Riser on Concrete Floor, Tactile transducers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-17-2007, 01:45 PM - Thread Starter
A320Driver's Avatar
I will be building a riser approximately 15'x7' isolated on a concrete floor that will support 4 Berkline 90's. I'd be interested in recommendations for the number of tactile transducers required for this size of platform. I haven't decided between the Buttkicker or Clark Synthesis, but would like to know if one Buttkicker or one Platinum would do the trick.
I have another 2 Berklines in the front row that I'm planning to shake with the Crowsen TES 100' - can't afford them for the rear 4 chairs.
Any advice would be appreciated as I'm at the pre-wire stage.
A320Driver is offline
post #2 of 6 Old 03-17-2007, 01:46 PM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
I would wire for two Buttkickers and two will give you more placement options as well as even out the sensation across the platform. I doubt one will cut it, but why risk it?
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #3 of 6 Old 03-17-2007, 03:08 PM
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 437
I definitely would think you would need more than one. My riser is built on a concrete floor (measures roughly 10'6" by 10') and 1 isn't nearly enough to shake a couch satisfactorily. I agree with above poster, 2 would be a better option and would even out the sensation more.
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #4 of 6 Old 03-18-2007, 02:48 AM
Soundood's Avatar
Also agree...two is the right number. More is always fun but probably not necessary.
"Did you make 'em fine-ass-soundin' speakers over there what would sound gooder than hell comin' out of the back of my truck-boat-truck?"
-Early Cuyler. Poet Liquoreate
Soundood is offline
post #5 of 6 Old 03-18-2007, 06:19 AM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
You could also consider the Earthquake Quake 10.0. One should be powerful enough to shake the whole platform. Here is a Secrets review of the product. You could also use it with the Buttkicker amp if you don't want to spend the $$$ for the Earthquake amp.
Craig
Lombardi said it:
Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #6 of 6 Old 03-18-2007, 07:38 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
Craig
Hey craig,
That is another nifty option! I had not seen that before. A little pricey though. But, it might be worth it according to the review.
Joe = LFE Addict
jpmst3 is offline
