Can't Decide Which SVS To Get - AVS Forum | Home Theater Discussions And Reviews
Old 11-20-2007, 07:40 PM - Thread Starter
jkmu2's Avatar
My theater room is 26X14. I am having trouble figuring out which model to get. I don't want to get something that is overkill though. I am thinking either the Pc Ultra or the PB Ultra 13. I have a stage with a proscenium so the cylinder would be ideal but would that affect the bass since its back there? The other option is getting the box sub and putting it out in front of the proscenium on the floor where the corner meets which would put it more out in the open and not behind a structure like the cylinder would be.
Also, for that size of a room are these subs overkill?
jkmu2 is offline
Old 11-20-2007, 07:46 PM
elmalloc's Avatar
Quoted: 51 Post(s)
Liked: 49
Contradictory statements, you don't want overkill yet you mention SVS latest and greatest subs.
elmalloc is offline
Old 11-20-2007, 07:49 PM - Thread Starter
jkmu2's Avatar
I don't want to skimp but will either of those be too much for a room that size?
jkmu2 is offline
Old 11-20-2007, 07:53 PM
McLoki's Avatar
You're in luck. As part of the clean sheet redesign for the new flagship ultra-13 sub, they added a volume control.
McLoki is offline
Old 11-20-2007, 08:02 PM
Ironmike86's Avatar
No get it then your done. Not over kill imo unless the room is sealed they you maybe able to go smaller but I wouldn't JME
Ironmike86 is offline
Old 11-20-2007, 08:04 PM - Thread Starter
jkmu2's Avatar
Ok, the volume knob would definately help. I just don't want to overpower everything else. I currently have a pair of Def Tech in wall subs which was stupid because the rattling is unavoidable and they just don't pack enough punch but oh well lesson learned.
jkmu2 is offline
Old 11-20-2007, 08:19 PM
ransac's Avatar
Quoted: 31 Post(s)
Liked: 41
In that size room, if it is a sealed room, then only the PB10 might have to strain. With either Ultra, you are getting the best sounding SVS sub with enough output headroom that the grin on your face will tell you it is not overkill.
Randy
ransac is offline
Old 11-20-2007, 08:33 PM
jhan1000's Avatar
There is no such thing as overkill... IMHO, getting the new Ultra13 is a no brainer if you can afford it.
Life is good.
jhan1000 is offline
Old 11-20-2007, 08:57 PM
mojomike's Avatar
Liked: 30
It's only overkill if you calibrate it too hot. The 13Ultra is about high SQ and a lot of headroom. Headroom is a luxury you should always try to afford. You don't actually hear headroom, but when you run out of it, the SQ goes right with it.
mojomike is offline
Old 11-20-2007, 09:10 PM
Warpdrv's Avatar
Get the 13, It won't be too long, and you will buy another one...
You can never have enough bass !!!!
Warpdrv is offline
Old 11-20-2007, 09:18 PM
lalakersfan34's Avatar
He's right. I got a PB10 for my tiny 11x10 room about a month ago and I've already talked to Ed Mullen from SVS about adding another SVS to my system. If you can afford an Ultra (PC or PB), get it! Sound quality will be excellent, and as mojomike said, headroom is something you never hear, but as soon as you run out it ruins the experience a la port chuffing, driver bottoming, and distorted bass that can't keep up with the rest of the system.
lalakersfan34 is offline
Old 11-21-2007, 05:57 AM - Thread Starter
jkmu2's Avatar
Ok, what about the cylinder vs the box sub? If I put the cylinder behind the proscenium will that affect the bass?
jkmu2 is offline
Old 11-21-2007, 07:22 AM
Summa's Avatar
Quoted: 104 Post(s)
Liked: 274
Am I the only one wondering what the f**k a proscenium is?
Summa is offline
Old 11-21-2007, 07:44 AM
tonybradley's Avatar
Unfotunately, I think you are
Do a search on the Dedicated HT thread.
Tony
tonybradley is offline
Old 11-21-2007, 07:47 AM
JKnPA's Avatar
Try a dictionary..........
http://dictionary.reference.com/browse/proscenium
* I can't help him, so I really didn't care what it meant......
John K.
JKnPA is offline
Old 11-21-2007, 07:50 AM - Thread Starter
jkmu2's Avatar
Basically, I have a stage and then dummy walls built on the left and right that are covered with gom fabric that hide the left and right channels. So the sound can escape but didn't know whether the sub being back there behind wooden structures would dampen the sound?
jkmu2 is offline
Old 11-21-2007, 09:47 AM
johnz11's Avatar
I haven't heard the PC but my PB13U is excellent and hard to fault from a sound quality point of view.
John
johnz11 is offline
Old 11-21-2007, 11:02 AM
jedi.night's Avatar
Quoted: 27 Post(s)
There is no difference between the box and cylinder subs of the same line.
Just a matter of taste really....box or round!
jedi.night is offline
Old 11-21-2007, 11:38 AM - Thread Starter
jkmu2's Avatar
I'm not worried about the difference. What I am curious about is if I go with the cylinder and put it back behind the stage whether all the wood from the structure will dampen the bass affect vs the box out on the floor in front of the stage.
jkmu2 is offline
Old 11-21-2007, 12:12 PM
Ron Temple's Avatar
Quoted: 163 Post(s)
Liked: 133
A definite maybe, depending on how much reinforcement it creates. I had a cylinder in a corner, loaded behind a big DLP, large fronts and a fully loaded rack/stand, with no drawbacks. It might be just fine. If you go with the cylinder and have to move it out, at least you can pick it up.
I don't lurk as much as I used to and I NEVER listen. Comes from being old and cynical.
Ron Temple is offline
