Official SVS Ultra 13 thread - Page 355 - AVS | Home Theater Discussions And Reviews
 38Likes
post #10621 of 10641 Old 03-30-2015, 07:14 PM
Mongo171's Avatar
Quoted: 412 Post(s)
Liked: 924
Originally Posted by MitchPope View Post
Oppo analog out to SW and AIX disc and still nothing.
I have an OPPO, too. Are your main speakers set to Small? Is the subwoofer set to On? Subwoofer gain turned up? Is the RCA on the back of the OPPO, as well as the amp on the sub, securely connected? Maybe a switch on the sub's amp got switched?
Maybe give SVS a call tomorrow. I'm surprised Ed Mullen, of SVS, doesn't monitor this thread. He monitors the SVS Owners thread. They'll be able to isolate the problem. Just make sure everything is Kosher with the OPPO.
"I am a Meat Popsicle." - Corbin Dallas, "The Fifth Element"
Klipsch Chorus II (Mains); Klipsch Academy (Center) (KLF-C7 waiting in the wings); Klipsch RS-62 II (Surrounds); SVS PC13-Ultra (Big Bada Boom); ATI AT1505 (Amp); OPPO BDP-105 (Blu-ray Player); Panasonic 60GT50 (Plasma TV)
Mongo171 is offline
post #10622 of 10641 Old 03-30-2015, 07:26 PM
MitchPope's Avatar
All checked; listened with finger on subwoofer cone and no output at all from L or R RCA sub input at 0dB on the amp.
MitchPope is online now
post #10623 of 10641 Old 03-31-2015, 07:26 AM
Mongo171's Avatar
Quoted: 412 Post(s)
Liked: 924
Give SVS a call. They can help you better than I can. 1.877.626.5623
Mongo171 is offline
post #10624 of 10641 Old 03-31-2015, 09:00 AM
mattdub1's Avatar
Quoted: 147 Post(s)
I know sounds stupid but has anyone used a car wax on the piano finish to hide swirls ?
mattdub1 is offline
post #10625 of 10641 Old 03-31-2015, 06:30 PM
Whacked!'s Avatar
I don't think car wax sounds stupid at all. I've done it and redo it every 12 - 18 months. Restores the shine, does help a little with swirls, and seems to keep the dust down.
Whacked! is offline
post #10626 of 10641 Old 03-31-2015, 07:08 PM
mattdub1's Avatar
Quoted: 147 Post(s)
^^ what kind of wax do you use? I was thinking some meguiars nxt liquid. I just got my replacement sub and there's some swirl marks in the finish which I can see (I have dimmers in my room). My last one had the same thing...which I find odd for a 2k sub. Has anyone else noticed swirl marks on their sub right out of the box?
mattdub1 is offline
post #10627 of 10641 Old 04-01-2015, 11:03 AM
MitchPope's Avatar
I've been dealing with their Canadian distributor. They are going to have me swap out the amp and see if that fixes it.
Mongo171 likes this.
post #10628 of 10641 Old 04-01-2015, 04:16 PM
Whacked!'s Avatar
I'm using Meguires Deep Crystal carnuba wax. Any good carnuba should be fine. I never noticed the swirls ootb but their pretty much inevitable anyway.
TomC1315 likes this.
Whacked! is offline
post #10629 of 10641 Old 04-01-2015, 04:51 PM
Liked: 1
I have used Meguirar's ULTIMATE Polish with much success on my wilson watts..piano black finish. removed swirl marks and some minor scratches. Followed up with a good auto wax (I used Sonax). Had to rub a little harder on the scratches, but more importantly this product did not add any swirls...just removed them.
ccssid123 is offline
post #10630 of 10641 Old 04-03-2015, 07:53 PM
mattdub1's Avatar
Quoted: 147 Post(s)
So I watched my first movie tonight with the new replacement sub. Wasn't a bass heavy movie so didn't hear the sub much. 3/4 through I did a channel test tone and the sub didn't play anything. Its set to auto mode. I toggled the auto switch, turned off the power and back on...no sound. Then all of a sudden the test tone started playing. This is the second time this has happened. Could there potentially be an amp issue? Or does the auto feature turn the sub off if nothing plays through it for awhile during a movie and then it takes a bit to catch the signal again and turn back on? Seems really odd
mattdub1 is offline
post #10631 of 10641 Old 04-03-2015, 09:00 PM
RobZ's Avatar
Quoted: 85 Post(s)
Liked: 25
3M hand glaze also works well for the swirl marks. Top it off with a good carnuba wax and it'll go from looking like an old truck just run through an automatic car wash to Ralph Lauren's black Bugatti at Concorso d'Eleganza Villa d'Este.
RobZ is online now
post #10632 of 10641 Old 04-03-2015, 09:02 PM
mattdub1's Avatar
Quoted: 147 Post(s)
Thanks...I take it you've used this combo? And did you have swirls out of the box on yours?
mattdub1 is offline
post #10633 of 10641 Old 04-03-2015, 09:13 PM
RobZ's Avatar
Quoted: 85 Post(s)
Liked: 25
Yes. My first Ultra is now around 7 years young. I also have a new B stock that has minor swirls as expected.
RobZ is online now
post #10634 of 10641 Old 04-03-2015, 09:19 PM
mattdub1's Avatar
Quoted: 147 Post(s)
Thanks for the tip. Mine isn't b stock tho so that's why I was wondering if some swirls are normal.
mattdub1 is offline
post #10635 of 10641 Old 04-04-2015, 07:37 AM
Mongo171's Avatar
Quoted: 412 Post(s)
Liked: 924
With the Auto function, if no signal is present, the sub will turn off. When a signal is present, the sub will turn on, but it takes a few seconds for a soft start up.
If you're watching a movie, just turn the sub on. Don't use the Auto function.
Mongo171 is offline
post #10636 of 10641 Old 04-04-2015, 07:55 AM
mattdub1's Avatar
Quoted: 147 Post(s)
So shouldn't it come on if I run a test tone through it? I left the test tone on for over a minute and nothing happened. I also turned the power switch off and on and flipped the auto on switch to the on position and didn't get any sound .
mattdub1 is offline
post #10637 of 10641 Old 04-04-2015, 08:02 AM
Whacked!'s Avatar
If you toggle the power, it will take a little bit before it comes back to life, at least 5 mins, maybe more. If cycling the power, it is best to leave it off for 5-10 mins, it should come back right away if you do that and there are no other issues. There have been other reports of auto not working very well for some folks, they end up just leaving it on.
Whacked! is offline
post #10638 of 10641 Old 04-04-2015, 08:06 AM
mattdub1's Avatar
Quoted: 147 Post(s)
OK ... I left it in the on position last night to see what happens this morning. Its just weird to me that I cycled the power 2-3 times and the light on the sub display was on but no sound. Its also strange that during the first half of the movie there was sound but not during the last half where I couldn't get the sub back on even tho the signal was there
mattdub1 is offline
post #10639 of 10641 Old 04-04-2015, 03:28 PM
Whacked!'s Avatar
^I think the best thing now would be to talk to SVS.......
Whacked! is offline
post #10640 of 10641 Old Today, 02:45 PM
MitchPope's Avatar
Replacement amp fixed the problem. Pumping out the bass once again!
post #10641 of 10641 Old Today, 02:59 PM
RobZ's Avatar
Quoted: 85 Post(s)
Liked: 25
Dual PB13 Ultras hiding their faces:
RobZ is online now
Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer
