Official Epik Subwoofer Thread - Page 124 - AVS Forum | Home Theater Discussions And Reviews
 52Likes
post #3691 of 20891 Old 09-03-2008, 04:07 PM
thirdeye11's Avatar
Originally Posted by union1411 View Post
well i considered everything - the tiny cage that i called my home theater room, the room gain that will add dbs in the lower range, the fact that i'm not running a sports stadium but a home theater, and the fact that in 1920 my walkup building's engineer probably did not account for something like a conquest shaking its foundation - and decided that the conquest/castle are likely overkill (would i really ever benefit from all that headroom or the really low extension that much/often?)
so that leaves the knight. but with the long wait times, i wasn't too thrilled. so i pulled the trigger on a mfw-15 an hour ago. so i'll see how that goes and if my bass fetish is not satisfied by that, then i'm ignoring all of you and ordering a conquest/castle. maybe four of them just to show off to all of you (for that brief moment before all 4 of them cause me to implode and turn into dust)
I think you're going to be seriously stoked with that subwoofer. Let us know your results even though this is the Epik thread. Then again maybe you should post results as its own topic in the forum, or feel free to PM me with what you think of that massive sub in such a small space. I'd be curious to know your results.
thirdeye11 is offline
post #3692 of 20891 Old 09-03-2008, 05:46 PM
Dionyz's Avatar
Quoted: 57 Post(s)
Liked: 48
Originally Posted by thirdeye11 View Post
When you calibrated your system, did you turn up to reference levels, then set the mains at 75 or 85db? If so what did you calibrate your subwoofer at? I calibrated mine at 85db each channel with my AVR-5800 on 00 (volume) and then the subwoofer I put at around 85 db. Didn't like the amount of bass I had so I upped it to 90db (5db hotter than the mains) still wasn't quite enough. I bumped it up to around 92-93 db (or 7-8db hotter than the mains). This put my settings on my Epik Tower's gain knob at around 11:30 and the receiver's LFE out at -3db.
I'm curious how my settings compare to yours. Obviously my mains are no where near as sensitive as yours, and my power also isn't as strong either. I'm only putting about 200wpc into the mains which are also 4 ohm speakers (Salk SongTowers). My speakers are true rating of 88db/m @ 1 watt. I imagine the 100 db rating on the RF-83's is a little overstated, but probably not by much. You've still got a lot more headroom on me.
So anyway tell me how you calibrated. That Nazgul scene is indeed quite awesome One of the few I've had a chance to watch on my new theater
-Chad
It is calibrated almost same as yours.
I ended up at ~12:00 on the conquest and LFE at -4.0 dB
Calibrated with Audyssey
Dionyz is offline
post #3693 of 20891 Old 09-03-2008, 06:47 PM
bertschb's Avatar
I'm thinking about getting the Conquest but laying it on it's side (a smidge too tall for optimum WAF). Does this adversly affect performance? Can anybody post photos of the bottom of the sub? If I lay it on it's side do I need to put rubber feet on the side?
Brian
bertschb is offline
post #3694 of 20891 Old 09-03-2008, 07:05 PM
chengbin's Avatar
Actually, the Conquest is supposed to be laying on its side and it actually sounds better that way. Best of both worlds for you huh?
chengbin is offline
post #3695 of 20891 Old 09-03-2008, 07:25 PM
KBMAN's Avatar
Quoted: 258 Post(s)
Liked: 144
Hey y'all,
I'm really curious about epik subs....I'm also looking at SVS HSU, and AV123.....I have about 1,100 dollars to spend, but want something RELIABLE and LOUD, LOW, and ACCURATE....I was looking at the castle, but also looking at the Tower with it's larger cabinet. What sub will fit the bill in my poorly acoustic 16x22 room? BTW, right now I have a sunfire signature sub and I blew the passive radiator on it ANY feedback would be great!
KBMAN is offline
post #3696 of 20891 Old 09-03-2008, 07:44 PM
warlord260's Avatar
Originally Posted by KBMAN View Post
Hey y'all,
i have 2 towers in a room similar to yours. is flat out scary.
gain on the subs 11:00,and i run few db hot.
so i have plenty left,headroom.
if i had to do again and i had $1100 i would get a castle.
$1100 would probably include shipping too.
with a castle in that room you will have no regrets
you wont have to worry about it.
i would say for the money either 2 mfw-15, or a castle. thinking castle is cheaper.
if you move up to the $1700-$1800 range svs ultra13, or the epik conquest
warlord260 is offline
post #3697 of 20891 Old 09-03-2008, 07:44 PM
bertschb's Avatar
Originally Posted by chengbin View Post
Actually, the Conquest is supposed to be laying on its side ...
Is the bottom finished like the sides? I don't want it to look weird. My wife is an incredibly accomodating person but I want to minimize the shock of having a coffin in the family room :-)
bertschb is offline
post #3698 of 20891 Old 09-03-2008, 08:03 PM
thirdeye11's Avatar
Yes. Same finish all the way around.
post #3699 of 20891 Old 09-03-2008, 08:04 PM
thirdeye11's Avatar
Good to know I calibrated manually like a computer did
post #3700 of 20891 Old 09-03-2008, 08:06 PM
bertschb's Avatar
What do the feet look like? Will it look obvious that it's on it's "side"?
bertschb is offline
post #3701 of 20891 Old 09-03-2008, 08:09 PM
KBMAN's Avatar
Quoted: 258 Post(s)
Liked: 144
what's the warranty on epik? That guy above talked me into getting a Castle.....not god, the above poster....but I'm sure god has somthing to say, or hear about this!
KBMAN is offline
post #3702 of 20891 Old 09-03-2008, 08:16 PM
stepyourgameup's Avatar
Liked: 29
7 years on the driver and 2 on the electronics. Be prepared to wait about a month before it ships.
Alcohol. The cause of and solution to all of life's problems.
stepyourgameup is offline
post #3703 of 20891 Old 09-03-2008, 08:18 PM
kemitchell's Avatar
They don't have feet.
~kyle
kemitchell is offline
post #3704 of 20891 Old 09-03-2008, 08:19 PM
bertschb's Avatar
Perfect! Thanks. Sounds like all 4 sides are fair game!
bertschb is offline
post #3705 of 20891 Old 09-03-2008, 09:13 PM
warlord260's Avatar
so the wait starts
this is the painfull part
but when it arrives it is like christmas for big kids
you will not be dissapointed
post #3706 of 20891 Old 09-03-2008, 09:32 PM
John H's Avatar
That is exactly my set-up; Klipsch RF-83s fronts, RC-64 center and 4 RS-62 surrounds - ridiculously efficient horns all arround. And I am driving them with and IcePower amp that delivers ~ 250 w/ch into 8 ohm and ~500 w/ch into 4 ohms (RF-83s dip to about 3.5 ohms around 200 Hz). The dynamics produced by this setup are unbelievable.
The Conquest does a great job. It actually shakes the concrete foundation of the HT room. Leaves nothing to be desired for 99.9% of normal folks.
Dionyz,
That's the speaker configuration I was thinking about ordering. I have been using Definitive Technology bipolars for about 8 years and was planing on switching to directs. The other day I posted over in the Klipsch owner thread post #4007. I would be driving them with a B&K Reference 200.7
I was looking for some owners of those models as it is something that my dealer would need to order. Maybe you could reply?
John
John H is offline
post #3707 of 20891 Old 09-04-2008, 06:14 AM
SoundsGood's Avatar
Anyone have any pictures of an Epik sub with the Rosenut veneer finish? (actually, I'm surprised they're not on Epik's website)
SoundsGood is offline
post #3708 of 20891 Old 09-04-2008, 06:21 AM
Dionyz's Avatar
Quoted: 57 Post(s)
Liked: 48
Originally Posted by John H View Post
Dionyz,
John
Do not forget the mail order option. Klipsch now has authorized several mail order retailers to sell their products. That is how I purchased most of my set-up, except for the RF-83 which I got at local UE which was discontinuing the line and I got a 55% discount (basically equal to the RF-63 price with typical discount).
I would also think twice about spending the extra $ to get RF-83 rather than RF-63. I auditioned both of them. RF-83 goes a bit lower than RF-63, but other than that I found them both very comparable. Which if you have a good sub in your system, does not matter. Plus the drivers are a better match with the rest of the system.
I was going to buy the RF-63s until I came across the deal at UE on RF-83s which I could not refuse.
Dionyz is offline
post #3709 of 20891 Old 09-04-2008, 06:55 AM
thirdeye11's Avatar
I don't think they are building it right now. They're trying so hard to keep up with the black orders that I simply don't think it has been an option for Chad and Co.
If you want to see a picture of it though there is a picture of the Rosenut veneer on the very front page at www.epiksubwoofers.com.
-Chad (not from Epik)
post #3710 of 20891 Old 09-04-2008, 06:59 AM
thirdeye11's Avatar
I assume you mean me. And I hope your experience is positive
I have very little bad to say about the whole Epik experience except the fact that Chad (or anyone at Epik for that matter) is very difficult to get on the phone. Moving to the subwoofer itself though warrants some high praise. Even in my acoustically untreated room I get amazing response out of the Epik Tower and it literally shakes my entire room. I have it isolated from the floor on an Auralex Great Gramma and it still manages to shake the concrete slab floor during intense passages
My neighbors have not complained yet oddly enough, but I can assume this will happen in time. I basically want to watch movies on a daily basis now. I have all new speakers all the way around (all 5.1) and the thing I most look forward to is hearing the Epik Tower (and I bought really good mains and surrounds/center too).
Please let me (and everyone else in this thread!) know your experiences once you receive it. If you need any help calibrating let us know as well and we can point you in the right direction.
-Chad
post #3711 of 20891 Old 09-04-2008, 07:08 AM
SoundsGood's Avatar
Yeah, thanks, but I mean a "real life" pic... one that an owner has taken.
post #3712 of 20891 Old 09-04-2008, 07:11 AM
kip_'s Avatar
I'm pretty sure they haven't shipped out any Rosenut subs.
kip_ is offline
post #3713 of 20891 Old 09-04-2008, 08:36 AM
warlord260's Avatar
-Chad
man thats hot.
i level matched speakers to 75 db using test tones on my onk 705.
the combined output of the towers set at 77db
so when you say 90db on your sub. is that un corrected with spl meter?
if so that is hot.
post #3714 of 20891 Old 09-04-2008, 08:55 AM
Down's Avatar
Originally Posted by warlord260 View Post
man thats hot.
if so that is hot.
Excuse me if I'm mistaken here, but-
Since he calibrated at 85db, having the subs calibrated at 90db would be comparable to having them calibrated to 80db when using a 75db baseline. Still hotter than your 77db, but not nearly as much as it may sound.
Down is offline
post #3715 of 20891 Old 09-04-2008, 09:01 AM
thirdeye11's Avatar
Exactly. I put the receiver volume at 00 and calibrated the mains at 85 db and the subwoofer around 92-93db. When I listen to movies however I am listening at -10 volume so my subwoofer would be a few dbs hotter than yours but really not by much as previously stated by Down.
post #3716 of 20891 Old 09-04-2008, 09:08 AM
warlord260's Avatar
o.k. i get it now it was the mains at 85db realitive to the sub that i must have overlooked.
post #3717 of 20891 Old 09-04-2008, 09:18 AM
Down's Avatar
Out of curiousity, is there any benefit to calibrating at 85 instead of 75? It seems that when I see it mentioned people usually say it doesn't, but I've wondered if there might be a difference in lower than reference listening?
Down is offline
post #3718 of 20891 Old 09-04-2008, 09:24 AM
Ron Temple's Avatar
Quoted: 163 Post(s)
Liked: 133
The SPL meter is 2-3 dbs off for the sub. At 93dbs you are 10-11dbs hot. If that sounds good to you then great. Have you done a frequency response graph to see what your sub is doing? Running the sub that hot in my room would definitely effect the blend at crossover and cause a heavy bloom that would muddy up the sound. I'm not criticizing, I'm just wondering if you have a null going on that effects your output.
I don't lurk as much as I used to and I NEVER listen. Comes from being old and cynical.
Ron Temple is offline
post #3719 of 20891 Old 09-04-2008, 09:27 AM
warlord260's Avatar
i guess it would depend on what receiver you have
on a thx cert. receiver the test tones are 75db. so if level matched at 75db with the tones 0 would be reference
post #3720 of 20891 Old 09-04-2008, 11:43 AM
thirdeye11's Avatar
I calibrated that way because that's how close it was out of the box. I have a THX Ultra II Certified receiver (Denon AVR-5800) and when I was at 00 on the volume, the mains were 84db. I bumped each up 1 db and it was at 85db. I've seen people recommend both 75 and 85db, but I always listen to movies at -10 db on the volume knob so I'm listening where the test tones are at 75db which on my device is -10.
Subwoofers , Epik Legend Subwoofer
