Official Epik Subwoofer Thread - Page 275 - AVS Forum | Home Theater Discussions And Reviews
 53Likes
post #8221 of 20921 Old 07-15-2009, 10:51 AM
Snowmanick's Avatar
Quoted: 299 Post(s)
Liked: 418
I use the Soundblaster Live external, my radio shack SPL meter on a tripod and connect through my AVR's front ext. audio jack. I have never used an external media disc with REW as I didn't find a need. REW has a test tone generator and can run full sweeps in seconds. Additionally, with an SMS-1 or BFD it has a filter generator to wither tell you exactly what freq, what attenuation level and what Q to put the filters at, which takes a lot of guesswork out of it. You can sill finetune and tweak but it gets you very close pretty quickly.
As for the null, I am not a big fan of boosting freq's as it eats headroom to fight your room, placement of yourself and/or sub can be the most effective solution (or multiple subs, room treatment, etc, but you can move your sub for free).
The shack's guides are pretty thorough and if you follow them can take you through the process. I found it took me a couple hours the first time to figure out how to set everything up, create calibration files for my sound card and SPL meter, and figure out how/what I was doing. After that it is much quicker.
Selling my Def Tech BP80xx series speakers
http://www.avsforum.com/forum/209-au...-speakers.html
And a like new Rega Exact cartridge
http://www.avsforum.com/forum/209-au...condition.html
Snowmanick is offline
post #8222 of 20921 Old 07-15-2009, 10:58 AM
fab5valentine's Avatar
Q? After calibrating the SC do you run calibration for your RS meter or do you enter the RS meter calibration file instead..
-fab
-fab5
Bass, an obsession or addiction?
fab5valentine is offline
post #8223 of 20921 Old 07-15-2009, 11:29 AM
mcjasonb's Avatar
Liked: 113
i just saw all the talk about the eQ.2. i have one on my Epik Sentinel and it did the trick. i used REW to run sweeps, and dialed in the eQ.2 rather quickly. i guess my room is cooperating in the sub bass area as i only had to use one of the two bands. i had to do a narrow, medium size cut at around 53-54hz. using only the one band i was lucky enough to get a flat response (+/- 4db) from 17hz up to 80hz. i could have it flatter if i wanted but i have a natural house curve going on that i am very happy with.
my advice for anybody looking to possibly get a sub eq is to do some testing with REW to see if you need an EQ and how many bands you will need to get the desired response. if you only have 1 or 2 trouble spots then the eQ.2 is the easiest way to go.
this may sound strange but i'm old school. i'd much rather do the tuning on my own instead of letting Audessy or something similar do the tuning for me. this way i have control over everything, and i know exactly what is going on. i haven't researched Audessy that extensively but if it boosts anywhere then that is a no no. EQ IMO should only be used to tame peaks.
also, i do plan to get a second Sentinel eventually which will be placed next to my other front speaker and i feel that the eQ.2 will still be plenty of eq. it has two summed outputs so it will work easily with duals.
Nearfield rig: Laptop -> JDS Labs ODAC -> Emotiva Mini-X -> Pioneer SP-BS22-LR & SW8-mk2Headphone rig: laptop -> JDS Labs ODAC -> Emotiva Mini-X speaker taps -> modded AKG Q701H.T.: PS3 - Yamaha RX-V2500 - Infinity Alpha 50's - Alpha center - Harmon Kardon HKB6 rears, Epik SentinelMy last.fm profile
mcjasonb is offline
post #8224 of 20921 Old 07-15-2009, 02:25 PM
Snowmanick's Avatar
Quoted: 299 Post(s)
Liked: 418
-fab
I am probably going to describe this incorrectly, but "Q" is the "Quality Factor" , or "sharpness" in the width of the cut, it can be a narrow frequency band you are directing the subwoofer to affect or a large one. The easiest way I visualize this is if you are pulling an elastic string that is attached at two ends. If you just pull it down the whole string will be affected (bends down to your fingers from both ends). Now if you were to place two supports under the string at a certain area and then pull the string it should still be reasonably unchaged past the supports (tension not withstanding) but be pulled down to your fingers inside of hose supports. You can widen or narrow or narrow the distance between those supports and the string will be bent over a wider or narrower length. The distance between the supports would be the "Q", the area that is being directly affected.
As for the SPL calibration, I have a Rat Shack meter so I found the calibration file for my model, saved it on my laptop and then loaded it through REW.
post #8225 of 20921 Old 07-15-2009, 04:16 PM
Ah.... Thanks!
-fab5
post #8226 of 20921 Old 07-16-2009, 09:25 AM
GPowered's Avatar
GPowered is offline
post #8227 of 20921 Old 07-16-2009, 10:21 AM
DoubleATheater's Avatar
I was just wondering if you had sold it yet.
DoubleATheater is offline
post #8228 of 20921 Old 07-16-2009, 08:35 PM
GPowered's Avatar
Nope, decided to give it some addtional thought over the last couple weeks. I am really going to miss it but it's best that I sell it to someone that is more into the HT scene right now. I am going more in the direction of 2-channel and music - much easier to play with with small children around. Still love my my surround setup though and I have a REL sub so I won't be subless. The REL is much more kid friendly lol.
GPowered is offline
post #8229 of 20921 Old 07-17-2009, 07:16 AM
Gov
Gov's Avatar
Quoted: 118 Post(s)
Liked: 184
Now come on Kids don't stay young forever Soon you will be thinking HT again and will need to get another Phoenix if you sell it, lol!
Main HT Room: Panny TC-P65VT60 (calibrated by Chad B), Denon AVR-4311, Comcast X1 DVR, Apple TV3, Sony BDP-S5100, Speakers: Ascend Acoustics Sierra Towers, Sierra Horizon and HTM-200SE, Dual Power Sound Audio XV15 Subwoofers
Basement HT Room: Panny TC-P58V10 (Black Level Restored!), Denon AVR-E300, Comcast X1 STB, Sony BDP-S590, Speakers: Ascend Acoustics CBM-170SE (L/R), Ascend Acoustics CMT-340SE-C, Wave Crest HVL-1 (Surr) and Dual Power Sound Audio XV15 Subwoofers
Gov is offline
post #8230 of 20921 Old 07-17-2009, 08:09 AM
DoingOK's Avatar
For those that are curious what a Vanquish looks like compared to a Sentinel.....here ya go. I was doing a little A-B comparison for the hell of it. Uh......big difference in output. Real big difference as expected. Just got the Sentinel an hour ago (FedEx guy hates me) so I'm just beginning to test it out. Both have the same driver and amplifier so I just set the levels the same and swapped out XLR cables to test between them. Gonna play some other stuff now (Aja, Mark Knopfler, Ms. Krall, etc.)
DoingOK is offline
post #8231 of 20921 Old 07-17-2009, 08:38 AM
Hksvr4's Avatar
Quoted: 33 Post(s)
Liked: 37
^^That's a sweet set up.!!
Hksvr4 is offline
post #8232 of 20921 Old 07-17-2009, 10:06 AM
sketch2099's Avatar
DoingOK, it's awesome that you're doing AB comparisons, it's definitely worth it for people who are trying to determine where the differences are and how much of a difference there is between the two. like where is the sentinel's output greater? just lower end? is the higher mid bass comparable? how's the sound quality comparison when outputing the same volume? is the sealed design really noticably more "musical" than the ported sentinel?
and definitely a good looking set up you've got there
sketch2099 is offline
post #8233 of 20921 Old 07-17-2009, 10:20 AM
femi's Avatar
Quoted: 133 Post(s)
Liked: 151
I test my Dynasty with blu-ray of The Incredible Hulk (2008). WOW! The bass was amazingly LOUD and ACCURATE. There were several scenes that startled me. I thought my house was going to fall down.
I have a velodyne SPL12R which I purchase in 2001 and I love that sub to death but man the Dynasty is another level. I turn both sub on & watched The Incredible Hulk. Man I just couldn’t stop grinning from ear to ear. I am going to rewatch alot of my movies again with this beast.
(2)JTR Cap 4000---(6) Enclosures Seal SI HT-18's---Behringer iNUKE 6000DSP--- Behringer iNUKE 3000DSP---Denon AVR-4250CI---(5)Behringer Eurolive B215XL---(2)Klipsch SS-1 Surround---JVC RS500---Sony HW50es---VApex Fixed frame 135" 16:9---Oppo BDP-93---Toshiba HD DVD-XA2---Xbox 360---PS4---Darbee Darblet DVP-5000---Harmony 1100 remote
femi is offline
post #8234 of 20921 Old 07-17-2009, 06:31 PM
kaczmarczyk's Avatar
I'm still getting unsatisfactory bass with my Dynasty though it appears to beonly on HD audio movies now. DD and Pro Logic sound great but the bass is almost none existent on HD audio movies. I got to believe this must be a setting within my Denon 2309 receiver; however, I have searched to no avail on correcting this problem. Have any Epik owners experienced this problem? Anyone familiar with the 2309? I have also posted this question in the 2309 forum but I'm hoping someone here might have a quick setting fix for me here.
kaczmarczyk is offline
post #8235 of 20921 Old 07-17-2009, 06:38 PM
mcjasonb's Avatar
Liked: 113
whats it calibrated to? did you calibrate it to 75db (or higher) with a radio shack meter?
mcjasonb is offline
post #8236 of 20921 Old 07-17-2009, 06:55 PM
All speakers were calibrated to 75 before; however, I have rerun Audyssey several times since then following the Audyssey set up guide. Again, non HD Audio bass sounds awesome but HD Audio bass is poor so I'm thinking it's a setting within the AVR vs the speakers not being calibrated correctly.
post #8237 of 20921 Old 07-17-2009, 07:45 PM
mcjasonb's Avatar
Liked: 113
could it possibly be a setting in the blu-ray player?
mcjasonb is offline
post #8238 of 20921 Old 07-17-2009, 07:58 PM
Dreamy looking
post #8239 of 20921 Old 07-17-2009, 08:20 PM
Snowmanick's Avatar
Quoted: 299 Post(s)
Liked: 418
I'm thinking along the same lines. If you are using a PS3 there are a few setup steps you have to take to keep the player from automatically applying a limiting feature. I am completely blanking on what it called and no where near my PS3 at the moment, but I remember the default setting in the PS3 was auto and I had to manually change it to off.
post #8240 of 20921 Old 07-17-2009, 09:16 PM
My blu-ray is a Panasonic BD30K and I have been through the menu numerous of times and have searched that forum to no avail as well.
post #8241 of 20921 Old 07-17-2009, 09:49 PM
GPowered's Avatar
True, but it's quite a beast to have around to be inactive most of the time. It was far from a waste though - sometimes I have to experience something to determine whether it fits long term. Although this sub has endless amounts of headroom for HT - seriously I don't think it can bottom out in normal situations - it's kind of like .......... that was fun but now it's time to sell it and move on to something that i can get more use out of ... like a nice Integrated w/ a HT bypass for critical 2 channel listening.
I really hope one of you guys that was going to get one of the smaller subs due to budget is able grab my Phnx. That would make me happy. Price is just a few bucks over a Sentinel @ $850 + shipping. $875 w/ Paypal
GPowered is offline
post #8242 of 20921 Old 07-17-2009, 10:55 PM
Hksvr4's Avatar
Quoted: 33 Post(s)
Liked: 37
Turn the audessey off and set all speakers to 75db with the meter. Turn the gain up on the sub. Then turn it down to your liking. Wait...didn't we try this already?
Hksvr4 is offline
post #8243 of 20921 Old 07-18-2009, 06:17 AM
floridapoolboy's Avatar
Hey, nice sub, I've been wanting to upgrade! Would you consider driving it down to Ft Myers?
floridapoolboy is offline
post #8244 of 20921 Old 07-18-2009, 07:32 AM
mrjulius's Avatar
For my fellow Epik owners:
A bit off topic but since everyone here helped me choose the Dyanasty...
I have been on the fence regarding the Buttkicker's for awhile now. I have been reading everything that I could find. This week I bit the bullet and got the Buttkicker LFE kit.
Now I have the Dynasty smacking me in the face and a Buttkicker LFE kicking me in the well...you know.
Absolutely amazing setup. I thought that I would need two kickers but the one is more than I will ever need. I'm only running the amp (included in the kit) at or near the 10 O'clock position and that is all I can take. Any more and I would have to put up a set of ropes and have a licensed ride operator at the controls.
The usual online spots are all back ordered. One even called the company for me and was told that they are back ordered. I did find one place that had them in stock. I ordered it and I had it on my doorstep in 24 hours.
If anyone has been thinking about it...do it. I have played all of my reference material and I'm still grinning I have played music and HT material with the Dynasty on and kicker off, then kicker on. Fantastic match with the two running together. Neither one overpowers the other.
The opening scene of Top Gun when the jet takes off of the carrier. Holy Cow I was on that jet !
the combination of the Dynasty and the Buttkicker put me where I wanted to be. Can I say it...I'm done. No need for any more bass
I don't want to break any possible forum rules. The place that I got it was an "Audio" place on the web with a "Beach" theme. Cheapest price and shipping was $5. The box came in at 44 pounds for the kit. I checked the website this morning and they have 9 in stock. They even called my telephone to verify the order after I placed it online.
Again, thanks all for the help on the Dynasty purchase, maybe I helped someone that was on the Buttkicker fence.
Anyway, off to the basement to run the wire for a more permanent solution.
mrjulius
The Evil Plan = (Dynasty + Empire) / at 40 Hz !
mrjulius is offline
post #8245 of 20921 Old 07-18-2009, 07:50 AM
snookfisher's Avatar
GPower...check your private messages!!
snookfisher is offline
post #8246 of 20921 Old 07-18-2009, 10:31 AM
mcjasonb's Avatar
Liked: 113
i just watched Kung Fu Panda on blu-ray with my Sentinel at -8 from reference.
the movie had some pretty good, strong bass and the Sentinel shook the room with ease. there was a lot of low stuff and lots of higher stuff that had some REALLY nice impact. it's worth a watch even though it is a kids movie.
mcjasonb is offline
post #8247 of 20921 Old 07-18-2009, 10:35 AM
Ron Temple's Avatar
Quoted: 163 Post(s)
Liked: 133
It sounds like your receiver isn't applying the 10-15db LFE boost. You didn't specify if you are connected via HDMI or analog. It usually applies only to analog. Some receivers have a separate LFE setting where you can set it to +10 or +15db. This boost is applied automaticly in through optical or coax, but evidently it's not doing it for your connection method. If yours doesn't have one, then you'll have to boost the sub gain and recablibrate your other sources. I'm using an Oppo BD 83 via analog and my pre/pro doesn't offer BM over analog, so I have to boost the sub gain, up the sub channel trim to +10 and still boost the player's BM to equal the same bass output as digital sources. It's a PITA, but that's what it is. Not the sub's fault.
I don't lurk as much as I used to and I NEVER listen. Comes from being old and cynical.
Ron Temple is offline
post #8248 of 20921 Old 07-18-2009, 09:36 PM
GPowered's Avatar
sold!!!
GPowered is offline
post #8249 of 20921 Old 07-19-2009, 05:39 AM
sold!!!
Congrats,
What are you thinking of replacing it with??
post #8250 of 20921 Old 07-19-2009, 07:08 AM
sold!!!
Nice job, now I won't have to drive up to Sarasota! The search goes on.........
Subwoofers , Epik Legend Subwoofer
