User experiences on Velodyne SMS-1 - Page 10 - AVS Forum | Home Theater Discussions And Reviews
Old 12-19-2010, 09:03 PM
math wizard's Avatar
Quoted: 33 Post(s)
Originally Posted by TJHUB View Post
They are unaltered as are the high pass outs. Both work with the unit turned off.
Does this mean no ADC to DAC conversions?
Emotiva UMC-200, USP-1, XDA-2, XPA-2, XPA-3, ERC-1, OPPO UDP-203, Polk Audio RTi12, Polk Audio CSi5, Polk Audio RTiA1, Epik Knight, Velodyne SMS-1, Sony XBR65X850C, DirecTV C61K (4K Genie Mini), APC H15, Emotiva CMX-2, Harmony Touch, Emotiva X-series Cables
math wizard is offline
Old 12-19-2010, 09:19 PM
TJHUB's Avatar
There is no conversion.
TJHUB is offline
Old 12-19-2010, 10:25 PM
eiger's Avatar
Quoted: 12 Post(s)
I'd like some advice from the pros -
I have a dedicated HT room where I recently added a second sealed ED A7s-450 sub. (Dual 18"'s). I'm spending lots of time learning about optimizing for room response.
I have MultiEQ XT with my system, but I'd like recommendations on if fine tuning my room with Auddsesey and if that's enough for my EQ/Bass Management needs, or a more elegant solution such as the SMS-1 is helpful.
Feedback appreciated.
eiger is offline
Old 12-19-2010, 11:59 PM
mojomike's Avatar
Liked: 30
What I do is run the Audyssey, then follow it by tweaking the bass afterward with the SMS-1
mojomike is offline
Old 12-20-2010, 12:43 AM
edoggrc51's Avatar
Quoted: 51 Post(s)
Liked: 64
Same here.
edoggrc51 is offline
Old 12-20-2010, 07:45 AM
enricoclaudio's Avatar
Quoted: 1127 Post(s)
Liked: 1168
Originally Posted by edoggrc51 View Post
Same here.
Another same here.
Enrico Castagnetti @ Rythmik Audio
Media Room: Ascend Acoustics Sierra Towers w/ RAAL, Horizon w/ RAAL & Sierra 2s | Rythmik F12SE (x2) | Marantz SR7008 | Parasound Halo P5 | Emotiva XPA-3 & XPA-200 | Oppo 105D | Sony HW40ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac|
Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz NR1606 | Emotiva XPA-200 Gen 2 | Samsung UN50JU6500 |
enricoclaudio is offline
Old 12-20-2010, 08:29 AM
Rob Morse's Avatar
Quoted: 106 Post(s)
Liked: 41
Thanks for the reply. another question, Are the signals coming from the "THRU" output of the SMS-1 unaltered? I thought that I read that the signal from this output was unaltered, but I can't remember the source of that information.
Yes, the Thru-puts are unaltered.
When in comes to audio there are seldom right and wrong answers.  The opinions of "experts" are just that, and should be used as a suggestion only.  Remember at the end of the day it is your money, your system, and you will need to listen to it.
Rob Morse is offline
Rob Morse's Avatar
Quoted: 106 Post(s)
Liked: 41
This is our recommendation.
Old 12-20-2010, 10:05 AM
bsoko2's Avatar
Quoted: 71 Post(s)
Liked: 78
You want to set up your sub first with the SMS-1, then run Audyssey. If you run Audyssey first then run the SMS-1, you can screw up the Audyssey settings. Always, set the sub(s) up first, then run the reciever EQ like Audyssey or MCACC.
bsoko2 is offline
Old 12-20-2010, 10:45 AM
SharpOne's Avatar
Quoted: 21 Post(s)
I thought you were just supposed to run Audyssey first with the EQ in the system, so Audyssey could account for the time delay. Then run the sub EQ over the top of that as it had more filters available for finer tuning.
lol, I think I'm confused now!
SharpOne is offline
Old 12-20-2010, 11:05 AM
Rob Morse's Avatar
Quoted: 106 Post(s)
Liked: 41
You are able to run the Audyssey or the SMS in either order. Remember if the Audyssey was doing such a phenomenal job to begin with then your subwoofer response would already be flat and there would be no need for the SMS-1 at all. Why dial in the subwoofer with the parametric EQ then allow Audyssey to change it?
Ultimately in our testing we found running the SMS after Audyssey yeilded the best results in our room with our equipment. As always your individual results may vary.
bsoko2's Avatar
Quoted: 71 Post(s)
Liked: 78
Audyssey will tell you to run the sub EQ first then Audyssey. Audyssey is always the final as it sets it's filters for the whole system. You never want to change what Audyssey has set.
bsoko2 is offline
Old 12-20-2010, 11:57 AM
ninja12's Avatar
+1. I also think it's best to run the sub eq first and then run Audyssey. Remember, Audyssey is hearing everything and making decisions based on what it hears. I don't think it's a good idea to adjust the sub's eq after Audyssey has run. I thinking having the sub eq'd first and then run Audyssey may make it easier on Audyssey and cause Audyssey to apply its' resources in other places if the sub eq is good. For my setup, that's how I do my system. But, every room and every setup is different. So, it really boils down to what works best for you and your setup. Good luck to you.
ninja12 is offline
Old 12-20-2010, 12:24 PM
Rob Morse's Avatar
Quoted: 106 Post(s)
Liked: 41
The chicken or the egg conundrum will continue forever.
Old 12-20-2010, 12:26 PM
Rob Morse's Avatar
Quoted: 106 Post(s)
Liked: 41
Except the part where Audyssey sets the LFE gain to near -8dB on many systems.
Old 12-20-2010, 12:31 PM
ninja12's Avatar
I agree with that too. Decisions decisions. Who's right. Who's wrong. I guess we will never know the real answer, and they said this hobby was straight forward.
ninja12 is offline
Old 12-20-2010, 12:35 PM
ninja12's Avatar
I would think that means the sub's volume is too high. I would just turn down the sub volume and rerun Audyssey. For my setup, which I have 2 DD-18s daisy-chained together, and love them very much, good job Velodyne, I have my volume set on 2. Inside my pre-pro, the volume trim for my sub channel is +1. They fill my 4032 cubic feet room very, very, very nicely. The bass is full, clean, and very accurate. My wife always ask me why do I always look like the Joker.
I will post my chart, from my room correction system, tonight.
ninja12 is offline
Old 12-20-2010, 02:21 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
Whichever order you run them in, if you're going to use them together, it's important to have the SMS-1 in the system before you run Audyssey. This allows Audyssey to account for the latency of the SMS-1's A/D D/A converters when it sets the Subwoofer Distance.
My preference, when I used the SMS-1 with Audyssey MultEQ XT, was to run Audyssey first and then clean up the resulting FR with the SMS-1. I would put the SMS-1 in Preset 6, (all filters flat), and then run Audyssey. After Audyssey XT, there were usually only some minor "tweaks" that needed clean up.
You're right, Rob! The latest version of Audyssey, XT32, does such a great job, that I have removed my SMS-1 from my system. Here is the Audyssey XT32 result on my 3 Submersives:
That's just the subs, (no speakers), but with an 80 Hz crossover. Yep, that's +/-1 dB from 16 Hz to 80 Hz. No need for a parametric EQ now.
Here is the total system response:
(The rising low end is from the DSP program in the Submersives, which was turned on after running Audyssey XT32.)
Anyway, I'm selling my SMS-1 to a friend. I don't need it anymore. At one time, it was a great addition to my system, but it has been outdated by Audyssey XT32.
Craig
Lombardi said it:
Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
Old 12-20-2010, 02:45 PM
ninja12's Avatar
As promised, here is my chart. It also has the rears and center channels along with sub. The red measurement, for the sub which also has the eq engaged, is what my room correction system, ARC (Anthem Room Correction), is hearing before applying any correction. The blue dashed lines is the target, and the green line is what it actually did as far as hitting the target. You will also noticed, in the other charts, that I introduced a little house curve which is kicking in around 300 - 400 Hz and the final result of the sub is factoring in the house curve. Also, all of my speakers are crossed over at 60 Hz. However, my sub is actually kicking in at 120 Hz since it doesn't have any problems at all up 120 Hz; but, ARC blends the sub, as well as the other speakers, very nicely. Anyway, enough with the typing. Here's the chart.
ninja12 is offline
Old 12-28-2010, 12:22 PM
larry7995's Avatar
Quoted: 49 Post(s)
Liked: 60
I ordered an SMS-1 from B&H yesterday, going to use it for my eD A7s-650 when it arrives
larry7995 is offline
Old 12-29-2010, 11:15 PM
Limp Fox's Avatar
Quoted: 32 Post(s)
Craig
I was thinking about ordering one of these and using it in favor of the eq.2 that came with my A7s 450, but after reading your post I think I will just mess with the eq.2 some more and wait untill I upgrade my Onkyo TX NR807 some time in the future to a receiver with XT32. Pretty impressive chart you had there with just running the newer Audyssey version
Judd
US ARMY: 11C48
Come on Retirement. May 2017, can't come soon enough!
Limp Fox is offline
Old 04-15-2011, 10:27 PM
vinodk's Avatar
Quoted: 84 Post(s)
Liked: 33
Does SMS1 have any processor delay & if so by how much?
Vinod
vinodk is offline
Old 04-15-2011, 10:32 PM
edoggrc51's Avatar
Quoted: 51 Post(s)
Liked: 64
While I'm not sure on how much the delay actually is, I do remember reading that you're suppose add 4ft to the sub distance to make up for the slight delay.
Old 01-01-2012, 01:46 PM
cuzed2's Avatar
Quoted: 188 Post(s)
Liked: 242
Just a a greedy personal bump to get this one near the top (for additional study later)
Cuzed2
CuznEddy Cinema
cuzed2 is online now
cuzed2's Avatar
Quoted: 188 Post(s)
Liked: 242
A greedy personal bumo - to bring this one back near the top
Cuzed2
CuznEddy Cinema
Old 01-01-2012, 02:11 PM
Topend's Avatar
I sold my SMS-1. It is the most user friendly PEQ out there and I learnt a lot from the experience of owning one.
I now use an Omnimic and the EQ built into my processor.
Dave.
Topend
I listen to 50% HT and 50% 2 channel music.
Topend is offline
Old 01-01-2012, 02:43 PM
cuzed2's Avatar
Quoted: 188 Post(s)
Liked: 242
I might have been your buyer.
About 3 weeks ago on ebay?
Cuzed2
CuznEddy Cinema
Old 01-01-2012, 03:24 PM
Topend's Avatar
Could be, I sent it to Perth.
Dave.
Topend
Topend is offline
Old 01-02-2012, 09:18 AM
cuzed2's Avatar
Quoted: 188 Post(s)
Liked: 242
Nope I am a different buyer - I'm in the Chicago area.
Sidenote: I played around with REW this past spring and eventually got results. However; the SMS-1 is awesome and way easy by comparison, and seeing results instantly is priceless!!
Cuzed2
CuznEddy Cinema
Old 01-02-2012, 01:14 PM
Topend's Avatar
Seeing the results instantly, even while making PEQ adjustments, sure is good.
Not only are you in a different city to my buyer, different country and hemisphere too.
Dave.
Topend
Topend is offline
