I need help connecting two subwoofers to one subwoofer output - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-09-2007, 09:52 AM - Thread Starter
kemiza's Avatar
Liked: 92
I own a Klipsch RSW-12 Subwoofer and a Def Tech Powerfield 15 Plus. When I connect the second subwoofer(Def Tech Powerfield 15 Plus) to the
line out(Klipsch RSW-12) it seems like both subs put out less
bass. Why is that? Is there a way to fix this? I even tried a y-cable from the subwoofer output on the receiver. The same thing happens. I think the preamp level/voltage from the receiver isn't strong enough for both subs.
Panasonic TC-P50ST60 plasma HD television, Onkyo TX-SR805 and PIONEER ELITE VSX-47TX receivers, Klipsch RB-75(2 pair) and RB-61 bookshelf speakers, Klipsch RSW-10, RSW-12(2), Velodyne HGS-12, HGS-18 subwoofers, OPPO BDP-103, PS3 80G, PIONEER DV-525 dvd player, Klipsch RS-42 surrounds, Klipsch RC-52 center channel
kemiza is offline
post #2 of 8 Old 10-09-2007, 09:53 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
That is what it sounds like. It is being attentuated to much when split.
Do you have good quality cables? Sometimes a cheap Y can make a difference. We are talking very low voltage...
Can you just turn them up accordingly?
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #3 of 8 Old 10-09-2007, 10:04 AM
bsoko2's Avatar
Quoted: 71 Post(s)
Liked: 78
Did you calibrate each sub individually and you need to use a good quality "Y" cable.
Bill
bsoko2 is offline
post #4 of 8 Old 10-09-2007, 10:22 AM
ggunnell's Avatar
Even if your receiver has no output level adjustment for the subwoofer, (if that's true put a new receiver on your Holiday shopping list ), there should be adequate output voltage to drive two subs -- if connected in parallel (as you are doing with the Y connector) each sub input will still see the full output voltage, perhaps less a small amount because of the lower total input impedance of the two subs in parallel.
A more likely scenario is that you have acoustic cancellation between the two subs. If either one of the two subs has a continuously varable phase control, try twirling it while bass is playing -- if just 0 or 180 degree switches, try both positions.
Your strongest bass, and your best blending of non-identical subs, and your easiest way to minimize acoustic cancellation, is to co-locate the two subs -- stack them or run them side by side.
ggunnell is offline
post #5 of 8 Old 10-09-2007, 10:25 AM
Splicer010's Avatar
Liked: 39
Just split the sub output on the AVR and run seperate lines to each sub...DO NOT connect one sub to the other one...
Splicer010 is offline
post #6 of 8 Old 10-09-2007, 10:41 AM - Thread Starter
kemiza's Avatar
Liked: 92
All cables are Monster. Turning up the volume doesn't help either.
kemiza is offline
post #7 of 8 Old 10-09-2007, 10:41 AM - Thread Starter
kemiza's Avatar
Liked: 92
Bill
Yes
kemiza is offline
post #8 of 8 Old 10-09-2007, 10:42 AM - Thread Starter
kemiza's Avatar
Liked: 92
Tried both ways. I think the voltage is too low for both subs.
kemiza is offline
