Nemo--Darla Scene--Subwoofer Test - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 274 Old 02-28-2007, 05:27 PM
Static Wick's Avatar
Originally Posted by crackyflipside View Post
I was in physical pain the day after because I wasn't using hearing protection.
I always use hearing protection when conducting measurements and test, I want to be able to enjoy the fruits of my labor.
Static Wick is offline
post #92 of 274 Old 02-28-2007, 05:32 PM
movies2090's Avatar
Quoted: 37 Post(s)
Liked: 25
1. 99db from listening postion
2. xxx-didn't try
3. 3000cu ft
4. a PB12-Plus colocated w/ PB12-ISD
5. Master Volume -12db Sub calibrated to 78db on SPL meter (+3db hot)
movies2090 is online now
post #93 of 274 Old 02-28-2007, 05:40 PM
frockc's Avatar
ok i redid my tests... C weighting fast Max... didn't see anypoint in going to 0 MV... when all three were scary lol...
1. 106dB on very old digital meter 11-12ft away...
2. 115dB
3. 4000cf first level of a townhome open stairs to upper two levels and lower level
4. JL fathom 113
5. -15 MV, sub calibrated 75dB flat with speakers at 0 MV
1. 108dB on very old digital meter 11-12ft away...
2. 119dB
4. JL fathom 113
5. -10 MV, sub calibrated 75dB flat with speakers
1. 110dB on very old digital meter 11-12ft away...
2. 119dB
4. JL fathom 113
5. -5 MV, sub calibrated 75dB flat with speakers
frockc is offline
post #94 of 274 Old 02-28-2007, 05:54 PM - Thread Starter
bgillyjcu's Avatar
2. 115dB
4. JL fathom 113
2. 119dB
4. JL fathom 113
2. 119dB
4. JL fathom 113
HOLY COW MAN!!
Those numbers are staggering for that "little" sub. First you have a HUGE open space from what you said, and still, at -5db MV you still hit 110db from your LP.
Twitter @ Clefoodandbrews
bgillyjcu is offline
post #95 of 274 Old 02-28-2007, 06:03 PM
DrPainMD's Avatar
2. 115dB
4. JL fathom 113
2. 119dB
4. JL fathom 113
2. 119dB
4. JL fathom 113
I don't understand why it's the same 119db when at -10MV and -5MV.Should'nt it be higher with -5 MV ?
super dirty , super clean , pow
DrPainMD is offline
post #96 of 274 Old 02-28-2007, 06:04 PM
jhan1000's Avatar
I think the subwoofer had reached its limits.
Looking at JL Audio's max output data (GP @ 1 meter), they were reporting 117.1db at 31.5Hz and 121.2db at 50Hz.
Life is good.
jhan1000 is offline
post #97 of 274 Old 02-28-2007, 06:04 PM
jmcomp124's Avatar
This is what I was looking for. It appears to me that the f113 is compressing.
frockc,
Can you observe to see if the clip/amp limiter light is coming on?
jmcomp124 is offline
post #98 of 274 Old 02-28-2007, 06:05 PM
jmcomp124's Avatar
Originally Posted by bgillyjcu View Post
HOLY COW MAN!!
With almost half a foot of excursion, I am not surprised at all.
post #99 of 274 Old 02-28-2007, 06:05 PM - Thread Starter
bgillyjcu's Avatar
My guess.......Reaching his limit......You can only turn it up so loud before it will reach compression and maybe even bottom. I think his BEST volume was the -10db. At -5db as you noted, the data didn't really go up much more at all from the LP and leveled off at 1Meter.
Every sub has a limit!
And hey! Thats a lot of output for a single sub in a 4000cubic foot room!!!
post #100 of 274 Old 02-28-2007, 06:07 PM - Thread Starter
bgillyjcu's Avatar
LOL
And DAMN you guys are fast to respond....took me 60seconds to type that last one and I come back and there is already 3 responses!
post #101 of 274 Old 02-28-2007, 06:10 PM
DrPainMD's Avatar
with my results, when I turn up the MV (ex. 3db) I get roughly the same increase with the spl reading (+3db) for the sub. I'm no expert, so I don't know whats happening.
DrPainMD is offline
post #102 of 274 Old 02-28-2007, 06:12 PM
jhan1000's Avatar
frockc,
I don't think there is a clip / amp limiter light on the JL Audio... I've pushed my Fathom pretty hard to the point where I know its compressing, and have not seen any lights go off.
When I had the AV123 ULW-12, the amp light would turn red everytime the limiter was activated.
Life is good.
jhan1000 is offline
post #103 of 274 Old 02-28-2007, 06:15 PM
frockc's Avatar
well yea the sub is not bottoming out when i get it to -5MV... one thing is i had the sub in the right side of my living room basically the middle of the first floor and then i shifted it to the left side which at the back has the staircase that goes to the upper 2 levels... did this because a much better FR on the left side since itz a true corner...
i did try the movie pulse at the end where the bass is just crazy and if i go to -5MV in the trueHD track over analogs it bottoms out.... but if i switch over to the coaxial output the bass actually sounds louder at the same -10MV but at -5MV it will bottom out also even though the sound is much louder...
really amazing sub... just brings a smile to my face since i had a NHT 12 before...
understandable the bottoming out at that point though so not really dissappointed...
here are some pics of my room....
frockc is offline
post #104 of 274 Old 02-28-2007, 06:20 PM
frockc's Avatar
One thing is on pulse i was making my lights flicker lol...
what is the clip/amp limiter light u are talking about jmcomp???
frockc is offline
post #105 of 274 Old 02-28-2007, 06:23 PM
DrPainMD's Avatar
That just adds to the movie experience LOL
When playing the Darla scene, things in my room started to rattle that never rattled before (windows, pictures on the wall), with my -4db result. (101db @ LP and 110 at 1 meter , 25-31PCi)
DrPainMD is offline
post #106 of 274 Old 02-28-2007, 06:30 PM
jmcomp124's Avatar
Looks like your sub does not have such an indicator. Your room looks very difficult for a sub. Can you post a better picture of the corner where it is at now? The best way to load this sub would be to place it a corner so it is loaded by 2 walls and the floor.
If you calibrated with Avia, then your processor may have adjusted the LFE offset by 10dB. In TrueHD, I don't know how it works, but it appears that you have to claibrate the processor/receiver differently for TrueHD unlike coaxial input. You probably maybe unintentionally calibrating it 10dB hot with TrueHD. You may want to ask about this in the processor forum.
post #107 of 274 Old 02-28-2007, 06:43 PM
frockc's Avatar
yea here is a pic it sits now where that tripod is... i calibrated the speakers using the processor itself to have ref 0 at 75db... the analogs i calibrated using the THX optimizer on the Finding nemo dvd and they all seem to be at 75db also... i think the analogs on the HD DVD player XA2 are just lower all around i know i had to boost the sub for 7.1 analogs by 10 db which is common for analogs...
frockc is offline
post #108 of 274 Old 02-28-2007, 07:24 PM
dirtraven1's Avatar
Master Volume -34 Sub Cal at 75db flat.
did you mean to put master volume of -34?
that doesn't make sense... -34db is low....unless you have the reference level at like -25db or something...
MV on my Yamy says -34db when my SPL reads 75db with pink noise. I run klipsch references all around.
If that makes sense.
dirtraven1 is offline
post #109 of 274 Old 02-28-2007, 07:33 PM - Thread Starter
bgillyjcu's Avatar
I wish we could get some people with MULTIPLE subs to do this.
Also I'd like to see some 3.3 with turbo and some HO with turbo.
I'd like to see some more SVS PLUS and ULTRA subs as well.
And how about NON SVS and HSU people.....anyone out there?
Maybe you can message some members and get them to take part in this
post #110 of 274 Old 02-28-2007, 08:05 PM
jmcomp124's Avatar
Agree. Some 3.3 and HO numbers would be a valuable addition.
post #111 of 274 Old 02-28-2007, 08:10 PM
mojomike's Avatar
Liked: 30
Triple subs:
Two SB12Plus's hooked up in stereo with the L&R mains and a 2 x 10" TC-1000 6.5 cu ft. ported box, powered by Behringer EP2500, hooked up to LFE.
115 db in Listening area, about 14 ft.
126 db 1 meter from ported sub, Behringer lighting up like a Christmas tree
6120 cu ft. open room.
mojomike is offline
post #112 of 274 Old 02-28-2007, 09:06 PM
DrPainMD's Avatar
Do you have a more recent pic with the sub in the pic? Would like to see it in your room layout.
DrPainMD is offline
post #113 of 274 Old 02-28-2007, 09:21 PM
MKtheater's Avatar
Quoted: 1589 Post(s)
Liked: 1116
1. 110 db from Listening Position (analog SPL Meter-fast)
2. 115 db from 1 meter (analog SPL Meter-fast)
3. 2300cuft (sealed )
4. A single SVS PB12/plus/2 tuned in the 16 hz tune
5. Master Volume -10db Sub calibrated to 75db on SPL meter. Ref is 0, all speakers are set to 75 db's.
1. 111 db from Listening Position (analog SPL Meter-fast)
2. 116 db from 1 meter (analog SPL Meter-fast)
5. Master Volume -5 db Sub calibrated to 75db on SPL meter. Ref is 0, all speakers are set to 75 db's.
2. 117 db from 1 meter (analog SPL Meter-fast)
5. Master Volume 0 db Sub calibrated to 75db on SPL meter. Ref is 0, all speakers are set to 75 db's.
My sub in the 25 hz mode will yield at least 6 more db's in my room.
Marantz 7702 Atmos
MKtheater is offline
post #114 of 274 Old 02-28-2007, 09:46 PM
jmcomp124's Avatar
Hi Mk,
Good to see you here. From you measurements it looks like the Plus/2 is compressing above MV -10. Have you measured the 20Hz mode?
Jai
post #115 of 274 Old 02-28-2007, 09:55 PM
MKtheater's Avatar
Liked: 1116
Hi Jai,
How is the dts-20? Yes I know it is compressing, but the sub never bottoms or sounds bad and I am running it in it's least efficient tune. I will re-run it in its native tune tomorrow, I will even do it in the 20 hz tune. Remember this sub was built for 118 db's in the 16 hz tune, 121 db's in the 20 hz tune, and 124 db's in the 25 hz tune at 1 meter. We will see.
Marantz 7702 Atmos
post #116 of 274 Old 02-28-2007, 10:04 PM
jmcomp124's Avatar
Hi James,
The DTS-20 is awesome!! The problem is completely gone and it rocks. I have to do a lot of listening and testing before I post anything on it. The size is still overwhelming us and in fact I have an interested buyer so I think I will be selling it shortly. Mine is a pretty large effective 7000 cu ft room. I already tried the Darla scene and at 17 ft away I think we saw 110dB uncorrected in a very old analog meter. My friend was holding the meter while I was listening in awe. I think I was at MV +6 calibrated at 75dB running 2dB hot. I Equed it last night but haven't had the opportunity to measure to contribute to the thread it. I get back home pretty late and don't want to bother the neighbors. I will post it over the weekend.
-Jai
post #117 of 274 Old 02-28-2007, 10:13 PM
TheEAR's Avatar
2. 115dB
4. JL fathom 113
2. 119dB
4. JL fathom 113
2. 119dB
4. JL fathom 113
Good show,great showing in fact. I wonder what multiples do in a tiny space.
Ask yourself mortal , do you have as much displacement as me ? The answer is no unless you have a Windmere fan sub.
TheEAR is offline
post #118 of 274 Old 02-28-2007, 10:14 PM
frockc's Avatar
here are some more pics...
also i forgot to say i got a marantz 8500 so i dont think there is an easy way to disconnect the speakers so i left them on...
frockc is offline
post #119 of 274 Old 02-28-2007, 10:21 PM
cschang's Avatar
Quoted: 107 Post(s)
Liked: 164
Fun thread!
For the 1 meter measurements, are you guys measuring equal distance from the ports(if you have them) and driver(s)?
-curtis
Owner of Wavecrest Audio
Volunteer Mod at the Ascend Acoustics Forum
Like all things on the Internet, do your research, as forums have a good amount of misinformation.
Help beat breast cancer!
cschang is offline
post #120 of 274 Old 02-28-2007, 10:26 PM
jmcomp124's Avatar
Ok Brad. The big boys are coming in now . Your thread this time has attracted some very good attention and you are making up for that other silly thread which got deleted. I for one really appreciate what you came up with. Did I motivate you with my 3 year old post on the PB2Plus and Darla scene? Just curious.
