How do I hook up two subs (7.2)? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 10-17-2007, 05:59 PM - Thread Starter
SeanCJ's Avatar
Quoted: 74 Post(s)
Hello,
I am considering setting up two subs to cover my large room. The room is 24'x26' with 12 foot ceilings. I've been told that two smaller subs would cover the room far better than a single large sub.
Can someone explain how I would go about hooking this up and doing it right?
Sean
SeanCJ is offline
post #2 of 16 Old 10-17-2007, 06:02 PM
Max Lomax's Avatar
Loop out or RCA splitter.
Max Lomax is offline
post #3 of 16 Old 08-22-2008, 08:22 PM
matthewmon's Avatar
I have this same question. how can i have two subs? what do i need? can a 5.1 receiver do it?
matthewmon is offline
post #4 of 16 Old 08-22-2008, 08:35 PM
rlj5242's Avatar
Quoted: 48 Post(s)
Liked: 40
See post #2 for the answer.
And it will still be .1 even if you have 12 subs. There is still only 1 discreet LFE channel of sound no matter how many times you split the signal.
-Robert
rlj5242 is offline
post #5 of 16 Old 08-22-2008, 08:43 PM
penngray's Avatar
Liked: 43
I have 4 subs...one RCA connection on the back of the AVR.
Of course I added an EQ in between so mine has more wires involved but you can just use an RCA Y cable!!
penngray is offline
post #6 of 16 Old 08-22-2008, 09:09 PM
matthewmon's Avatar
can i plug into the 2 subs with speaker wire and then connect the front right and left speakers to the subs?
post #7 of 16 Old 08-22-2008, 09:18 PM
penngray's Avatar
Liked: 43
Do you not have an LFE channel on your AVR? I wouldnt use speaker wire (from your mains correct?)
I think you are not getting the full LFE and full potention of the crossover setup when you use your mains speaker wire.
penngray is offline
post #8 of 16 Old 08-22-2008, 09:28 PM
matthewmon's Avatar
its my only choice....my room is wired with 14gauge speaker wire. first people told me i had to have an rca cable and I was disappointed, then people said I could use the speaker wire for a sub and I got excited. which one is it?
post #9 of 16 Old 08-22-2008, 10:16 PM
Tulpa's Avatar
Liked: 61
Depends on your sub, but many can use both an RCA cable and speaker wire. Look on your sub. You should have an RCA input (or two) or speaker type binding posts/clips, or both.
Not sure how you'd do two subs with speaker wire.
RCA cable is easy. They make splitters. Are you sure you can't just run RCA cable?
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
post #10 of 16 Old 08-23-2008, 11:08 AM
matthewmon's Avatar
here are 3 pics of the front of my room. I don't see how I could use an rca cable, shoulda wired for it but at the time I had no idea where I would want it to go. the two speaker wire outlets have 14gauge speaker wire in them. I guess I'll just get one sub and put it along side the chair on the right and then wire from that sub to the front right speaker. I've had a couple people say it is possible....
post #11 of 16 Old 08-23-2008, 06:51 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
If you have speaker level connections on your subs, you could run "stereo" subs. Run the left channel speaker wire to the left sub and the right channel speaker wire to the right sub. From the subs, run speaker wire to the speakers. Then tell your receiver you have "no" sub(s) and set the left and right speakers to "large". This will redirect the LFE channel to the L/R speakers.
Craig
Lombardi said it:
Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #12 of 16 Old 08-23-2008, 08:38 PM
matthewmon's Avatar
awesome. i'll just try one sub first. i'm glad i can have a sub because for a while I was thinking I wouldn't be able to have one.
don't you want the LFE going to the dedicated sub though?
post #13 of 16 Old 08-23-2008, 09:00 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
Ummmm... you can't do "stereo" subs with just one sub.
Ideally, with an RCA level signal, yes, you would want a "dedicated" LFE + redirected bass subwoofer. You asked about how to do this with 2 subs and speaker level signals. My explanation was based on this.
Lombardi said it:
My System
post #14 of 16 Old 08-23-2008, 10:07 PM
matthewmon's Avatar
oh ok. so how do I do one sub w/ speaker level signals?
post #15 of 16 Old 08-23-2008, 10:24 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
If the sub has L/R speaker level inputs, you can use the sub as the "Bass Management" device. Run both speaker level inputs to the sub and both speaker level outputs to the speakers. Depending on how good the BM is in the sub, you can expect similar results to receiver-based BM. However, most subwoofers don't have "similar" BM capabilities as a good receiver/pre/pro.
What speakers, sub and receiver/pre/ro do you have?
Lombardi said it:
My System
post #16 of 16 Old 08-24-2008, 02:40 PM
matthewmon's Avatar
i want the bic acoustech h-100 sub and the speakers will be Definitive Technology Studiomonitor 350s. I haven't decided what receiver to buy. I just want what whatever the cheapest receiver is that will give me adequate power, 7.1...5channel + 2, and let me use my plasma tv, blu-ray, and dish network. thanks!
