acoustical panels which have helped overall sound tremendously ( best used 300$ ever for HT), I am generally happy with amount of mid bass I get , would like some extension in to 10-20 Hz region. Space is at premium, have room for sub that is not higher then 22" and not deeper then 23 in front of the screen and then space for 19" wide and 24 deep in the back, just by the riser. You can see my space in the signature link.
What would be your suggestion? I am comparing options with HSU, SVS, Rhythmic, PSA or vintage Def Techs.
Change is the only constant.
My HT: http://www.avsforum.com/forum/19-ded...l#post32691273
sinisanav is offline
post #6614 of 6628 Old 03-17-2015, 04:47 PM
shadyJ's Avatar
Quoted: 763 Post(s)
Liked: 818
I would be looking at a couple of Hsu ULS-15s. They fit your dimensions and ultra deep bass is their forte. You can get more bass at 20 Hz out of a ported sub, but a sealed will give you output at 10 Hz, which no ported sub can do. What distinguishes the ULS from other sealed 15"s is its XBL^2 driver. It may not have more maximum headroom than other 15"s, but within its dynamic range it will play cleaner and with greater linearity, so for loudness levels below its xmax it will play with lower distortion and totally neutral response.
sinisanav likes this.
post #6615 of 6628 Old 03-18-2015, 10:02 AM
ChromeJob's Avatar
Quoted: 67 Post(s)
Just bought a VTF-2 Mk 4. A little worried about the reports of amps going bad in a few years, but still very jazzed by the flexibility and performance. Seeing 25Hz, 20Hz and 16Hz actually working in my home is thrilling.
Does anyone know if there's a post or discussion in this thread about what to listen for in the Hsu/BAS test CD musical selections? First track, the Saint-Saens Organ Symphony excerpt, no brainer, but for the second...? TIA.
Addendum: Track 1, engineer (or someone) mentions a clean 16Hz subharmonic from the organ. Various subharmonic tones heard in this track. Track 2, low E-flat from the organ at the finale. Track 5, notes mention you may hear the door open and close as trumpeters rejoin. But ... subwoofer indications? Tracks 3, 4, I don't see any suggestion of what to listen for from the subwoofer.
Modest "theater": Samsung UN40ES6150, Panasonic BDT210, Yamaha RXV775. Bose 401 mains, 301 Series III surrounds, Yamaha NS-C444 center, Hsu VTF-2 Mk4.
ChromeJob is offline
post #6616 of 6628 Old 03-18-2015, 10:11 AM
ambesolman's Avatar
Quoted: 616 Post(s)
Liked: 545
My cd came with a piece of paper that had a little writeup on each track.
post #6617 of 6628 Old 03-18-2015, 11:10 AM
Quoted: 12 Post(s)
Liked: 3
Yeah paper slip that came in the cover with the CD. But here ya go.
http://imgur.com/LZzE44p
http://imgur.com/VtczYLn
bigsweezey is offline
post #6618 of 6628 Old 03-18-2015, 12:00 PM
ChromeJob's Avatar
Quoted: 67 Post(s)
Thanks, guys. I do have the slip, my apologies for being unclear. I see suggestions for Track 1 and 2 for what to listen for from the subwoofer.[1] I was curious about the others (3 - 5). I've used the test tones to set volume trim and crossover, actually track 22 (sweep from 200Hz to 80Hz) has identified a little problem around 120-130HZ in my mains, so I've boosted my crossover up a bit to use the VTF-2's range. So far,... splendid improvement.
I'm trying to find my copy of the Delos Engineer's Choice CD, which didn't so much have hi-fi demo tracks, but examples of recording techniques and venues. Some really great, naturalistic recordings. It's in a box somewhere. Derp.
[1] 1: Organ produces subharmonic tones, down to 16Hz. 2: Low E-flat form the organ at the finale.
post #6619 of 6628 Old 03-18-2015, 04:09 PM
jbwiljr's Avatar
So I have had my VTF-2 MK4 for a few weeks and was starting to get slightly concerned. I had a buzz at certain frequencies but couldn't pin it down. I got a Subdude HT and that helped clean things up on my tile floor, but that buzz still came up every once in a while. I finally nailed it down "literally". The old Victrola next to my subwoofer has 3 rear panels that resonate perfectly at somewhere between 60 - 80 HZ. I inserted a few nails along the edge of the offending panels and the buzz is gone. Holy cow this Hsu ROCKS!!!
jbwiljr is offline
post #6620 of 6628 Old 03-24-2015, 10:23 PM
taoggniklat's Avatar
Hey there...
So I have had the VTF2-Mk2 for a few years now and it sounds (feels) great in my room. Of course I would love to splurge and get the latest and greatest upgrade but money is tight. I found someone selling the same VTF2-MK2 for $350 locally, wondering if I should grab it and have duals...or save my pennies for VTF15's down the road.
taoggniklat is offline
post #6621 of 6628 Old 03-24-2015, 11:48 PM
shadyJ's Avatar
Quoted: 763 Post(s)
Liked: 818
Originally Posted by taoggniklat View Post
Hey there...
The VTF15h subs will have a LOT more output, and they will dig deeper too. I would go for the VTF15h or the VTF3 mk5. Also, I think 350 is a bit high for an older sub like that. It doesn't strike me as a great deal, I would pass on that.
post #6622 of 6628 Old 03-25-2015, 12:10 AM
ChromeJob's Avatar
Quoted: 67 Post(s)
Maybe you could talk that party down... Dual subs are a oft-recommended configuration.... How old is your VTF-2 Mk 2?
post #6623 of 6628 Old 03-25-2015, 09:23 AM
HsuKevin's Avatar
Quoted: 29 Post(s)
Liked: 53
Also bear in mind that the VTF-2 Mk2 is closer in performance to our VTF-1 Mk2.
ChromeJob likes this.
Kevin W.
Hsu Research
Sales and Marketing Representative
HsuKevin is offline
post #6624 of 6628 Unread Yesterday, 09:31 PM
DaveyMac's Avatar
Quoted: 117 Post(s)
Scratching Noise
One of my new VTF3 MK5 subs does something odd...
When I adjust the volume gain knob, there is a scratchy/feedback noise. It's major enough I can stomp my foot and it does it. It sounds lie a needle being dragged on a record sort of, tat type of sound.
There's no way the sub got broke somehow, I've never played it anywhere close to its max.
I fear it's probably doing this all the time, although I don't hear it while music is playing.
Should I be worried? Only one is doing it. I noticed when level adjusting with Audyssey multi sub eq.
DaveyMac is online now
post #6625 of 6628 Unread Today, 05:56 AM
gadgtfreek's Avatar
Quoted: 254 Post(s)
Liked: 394
I've seen that on other stuff, get with HSU and get a new amp sent to you.
65" VT50 / Oppo 103D
Denon 4520CI / Emotiva XPA-3
Klipsch RF82 II and RC62 II / Hsu VTF-15H (2)
gadgtfreek is online now
post #6626 of 6628 Unread Today, 06:03 AM
shadyJ's Avatar
Quoted: 763 Post(s)
Liked: 818
I would give Hsu a call about that. Sound like some crud may have gotten into the potentiometer knob. It may be a simple fix you can do at home, maybe, like removing the knob and cleaning it out with alcohol, but you really need to get in touch with Hsu before you take anything apart.
post #6627 of 6628 Unread Today, 06:04 AM
DaveyMac's Avatar
Quoted: 117 Post(s)
Wow that really sucks. I have no clue how to take it apart and do that type of stuff.
I messed with it more last night and it seems to only do it when I am moving gain knob. While Audyssey is sending the sub tone to level match subs (shows db's of sub on TV in rea time), that's when it occurs. If I tap on the knob even, it's like tapping needle on a record player. I'm really hoping they will just give me an idea to fix it.
Should I worry about it, if I don't hear it while listening to a media source?
post #6628 of 6628 Unread Today, 06:08 AM
gadgtfreek's Avatar
Quoted: 254 Post(s)
Liked: 394
The issue is, sub is new and it may get worse. I'd get it fixed under warranty.
I've had to do things like this, even replacing a speaker in a def tech bookshelf. They can tell you exactly how to do it and help you with it. It's easier than sending the sub back Id imagine!
Hsu Research , Hsu Vtf3 Mk4 , Hsu Vtf2 Mk4 , Hsu Research Hb1 Mk2 , Hsu Research Vtf 2mk3 , Hsu Research Hc 1 Mk2 , Hsu Vtf 15h Subwoofer , Hsu Research Uls 15 Subwoofer , Hsu Research Stf 1 Subwoofer 150 Watt
