Official SVS Ultra 13 thread - Page 313 - AVS Forum | Home Theater Discussions And Reviews
 74Likes
post #9361 of 10747 Old 12-22-2011, 02:53 PM
Bill3508's Avatar
Originally Posted by Browninggold View Post
Do you know what the recommended setting is. On the older BASH everyone said set between 10-11 on the dial. Thanks
I don't think there is a specific setting. Just set it with a Mic at 75 db with the rest of your system. Everyone's setting will be slightly different. One other poster was at -10 so these amp need to be turned up more than the old bash it seems.
A wise man once said if it sounds like a broken record there is a motive behind the message.
Bill3508 is offline
post #9362 of 10747 Old 12-22-2011, 02:59 PM
Browninggold's Avatar
Liked: 37
Thanks Bill for the info. I set mine using Audyssey on my Denon A100 and had @ -20 wasn't bad but I bumped it up to -15. @. -10 in my room the Ultra popped so I backed it down.
"We can complain because rose bushes have thorns or rejoice because thorn bushes have roses". - Abraham Lincoln
Browninggold is offline
post #9363 of 10747 Old 12-22-2011, 03:01 PM
Bill3508's Avatar
What does audyssey have the receiver settings at, just wondering?
Bill3508 is offline
post #9364 of 10747 Old 12-22-2011, 03:14 PM
Liked: 37
FL -9
C. -9.5
FR -10
SR -6
SL -6
Sub -4.5
Klipsch RF 7IIs across the front
post #9365 of 10747 Old 12-22-2011, 04:27 PM
Bill3508's Avatar
FL -9
C. -9.5
FR -10
SR -6
SL -6
Sub -4.5
Bill3508 is offline
post #9366 of 10747 Old 12-23-2011, 07:46 PM
rampage123's Avatar
Quoted: 12 Post(s)
Mine (bash) are at 12
rampage123 is offline
post #9367 of 10747 Old 12-24-2011, 05:42 AM
Liked: 37
post #9368 of 10747 Old 12-24-2011, 07:47 PM
SKINSnCANES's Avatar
Liked: 25
Does anyone here have photos of how they handles these large subs in their HT?
I have a PC13 Ultra and am buying a second, which can be either the box or cylinder. My Theater is only 17x14 and these big boys make all the designs a pain...
Right now I'm going to lie them on their side front and rear center. The front will be under the screen and the rear right up against the wall and seating. Im planning on having the 7.5 inch GIK monster panels on the rear walls and the try traps in the front corners.
SKINSnCANES is offline
post #9369 of 10747 Old 12-26-2011, 08:32 AM
pbc
pbc's Avatar
Quoted: 347 Post(s)
Liked: 206
Ended up writing a review of the sub last week (hey, I was bored) after swapping out my old BASH amp for a Sledge amp (swapped with another member). In case anyone was curious about whether I thought there was a noticeable difference in "SQ" or not ....
http://www.hometheaterequipment.com/...th-User-Review
My DIY Subs ... http://www.avsforum.com/avs-vb/showthread.php?t=1233892
J Dunlavy:.. if you stop to think about it, no loudspeaker can sound more accurate than it measures.
pbc is offline
post #9370 of 10747 Old 12-26-2011, 10:05 AM
mojomike's Avatar
Liked: 30
That is a terrific in-depth review if the PB13. It is very nicely done. You could very well have a future as a writer for some audio publication. I would like to make one very minor correction. You describe the JTR Captvator as "much larger." While it is indeed larger, it is in fact just less than only about 11% larger than the PB13 at 7.81 cu. ft. vs 7.08 cu. ft. It also actually takes up a good deal less floor space with about 5" less depth.
mojomike is offline
post #9371 of 10747 Old 12-26-2011, 10:29 AM
pbc
pbc's Avatar
Quoted: 347 Post(s)
Liked: 206
Thanks Mike, will correct that when I get a chance. Figured from the pics I've seen it looked much larger but shouldve checked the specs
pbc is offline
post #9372 of 10747 Old 12-26-2011, 10:45 AM
Toe
Toe's Avatar
Quoted: 1473 Post(s)
Liked: 1839
That was one AWESOME review PBC!
Toe is online now
post #9373 of 10747 Old 12-26-2011, 06:22 PM
ransac's Avatar
Quoted: 31 Post(s)
Liked: 41
A nice write up by someone that obviously has too much free time. Better than many so-called professionals have done, Steve.
You did point out what I consider a major flaw in the design. That's where the control knob and display is located. The control and display are cabled to the control board (instead of being integrated on the board) so it would be easy to use a longer cable and place the unit on the front baffle or even recessed in the top (though not ideal if you want to stack subs).
Anyway, keep writing like that and you could get a job at 'Canucks on New Fangled Electric Stuff' ezine.
Randy
ransac is offline
post #9374 of 10747 Old 12-26-2011, 08:18 PM
rampage123's Avatar
Quoted: 12 Post(s)
Very Well Done !!!
post #9375 of 10747 Old 12-26-2011, 11:06 PM
Elfather's Avatar
Thanks for the review Pbc. really enjoyed reading it. Excellent Job.
Elfather is offline
post #9376 of 10747 Old 12-27-2011, 01:38 AM
Quoted: 1394 Post(s)
Liked: 589
pbc,
Top quality review!!!!
Have to ask, what do you do for a living?
JimP is offline
post #9377 of 10747 Old 12-27-2011, 06:01 AM
pbc
pbc's Avatar
Quoted: 347 Post(s)
Liked: 206
Originally Posted by JimP View Post
pbc,
Isn't it obvious? Im a CFO! Clearly...
pbc is offline
post #9378 of 10747 Old 12-27-2011, 06:07 AM
pbc
pbc's Avatar
Quoted: 347 Post(s)
Liked: 206
Yeah. The knob location drove me nuts. Didn't the original pics of the SB line show the IFC on the front of the sub? Guess the added cost/complication wouldve just added cost. Plus they wouldn't have been able to use the new amp in the old boxes if they did that. I've heard they're having difficulties sourcing BASH amps now.
pbc is offline
post #9379 of 10747 Old 12-29-2011, 07:17 AM
Archaea's Avatar
Quoted: 2857 Post(s)
Liked: 2436
Anyone somewhat local to Kansas City want to bring a pair of PB13 Ultras over to the KC blind shootout on Jan 14? We may have one available, but likely not a pair - yet. If so please shoot me a PM, or respond in the thread below.
http://www.avsforum.com/avs-vb/showthread.php?t=1369860
Archaea is online now
post #9380 of 10747 Old 12-29-2011, 08:23 AM
Gorilla83's Avatar
Quoted: 374 Post(s)
Liked: 514
Great idea. Hope you don't mind me piggybacking on your idea for our meet, LOL. We are also hosting a GTG in the PA/NJ/MD/NY/DE area on February 11th and would love to hear a pair of Ultras as well. We currently have pairs of JTR Caps, Seaton Submersive HP, single Subersive F2, CHT 18.T, and Dual opposed MFWs, JL F113s. A pair (or even single if needed) of Ultras would really complete our comparison for the day!
Thread:
http://www.avsforum.com/avs-vb/showthread.php?t=1378707
Gorilla83 is online now
post #9381 of 10747 Old 01-01-2012, 07:38 PM
bibsy's Avatar
Does an AS-EQ1 help blend 2 different subs together ? Just recently got a pc13 ultra to compliment my pc12nsd
Or am i better off with just the pc13u as the pc12nsd might just hold it back or introduce distortion
bibsy is offline
post #9382 of 10747 Old 01-01-2012, 08:03 PM
mojomike's Avatar
Liked: 30
Two subs with similar low end rolloff characteristics should be able to be made to work well together. The PC13 in 20hz tune should have similar, all though much more powerful, low end performance. There is no reason these two shouldn't work well together.
mojomike is offline
post #9383 of 10747 Old 01-02-2012, 06:16 AM
d_m1010's Avatar
Quoted: 64 Post(s)
Liked: 184
It makes my 4 Ultras and 2 Pluses blend nicely together.
Psn: memnoch1010
Xbox live: meadoch
d_m1010 is offline
post #9384 of 10747 Old 01-02-2012, 09:03 AM
Liked: 25
Holy **** did you say four ultras! I'm getting a hard time from people because I'm going to get a second! How big is the room? Any link to a build thread or pics?
post #9385 of 10747 Old 01-02-2012, 09:11 AM
d_m1010's Avatar
Quoted: 64 Post(s)
Liked: 184
Lol 12x12x8 room.
Psn: memnoch1010
Xbox live: meadoch
d_m1010 is offline
post #9386 of 10747 Old 01-02-2012, 09:16 AM
Liked: 25
Lol 12x12x8 room.
of course...four ultras in a big closet...shoudl have known lol.
is this a theater or just a room with an insane amount of bass? Its gotta be awesome in movies. Do you just have them all running low to even out response? Seems ilke way overkill but theres some jealousy in my voice lol
post #9387 of 10747 Old 01-02-2012, 04:38 PM
d_m1010's Avatar
Quoted: 64 Post(s)
Liked: 184
lol closet.
They are all set to 20hz (incluing the Pluses) and the ASEQ1 along with individual spl meter readings evens out the response.
Psn: memnoch1010
Xbox live: meadoch
d_m1010 is offline
post #9388 of 10747 Old 01-02-2012, 08:44 PM
bibsy's Avatar
Thanks for the reply guys ! Ill post pics when I have everything set-up. My room is 18x12x9 so hopefully these 2 babies will do until I can afford another ultra
bibsy is offline
post #9389 of 10747 Old 01-03-2012, 02:55 PM
Liked: 25
lol closet.
lol you know what I mean hopefully you took no offense. Its not a closet for you the listener, its a closet for those 4 (6) subs! Its like they are trapped but Im sure they are fully capable of breaking out! RIP walls...
post #9390 of 10747 Old 01-03-2012, 03:05 PM
d_m1010's Avatar
Quoted: 64 Post(s)
Liked: 184
No offense taken. It is cozy, but I'd have it no other way.
Psn: memnoch1010
Xbox live: meadoch
d_m1010 is offline
Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer
