Official SVS Ultra 13 thread - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 72Likes
post #181 of 10742 Old 09-03-2007, 11:02 AM
craigsub's Avatar
Originally Posted by ransac View Post
You have to remember, the new Ultra is just that, a totally new sub. It is not a simple upgrade to an existing, tried and true sub. As with the HO, early adopters are going to expose weaknesses the OEM didn't find. You will do things with your sub the testers didn't try. Look at Craig's problem. He went on a business trip and when he came back a couple days later, the Ultra wouldn't work. I'm pretty sure SVS didn't run this test. Now we know the new Ultra won't be ignored. Looks like it has a fatal attraction for Craig. Wonder what it will do when it sees him playing with other subs. Hope you don't have a rabbit, Craig.
That was funny enough to warrant a quote.
GREAT stuff, Randy.
craigsub is offline
post #182 of 10742 Old 09-03-2007, 06:36 PM
Ron Temple's Avatar
Quoted: 163 Post(s)
Liked: 133
Well it's official...the PB13Ultra arrived on Friday, on Saturday I sold both my DIY Plus and today my 20-39+. It took all of about 40 seconds to make that decision. Simlar output, but as the early guys expressed, no thud, sharp attack, I can't detect any overhang, and fit and finish are superb. I wasn't sure about the Rosenut. My floors and furniture are dark oak (the floors red oak). I though Natural Oak was the way to go, but the Rosenut actually works better. I haven't had to deal with the size and weight issue before (other than the DIY), but I'll put up with the challenge.
Dual Pluses were awe inspiring in my setup and I wasn't sure if the Ultra would be worth the upgrade...I was totally wrong. I listen to a lot of music, the Pluses were good, but can't touch the Ultra13. It reminds me of the DD15 I had here briefly, but on steroids.
The only drawback is my room limitations. My wife was gone over the weekend, so I just dropped it into my preferred spot between my display and my FR. This is optimum for my room with every sub I've tried. I couldn't keep it there, just too big, so I put it back in the left corner behind the display with the help of my son yesterday. Corner gain decreased the SQ a bit(20dbs up from 15-40hz, it then slopes down gradually, thankfully, to 80dbs from 40-100hz) which I hope PEQ and room correction will fix. I'll experiment, but the damn thing is so heavy and stuck in an awkward postition to adjust...difficult to do by myself. Anyway, I'll get it done...even the corner position is far superior to my fairly flat duals.
Craig was correct in his comments on an another thread. For HT and if your particular taste lends you to prefer the low level impact that translates to rumble and sometimes thud of the Plus/2 or dual Pluses, there's no need to upgrade. If you want to hear and feel the sting of the explosion or bass note as a sharp attack with consequent punch the Ultra is what you should aim for. I prefer it...finish on the Rosenut is amazing.
I don't lurk as much as I used to and I NEVER listen. Comes from being old and cynical.
Ron Temple is offline
post #183 of 10742 Old 09-03-2007, 06:57 PM
getech's Avatar
Dual Pluses were awe inspiring in my setup and I wasn't sure if the Ultra would be worth the upgrade...I'm was totally wrong. I listen to a lot of music, the Pluses were good, but can't touch the Ultra13. It reminds me of the DD15 I had here briefly, but on steroids.
The only drawback is my room limitations. My wife was gone over the weekend, so I just dropped it into my preferred spot between my display and my FR. This is optimum for my room with every sub I've tried. I couldn't keep it there, just to big, so I put it back in the left corner behind the display with the help of my son yesterday. Corner gain decreased the SQ a bit(20dbs up from 15-40hz, it then slopes down gradually, thankfully, to 80dbs from 40-100hz) which I hope PEQ and room correction will fix. I'll experiment, but the damn thing is so heavy and stuck in an awkward postition to adjust...difficult to do by myself. Anyway, I'll get it done...even the corner position is far superior to my fairly flat duals.
Can't wait for my Ultra13 to be delivered sometime late this week. I have one coming in and hopefully another to follow depending on potential need.
Very good feedback regarding your initial reaction to your new Ultra....thanks and enjoy it!!
getech is offline
post #184 of 10742 Old 09-03-2007, 06:59 PM
getech's Avatar
By the way, if anyone needs an Velodyne SMS-1, I can get you one for $539 delivered...brand new, and factory sealed. Great addition for your HT and correctly dialing in your sub & speakers.
getech is offline
post #185 of 10742 Old 09-03-2007, 07:38 PM
AnthemAVM's Avatar
So I need Dual 13's and Dual Plus/2 as I like both sounds? How hard would it be to make that work?
AnthemAVM is offline
post #186 of 10742 Old 09-03-2007, 10:07 PM
Warpdrv's Avatar
With the SMS you are surely limiting your low end responce as it has such a really drastic rolloff under 20hz... which is a serious reason people are shooting for in HT..... I have one, and it makes for great protection for these low tuned DIY and what the new Ultra aiming for...
I have one, and I got a much better price on it then that...
But they are great units... but you could do better with Laptop and REW and a BFD....
I really would like a pair of the Ultras... contemplating very hard...
Warpdrv is offline
post #187 of 10742 Old 09-03-2007, 10:39 PM
otk
otk's Avatar
just do it
get out that credit card and do it, you only live once
All this noise about noise.
Finding the acoustic sweet spot.
otk is offline
post #188 of 10742 Old 09-03-2007, 11:28 PM
rossandwendy's Avatar
Quoted: 57 Post(s)
Liked: 57
Ron, great first impressions!
How big is your room, and is it sealed or open?
Cheers,
Ross
_____________________________________
Receiver: Marantz SR7008
Source: Oppo BDP-83 multi-region, Sony BDP790 3D
Display: Sony 45ES on Silver Ticket 120" screen
Speakers/Sub: EMP Tek R55Ti, R56Ci, R5Bi, dual Rythmik L22's
rossandwendy is offline
post #189 of 10742 Old 09-04-2007, 01:14 AM
Ron Temple's Avatar
Quoted: 163 Post(s)
Liked: 133
Cheers,
Ross
My family room is 18x14x8 with a 5' opening into the rest of the front of my house, about 5500 more cube. It's never really been a tremendous problem to pressurize the room as the rig is oriented away from the opening. The LP get's the first blush, the rest of the house gets the reflection. I don't have too many issues except room gain, no deep nulls near our LP. My wife wants me to move everything to our living room in the while she's at her moms. I been planning on it for a long time, just need to wire it (and I'm to tall to fit under the house).
post #190 of 10742 Old 09-04-2007, 07:20 AM - Thread Starter
Tweakophyte's Avatar
This wouldn't be the dad-went-out-of-town-let's-pwn-his-HT test... would it?
... starting the long process of upgrading to 4K in the Home Theater...
Tweakophyte is offline
post #191 of 10742 Old 09-04-2007, 04:28 PM
movies2090's Avatar
Quoted: 37 Post(s)
Liked: 25
Here are my newer numbers. I moved up my chair a few feet forward. All these numbers are uncorrected. My test CD was calibrated to 80db at -17Master Volume. How do these look now? any better?
15hz-68.5
20hz-80
25hz-90.5
30hz-93.5
35hz-92.5
40-94
45-95
50-100
55-102
60-98
65-91
70-87.5
75-91
80-94
85-93
90-86
95-77
movies2090 is offline
post #192 of 10742 Old 09-04-2007, 04:45 PM
mojomike's Avatar
Liked: 30
Those numbers look better. How does it sound now?
You can use the PEQ to bring down the peak from 50 - 60 hz and they will look even better.
mojomike is offline
post #193 of 10742 Old 09-04-2007, 05:56 PM
MusicFirst's Avatar
Is this true even after the latest update that has the lowest filter to adjust going down to 5Hz? Doesn't seem to make much sense that you could adjust down at the 5Hz area if there is no signal to really adjust.
MF
MusicFirst is offline
post #194 of 10742 Old 09-04-2007, 08:29 PM
peyton18's Avatar
Sorry, to jump in at this point guys but want to be sure on this. Does the Ultra come with PEQ, I have read SVS's advertising and it claims additional controls for "room compensation". Your thoughts? Also, as an earlier poster mentioned. For 80%HT/20% Music would I be better off with the plus 2's?
peyton18 is offline
post #195 of 10742 Old 09-04-2007, 08:37 PM
mojomike's Avatar
Liked: 30
Peyton, the Ultra has a single band PEQ as well as a Room Compensation control.
The Plus/2 will get you slightly more overall output above 25hz, but the Ultra will play deeper and should have better sound quality.
mojomike is offline
post #196 of 10742 Old 09-04-2007, 08:43 PM
Willd's Avatar
MF
Yes, its still true, even with the latest update. Crazy, I know.
Willd is offline
post #197 of 10742 Old 09-05-2007, 06:45 AM
Warpdrv's Avatar
MF
That fix was found to be ineffective..... the heavy roll off still exists...
Warpdrv is offline
post #198 of 10742 Old 09-05-2007, 07:19 AM
kweezr's Avatar
Frequency response comparing dual PB13s vs. PB12-ultra/2 at 20Hz tuning
kweezr is offline
post #199 of 10742 Old 09-05-2007, 11:15 AM
MusicFirst's Avatar
That really sucks! I have not used mine in a couple of months due to moving, not sure if I want to use it now. If I use the bypass mode will it still roll-off like that? I'm thinking I can use the 1-band auto-PEQ in my f113 to tame the worst freq. problem in my room and hopefully that will be good enough for movies, and use a preset on the SMS-1 for music listening. That or maybe I should just get a PB-Ultra 13 for movies (the future wife might kill me though (she thinks the f113 is too big already)
MF
post #200 of 10742 Old 09-05-2007, 01:02 PM
AnthemAVM's Avatar
Has Velodyne recognized the problem, and are they working on it? I have been very spoiled that the one company I have worked with (Anthem) has been great about fixing bugs.
Michael
post #201 of 10742 Old 09-05-2007, 01:44 PM
Heinrich S's Avatar
Liked: 30
It has been announced that a firmware update will disable the subsonic filter outright (if you choose to do so). I think the update is downloadable now.
Cheers !
Heinrich S is offline
post #202 of 10742 Old 09-05-2007, 01:52 PM
Warpdrv's Avatar
Cheers !
Do you possibly have a link to that information Heinrich....
Interesting, I haven't heard anything about that fix... I have the SMS and I like it... but the steep rolloff will have limitations for my system when I complete my Dual 15" DIY subs.
Warpdrv is offline
post #203 of 10742 Old 09-05-2007, 02:00 PM
Heinrich S's Avatar
Liked: 30
I spoke to Curt and he revealed to me that there would be a firmware update to disable the subsonic limiter. If you go to the Velodyne support thread, go back 2 pages or so.
post #204 of 10742 Old 09-05-2007, 02:23 PM
Mozvz's Avatar
Is this the version you are referring:
This is NOT the latest software version for the SMS. The new firmware is NOT posted yet on Velo's web site.
Version 2.12
This is a special version of the SMS-1 software that permits setting the subsonic filter down to 5 Hz. This should only be used for subwoofers capable of reproducing frequencies this low (not common). All other functions of the SMS-1 perform identically to the 2.1 version.
http://www.velodyne.com/velodyne/sup...x?sid=208d786c
"Man plans, God laughs"
Mozvz is offline
post #205 of 10742 Old 09-05-2007, 02:25 PM
Richard Mayer's Avatar
Version 2.12
No. The new firmware is not yet available.
Richard Mayer is offline
post #206 of 10742 Old 09-05-2007, 02:29 PM
Mozvz's Avatar
Richard,
Thanks for the clarification!! I just wanted to post that version in case someone thought it was the new version. It's obvious the 2.12 version is not the fix the previous poster was referring to in his post. I'll edit my previous post to bring it to anyone's attention it's not the latest version that will be available ??.
Mozvz is offline
post #207 of 10742 Old 09-05-2007, 02:37 PM
Heinrich S's Avatar
Liked: 30
Perhaps Bruce can chime in. It has been confirmed by both Bruce and Curt that the subsonic filter will be able to be bypassed completely. I am getting my own SMS-1 hopefully tommorrow so this is good news indeed.
post #208 of 10742 Old 09-05-2007, 03:23 PM
Warpdrv's Avatar
All this discussion is off topic from the SVS, lets take it to the Velodyne Thread...
Including myself...
Warpdrv is offline
post #209 of 10742 Old 09-05-2007, 03:26 PM
Yes, it will be available (did someone say by the end of September?). But it's not the v2.12, which has been available for many months already. v2.12 doesn't bypass the subsonic filter, or even set it down to 5 Hz (even though they say so). Let's hope the new firmware will offer a relatively flat response down to ~DC.
post #210 of 10742 Old 09-05-2007, 05:52 PM
ggunnell's Avatar
I know a lot of folks worked hard on the new Ultras, but I want to direct a compliment to Mr. Stephen Ponte the Ultra13 driver designer, for coming up with a driver that will put out an enormous amount of subsonic energy and will still play small ensemble bass at low listening levels. It's very difficult to design a transducer that responds linearly in both small signal conditions and large signal conditions. Thanks, Stephen, and everyone at SVS, for making this available. IMO, YMMV, etc.
ggunnell is offline
Svs Sb13 Ultra Piano Gloss 13 Inch 1000 Watt Powered Subwoofer
