vtf3 mk3 came today wow it's a monster (pics) - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 137 Old 05-12-2007, 08:44 PM
Kevin12586's Avatar
lvisneau, when you did your test w/out turbo, where you in max output or extension? It looks like max output, to compare apples to apples, if it was max output could you run your sub in max extension without turbo?
Kevin12586 is offline
post #122 of 137 Old 05-13-2007, 05:23 AM - Thread Starter
lvisneau's Avatar
I was in max output.
so i did a comparison w/ turbo in max ext and w/out in max ext w/port plug. and the #'s were identical. maybe the turbo kicks in under 16 hz. but i don't have tones under 16 nor do i need under 16- do I? anyways, the turbo will be returned.
My sono build
Psn Id- lvisneau or lvizzzy
Xbl- chief vizzy
lvisneau is offline
post #123 of 137 Old 05-13-2007, 09:11 AM
xcjago's Avatar
Quoted: 13 Post(s)
The freq response should be the same in max extension mode whether you use the turbo or not. But with turbo, it will play louder without port noise.
xcjago is online now
post #124 of 137 Old 05-13-2007, 09:13 AM
Megalith's Avatar
Quoted: 22 Post(s)
Looks like a laundry machine.
Megalith is offline
post #125 of 137 Old 05-13-2007, 09:52 AM - Thread Starter
lvisneau's Avatar
louder at 16hz and below only?
My sono build
Xbl- chief vizzy
lvisneau is offline
post #126 of 137 Old 05-13-2007, 07:31 PM
xcjago's Avatar
Quoted: 13 Post(s)
Well, port noise can occur at somewhat higher frequencies as well. I would say the turbo helps at 18hz and below.
post #127 of 137 Old 05-14-2007, 04:55 AM - Thread Starter
lvisneau's Avatar
hmmmm, now i completely confused about keeping this thing. maybe i'll do one more test for port noise before i send it back.
My sono build
Xbl- chief vizzy
lvisneau is offline
post #128 of 137 Old 05-14-2007, 05:06 AM
spyboy's Avatar
Liked: 48
I expect to keep my Turbos. Adding a foot of additional dual 4 inch ports makes a difference. Sometimes I blow the port plugs out of my 'HOs, when I don't have the Turbos attached.
All the Best
spyboy is offline
post #129 of 137 Old 05-14-2007, 11:27 AM - Thread Starter
lvisneau's Avatar
All the Best
hey spyboy, how can i get that house shakin spl and the low fr. all at once. can i use the turbo in max output mode? would that help at all. should i use the turbo and just turn it up to fill in the gap? i'm pullin out my hair here.
My sono build
Xbl- chief vizzy
lvisneau is offline
post #130 of 137 Old 05-14-2007, 12:07 PM
Kingrsl's Avatar
The turbos are only for max extension mode. You can do damage to the amp if the settings are incorrect from what I hear. I've since reconsidered and I'm keeping my turbos. All I needed was to do a little more tweaking with room placement. I don't feel i'm losing enough above 20hz for me not to use the turbo. It doesn't hurt having dual subs either.
Kingrsl is offline
post #131 of 137 Old 05-14-2007, 12:46 PM - Thread Starter
lvisneau's Avatar
thanks for the reply king, i'm just about to put the turbo back on and try again.
My sono build
Xbl- chief vizzy
lvisneau is offline
post #132 of 137 Old 05-14-2007, 12:58 PM
xcjago's Avatar
Quoted: 13 Post(s)
Using the Turbo in max output mode would actually be ok. It will give you performance somewhere in between the normal max extension mode and max output.
The only time where you can damage the sub is if you put it in max extension mode with both ports open and no turbo.
post #133 of 137 Old 05-14-2007, 01:11 PM - Thread Starter
lvisneau's Avatar
gonna check it right now!
My sono build
Xbl- chief vizzy
lvisneau is offline
post #134 of 137 Old 05-14-2007, 01:43 PM - Thread Starter
lvisneau's Avatar
tried it with some hard hitting movies and it seems to hit much harder w/out the turbo. maybe i'll put it in the attic for now.
My sono build
Xbl- chief vizzy
lvisneau is offline
post #135 of 137 Old 05-14-2007, 03:00 PM
Kingrsl's Avatar
What movies were you testing with? Most movies have the heavy bass in the 20hz and higher range. There are some movies where there are some sub 20hz effects and it's definately noticeable at my house between max extension and max output modes: Casino Royale, Pulse, Flight of the Phoenix, Pearl Harbor, Jurassic Park 3, and WOTW to name a few. It all comes down to personal preference though.
Kingrsl is offline
post #136 of 137 Old 05-14-2007, 04:56 PM
Mathesar's Avatar
Ya I have the same experience, whenever I compare movies or music there's noticeably more impact without the turbo applied, but as mentioned above some movies benefit from the turbo which is one of the reasons I bought a 2nd sub and kept the turbo.
Mathesar is offline
post #137 of 137 Old 05-30-2007, 02:00 PM - Thread Starter
lvisneau's Avatar
I have recently put my turbo back on for good. it seems to get a flatter response. i noticed that some frequencies were way too loud and w/turbo it was better, still room shaking but shaking at all frequencies not just 1.
My sono build
Xbl- chief vizzy
lvisneau is offline
