Official Epik Subwoofer Thread - Page 691 - AVS Forum | Home Theater Discussions And Reviews
 52Likes
post #20701 of 20897 Old 03-10-2016, 07:05 PM
nickwin's Avatar
Quoted: 12 Post(s)
I'm looking for a second Empire, if anyone is thinking about getting rid of theres with a working amp shoot me a PM.
nickwin is offline
post #20702 of 20897 Old 03-20-2016, 06:47 PM
nickwin's Avatar
Quoted: 12 Post(s)
Can anyone comment on the later (GPM-500 based) empire amp? Did these sound the same as the amp that shipped with early Empires? Any more or less prone to failure?
nickwin is offline
post #20703 of 20897 Old 03-20-2016, 07:27 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4778
Believe that is the replacement amp I got when my original failed. I didn't notice any significant difference but I didn't particularly try and find any either....running fine ever since replacement for 4 years now at the end of this month.
lovinthehd is offline
post #20704 of 20897 Old 03-21-2016, 07:58 AM
nickwin's Avatar
Quoted: 12 Post(s)
Cool, thanks for sharing. Glad to hear its still going strong. I might end up with one of each in my system and just wanted to make sure they would play nice together. I assume they are tuned the same but you never know with the ways things were going towards the end at Epik.
I did notice that the amp pictured on Data-bass.com is the newer one and those measurements look great to me.
Anyone else?
nickwin is offline
post #20705 of 20897 Old 03-26-2016, 01:52 PM
Liked: 1
I started playing while I weigh my options. Do you think I have a shot of replacing the 4 capacitors making the amp functional again or do you think the burn killed any chance? The amp always powered on...no sound was produced.
ID:	1339762   Click image for larger version
ID:	1339770   Click image for larger version
ID:	1339778   Click image for larger version
russ0230 is offline
post #20706 of 20897 Old 03-26-2016, 02:06 PM
sandbagger's Avatar
Quoted: 17 Post(s)
Liked: 32
Its always worth a try.
Clean the board real good with alcohol. see whats left of the traces, hope there is enough left to rewire the traces with wire. you might have to ask someone to take a pic of the board in that area to get the traces right. Then replace the caps.
Kevin
Motor City Custom Audio
Bringing you Custom subwoofer kits, with flames if you want
sandbagger is offline
post #20707 of 20897 Old 03-26-2016, 02:29 PM
Liked: 1
Ugh, I don't know if I feel like rewiring (could be the beer talking ). It sounds like more work than its worth. Regardless, I might give it a day to think about...I don't want to burn myself on the soldering iron tonight.
I doubt I have those same capacitors anyway. I've only ever tried replacing capacitors once and that was on my Samsung TV. If the ones I have are smaller are they going to pop instantly?
russ0230 is offline
post #20708 of 20897 Old 03-26-2016, 02:51 PM
sandbagger's Avatar
Quoted: 17 Post(s)
Liked: 32
the size needs to be the same, I sometimes up the voltage rating 1 step
Kevin
post #20709 of 20897 Old 03-26-2016, 05:25 PM
sabotage's Avatar
So after 4 years, the amp on my Legend finally went out.
I've got a Behringer iNuke NU-6000DSP in my cart, but was wondering how much of a difference the DSP makes and is it worth the $50 difference between the NU4-6000 and the 6000DSP. FWIW, I'll be plugging into the subout of a Pioneer SC-1522K.
I've also got 3 AuraSound AST24B trandsucers running off a Dayton SPA 250 that I'll probably swap out for the 2nd channel on the iNuke.
sabotage is offline
post #20710 of 20897 Old 03-26-2016, 07:50 PM
derrickdj1's Avatar
Quoted: 956 Post(s)
Liked: 679
Get the DSP version. It's very valuable in shaping the FR.
sabotage likes this.
derrickdj1 is offline
post #20711 of 20897 Old 03-27-2016, 08:34 AM
Dreamliner's Avatar
Quoted: 624 Post(s)
Liked: 184
2 votes for the 6000DSP. Its what I have and I really like it. Buy it from Sweetwater. Call them on the phone and ask for a discount and pickup the Neutrik connectors you'll need and perhaps the 1/4 to RCA if you don't have it.
Also, be sure to register to extend the warranty with Behringer. 3-year is NOT automatic.
Dreamliner is online now
post #20712 of 20897 Old 03-27-2016, 08:55 AM
sabotage's Avatar
Thanks gents, DSP it is.
I've never actually called in for a discount, do I outright ask if that's the best price they can do? What kind of discount can I expect?
sabotage is offline
post #20713 of 20897 Old 03-27-2016, 08:58 AM
Dreamliner's Avatar
Quoted: 624 Post(s)
Liked: 184
I just called, told them the part numbers I needed and asked for the best they can do. It's not a ton (not a lot of margin to begin with), but its probably around 10%.
sabotage and derrickdj1 like this.
post #20714 of 20897 Old 04-04-2016, 08:01 AM
sabotage's Avatar
Thanks all, amp came in Friday. If anyone's interested, here's photos of my install.
I ended up using the following
GLS Audio Speaker Plug Twist Lock Male SpeakOn connector
http://www.amazon.com/GLS-Audio-Spea.../dp/B00LW8VLRU
GLS Audio Speaker Jack Twist Lock 4 Pole Round Female SpeakOn connector
http://www.amazon.com/GLS-Audio-Spea.../dp/B00YQJYEJO
Milwaukee Model # 49-56-9662 Hole Dozer Hole Saw with Arbor
http://www.homedepot.com/p/Milwaukee...9662/202327732
I'm running it in Bi-Amp 1 mode with all filters disabled. The 2nd channel is now going to a pair of AuraSound AST-2B-4 tactile transducers that I have installed in the couch.
Dre325 and skypop like this.
sabotage is offline
post #20715 of 20897 Old 04-08-2016, 11:51 AM
BHarris's Avatar
Hello!
Total newbie here. How do I go about connecting the speakon out to my receiver? (Trying to revive my legend w/inuke1000)
BHarris is offline
post #20716 of 20897 Old 04-08-2016, 11:38 PM
Dreamliner's Avatar
Quoted: 624 Post(s)
Liked: 184
Originally Posted by BHarris View Post
Hello!
This post from me tells you everything you have to do. It is pretty straight forward.
post #20717 of 20897 Old 04-09-2016, 08:58 AM
BHarris's Avatar
This post from me tells you everything you have to do. It is pretty straight forward.[/quote]
Thank you. I did read the post once. However, I should have paid a little more attention as to what was being said.
BHarris is offline
post #20718 of 20897 Old 04-13-2016, 10:34 AM
Molon_Labe's Avatar
Quoted: 2104 Post(s)
Liked: 2186
I joined the Epik family today. I bought two of them to use in my living room for $350 plus diesel to go pick them up. I figure I will be in them about $400 which is exactly what I was looking for in my living room.
Molon_Labe is offline
post #20719 of 20897 Old 04-13-2016, 10:54 AM
skypop's Avatar
Quoted: 209 Post(s)
Liked: 117
Which ones did you get?
2 Channel: Fi 2A3 mono's,Hovland HP100 W/MM Phono Stage,Technics SP10MK2/SME/Benz,Medallion Cabinets With Fostex 206EN Drivers,Peerless Subs....HT:126" Seymour AT Screen,JBL Studio 590's LCR,JBL 8340a Surrounds,JBL HT5 Fr Heights, and JBL SCS8 Rear Heights,JBL Studio 580's Back Surrounds,2 Epik Empire Subs,HSU Midbass Sub,Marantz 7702MK2,Outlaw 7125,Marantz Ma500's,Panasonic UB900,Toshiba HD35,JVC RS400. Black Velvet.
skypop is offline
post #20720 of 20897 Old 04-13-2016, 10:59 AM
Molon_Labe's Avatar
Liked: 2186
I dunno, they are Epik Empires. I thought they were all the same.
post #20721 of 20897 Old 04-13-2016, 11:09 AM
skypop's Avatar
Quoted: 209 Post(s)
Liked: 117
Epik made more than the Empire. They made the Legend and the Conquest and I believe one other that was a Cylinder Type Sub also. Congrats, I have 2 Empires that I use in my HT and they sound great! If my amp ever goes than I'll just get an outboard amp for them. Maybe I have the better amps because I did have to replace them once or twice while Epik was still in business. Either way that's a great deal you got there.
skypop is offline
post #20722 of 20897 Old 04-14-2016, 06:51 AM
Molon_Labe's Avatar
Liked: 2186
Sorry about that confusion. I thought this was an Epik Legend thread, not realizing it was thread for all Epik products. That is why I couldn't figure out what you meant when you asked which kind they were. I remember the Conquest. That was the beast for a number of years back when it was all about Epik, SVS, and eD.
skypop likes this.
post #20723 of 20897 Old 04-14-2016, 08:02 AM
basshead81's Avatar
Quoted: 225 Post(s)
Liked: 6228
^Epik legend is a 12" dual opposed 300 watt sub, The Epik empire is a dual opposed 15" 600 watt sub.
basshead81 is offline
post #20724 of 20897 Old 04-14-2016, 08:06 AM
Molon_Labe's Avatar
Liked: 2186
I got the 12" Legend. I know it won't have a lot of extension but it will be a nice addition to my living room system.
post #20725 of 20897 Old 04-14-2016, 08:12 AM
skypop's Avatar
Quoted: 209 Post(s)
Liked: 117
The Legend is a good sub,perfect for smaller rooms or living rooms where you don't want a big subwoofer taking up Alot of space.
Molon_Labe likes this.
skypop is offline
post #20726 of 20897 Old 04-14-2016, 08:15 AM
Molon_Labe's Avatar
Liked: 2186
Agreed and the primary reason I jumped on these in the for sale forum. If I need a bass fix, the theater room upstairs has two Deep Sea Sound 24" Marianas.
skypop likes this.
post #20727 of 20897 Old 04-14-2016, 05:34 PM
BHarris's Avatar
My iNuke1000 came in today. After converting everything and hooking it up, I get very little volume out of it even when the amp volume is max. My audioengine p4's dish more out than the sub. Is there something I am Overlooking?
I even wired the sub wires directly to the speakon so I could rule out the wire I bought and the spade connections. I have to nearly max my receiver and amp to get any sort of decent response from it even then.
BHarris is offline
post #20728 of 20897 Old 05-03-2016, 06:09 PM
srpawski's Avatar
Quoted: 16 Post(s)
In case anyone is interested, on Ebay, I presume it is Chad since the seller ID is from Woodstock, Il, there are 10 brand new Legend Amps for sale all new in box for $225 each.
srpawski is offline
post #20729 of 20897 Old 05-03-2016, 07:34 PM
globalgreg's Avatar
Liked: 29
What an a-hole
globalgreg is offline
post #20730 of 20897 Old 05-03-2016, 07:42 PM
WantMore's Avatar
Quoted: 28 Post(s)
Liked: 56
I feel fortunate to say that my Epik Sentinel is still performing well about 6 years later! *knocks on wood* (Although the bug to buy a PSA S1800--but more likely the S3600i has been really hard to fight off of late.)
WantMore is online now
Subwoofers , Epik Legend Subwoofer
