***Official HSU owners/support thread!*** - Page 249 - AVS Forum | Home Theater Discussions And Reviews
 499Likes
post #7441 of 7461 Old 04-12-2017, 11:49 AM
veger69's Avatar
Quoted: 54 Post(s)
Originally Posted by deano86 View Post
It's spelled out in the user manual...typically max extension mode... one port plugged, EQ1, etc...
Thanks deano86 and TomC
veger69 is offline
post #7442 of 7461 Old 04-12-2017, 12:05 PM
Tom C's Avatar
Quoted: 74 Post(s)
Liked: 76
Originally Posted by Pogre View Post
The (almost) finished new configuration. I say almost because after carefully pulling the logos off using a hot hair dryer some glue residue remains. I called Hsu and ended up geting Kevin! He sent my question up the ladder to Dr Hsu himself and he didn't have much outside of coloring over the glue with paint or something... I was considering a solvent but I don't wanna mess up the fabric. The logos are still basically perfect, I was thinking about putting them back on in the correct orientation on the new "bottom".
I really, really like how they look now and as an added bonus it even improved my bass response! It's improved in my seating area and throughout the whole room, even into the kitchen and side room. It sounds great now (not that it didn't before). Audyssey trimmed it back a couple more db's than where it was previously after I calibrated again.
Even though we didn't really find the solution, Kevin was awesome. He called me back a little later in the day with what he had. Thanks Kevin!
You might try a black marker, like a Sharpie, to color it.
Pogre likes this.
LG OLED55B6P (Calibrated by AVICAL)
Denon AVR-X4200W ** oppo UDP-203 **oppo BDP-103D
HR44 DirecTV ** Panamax 5300 ** Harmony One Universal Remote
Hsu HB-1 MK2 (L, R & S) ** Hsu HC-1 MK2 (C) ** Hsu VTF-15H (sub)
Crowson Technology Level 2 Motion System
Tom C is offline
post #7443 of 7461 Old 04-12-2017, 04:18 PM
TheCarFather's Avatar
Quoted: 50 Post(s)
Liked: 56
That is very interesting, I'm really surprised laying them on their side made a difference in sound quality. I wish I had the room to try it, but unfortunately I don't think I do. Care to go into more detail on how the bass changed?
Receiver: Denon X1200W
Mains: Pioneer FS52
Center: Pioneer C22
Surround: Pioneer BS22
Rears: Polk T15
Sub: (2) HSU VTF-3 MK5 HP
TheCarFather is offline
post #7444 of 7461 Old 04-12-2017, 04:27 PM
Pogre's Avatar
Quoted: 38 Post(s)
Liked: 40
It's not night and day. I also put a lot of time into trying different configurations (both ports on the outside, both ports on the inside, one inside and one on the outside, etc.) It very well could be just from changing the positions, and I think it is, because they're not oriented the same way at all.
I have a little bit more headroom (Audyssey trimmed them back 2 more db from where they were) and it just seems smoother. Placebo because I'm all jazzed about how they look? Maybe. But room correction did trim them back some more so...
Sub placement can be funny. Sometimes just moving one 6" or a foot either way can make a big difference. They've definitely been moved from the original layout. Both in distance apart and in height.
Pogre is offline
post #7445 of 7461 Old 04-12-2017, 06:05 PM
Pogre's Avatar
Quoted: 38 Post(s)
Liked: 40
Originally Posted by HsuKevin View Post
Thanks for calling in! It was a pleasure speaking with you. Glad to hear that placing them on their side improved the bass. I'll keep looking into options for removing that glue. Sorry we weren't able to come up with a solution for removing it.
I've come up with a solution that I'm satisfied with for now. My wife found an old black shirt that she doesn't wear any more. The cloth used to make it has a similar pattern as the cloth on the grille. Even better when I stretched the strips of fabric a little, strips I cut by laying a chunk of the shirt so it was lined up with the grain of the fabric of the grilles.
I took a few pics to document my progress.
ID:	2081817   Click image for larger version
ID:	2081825   Click image for larger version
ID:	2081833   Click image for larger version
ID:	2081841   Click image for larger version
ambesolman and HsuKevin like this.
Pogre is offline
post #7446 of 7461 Old 04-12-2017, 06:38 PM
Pogre's Avatar
Quoted: 38 Post(s)
Liked: 40
I made the strips a little big, so when the glue dries I can trim some off if necessary. Just used plain old elmer's glue and only applied a little bit to the residue that was left on the speaker. I tried coloring the residue in with a sharpie. It's in one of the pics. As you can see it was a no go. The last one is from where I sit. Pretty much invisible with the blinds closed on the sliding glass door to the left of the left speaker. Not perfect though. When the blinds are open you can see the patch on the one on the left. *twitch*
When it dries I'll trim off any excess cloth and see if I can do something to make it blend better. I'm decently happy with it and there was no permanent damage done and I didn't spill any glue. It's better than the glue, for sure.
Here's the culprit responsible for the hair in the one pic... Misty. She's my baby. Follows me everywhere.
Tom C and HsuKevin like this.
Pogre is offline
post #7447 of 7461 Old 04-14-2017, 09:21 AM
HsuKevin's Avatar
Quoted: 94 Post(s)
Liked: 152
Awesome! Looks great.
One more week till AXPONA. If you're planning on going, feel free to bring in an audio track that you would like to listen to.
I had a chance to pick up Arrival 4k. Excellent soundtrack and mixing. Any other movies you folks are enjoying?
Kevin W.
Hsu Research
Sales and Marketing Representative
HsuKevin is offline
post #7448 of 7461 Old 04-14-2017, 09:44 AM
Pogre's Avatar
Quoted: 38 Post(s)
Liked: 40
I haven't had an opportunity to check it out in 4k yet, but did watch the blu ray. Great movie.
Hey, check it out...
ID:	2083825   Click image for larger version
ID:	2083833   Click image for larger version
Tom C likes this.
Pogre is offline
post #7449 of 7461 Old 04-14-2017, 10:42 AM
gwsat's Avatar
Quoted: 2705 Post(s)
Liked: 2994
I thought the Arrival UHD HDR DTS-HD MA 7.1 disk looked and sounded wonderful. Some have complained that the images were excessively dark. I didn't think so but that's a discussion for another thread.
I almost didn't buy the disk because it didn't have a TrueHD Atmos soundtrack but ended up happy that I did buy it. The audiotrack has a lot of wonderful surround effects and the LFE is demonstration quality.
HT setup: Sony 75XBR X940D UHD HDR TV; Kaleidescape Strato Movie Server 6 TB; Yamaha RX-A3060 AV receiver; Crestron Control System; Hsu VTF-3 MK3 Turbo subwoofer, 6 Hsu HB-1 Bookshelf speakers, 1 Hsu HC-1 Center speaker, 4 Focal ICW8 in-ceiling Atmos speakers; Oppo UDP-203 4K HDR BD player; Mac Mini HTPC. TiVO Bolt 1TB DVR; TiVo Premiere Elite 2 TB DVR
gwsat is online now
post #7450 of 7461 Old 04-14-2017, 10:52 AM
sdrucker's Avatar
Quoted: 750 Post(s)
Liked: 507
Count on it. Will you have a 4K player at the show?
Audio Gear: Trinnov Altitude 16/24, NAD M27 and Wyred4Sound MMC-7 amps
Display: Panasonic VT50, Lumagen Radiance Mini. Misc.: Oppo 103, Samsung K8500 UHD player, JRiver
Speakers: PSB Imagine T3 L/R, Center, Imagine T Wides and Rears, T2 Side Surrounds,
PSB Imagine XA Dolby AE Speakers (4), HSU ULS-15 Mk 2 subs (4) - 9.4.4
sdrucker is online now
post #7451 of 7461 Old 04-14-2017, 11:27 AM
HsuKevin's Avatar
Quoted: 94 Post(s)
Liked: 152
Yea, I hear ya. I wasn't too bothered by the darker, more muted tones. In many cases that could actually help in adding to the feel/tone of the movie. I know Zack Snyder is probably the most heavily criticized for the use of muted tones, but as you stated, that discussion is for another thread.
That would be nice! Unfortunately, we haven't quite made the jump to that yet. I only have a 4k setup in my home.
Kevin W.
Hsu Research
HsuKevin is offline
post #7452 of 7461 Old 04-15-2017, 01:17 PM
as in "O.G." Alonzo
galonzo's Avatar
Quoted: 660 Post(s)
Liked: 718
.... Any other movies you folks are enjoying?
The wormhole scene from Interstellar is still my go-to demo scene currently
UN78HU9000FXZA(TS01)/SEK-3500U || UDP-203 (fw: 42-0329)
Denon AVR-X4200W || Atmos/DTS:X 5.1.4:
Fronts = Klipsch R-3650-WII (x2), Surrounds = Klipsch G12 (x2)
Center = Klipsch RP-160M, Sub = HSU VTF-3 Mk 5,
TFs = Klipsch R-2650-C (x2), TRs = Polk RC80i (x2)
UN65JS9500FXZA (TS01) || UBD-K8500 || Chromecast Ultra
Last edited by galonzo; 04-21-2017 at 06:12 PM. Reason: added clarification for timing reference
galonzo is online now
post #7453 of 7461 Old 04-15-2017, 08:16 PM
HsuKevin's Avatar
Quoted: 94 Post(s)
Liked: 152
Yea that's a great scene. A lot of low 20 Hz bass. We used that quite a bit on our demos at various shows.
galonzo and yippiechicken like this.
Kevin W.
Hsu Research
HsuKevin is offline
post #7454 of 7461 Old 04-15-2017, 08:28 PM
Pogre's Avatar
Quoted: 38 Post(s)
Liked: 40
I just bought a Blu Ray copy of Interstellar on ebay for 6 bucks. I liked it and I keep hearing about that wormhole scene. I gotta watch it again and 6 bucks was hard to pass up.
yippiechicken likes this.
Pogre is offline
post #7455 of 7461 Old 04-15-2017, 08:44 PM
yippiechicken's Avatar
Quoted: 12 Post(s)
Originally Posted by galonzo View Post
The wormhole scene from Interstellar is my go-to demo scene
That scene actually gets pretty uncomfortable if I crank it up loud enough. My set up is in the basement and it'll easily rattle stuff up on the main and 2nd floors. It's awesome!
galonzo, Pogre and HsuKevin like this.
yippiechicken is offline
post #7456 of 7461 Old 04-15-2017, 08:48 PM
HsuKevin's Avatar
Quoted: 94 Post(s)
Liked: 152
I know what you mean. Listening to that on and off for several hours started giving me a headache
Kevin W.
Hsu Research
HsuKevin is offline
post #7457 of 7461 Old 04-19-2017, 09:41 AM
HsuKevin's Avatar
Quoted: 94 Post(s)
Liked: 152
Had a few inquiries about show pricing. For AXPONA attenders, we will have special pricing for some of our subs.
sdrucker likes this.
Kevin W.
Hsu Research
HsuKevin is offline
post #7458 of 7461 Old Yesterday, 04:09 PM
Luisfc1972's Avatar
Quoted: 188 Post(s)
for a room thats approx 12 x 18 or so is the vtf2 mk5 overkill?
im upgrading from a bic america f12
Luisfc1972 is offline
post #7459 of 7461 Old Yesterday, 05:19 PM
deano86's Avatar
Quoted: 249 Post(s)
Liked: 129
No... when it comes to subwoofers.... there is no such thing as overkill!!
deano86 is online now
post #7460 of 7461 Old Yesterday, 07:40 PM
Luisfc1972's Avatar
Quoted: 188 Post(s)
was just about to order and at the last page there is an option for optional coupon/promotional code.
are there any? would like to order tonight.
post #7461 of 7461 Old Today, 09:20 AM
ChromeJob's Avatar
Quoted: 909 Post(s)
Liked: 416
Send a message via Yahoo to ChromeJob Send a message via Skype™ to ChromeJob
Nope. It should fill your room without straining. Do all the usual, subwoofer crawl, setup as prescribed, test with the disc they send you.
“Phil? Phil Connors?!”
Are ya new here? Please read FAQs and forum stickies. Like posts that help you. Don't ask a question and then disappear.
A: Yamaha RX-V775. Bose 401 mains, 301 Series III surrounds, Yamaha NS-C444 center, Hsu VTF-2 Mk4.
V: Samsung UN40ES6150, Panasonic DMP-BDT215, Yamaha DVD-S550. Apple TV 4gen. Chromecast 1gen.
ChromeJob is online now
Hsu Research , Hsu Vtf3 Mk4 , Hsu Vtf2 Mk4 , Hsu Research Hb1 Mk2 , Hsu Research Vtf 2mk3 , Hsu Research Hc 1 Mk2 , Hsu Vtf 15h Subwoofer , Hsu Research Uls 15 Subwoofer , Hsu Research Stf 1 Subwoofer 150 Watt
