Official SVS Ultra 13 thread - Page 349 - AVS Forum | Home Theater Discussions And Reviews
 72Likes
Old 06-16-2014, 03:38 AM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 518
Thought about that myself, put the SB12+ on top, or on the other side of the TV with the SB Ultra 13. Loop from one to the other, then use antimode.
Good idea or not?
fatbottom is offline
Old 06-16-2014, 04:15 PM
Kini62's Avatar
Quoted: 1415 Post(s)
Liked: 1300
Originally Posted by autreym View Post
Pseudo dumb question.
I had the great fortune of buying a SB13 Ultra with less than a year of use for a great price, and have two decent but not great subs currently hooked up (think Elemental Designs A2-300 + Klipsch RW-12)
My question is, would I be better off running all 3 subs or just the SB13 Ultra since it's so far and away superior to the other two?
Try it and see or hear for yourself. You've got nothing to lose but a little time.
I was and still am surprised at the improvement I got when adding my Def Tech into my system.
autreym likes this.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
Old 06-21-2014, 10:04 PM
C44
Quoted: 30 Post(s)
Liked: 6
Hi folks,
I picked up a new PB13 Ultra today. Unpacked it, set it up but aside from the quick set up guide, it had no other instructions. Is there an on-line manual that I can download?
C44 is offline
Old 06-21-2014, 10:13 PM
bear123's Avatar
Quoted: 1706 Post(s)
Liked: 2513
You are likely to greatly improve your FR above 30/40 Hz. The problem will be in the deep bass where the difference in roll off between the sealed and ported subs cause them to be out of phase, resulting in bad cancellations. So for music it would probably improve things. For movies it would be a train wreck.
autreym likes this.
bear123 is online now
Old 06-21-2014, 10:35 PM
autreym's Avatar
Man you are spot on, I have spent the last 2 days trying to balance the 3 subs and it's been virtually impossible. Doesn't help that I need to keep relatively low volume levels (2 year old) so testing bass heavy scenes or test tones is tricky.
I eventually just went to the Ultra by itself and have been focused on getting it dialed in perfectly.
LOVE it so far, it actually sounds fantastic even at relatively low volume levels with BOTH music and movies. Amazing sub.
But I keep wondering how duals would sound...can't get it out of my mind enough to even enjoy the single SB13 Ultra
autreym is offline
Old 06-22-2014, 03:07 AM
Mongo171's Avatar
Quoted: 828 Post(s)
Liked: 1251
Originally Posted by C44 View Post
Hi folks,
Congrats!
Here you go: http://www.svsound.com/support/document-library
"I am a Meat Popsicle." - Korben Dallas, "The Fifth Element"
Mongo171 is offline
Old 06-22-2014, 07:22 AM
bear123's Avatar
Liked: 2513
I think you are on the right track....get it set up as good as you can with the single ultra. And yes, duals will sound better especially for music. From what I have seen, one sub usually gives a pretty good response under 40 Hz, but very uneven above 40 HZ. So for movies, you mainly gain headroom in the deep bass with dual subs, but they give a much better quality bass for music due to the flatter response you can get.
I suggest your next step, if you are serious about having great bass, is to get Umik-1 mic from miniDSP, download REW, and measure your room. For $75 you can check you in room Frequency response and determine if you need to adjust placement or if a second sub is really needed. I was happy with one sub until I measured the room..........
autreym likes this.
Old 07-11-2014, 12:37 PM
Actionable Mango's Avatar
Quoted: 24 Post(s)
Liked: 30
Hi folks, I'm going to look at buying a used pc13 ultra, and the seller is willing to demo it for me before purchase. Is there anything in particular I should listen for or visually inspect in order to ensure it is okay? Any common problems I can check for?
Also, it is an older model with the Bash amp, is there a significant difference in performance or anything else I should be worried about with it?
Actionable Mango is offline
Old 07-11-2014, 04:11 PM
rampage123's Avatar
Quoted: 12 Post(s)
Just a little less powerful. Nothing substantially different.
rampage123 is offline
Old 07-11-2014, 08:18 PM
Reference_head's Avatar
Quoted: 142 Post(s)
Liked: 730
Just look it over and have a listen.
Klipsch Pro Cinema KPT-904 L/C/R, Pro Cinema KPT-1201-T2 for sides and Heresy II for backs.
SVS PB13-Ultra, PB12-Plus x2, and Velodyne SMS-1 Sub EQ
SC-55 elite and B&K 200.7 S2
JVC RS-45 Projector, and Seymour CS 125” 2.35 screen
Oppo BDP-103 9 ATS Acoustic panels
Reference_head is offline
Old 07-15-2014, 09:20 AM
steady teddy's Avatar
Quoted: 97 Post(s)
Liked: 49
RCA vs. Balanced connections
I've owned the PB13 Ultra for about 6 years. I have always used the RCA connection.
I purchased a Marantz AV 8801 last Fall and was considering using the XLR connection to the sub. This would not be easy since all of my AV equipment is in a closet in another room and everything is wired in the walls. If I want to use the Balanced connection on the PB13 Ultra I'd have to run roughly 30' of XLR cable through the walls again.
I'm wondering if all that work would really be worth it. Have any long time PB13 Ultra owners gone from RCA to XLR and is there a discernible difference?
Thanks in adavance
Rest of My system:
Emotiva XPR-5
Oppo BDP105
Mains - Revel F208
Center - Revel C208
Surrounds - Def Tech BP 2000TL
steady teddy is offline
Old 07-29-2014, 08:35 PM
wadeh911's Avatar
Quoted: 79 Post(s)
Liked: 72
I replaced my long RCA runs to my 13 ultras with XLR and that solved my noise issues. Was getting soft buzzing that was driving me nuts. My cables were on floor rather than in walls. In my case, yes there was a discernible improvement as noise is completely gone.
After spending the substantial monies for dual 13 ultras, the XLR solution worked well for me. YMMV.
South Florida is my Theater
Listen to live music and recreate it at home.
wadeh911 is offline
Old 08-03-2014, 11:39 AM
Quoted: 97 Post(s)
Liked: 49
Thanks for the reply. I don't have any buzzing, not that my ears can hear anyway. I contacted SVS on this and they said XLR would make no difference unless I was the having noise issues that you mentioned.
Old 08-03-2014, 04:22 PM
darthray's Avatar
Quoted: 939 Post(s)
Liked: 895
Thanks in adavance
Rest of My system:
Emotiva XPR-5
Oppo BDP105
Mains - Revel F208
Center - Revel C208
We got the same sub and Audio processor
I change all my connection to XLR and there is no going back.
Less floor noise (slight hisss from RCA to none with XLR).
A much better connection since they lock in.
Also look much better and profesional.
A little expensive but well worth-it if you can afford it.
A friend of mine who work on radar told me they use all XLR connector with Belden cable.
So I ask him how far they go before putting a signal booster.
His answer, 10 miles!
Ray
darthray is online now
Old 08-07-2014, 12:40 PM
Horace Clark's Avatar
Quoted: 23 Post(s)
Going Dual
After owning my SB13-Ultra for 3 weeks I've decided to go dual. Never thought I would have spent $3000 on subs. But let's face it; we are bass-junkies. I know there are cheaper solutions out there but when you get a taste of SVS there's no going back. BTW- this SB ultra rocks. Having 1 is more than enough, but having 2 should put me in bass heaven.
cchunter likes this.
Horace Clark is offline
Old 08-07-2014, 12:47 PM
cchunter's Avatar
Quoted: 495 Post(s)
Liked: 772
I agree 100%! I'm patiently waiting for funds to get my second SB13 Ultra. Probably not till this time next year. Congrats on the duals and let us know how much better it is than just a single sub. How big is your room? Mine is just a tad under 2000 cu ft.
Denon 4520
Klipsch RF-7II's, RC-64II, RS-62II's
SVS SB13 Ultra
Oppo 203 Sony PS4
Panamax 5300PM
Sony 65XBR850D 4K
cchunter is offline
Old 08-08-2014, 11:07 AM
bambam's Avatar
Quoted: 70 Post(s)
Liked: 38
I may be selling a pair of PB-13 Ultras in Piano Gloss Black. PM me if you have any interest.
bambam is offline
Old 08-18-2014, 02:25 PM
cRock HT's Avatar
Quoted: 27 Post(s)
Liked: 37
Been following this thread for many YEARS now and just ordered dual PC-13s today! I've never owned anything other then a HTIB sub so hopefully these will make me crap my pants!
cRock HT is offline
Old 08-18-2014, 02:58 PM
Mongo171's Avatar
Quoted: 828 Post(s)
Liked: 1251
HTIB to twin cylinders?
Depends are highly recommended!
Mongo171 is offline
Old 08-18-2014, 03:00 PM
cRock HT's Avatar
Quoted: 27 Post(s)
Liked: 37
Ha! Lets hope so.
cRock HT is offline
Old 08-18-2014, 03:39 PM
LowerFE's Avatar
Liked: 41
I can't wait to hear your impressions!
LowerFE is offline
Old 08-18-2014, 03:46 PM
Mongo171's Avatar
Quoted: 828 Post(s)
Liked: 1251
Ha! Lets hope so.
I have one. Will be getting the 2nd hopefully by Christmas. So, I do know what one can do.
Mongo171 is offline
Old 08-20-2014, 01:59 AM
DekPM19's Avatar
Quoted: 115 Post(s)
Liked: 34
Which ultra to get I am looking for a ht sub and like the ultras do you think there is a Difference between the sealed or ported? I am planing on getting 2 one this year and one next year. My room is 24 x 15 with a 11 x 11 room open to the side with a 10' hall way coming into the room. Which one would you get.
Allen
DekPM19 is offline
Old 08-20-2014, 04:07 AM
fatbottom's Avatar
Liked: 518
Allen
For that, I'd look into PB or PC Ultra (ported)
I do prefer the SB but I'm in small room.
Old 08-20-2014, 09:11 AM
Mongo171's Avatar
Quoted: 828 Post(s)
Liked: 1251
+1
Ported for larger rooms.
Mongo171 is offline
Old 08-20-2014, 11:39 AM
DekPM19's Avatar
Quoted: 115 Post(s)
Liked: 34
Thanks the ported is what I was thinking about too, just wanted to get other people thoughts.
Allen
DekPM19 is offline
Old 08-30-2014, 07:39 PM
TomC1315's Avatar
Quoted: 134 Post(s)
Liked: 146
What's the size of the room they'll be in?
MartinLogan Motion 40s / 30 / LX16s
Marantz SR5007 / UD5007
Emotiva XPA-3
SVS SB13ultra
exercise room: MartinLogan LX16s / SVS SB2000
TomC1315 is offline
Old 08-30-2014, 08:42 PM
rel
rel's Avatar
At what size of room would you say is the max for the SB13? This is one on my short list, and my room is roughly 3200 cu ft.
rel is offline
Old 08-30-2014, 09:08 PM
Tim Glover's Avatar
Quoted: 83 Post(s)
Liked: 44
Any news on an Ultra replacement this year? I believe the PB13-U currently is about 4 years old? Just curious. I may be in the market soon.
Tim Glover is offline
Old 08-30-2014, 09:10 PM
cchunter's Avatar
Quoted: 495 Post(s)
Liked: 772
Depends what your main listening preference? Music or movies? If music it should be fine in that size room but if your watching movies more then you will need duals IMO. My room is 2000 cu ft and its great for music. It's actually really good for movies too but I would like a little more thump and am looking at buying another sometime next year. I'm 50/50 music to movies.
Denon 4520
SVS SB13 Ultra
Oppo 203 Sony PS4
Panamax 5300PM
Sony 65XBR850D 4K
cchunter is offline
Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer
