Official Epik Subwoofer Thread - Page 268 - AVS Forum | Home Theater Discussions And Reviews
 57Likes
post #8011 of 20929 Old 07-01-2009, 11:03 PM
stepyourgameup's Avatar
Liked: 29
Originally Posted by GPowered View Post
Very Interesting. I have a question as I am a little confused though. I have Audyssey Multi-EQ and Dynamic EQ (basically the same thing except it helps at lower volumes). It is my understanding that Audyssey sets levels, distance, type (x-over setting although this is generally more of a personal preference), AND helps to smooth out peaks and dips, etc.
Since you are running Anti-mode, what is the point of using Audyssey in addition to it? Anti-mode will smooth out FR and the levels, type, distance, etc. could be set with an RS Meter. Let me know because I was under the impression that Audyssey may not do that good of a job smoothing things. Is the Anti-mode worth the investment if I have Audyssey?
I have received good results regarding Audyssey MultEQ XT and my Tower/Dynasty and others will tell you that you don't need Anti-Mode with MEQXT. The best way to tell how your FR looks is with something like REW, which will show you a graph of your nulls and peaks. You can just use Anti-mode and disable Audyssey, but Anti-mode will do nothing for higher freqs. So, many people who have AM use Audyssey in combination.
Alcohol. The cause of and solution to all of life's problems.
stepyourgameup is offline
post #8012 of 20929 Old 07-01-2009, 11:04 PM
Snowmanick's Avatar
Quoted: 300 Post(s)
Liked: 419
The Anti-Mode will not cover your speakers, only the sub. Audyssey Multi-EQ is hit or miss on subs and can still benefit from an external EQ. In my setup Audyssey had to be seriously massaged to not neuter my sub but still missed most of the room induced peaks. I verified this through A LOT of time with REW. If you use a combination of an external sub EQ you can have that EQ focus on the sub's response (and in some cases such as the Anti-Mode and SVS AS-EQ1 it will also work on the Z-domain) and then you will run Audyssey Multi-EQ to adjust your mains.
External sub EQ's add a digital delay that Audyssey reads and compensates for by adding a distance equivalent in the settings.
The Z-domain (time) controls are some of the best features of Audyssey and equipment like the Anti-Mode. These set them apart from more rudimentary parametric EQ systems.
Selling my Def Tech BP80xx series speakers
http://www.avsforum.com/forum/209-au...-speakers.html
And a like new Rega Exact cartridge
http://www.avsforum.com/forum/209-au...condition.html
Snowmanick is online now
post #8013 of 20929 Old 07-02-2009, 12:06 AM
BRAC's Avatar
Can running MultEQ XT after another sub eq(PBK-1 in my case) have a possible negative/cancellation effect on the results of the initial sub only eq? I'm looking to add the PBK-1 kit to my Sub 12, but only if I can use it successfully in conjunction with my 3808's MultEQ XT. I'm hoping that using the two eq's together will provide even better results. Anyone have any experience using this combination, or MultEQ XT with some other eq?
Sorry, I know this is off topic, but since it came up...
BRAC is offline
post #8014 of 20929 Old 07-02-2009, 02:36 AM
lalakersfan34's Avatar
Liked: 25
Originally Posted by DoubleATheater View Post
I figured that as well, that's why I haven't shot them an email. I'd way rather buy a second Phoenix than build my own sub. The wife just won't let me spend that kind of money again yet. I'll probably just wait and save some more and see if I can change her mind.
Just to be clear, I wasn't trying to rain on your parade. Chad is a great guy and I think there's a chance that if you explained your situation he might give some suggestions on what you could build that might complement the Phoenix. I just don't think he'll help you clone it .
Chad does seem to be pretty secretive about his subs' specs (not that it's a bad thing...it's just what is). IIRC he had requested that people not remove and take pictures of their drivers and spread them online. This might have been at the very outset, though, when his products were still "under the radar". Since he's taken pictures of the new drivers and posted them on Epik's website, he might not have things as "under wraps" as they were before.
Just thinking out loud, I think the only ID company I've seen publicly discuss DIY or specific use of their components in DIY projects was SVS. As new revisions of drivers (such as the Plus line: 12.1, 12.2, 12.3) were released, users could upgrade their old subs to the newer drivers. SVS encouraged those who upgraded drivers to use their old drivers in their own projects. However, SVS still claimed that they could not give any schematics or designs to potential DIYers using their drivers. Furthermore, I don't remember ever seeing any actual T/S parameters listed.
lalakersfan34 is offline
post #8015 of 20929 Old 07-02-2009, 05:23 AM
DoubleATheater's Avatar
You're not raining on my parade at all. It's true that asking Chad for T/S would probably be like asking KFC for their recipe for the special herbs and spices that go on their chicken. I'll see how I can handle the wife, if push comes to shove maybe there is something I can compliment the Phoenix with. Not really a clone but a mate to make her sound just ask beautiful without taking away from it.
DoubleATheater is offline
post #8016 of 20929 Old 07-02-2009, 06:42 AM
ronjoo's Avatar
Originally Posted by lrstevens421 View Post
That Cherry finish is rather attractive, hmmm !!
yeah i think she finish it
ronjoo is offline
post #8017 of 20929 Old 07-02-2009, 07:41 AM
mrjulius's Avatar
I have Audyssey 2EQ which is their "crippled" version. It will only take three measurements and it will NOT set filters on the sub. I imagine that wherever the X-over is set it will not EQ below that point.
From the Audessey site:
2EQ
2EQ measures 3 room positions, uses a basic resolution filter for the satellites and does not apply a filter to the subwoofers.
I didn't know that I had this limitation with Audessey. I had charted my room response with Audessey enganged and then disengaged and the lines were identical. I couldn't figure out why. A few days ago I was reading up on Audessey and found that the 2EQ version does not affect the sub region.
My graph proved that out.
So for me the AntiMode was a home run. It picks up where the Audessey left off. That coupled with my "anything but flat" room response and very limited sub placement issues, probably made me the best candidate for the AntiMode.
Those starting out with fairly flat responses, I have read, benefit less.
The Evil Plan = (Dynasty + Empire) / at 40 Hz !
mrjulius is offline
post #8018 of 20929 Old 07-03-2009, 05:38 AM
dboff01's Avatar
Some pics of the Valor with new Epik puffy sticker.
dboff01 is offline
post #8019 of 20929 Old 07-03-2009, 05:55 AM
mcjasonb's Avatar
Liked: 113
nice!
Nearfield rig: Laptop -> JDS Labs ODAC -> Emotiva Mini-X -> Pioneer SP-BS22-LR & SW8-mk2Headphone rig: laptop -> JDS Labs ODAC -> Emotiva Mini-X speaker taps -> modded AKG Q701H.T.: PS3 - Yamaha RX-V2500 - Infinity Alpha 50's - Alpha center - Harmon Kardon HKB6 rears, Epik SentinelMy last.fm profile
mcjasonb is offline
post #8020 of 20929 Old 07-03-2009, 07:54 AM
cb450r's Avatar
Originally Posted by mcjasonb View Post
nice!
Ditto!
cb450r is offline
post #8021 of 20929 Old 07-03-2009, 08:16 AM
tdamocles's Avatar
Originally Posted by Hksvr4 View Post
The Dragon is smaller, weight, and goes to 20hz. I think the finish on the Dragon is better. Not a fan of the silver cone. The balanced and unbalanced inputs. If that matters to you. Relevative newly designed sub. More to date I guess. Those are the reason's why I picked the Dragon. Although the ED has more wattage at 1300w rms.
I'm sure with an EQ the eD would perform 20hz quite well. It has enough wattage to EQ it without a problem.
tdamocles is offline
post #8022 of 20929 Old 07-03-2009, 08:54 AM
Beautiful
post #8023 of 20929 Old 07-03-2009, 12:51 PM
mcjasonb's Avatar
Liked: 113
late last night i changed the layout of my whole room to make things more symmetrical and OMG the difference overall was very drastic. each speaker is now the same exact distance from the side walls and the wall behind them. sounds so much better, imaging has greatly improved, frequency response is much smoother now. my sub just happens to now be in a 1/3rd increment from the left side wall, i read that it would make a difference and it definitely did. i had to turn the sub gain down a little bit, and frequency response of the sub was greatly improved. extends a hair deeper, rolls off a hair shallower initially and just overall is much smoother from one end to the other.
today i had the house to myself for a couple hours and did some very loud critical listening. demo'd a whole bunch of different music and everything sounded great. i cannot believe the slam this single Sentinel now has. i can really feel it in my chest now. it's pretty F'in sweet. i guess proper placement really is the key followed by some slight EQ and phase adjustment. i was thinking that i may need another but this thing is really impressive, i couldn't ask for anything more.
a few pics:
this is the sub and mains together. i have a slight problem at 110hz, not sure if there is something i can do about it or not, but i don't notice it while listening to anything. the sub itself has a natural house curve on it, but when mixed with the mains ends up being relatively flat.
mcjasonb is offline
post #8024 of 20929 Old 07-03-2009, 01:31 PM
Liked: 29
Now for some room treatments.
post #8025 of 20929 Old 07-03-2009, 01:34 PM
mcjasonb's Avatar
Liked: 113
yup, i'm looking into that now. that's on my list, right after i find a job.
mcjasonb is offline
post #8026 of 20929 Old 07-03-2009, 01:51 PM
Gov
Gov's Avatar
Quoted: 118 Post(s)
Liked: 184
That Sentinel would like real nice with the new "Epik" logo on it
Main HT Room: Panny TC-P65VT60 (calibrated by Chad B), Denon AVR-4311, Comcast X1 DVR, Apple TV3, Sony BDP-S5100, Speakers: Ascend Acoustics Sierra Towers, Sierra Horizon and HTM-200SE, Dual Power Sound Audio XV15 Subwoofers
Basement HT Room: Panny TC-P58V10 (Black Level Restored!), Denon AVR-E300, Comcast X1 STB, Sony BDP-S590, Speakers: Ascend Acoustics CBM-170SE (L/R), Ascend Acoustics CMT-340SE-C, Wave Crest HVL-1 (Surr) and Dual Power Sound Audio XV15 Subwoofers
Gov is offline
post #8027 of 20929 Old 07-03-2009, 02:16 PM
mcjasonb's Avatar
Liked: 113
it might. you got one for me?
mcjasonb is offline
post #8028 of 20929 Old 07-03-2009, 03:32 PM
LilGator's Avatar
Just curious, but why is your sub toed in to the listening position?
LilGator is offline
post #8029 of 20929 Old 07-03-2009, 05:00 PM
fab5valentine's Avatar
Good News: I sold my old sub just now..
Bad News: I'm subless this weekend
Good News: I'm ordering an Epik in 5 minutes.
-fab5
-fab5
Bass, an obsession or addiction?
fab5valentine is offline
post #8030 of 20929 Old 07-03-2009, 05:15 PM
mcjasonb's Avatar
Liked: 113
just is, no reason.
mcjasonb is offline
post #8031 of 20929 Old 07-03-2009, 05:20 PM
jhuynh107's Avatar
-fab5
What sub did you sell and what Epik sub did you purchase?
jhuynh107 is offline
post #8032 of 20929 Old 07-03-2009, 05:47 PM
Sold: SVS PB12+/2 - Sold, I'll miss her..
Ordered: Epik Phoenix, 1st part of a dual set-up.. It would be very nice to have good output from one but 10K CU ft is a lot to ask, but another will be down the road.. SQ I'm looking forward too as well..
-fab5
-fab5
post #8033 of 20929 Old 07-03-2009, 06:20 PM
Ron Temple's Avatar
Quoted: 163 Post(s)
Liked: 133
-fab5
PPP on your part. Should have ordered the Phoenix and sold the +2 when it arrived.
I don't lurk as much as I used to and I NEVER listen. Comes from being old and cynical.
Ron Temple is offline
post #8034 of 20929 Old 07-03-2009, 08:25 PM
Muzikal-JRNE's Avatar
Try adjusting your main speaker positions so that the distances (of the speaker driver(s) that reproduce the 110Hz frequency) from the rear wall, side wall, and floor are not the same. It is a lesser known (but common) null effect that typically occurs in the 80 to 160Hz frequency range.
Cheers, Joe
Muzikal-JRNE is offline
post #8035 of 20929 Old 07-04-2009, 07:18 AM
theelviscerator's Avatar
Alrighty then...Its been two weeks since I ordered a dragon....should ship next week I hope..
Do you guys think once my MFW is working again they would work together very well?
One ported sub for LF, and the dragon for mid bass slam?
I have a 2200CF room fairly small.
I am no longer able to watch a movie. I am monitoring a video display with regards to chroma, brightness, contrast and correct pulldown.
theelviscerator is offline
post #8036 of 20929 Old 07-04-2009, 07:38 AM
mcjasonb's Avatar
Liked: 113
Cheers, Joe
so you're saying don't have them both symmetrical from the walls? i figured having them symmetrical would help keep the frequency response smoother for both individual speakers.
mcjasonb is offline
post #8037 of 20929 Old 07-04-2009, 07:44 AM
Fins^'s Avatar
From the link below:
"For the best soundstage balance the speakers should be equi-distant from the side walls and be a different distance from the rear walls. George Cardas has postulated on a formula for these distances."
http://www.audioholics.com/tweaks/sp...lacement-guide
Fins^ is offline
post #8038 of 20929 Old 07-04-2009, 07:45 AM
mcjasonb's Avatar
Liked: 113
interesting. i'll give that a read.
just read it and i am a bit confused. does he mean that they should not be the same distance from the back wall as they are to the side wall or does he mean that each main should be a different distance from the back wall? i find it hard to believe that each main should be a different distance from the back wall. so maybe i misunderstood.
i have each main 32 inches from each side wall and the back of the speakers are each 8.5" from the back wall. they are 6.5 feet apart from each other (measured from the inside most part of each speaker). if anything i'm going to guess that null is caused by the 8.5" distance from the back wall.
mcjasonb is offline
post #8039 of 20929 Old 07-04-2009, 08:00 AM
diff then the side wall distance...but the same for the mains.....
in other words say....two feet from the side, and 2.5 ft from the back wall...
post #8040 of 20929 Old 07-04-2009, 09:39 AM
mcjasonb's Avatar
Liked: 113
well then, i am already following that rule. my mains are each 32" from the side wall and then 8.5" from the back wall. i'm guessing i should try moving them farther from the back wall.
anyway.... we're getting off topic here.
mcjasonb is offline
Subwoofers , Epik Legend Subwoofer
