Official Epik Subwoofer Thread - Page 682 - AVS Forum | Home Theater Discussions And Reviews
 58Likes
post #20431 of 20939 Old 11-01-2014, 05:53 PM
dannybenz's Avatar
Quoted: 13 Post(s)
Originally Posted by Dreamliner View Post
I'm pretty sure Epik Empire #1 's Amp died...
Amp powers up with signal but there is no sound. It's not the source. I took the amp off, anyone see anything wrong?
Full resolution pics of amp. download for zoom, etc:
Spoiler!
If it is dead, I'll need an amp. I was wondering if the Behringer NU3000DSP has enough juice to run 2 Epik Empire's? I hardly have the volume up at all on the Emires now:
Audyssey Calibrated Level:
Minimum:
Questions:
1) Is my amp dead?
2) Troubleshooting ideas?
3) Epik Empire speaker impedance at amp? (4 Ohm)? (I'm assuming the drivers are 8 Ohm wired in Parallel)?
4) Thoughs on Behringer NU3000DSP?
5) Can the Behringer NU3000DSP run 2 Epik Empires? (Behringer says 2x880w @ 4 Ohm)
6) I know about the Behringer NU6000DSP, but based on my volume level, I wonder if it it necessary at all....?
7) Subs are on opposite sides of the room about 50ft each from the rack, okay to run speaker level? (I have 12GA flat speaker wire "lamp cord")
8) What should I do at the back of the subwoofer in place of the plate amp? (It seems sealed as I can't see into the cabinet)
Suggestions appreciated!
I removed the plate amp, cut the wires leading to the drivers and then removed all of the pcb's. I soldered the wire from the drivers to some 12awg wire and poked it through one of the holes on the metal plate, then put the naked plate back on the box. Looks cleaner this way.
I think I remember a while back, one of the Epik Empire owners used an inuke3000dsp to drive his pair without problems. I was considering that amp too as it was a helluva deal @ $170. But it looks like youre going to use an inuke 6k. Please report back as to how it performs. When I replaced my fried plate amps with an EP4k, there was a noticeable improvement in slam. Now I'm using a Crown XLS2000 because it runs much quieter.
dannybenz is offline
post #20432 of 20939 Old 11-01-2014, 06:03 PM
dannybenz's Avatar
Quoted: 13 Post(s)
Originally Posted by KidHorn View Post
There's nothing you can to insure your amps won't be damaged. All you can do is determine if they will definitely be damaged.
Thanks. I thought that maybe something was wrong because I saw a bright and LOUD spark when I first hooked up my Empires to an EP4000 and drove it loud. I wasnt sure whether the spark came from the subs or the amp because they are very close to each other. I checked the connections, and there didnt appear to be any shorts. But that was just a one time thing and the Behringer seemed to drive them fine after that although the fans were loud. I replaced the behringer with a crown and i just wanted to avoid that spark upon initial hookup. The Crown is working great. No sparks and no fan noise!
post #20433 of 20939 Old 11-01-2014, 06:08 PM
Dreamliner's Avatar
Quoted: 819 Post(s)
Liked: 312
I was thinking of having blank plates machined with banana plugs mounted. I wonder if the forum would be interested in this. I'm not sure how much it will cost but I'd imagine it'd be around $50 with the banana/speaker terminal. This would look the best. Some of the earlier Epik Empires do not have a MDF box for the amp and is open to the cabinet.
Everything seems to be alright with the 6000DSP. I'm volume matched with the plate amp setting shown above at about 1/3 on the gain knob (Audyssey volume calibration), I have an actual calibration mic on the way and will be playing a bit with REW to figure out any EQ settings.
The only issue I have is there is a pop/thump when killing power via a smart strip. Right now I am turning it off manually before system power down. It looks like I'll have to wire a relay into the power switch inside so I can trigger the power off with the receiver and avoid the thump.
The fan noise doesn't bother me a bit on the 6000DSP. Its honestly not that loud. I have my equipment in a different room and have other cooling fans in there, so I didn't really notice it. (I would never do the fan mod. Most people that do ignore the fact that their new 'quiet' fans are not pushing anywhere near the amount of air the stock fans do).
How do you power on/off the Crown, any thump? (you can test what a smart-strip or power sequencer would be like by simply unplugging it).
Dreamliner is online now
post #20434 of 20939 Old 11-01-2014, 06:20 PM
dannybenz's Avatar
Quoted: 13 Post(s)
I run a trigger wire from my preamp to my Belkin PF60. The Crown is plugged into one of the high current outlets on the belkin. I set it so that only that outlet is switched when it senses current in the trigger connection from the pre. So my pre triggers the Belkin to power up the crown. No thump.
I honestly thought this surge protector was overpriced and useless, but it is putting itself to good use.
Sent from my SM-P600 using Tapatalk
post #20435 of 20939 Old 11-01-2014, 06:23 PM
dannybenz's Avatar
Quoted: 13 Post(s)
Oh yeah and the belkin is also set to delay powering up the crown til everything else is on.
post #20436 of 20939 Old 11-01-2014, 06:29 PM
Dreamliner's Avatar
Quoted: 819 Post(s)
Liked: 312
Yeah. My thump is on the way down. It does it without anything connected to the inputs. Oh well. Nothing a relay can't solve. Plus it gets me trigger control from the receiver.
post #20437 of 20939 Old 11-01-2014, 06:40 PM
dannybenz's Avatar
Quoted: 13 Post(s)
Yeah well its good to hear about another Epik owner saving his subs. Its a shame that these amps plate amps were crap quality because the subs themselves sound great. There isn't much out there that can put out the mid bass spl of DUAL empires for under $1500ish. For me it was either take a risk and spend a couple hundred and try to salvage the situation with a pro amp or plunk down 3k for a triax or SubM. Before my amps died, I was always worried about when the plate amps would die. Now it feels good to crank it while having the peace of mind in knowing that the beefy pro amp wont crap out.
post #20438 of 20939 Old 11-01-2014, 08:59 PM
Dreamliner's Avatar
Quoted: 819 Post(s)
Liked: 312
That's exactly right. With 2 Epik Empires + the new amplifier total cost is $1850. I don't think I'd be able to buy a product that would be better for that money. 4 15" drivers, 2 enclosures and an amplifier is a lot for $1850. Maybe if I bought some Dayton Ultimax's and made my own boxes, but the Epik Enclosures look really nice.
post #20439 of 20939 Old 11-02-2014, 08:12 AM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4783
That spark would have freaked me out especially not knowing where it came from exactly! Are you bridging the Crown? No dsp unit at all? Or using Audyssey or something?
lovinthehd is offline
post #20440 of 20939 Old 11-02-2014, 08:17 AM
dannybenz's Avatar
Quoted: 13 Post(s)
The spark freaked me out. But that was with the Behringer and it never happened after that one time. The Crown is driving one sub from each channel, so no bridging here. I have measured the response with a cross spectrum umik, and I dont think I need a dsp that bad. There is a null, but the peaks are pretty much non existent. Not much that a dsp can fix. I have a minidsp, but its single ended. Maybe I'll try a bfd for kicks.
post #20441 of 20939 Old 11-02-2014, 10:30 AM
lovinthehd's Avatar
Liked: 4783
Thanks, was curious since there was boost in the original amp. What's a single ended minidsp?
post #20442 of 20939 Old 11-02-2014, 10:35 AM
dannybenz's Avatar
Quoted: 13 Post(s)
http://www.minidsp.com/products/mini...ox/minidsp-2x4
post #20443 of 20939 Old 11-02-2014, 10:42 AM
lovinthehd's Avatar
Liked: 4783
What's single ended about it? I'm not familiar with the term in this sense?
post #20444 of 20939 Old 11-02-2014, 10:45 AM
dannybenz's Avatar
Quoted: 13 Post(s)
Single ended = Rca connectors. It doesnt put out enough voltage to drive a pro amp to max output.
post #20445 of 20939 Old 11-02-2014, 11:01 AM
lovinthehd's Avatar
Liked: 4783
Thanks, had not heard of rca connectors termed that way (only in amps before), so the .9v isn't sufficient for the Crown's 1.4v for full output....forgot about that output voltage limitation with the rca version....err, single ended version .
post #20446 of 20939 Old 11-17-2014, 01:39 PM
fearfactoryman's Avatar
Wow has this thread grown since I last looked at it. The plate amp for my Epik Legend crapped out on me & my local electronics shop was unable to get it working again through over a month of trying to repair it. I am already on the hunt to buy a new sub, but am looking to find a plate amp that might work in the legend so that I can revive it & move it to another room. I know many people are just drilling a hole & using an iNuke amp to power it...but I was hoping someone had found a plate amp that was similar enough in size that it would work.
fearfactoryman is offline
post #20447 of 20939 Old 11-20-2014, 05:57 PM
the_phew's Avatar
What is the consensus on Dayton's 1kW plate amp? Suitable replacement for blown Empire plate amps? Will it fit? If so, how much cutting?
http://www.parts-express.com/dayton-...ifier--300-809
I sold my Paradigm Sub 1, bought two Epik Empires, then had a baby so I never got to turn them on. I go to check on them last week, and they won't even turn on. So I need replacement amps, and I think I have it narrowed down to two Daytons or two Crown XLS1000s. The Crowns are cheaper and probably more power, but I don't think they have auto-on and obviously they take up more space.
the_phew is offline
post #20448 of 20939 Old 11-21-2014, 01:56 AM
lovinthehd's Avatar
Liked: 4783
You have two new Empires that were both bad without ever being plugged in? Odds on that seem pretty long. How did you analyze the amps being at fault? The Crowns do not have a trigger or auto on, but my XLS1500s work well with a smart strip as slaves, using the avr as master. The XLS1500 and up has a significantly better SNR rating btw.
post #20449 of 20939 Old 11-23-2014, 06:29 PM
the_phew's Avatar
They were plugged in and auto-on, but I was using Audyssey LFC at the max setting while listening at lowish volumes, so they were doing basically nothing (which is why I never noticed them dying). Now neither unit will even switch on. They could have been dead for the past 6 months, I don't know. The fuses are fine, and I did check that the outlets/breaker are fine. Given the fact that the last wave of Epik plate amps seemed to be garbage, I think it's safe to assume my plate amps are dead.
Your comment about the SNR on the higher-end Crowns is appreciated, I hadn't realized that. I can't do the smart strip trick, because my AVR is 15 and 35 feet away from my subs, respectively. Nor can I trigger, because I only have sub cables running from the AVR to the subs (no trigger wire). Although I suspect a Class D amp has a low enough idle power consumption that leaving it on all day isn't a big deal.
Anyone try the Dayton plate amp?
the_phew is offline
post #20450 of 20939 Old 11-23-2014, 06:44 PM
lovinthehd's Avatar
Liked: 4783
Bit different than never having turned them on....maybe never having turned them up I turn my Empire off with my smart strip but leave two other wireless subs on all the time (no auto on/off)....never measured the penalty for leaving them on but I'd agree its probably not a lot of juice.
post #20451 of 20939 Old 11-23-2014, 09:03 PM
derrickdj1's Avatar
Quoted: 995 Post(s)
Liked: 733
I use to leave my legend on all the time. I went out of town and turned if off for the week. When I came back, the Legend was DOA.
derrickdj1 is offline
post #20452 of 20939 Old 12-10-2014, 09:23 AM
sealteamz6's Avatar
Does something like an Auralex Gramma Amplifier Acoustic Isolation Riser actually make any difference for dual opposing subs like the epik legends? I found a deal on them and was considering it in the case it helps but the cabinets barely vibrate at high volume levels and at low levels not at all.
sealteamz6 is offline
post #20453 of 20939 Old 12-10-2014, 09:33 AM
lovinthehd's Avatar
Liked: 4783
I've subscribed to this thread for a very long time and cannot think of anyone who has mentioned an foam/board thingy like the Auralex overpriced piece of foam/board thingy helping anything. The only times they seem to have an effect I've seen are on poorly supported wood floors and for other subs from what I can tell. These dual opposed design cabinets are so inert I cannot imagine it being of any help. Make one from similar materials and see for yourself if it makes any difference.....YMMV
post #20454 of 20939 Old 12-10-2014, 09:53 AM
sealteamz6's Avatar
That's what I was thinking but I figured I would ask just in case haha.
post #20455 of 20939 Old 12-17-2014, 12:54 PM
Vicious1's Avatar
I need some emergency help. Friend bought my Epik Conquest a while back, and today he calls me and says fuses are blowing immediately on plugging it in. I'm assuming the amp is likely blown. If so, what is a good replacement amp for it and how hard is it to replace the existing amp?
Vicious1 is offline
post #20456 of 20939 Old 12-17-2014, 12:54 PM
Vicious1's Avatar
Vicious1 is offline
post #20457 of 20939 Old 12-17-2014, 02:56 PM
mwolfe38's Avatar
My conquest amplifier died a few years back and I had it just sitting around in my garage for about a year, then I found out about this:
http://www.parts-express.com/bash-50...w-rms--300-752
It works great again. I haven't done much benchmarking as I did when I first got my conquest but it seems to do the job. It's a direct replacement, the cutout is the same size so it's incredibly easy to replace with this one. Just remove the current amplifier, which just means unscrew it, then pull it off the box (it may have a bit of glue on it as well so you have to wedge it off with a wide screwdriver or similar), then once you have the old one off, disconnect the wires and connect the new one, plug the speaker wires in in, and you're good to go. I've seen the amp for $200 from time to time but even at $250 it's worth it. Parts express has been having lots of $20 off type coupons lately so you might google around for a quick discount code.
Vicious1 likes this.
mwolfe38 is offline
post #20458 of 20939 Old 12-17-2014, 04:24 PM
Vicious1's Avatar
Thanks for the reply MWolfe38, I'll forward him the info.
Vicious1 is offline
post #20459 of 20939 Old 12-23-2014, 08:50 PM
Dre325's Avatar
Quoted: 74 Post(s)
Has anyone found a similar plug and play replacement amp for the Legend? I don't even mind if I have to modify the opening a bit as making it bigger would be easy.
with all these failures being reported, it seems like only a matter of time for legend owners!
Dre325 is offline
post #20460 of 20939 Old 12-24-2014, 06:46 AM
Coopaw's Avatar
I replaced mine with a Bash 500 and it has been working fine. You do have to modify the hole however.
Coopaw is offline
Subwoofers , Epik Legend Subwoofer
