Best Cable Type for Long Subwoofer cable runs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 06-05-2007, 09:33 AM - Thread Starter
TrzVpr's Avatar
What is the best type of cable to use in Long ~50ft. subwoofer cable runs?
The options I have are:
1) RCA
2) XLR
3) Coax w/ RCA adapters.
Which one will provide the best signal transfer at these distances?
I know coax is proven for distance but was wondering if balanced was a better option for signal clarity..
TrzVpr is offline
post #2 of 18 Old 06-05-2007, 09:49 AM
OvalNut's Avatar
Balanced XLR if possible as long as both the processor and sub have XLR connectors would be your ideal situation.
In reality though, a good shielded coax subwoofer cable can be just as good. I run a 50' standard coax subwoofer cable with no problems.
Tim
He drove a black and white pirate ship at 190 mph.
- Dale in the #3 will never be forgotten. Thanks for the memories.
OvalNut is offline
post #3 of 18 Old 09-01-2008, 09:45 AM
jcjrogers's Avatar
I have a similar question. I've seen some recommendations to use speaker wire for a subwoofer, but the Surroundbar 360 HTIB I'm getting doesn't have connections for extra speakers, only a sub-out connection. I don't know where or what type of sub cable to purchase. Is this cable I can get at Blue Jeans cable or Monoprice?
jcjrogers is offline
post #4 of 18 Old 09-01-2008, 12:59 PM
bsoko2's Avatar
Quoted: 71 Post(s)
Liked: 78
1) RCA
2) XLR
My room is 20 X 28 and I'm running 5 subs with arbout 72 feet of sub cable and 5 "Y" splitters. No problems with sound or anything else.
Bill
bsoko2 is offline
post #5 of 18 Old 09-01-2008, 01:12 PM
Ironmike86's Avatar
Bill
Where do hook all them Y splitters? Buy the receiver. By the subs or both?
Ironmike86 is offline
post #6 of 18 Old 09-01-2008, 03:38 PM
SUPERMANROB's Avatar
Well I'm using a 40 ft one from bluejeans(Canare LV-77S)thats working great so far.
SUPERMANROB is offline
post #7 of 18 Old 09-01-2008, 03:50 PM
penngray's Avatar
Liked: 43
I have 3 50ft RG6 coax cables from monoprice.com .....much cheaper then any other source out there and they are 100% reliable.
Why spend more money when you do not need too!
Although most of my subs are passive so I just run speaker wire too them.
penngray is offline
post #8 of 18 Old 09-02-2008, 10:09 PM
jcjrogers's Avatar
Blue Jeans Cable has an LC-1 analog 50ft sub cable for $64 (seems pretty steep). They also have a Belden for $50. I can't really tell about Monoprice because they don't label anything as "subwoofer cable". I believe I might have found the cable Penngray was speaking of for about $12, but not sure because not labeled as subwoofer cable. I really don't know how much I'm going to need, because I'm not sure where I'm going to be locating my subwoofer. However, where I think I'm going to put it, I'm going to have to go up a wall, over the ceiling, then back down a wall. I estimate I will need around 40' of cable, but want to get 50' just to make sure.
Another question, does sound degrade with the length of cable like say, video can degrade with length of HDMI cable?
post #9 of 18 Old 09-02-2008, 10:38 PM
Tulpa's Avatar
Liked: 61
Monoprice sells a 75ohm coaxial RCA ended cable (both RG59 and RG6) as their subwoofer cable. They also (correctly) advertise it as a composite video and a digital coaxial audio cable.
http://www.monoprice.com/products/su...02&cp_id=10236
You can swap that cable between your sub, your composite video device (such as a VCR), or your digital coaxial audio device (such as the digital output on a DVD player) and they would all work.
Put two of them together and you have a stereo pair of analog audio cables. Put three of them together and it's a set of component video cables. Might be slightly cheaper to buy the ones that they actually advertise as analog audio or component, but I believe they're all the exact same cable in the end.
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
post #10 of 18 Old 09-03-2008, 02:27 AM
NightHawk's Avatar
Generally speaking, no.
NightHawk is offline
post #11 of 18 Old 09-03-2008, 10:10 AM
bsoko2's Avatar
Quoted: 71 Post(s)
Liked: 78
bsoko2 is offline
post #12 of 18 Old 09-03-2008, 07:21 PM
jcjrogers's Avatar
Thanks folks. I went with the Monoprice. Hard to beat 50' of cable for $10. If for some reason I have problems in the future and want to buy something more expensive, I'm only out about $18 when you add the shipping.
post #13 of 18 Old 09-10-2008, 04:21 PM
brewbush's Avatar
On similar topic
Will I have an issues with a 50ft RCA/Subwoofer cable connected via female coupler to another 25ft RCA/Subwoofer cable for a loooooong run from pre/pro to subwoofer? I am assuming between RCA and XLR there is no difference in sound quality (and I can just use the pre-out subwoofer port instead of the dedicated sub XLR).
Epik Castle only has RCA inputs (no XLR). So it is a tossup between that and the PB13 Ultra.
I know Bluejeans has custom lengths but are more expensive then monoprice.
brewbush is offline
post #14 of 18 Old 09-11-2008, 10:32 AM
brewbush's Avatar
Originally Posted by brewbush View Post
On similar topic
As a follow up question. Can I use a long XLR cable (70+ feet) then a separate XLR-RCA (1 foot - daisychained) connector to hook up the Epik Castle?
Will I get the benefit from the XLR output from my pre/pro?
EDIT: I think I found a partial answer
Right, the processor is offering you 2 types of sub connections, use the one that matches your sub. They have the same signal. There is no difference except ease of connection.
and
They differ in level with the BAL output about 6dB higher. Of course, any such discrepancy is corrected in the setup process.
brewbush is offline
post #15 of 18 Old 11-14-2008, 10:50 AM
fbarra's Avatar
Quick question, will there be any noticeable delays by using a longer subwoofer cable than what I really need. I want to buy a 25ft sub cable from monoprice but also debating over the 35ft. I'm not planning a complicated install but just getting longer in case I want to experiment with different placement of the sub. Thanks for any opinions.
fbarra is offline
post #16 of 18 Old 01-17-2013, 12:30 PM
danbrotherston's Avatar
An HDMI cable carries a digital signal, your TV either works or it doesn't, there can be no degradation. You will either see a picture of not, does not matter how long a cable you buy, or how much gold plating.
Subwoofer cable on the other hand caries a low power analogue signal (in the case of an amplified sub anyway), which may degrade over distance, but coaxial RCA cables are fairly resistant to interference, you'd need a long run with noisy EM interference to have a problem.
danbrotherston is offline
post #17 of 18 Old 01-17-2013, 01:43 PM
Bill Fitzmaurice's Avatar
Liked: 4629
Happen to notice the date on the post you responded to? He's probably got it sorted out by now.
its phillip likes this.
Bill Fitzmaurice is online now
post #18 of 18 Old 01-18-2013, 11:23 AM
Do I care? I found the post, through search, its quite reasonable to not want misleading information left.
