Official SVS Ultra 13 thread - Page 325 - AVS Forum | Home Theater Discussions And Reviews
 74Likes
Old 04-03-2012, 09:44 AM
Ed Mullen's Avatar
Quoted: 81 Post(s)
Liked: 269
Originally Posted by warpdrive View Post
Just wondering: if I bump up the sub gain by 1 on sledge, does it mean I can balance it by decreasing the AVR sub level by -1dB? Or should I rerun Audyssey every time I change the sub gain?
Yes, exactly correct. It's a 1:1 ratio. No need to re-run Audyssey; it will maintain the overall sub channel level.
Ed Mullen
Director - Technology and Customer Service
SVS
"What We Do In Life, Echoes In Eternity"
Ed Mullen is offline
Old 04-03-2012, 02:21 PM
KevinG's Avatar
Quoted: 332 Post(s)
Liked: 160
Originally Posted by Ed Mullen View Post
If you regularly listen at loud to very loud levels, then I recommend setting the subwoofer gain to -10 (a 10 dB gain) and the Yamaha sub channel level to -10.5 (a 10 dB drop). While the overall calibration level won't change, the amp will make more peak power the closer to 0 dB the gain is set.
Ah, excellent....I'll do this tonight...thanks for the advice!
KevinG is offline
Old 04-03-2012, 03:08 PM
MitchPope's Avatar
Quoted: 26 Post(s)
Liked: 25
Good move - with the Sledge 800/1000 platforms, the higher the amp gain you can run (while still maintaining your overall calibration level by lowering the AVR sub channel level), the better the amp will perform.
Best advice I've found on here in a while! I just went from -16 to -6 on my PC13-Ultra and from +2 to -8 on the receiver. Played some Massive Attack tracks and I am definitely liking the change.
I have an AS-EQ1 as well, if I re-run the setup in the future, should I leave it at -6 dB or set it back to -16 dB where the software measured 75 dB in the room and just change it after?
MitchPope is offline
Old 04-03-2012, 03:10 PM
markabuckley's Avatar
Quoted: 95 Post(s)
Liked: 33
^^ now that I didn't know
I've been running my SVS at 1/4 volume
markabuckley is offline
Old 04-03-2012, 06:03 PM
jchong's Avatar
Liked: 32
Hi Ed, does this also apply to the BASH 750 amp?
I know that without the convenient digital display it's hard to know by how much you are increasing the amp gain, but just wanna know if the same principle applies. I can use a SPL meter to check the level.
jchong is offline
Old 04-03-2012, 06:08 PM
jchong's Avatar
Liked: 32
I'm interested in the answer to this also.
And a second related question, if I like to run the sub hot (say +3dB) post-Audyssey, should I bump it up in the AVR or at the sub amp?
jchong is offline
Old 04-21-2012, 03:56 AM
SweElite's Avatar
In thinking of buying a PC13-ULTRA but im a little concerned about the "white noise" issue. I recently sold a PC12 Plus and it had this issue.
SweElite is offline
Old 04-21-2012, 05:59 AM
Quoted: 95 Post(s)
Liked: 33
can I check please that running the sub at a lower port setting on the rear - than the physical configuration is ok ? (I think it puts less strain on the Sub anyway ?
ie:
2 Ports Open (PC-Ultra) - 15hz tune
amp panel set to 10hz tune
it just seems to remove a big room boost around 25-35 hz that room size doesn't correct - small/medium/large seems to have more effect lower down in the spectrum - sub 18-20hz
thanks
Old 04-21-2012, 08:13 AM
MitchPope's Avatar
Quoted: 26 Post(s)
Liked: 25
I'm starting to think the obvious answer is yes. There is no way I would read 75 dB at the new level when I take the first measurements.
The best change I've noticed is when listening to music in Direct mode.
Old 04-21-2012, 09:52 AM
dougmcbride's Avatar
ie:
thanks
Not OK - this leaves the sub unprotected from frequencies below tuning. The ports unload below tuning frequency leaving the driver with little resistance to bottoming when the subsonic filter is set lower than physical tune.
Doug
dougmcbride is offline
Old 04-21-2012, 10:04 AM
Quoted: 95 Post(s)
Liked: 33
Doug
ah ok thanks - I thought it was other way round - I thought setting the subsonic filter to a higher frequency than the actual port tuning was bad
Old 04-21-2012, 10:15 AM
Quoted: 95 Post(s)
Liked: 33
just re-read the manual and you are quite correct you shouldn't set subsonic filter lower than port
thats surprising as if anything in that setting it seemed to be cutting quite a lot of bass - but I'm no expert - its a pity as gave me a nice flat response - never mind - I've reset it back to be the same as the port
Old 04-21-2012, 10:43 AM
Gellidius's Avatar
i don't know which sub you have, but you might be able to tune it lower than 15 Hz (my PC12 Plus can be tuned to 12 Hz and the filter at 11 Hz);
this also could lower or flatten your bump.
it's worth a try.
Gellidius is offline
Old 04-22-2012, 04:22 PM
Ed Mullen's Avatar
Quoted: 81 Post(s)
Liked: 269
The original generation Sledge amps had a higher noise floor than we preferred (it was tied to the input sensitivity and associated signal/noise floor). This was corrected in subsequent production runs and the lower noise floor amp has been in circulation for a few years now. While all amps have a known S/N ratio and an audible noise floor, the improved version is very good and we've had no issues or complaints about it.
Ed Mullen
SVS
Old 04-23-2012, 01:06 PM
Quoted: 1394 Post(s)
Liked: 588
I'm having a problem with the shipping cost on my ebay auction of a PB ultra 13.
How have you guys been getting delivery of your PB Ultra 13s?
Thanks in advance.
JimP is online now
Old 04-23-2012, 04:16 PM
Thanks in advance.
PB13-Ultra's shipped in the US go motor freight - RL Carriers.
Cheers,
Doug
Old 04-23-2012, 07:05 PM
Liked: 588
Doug
A major thanks.
JimP is online now
Old 04-24-2012, 12:36 AM
Eli_'s Avatar
Hi Ed, I am also wondering if this applies to the BASH amp?
"the higher the amp gain you can run (while still maintaining your overall calibration level by lowering the AVR sub channel level), the better the amp will perform"
Eli_ is offline
Old 04-24-2012, 04:41 AM
Liked: 588
Mitch,
If you're up to experimenting, rerun your system so that your final subwoofer level in your preamp/receiver winds up at -4. At one time, that was considered optimum for giving your headroom in your preamp/receiver and a high enough signal to your sub so that the auto on would come on.
JimP is online now
Old 04-24-2012, 10:07 AM
Ed Mullen's Avatar
Quoted: 81 Post(s)
Liked: 269
The BASH amp has an analog gain stage which functions totally differently. It is not sensitive to gain setting and can be driven to full power at much less than full gain. So with the BASH, I prefer to just set the sub channel level somewhere around -5 and then adjust the gain until you obtain the desired SPL.
Ed Mullen
SVS
Old 04-24-2012, 10:30 AM
Milt99's Avatar
Quoted: 233 Post(s)
Liked: 246
Hey Ed. I'm a SVS customer(2 CS Ultras), any chance of buying a Sledge 1000 amp to replace my old Sampson?
It ain't ignorance causes so much trouble; it's folks knowing so much that ain't so
Milt99 is offline
Old 04-24-2012, 12:59 PM
fasted71465's Avatar
Thanks in advance.
It is free to Louisiana (iwish) Hello JimP.
fasted71465 is offline
Old 04-24-2012, 01:36 PM
Ed Mullen's Avatar
Quoted: 81 Post(s)
Liked: 269
The Sledge 1000 cannot drive both amps at the same time, unless they were wired in series for an 8 ohm load. The amp wouldn't make full power into that load, but that's not necessarily a bad thing considering the application.
No promises but send us a note to custservice@svsound and we'll at least kick it around.
Ed Mullen
SVS
Old 04-25-2012, 10:25 AM
Milt99's Avatar
Quoted: 233 Post(s)
Liked: 246
Thanks Ed!
Milt99 is offline
Old 04-27-2012, 03:02 AM
maxht's Avatar
I did it exactly that way and been enjoying it for a more than a year now. I still like this beast very much. Never fails to impress any visitor
Bass, please. Shaken, not stirred.
maxht is offline
Old 04-27-2012, 04:31 AM
saltysteven's Avatar
Question for the owners!!
I've never heard a 13" sub, is that the best of both worlds? 12 + 15 subs are both great and sound so different, sites this sub play a sound somewhere in the middle. Thanks for any info or a link to it
saltysteven is offline
Old 04-27-2012, 04:44 AM
Liked: 588
Hi fasted,
Wish it was free.
JimP is online now
Old 04-29-2012, 03:54 PM
Ed Mullen's Avatar
Quoted: 81 Post(s)
Liked: 269
Glad you are liking the performance improvement. If you re-run the AS-EQ1 in the future, set the subs to 75 dB (the AS-EQ1 needs this SPL to properly build an EQ file). After the EQ file is built, the AS-EQ1 won't be affected by the sub channel level or the overall sub calibration level. So you can perform the same gain maximimizing technique again after you re-run the AS-EQ1.
Ed Mullen
SVS
Old 05-01-2012, 01:26 PM
tpaxadpom's Avatar
Quoted: 39 Post(s)
Liked: 26
Hi Ed,
Do you mind sharing the specs for Bash and Sledge amp? PM would work for me if you don't want to post them on the board.
thanks
tpaxadpom is offline
Old 05-02-2012, 06:50 PM
boarder1995's Avatar
Quoted: 14 Post(s)
So, one of my 2 Ultras had its BASH amp go out and SVS is warranty replacing the plate amp with a Sledge amp (awesome company). Now I'll have one BASH and one Sledge unit. Anyone foresee issues mixing and blending the two manually before running mono sub Audyssey? I plan to level match them again and go from there. They're both equal distance from the main seating spot (my spot). Are there any slight group delay difference issues I might have to deal with now with two different amp styles?
I've been quite happy with my pair, but it's been kind of fun with a single unit, a bit more texture to the bass, a little more clarity. This is probably due to non-perfect blending before with my pair, but I'm always tweaking the system (don't we all?). I suppose if it's too much trouble mixing the two amps, and since I'm no longer as worried about all around the room even bass response, I may move one upstairs and start a dedicated 2 channel system.
Why do all of my threads suck? Is there an internet posting school somewhere? -wes k
boarder1995 is offline
Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer
