***Official HSU owners/support thread!*** - Page 54 - AVS Forum | Home Theater Discussions And Reviews
 585Likes
post #1591 of 7624 Old 07-31-2008, 01:40 PM
bsoko2's Avatar
Quoted: 75 Post(s)
Liked: 79
Originally Posted by cacihome View Post
THe MBM gain is too high...
Yeah you can try that.. Overall If you have the MBM nearfield and the 3.3 farfield you should(or I should say can) have the 3.3 at lets say 9:30 and the MBM at say 8:30...
The idea is that since you will be setting the VTF from 50 or 45hz-down (whatever) you wont be able to localize it as easily as the MBM which is closer to you, so it makes sense not to raise the MBM gain too high(and because the gain on the mbm is very sensitive too)
Start at 0db on your receiver... sub at 9:00 o clock.With the MBM with a very little less gain(8:30).
Let me know if you liked it...It is that what really matters...JEJEJ
AFter you do this play a movie that put the VTF3 MK3 to work... say WOTW.CHeck if your sub pops at your desired volume level(preferably play it a bit louder that you would normally) . If it does then on the receiver only back off say 5 dbs...else you are set for now...
He really needs to get a spl meter and set his subs up properly. Using the pink tones for this setup on the reciever is a good place to start.
Bill
bsoko2 is offline
post #1592 of 7624 Old 07-31-2008, 01:52 PM
cacihome's Avatar
Quoted: 37 Post(s)
Yeah, but he doesnt have one. These subs sound very good even when they are not entirely calibrated though.
But yeah if you can buy one King go for it...
Cacimar Hernandez
cacihome is offline
post #1593 of 7624 Old 07-31-2008, 04:22 PM
King_David's Avatar
Thanks a lot. I follwed your advice. I set the VTF-3.3's gain at slightly below 9 Oclock, and the MBM at 8:30. I even reset the gain in the reciever to 0db. I put on WOTW, and ZERO pop. I even raised the volume on the reciever higher, and the same result...NO POP. The bass is tighter, the LFE rocks the room, and there is no more boominess. Thanks buddy.
King_David is offline
post #1594 of 7624 Old 08-01-2008, 12:04 AM
King_David's Avatar
UPDATE: I actually had to raise the gain again because the LFE was not strong enough. i raised the VTF-3.3 to 9:00, and the MBM to 9:00 as well.
post #1595 of 7624 Old 08-01-2008, 05:31 AM
Kevin12586's Avatar
As someone else mentioned, you need to get an SPL meter. Right now you are just guessing, it may sound good right now, but after a proper calibration it can sound great.
You spent the money for the new receiver, 3.3 and MBM, so why not use their full potential by spending an extra $30-$50 and get an SPL and fully calibrate?
Good luck and enjoy
Kevin12586 is offline
post #1596 of 7624 Old 08-01-2008, 07:00 AM
cacihome's Avatar
Quoted: 37 Post(s)
Good to hear that man...!!!
Yeah, I said 9:30 on the 3.3 and 8:30 for the MBM...
One more thing... What is your room size and how far you are from the MBM, and 3.3?
Just my opinion here:
I really think that for normal people, and for HT use, the SPL meter tool is not a definitive requirement.At the end I just trust my ears! The system can actually sound very good without it. You just have to experiment and spend more time on trial and error....jeje For music the calibration gets more important.
Cacimar Hernandez
cacihome is offline
post #1597 of 7624 Old 08-01-2008, 07:05 AM
cschang's Avatar
Quoted: 134 Post(s)
Liked: 171
And to add to Kevin's post.....most people that try and calibrate by ear set the subwoofer level much higher than it should be, which is probably the reason you are bottoming the sub.
-curtis
Owner of Wavecrest Audio
Volunteer Mod at the Ascend Acoustics Forum
Like all things on the Internet, do your research, as forums have a good amount of misinformation.
Help beat breast cancer!
cschang is offline
post #1598 of 7624 Old 08-01-2008, 07:10 AM
cacihome's Avatar
Quoted: 37 Post(s)
THat is why I am saying the sub dial setting...On 0db on his receiver with the dial specs I gave him, he wont bottom it unless he plays it near reference...
With WOTW and LFE hot movies...
The 3.3 starts to bottom at -10db on that receiver(Onkyo 705), 0db on LFE receiver gain, flat eq settings, 10:00 o clock on sub dial(more or less...)
Cacimar Hernandez
cacihome is offline
post #1599 of 7624 Old 08-01-2008, 09:18 AM
bsoko2's Avatar
Quoted: 75 Post(s)
Liked: 79
He needs to set his system by meter, then by ear. DrPainMD site (I posted for him ealier) can educate him on the ins and outs of setting up his system.
Bill
bsoko2 is offline
post #1600 of 7624 Old 08-01-2008, 09:45 AM
cacihome's Avatar
Quoted: 37 Post(s)
It would be easier that way, I agree at least on that.
Cmon Bill I am just trying to help save him a few $$$, but definately with the meter it will be better...
Cacimar Hernandez
cacihome is offline
post #1601 of 7624 Old 08-01-2008, 10:10 AM
Kevin12586's Avatar
So he can spend about $1600 for the sub, MBM and receiver but $30 is pushing it?
post #1602 of 7624 Old 08-01-2008, 10:30 AM
a3plew's Avatar
I dont know about the other guy but I cant afford a spl meter right now. I have the vtf3.3 turbo and mbm-12. Money is tight right now lol. I'm a pretty broke college student now. Although I'm very happy even without a spl meter. But im slowly saving up for one.
Will
a3plew is offline
post #1603 of 7624 Old 08-01-2008, 10:47 AM
thsmith's Avatar
OP could do what a couple of my friends and I did which was to all chip in on it (about $10) and pass it around. Never been any conflicts and sits idle most of the time.
Additional benifit we helped each other and learned, a little friendly competition too.
thsmith is offline
post #1604 of 7624 Old 08-01-2008, 11:04 AM
cacihome's Avatar
Quoted: 37 Post(s)
HAHAHA.
You see...
Not everyone has unlimited budget....
Cacimar Hernandez
cacihome is offline
post #1605 of 7624 Old 08-11-2008, 11:41 AM
bori's Avatar
Quoted: 194 Post(s)
Liked: 126
So I ran audyessy with the 50hz crossover engaged. I calibrated the subs with the test tone on the receiver to 75 dbs then ran audyessy, all this was done with the crossover engaged. If this is the wrong way do I calibrate the subs with the XO off using the spl and pink noise? After this is done then do I run audyessy with the XO off or on?
bori is offline
post #1606 of 7624 Old 08-11-2008, 05:39 PM
bori's Avatar
Quoted: 194 Post(s)
Liked: 126
Anyone?
bori is offline
post #1607 of 7624 Old 08-12-2008, 03:07 AM
Bailman's Avatar
Bori, Please include more information if you wish to get good advice i.e. what sub, mains, amplifier or receiver etc. If you do not have large mains with a separate amplifier I would x/o @ 80Hz.
Bailman is offline
post #1608 of 7624 Old 08-12-2008, 03:33 AM
bori's Avatar
Quoted: 194 Post(s)
Liked: 126
Duel HSU 3.3 with turbos, MBM-12 and Onkyo 805 with Infinity Beta 50s.
bori is offline
post #1609 of 7624 Old 08-12-2008, 05:25 AM
Bailman's Avatar
http://www.avsforum.com/avs-vb/showthread.php?t=799936
Please have a look at this thread. I believe they specifically address your questions on page four.
Bailman is offline
post #1610 of 7624 Old 08-12-2008, 10:49 AM
bsoko2's Avatar
Quoted: 75 Post(s)
Liked: 79
I have posted on that page and was told that my method of seting up the MBM's with the true sub is not right. I know that the information that I posted works fine for me. So make of it what you will and maybe those that claim that I'm not correct will post for the rest of you on how they see it done.
Bill
bsoko2 is offline
post #1611 of 7624 Old 08-12-2008, 12:59 PM
bori's Avatar
Quoted: 194 Post(s)
Liked: 126
That is why I am asking because I saw your posts before going back and forth on the correct way to set it up. I actually set mine up the way you did. I just want to make sure its the correct way.
bori is offline
post #1612 of 7624 Old 08-12-2008, 01:02 PM
bsoko2's Avatar
Quoted: 75 Post(s)
Liked: 79
If it works for you, it is YOUR correct way. Go to: http://forum.hsuresearch.com/showthread.php?t=4003 as this has been discussed and the conclusion is, that it does work.
Bill
bsoko2 is offline
post #1613 of 7624 Old 08-12-2008, 04:11 PM
King_David's Avatar
I am considering some tower speakers and center from BIC to complement my VTF-3.3 and MBM set up. Do any of you guys have BIC speakers? I hear they were designed by Dr. Hsu himself.
All Acoustech models were designed and engineered with the assistance of the highly regarded Hsu Research engineering team.
http://www.bicacoustechspeakers.com/...d=306&offset=1
http://www.bicacoustechspeakers.com/...d=307&offset=1
Is there any advantage to using ALL towers for fronts, surr, and back surr speakers?
post #1614 of 7624 Old 08-12-2008, 11:57 PM
cyberbri's Avatar
Liked: 54
Bill
Bori,
See my post on that thread, #33.
cyberbri is offline
post #1615 of 7624 Old 08-13-2008, 12:02 AM
bori's Avatar
Quoted: 194 Post(s)
Liked: 126
So after I do that when I run audyessy do I have the XO engaged?
bori is offline
post #1616 of 7624 Old 08-13-2008, 12:09 AM
cyberbri's Avatar
Liked: 54
To run the eq to flatten out the final response of how the subs interact with each other in the room, here's what I would do:
--With the sub off, calibrate the MBM to the same level as the speakers
--With the MBM off, and the subs' xo switched off, calibrate them to the same level as the MBM and the speakers (since you have two, run them at the same time for calibrating, but when adjust so the gain knob is same for both of them)
--The above two steps match the level of the two subs to the same level, because you are matching their output at the same frequencies in the sub test tone
--Engage the subs' xo, turn all subs on, and calibrate the combined output of the sub and the MBM to match the level of the speakers
--Run the auto-eq
--Re-run the test tones to see if you need to readjust the sub level based on the auto-eq making cuts to frequencies (which will bring down your overall sub SPL level). You may not need to do this if part of the process includes setting the speaker/sub levels automatically as well.
You can eq individual subs separately, but when you introduce the output from all the subs, it probably won't be flat anymore due to the acoustics of the room and how the frequencies boost or cancel each other out at different spots in the room. That's why you eq the combined output.
I don't have an MBM, but when I eq my sub (3.2) manually, I run the test tones through the receiver so it goes through the main speakers and the sub. Otherwise I could eq the sub flat, but it wouldn't be flat once the bass from the mains is combined with it (due to the crossover slopes).
cyberbri is offline
post #1617 of 7624 Old 08-13-2008, 03:41 AM
bori's Avatar
Quoted: 194 Post(s)
Liked: 126
--Run the auto-eq
After running Audyessy you mention rerun the test tones. What part of the steps above are you talking about. Can you highlight what you mean by this?
bori is offline
post #1618 of 7624 Old 08-13-2008, 09:26 AM
cyberbri's Avatar
Liked: 54
Bori,
What I mean is, when you run the eq (after matching the volume of the sub and MBM), which will cut down various frequencies to flatten out the response, the volume or SPL level may be reduced. Unless Audyssey does an auto-setup to level match all the channels again, you will want to run the sub test tone again to make sure the subs are playing at the proper level compared to the speakers.
If the auto eq made a bunch of cuts, maybe the overall SPL is down 3dB. So re-do the test tone to make sure the subs are playing at the correct SPL level. Since the output should be much flatter, when you raise the level to the correct SPL, you may have much more bass slam since all frequencies will be hitting equally hard, not just a few (which throw off the calibration).
cyberbri is offline
post #1619 of 7624 Old 08-13-2008, 09:35 AM
bori's Avatar
Quoted: 194 Post(s)
Liked: 126
It did lower the spl down to 72 dbs. Run this again?
bori is offline
post #1620 of 7624 Old 08-13-2008, 11:03 AM
cyberbri's Avatar
Liked: 54
Yes, run through that process again.
The eq cut down frequencies, which reduced the overall SPL. Level match the low and high subs (MBM and sub) again, xo off (since you don't know where the frequencies that were cut by the eq are), then engage xo and calibrate combined output to 75dB or whatever level you calibrate to.
After eq'ing, it's possible that you may notice less "boom" or slam. If you had one or a few big peaks, you may have gotten used to how certain bass notes sounded with those peaks, which may have sounded cool. But with flat(ter) bass, all of the bass notes should hit equally hard, not just a few. Once you get used to it, it sounds great. If your Audyssey has settings for a house curve or something like that (that leaves the natural rise as you get closer to 20Hz), you may want to engage that to maintain the extra oomph of the very deep low end. Since it takes higher SPL to seem to be at the same "volume level" the lower you go.
cyberbri is offline
Hsu Research , Hsu Vtf3 Mk4 , Hsu Vtf2 Mk4 , Hsu Research Hb1 Mk2 , Hsu Research Vtf 2mk3 , Hsu Research Hc 1 Mk2 , Hsu Vtf 15h Subwoofer , Hsu Research Uls 15 Subwoofer , Hsu Research Stf 1 Subwoofer 150 Watt
