Official Elemental Designs Subwoofer Thread - Page 522 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #15631 of 15652 Old 12-27-2015, 05:14 PM
PTAaron's Avatar
Quoted: 26 Post(s)
Just for giggles I plugged up the port and ran a test...
Interesting result:
Sorry for all the separate posts... could probably just have done edits to the original...
-Aaron
My Basement Movie Room and Bar/Game Room - actually doing stuff now... please comment!
PTAaron is offline
post #15632 of 15652 Old 12-27-2015, 05:54 PM
hoopsrgreat's Avatar
Quoted: 42 Post(s)
Liked: 53
I bought my a7s-450 maybe 5 or 6 years ago. I have not had one issue with it. When I bought it, I was in a smaller house and had it in a living room. I have since bought a 2nd house with a dedicated movie room..... and of course I now want to run a second one. Anyone have one of these they looking to get rid of?
hoopsrgreat is online now
post #15633 of 15652 Old 12-27-2015, 07:29 PM
jstin's Avatar
@PTAaron , How did you plug the port? I don't know how to read the charts, do you think plugging it was beneficial? I just got a 1260w to replace the driver in my A2-300. Waiting for my repaired amp to come back from daveds50. In reading the booklet that came with the 1260w it seems to me that it prefers a non-ported box.
jstin is offline
post #15634 of 15652 Old 12-27-2015, 08:00 PM
PTAaron's Avatar
Quoted: 26 Post(s)
I rolled up a fleece blanket and stuffed it into the port...
I didn't leave it that way long enough to really play with it and listen to anything but it would be pretty easy to try it in the future. I'm no expert by any stretch of the imagination, so I'm not sure if it is worth doing or not.
-Aaron
PTAaron is offline
post #15635 of 15652 Old 12-27-2015, 08:52 PM
primetimeguy's Avatar
Quoted: 440 Post(s)
Liked: 248
Not an S, but someone in Minneapolis has an a7-450 on Craigslist for $500.
Sent from my SM-G360V using Tapatalk
primetimeguy is offline
post #15636 of 15652 Old 12-27-2015, 09:28 PM
mhuegerich's Avatar
I have an LT-500 and seem to have the somewhat common problem of blown fuse and dead amp. It's about five years old with about 600 hours of light use. Seems like it should last longer.
mhuegerich is offline
post #15637 of 15652 Old 12-27-2015, 09:31 PM
mhuegerich's Avatar
One follow up question... The Yung SD 500 amp seems to be a drop in replacement. Has anyone tried one of these? Seems like it may be the best route if I can't get the original repaired.
post #15638 of 15652 Old 12-27-2015, 09:44 PM
daveds50's Avatar
Quoted: 52 Post(s)
Liked: 32
600 hours is a lot for a Chinese amp. that is more than most last. this is not like the old days when manufacturers had pride in quality, this is China... i have a mid line Pioneer receiver that i bought brand new in 1977 that i still use in my office. it has never been worked on, yet, still gets played almost daily. that is not going to happen with most of today's budget electronics.
i responded to your message in a private message with my email address. but if you post two more times, you can answer me there.
the SD500 will work, but it is just more of the same. the original eD amp is a Yung. the new SD500 is a re-design... however, it is not an improved design, they just used cheaper parts. thats just the direction budget electronics are going these days. sad.
daveds50 is offline
post #15639 of 15652 Old 12-27-2015, 10:43 PM
aaranddeeman's Avatar
Quoted: 866 Post(s)
Liked: 234
Originally Posted by PTAaron View Post
I just added the polyfill back... guess it was just my imagination, only real changes is - the thing that is clear is that I need to move my seating if I can find a way!
Try flipping the sub 180 degree. In other words, the port should now be on opposite side.
If that is not possible, try if you can work with two 90 degree positions (port on left or right of current position).
I had a dip at 42 Hz (you can see my recent post). After flipping the sub 180 degree, the dip is not as deep. I will post the FR sometime later that shows both.
aaranddeeman is online now
post #15640 of 15652 Old 12-28-2015, 12:59 PM
PTAaron's Avatar
Quoted: 26 Post(s)
I'll give the turns a try - 180 won't work as a long term solution because it sits at the front of the room so the power light would be annoying
I'll play around with it some this coming weekend and do some graphs too
-Aaron
PTAaron is offline
post #15641 of 15652 Old 12-28-2015, 01:16 PM
Dr. Spankenstein's Avatar
Quoted: 21 Post(s)
Dave,
Obscure question here:
Do you know where on the amp board eD applied the SSF to the old LT1300 that they used in the A7s-450 and/or how to defeat it? I'm familiar with it's purpose, but I would prefer not to use the amp power just "boost" through it.
Any help would be appreciated and I will hold nobody responsible if I blow my driver.
This thing has served me well for a good number of years. Just want to see what it can do unfettered by the HPF. I believe it started somewhere around 20Hz.
Dr. Spankenstein is offline
post #15642 of 15652 Old 01-01-2016, 12:39 PM
rr14's Avatar
Quoted: 24 Post(s)
anyone know if there are any rebuild kits available for the 19ov.2 , 18" subwoofers? I have 2 with bad voice coils. Another that makes quite a bit of mechanical noise after I over drove it on my infinite baffle setup after rewiring. I'd hate to throw away the magnets and frames; could they perhaps be rebuilt using another brands gear/parts?
rr14 is offline
post #15643 of 15652 Old 01-02-2016, 03:29 PM
Limp Fox's Avatar
What's your location? I have one and am located in PA (zip: 17073). I never thought about selling it, but it just collects dust. I use my A2-300 because it works out better in my living room. It's in pristine condition. We could talk more through PM's if you're close and/or interested. I don't want to do it here and risk a warning or ban. I got one a few years ago
US ARMY: 11C38
another Deployment? ...you don't say
Limp Fox is offline
post #15644 of 15652 Old 01-14-2016, 05:48 PM
Quoted: 866 Post(s)
Liked: 234
Just wondering if I can find another A2-300 used, would that serve for a smooth bass response in my room.
I know it's rare to find these old subs, but that seems cheapest solution than going for entirely new one sub or a pair.
Of course I have just replaced the driver in my existing A2-300 and I was dreaming if I can find him a buddy, that would make a great pair.
What do guys think?
post #15645 of 15652 Old 01-15-2016, 09:15 AM
PTAaron's Avatar
Quoted: 26 Post(s)
What do guys think?
I was having the same thought actually... That or building a clone...
-Aaron
PTAaron is offline
post #15646 of 15652 Old 01-15-2016, 09:43 AM
JT78681's Avatar
Quoted: 1026 Post(s)
Liked: 667
The thread that never seems to die.
Display - Vizio M70‑C3
Receiver - Denon 4311CI
Speakers - Klipsch RF-82 II's, RC-62 II, RB-61 II's
Subs - Rythmik FV15HP's
JT78681 is online now
post #15647 of 15652 Old 01-15-2016, 09:53 AM
Quoted: 440 Post(s)
Liked: 248
What do guys think?
I may have a couple A2-250 for sale in the next month or so as I upgrade. Mine are the 10" which I think are the a2-250. Is the a2-300 the 12"? Mine also have the original drivers swapped with the Infinity 1060W.
post #15648 of 15652 Old 01-15-2016, 05:08 PM
Quoted: 866 Post(s)
Liked: 234
I flipped the original ED driver on CL. SO my effective price of swap to Infinity 1260W is just $10
post #15649 of 15652 Old 01-15-2016, 05:31 PM
Quoted: 866 Post(s)
Liked: 234
Yeah. The problem is, a2-300 is 12" and I would like to get the identical twin.
Secondly shipping that beast would cost fortune. Local pickup is the only viable option.
post #15650 of 15652 Old 01-16-2016, 09:20 PM
Quoted: 866 Post(s)
Liked: 234
Any idea how much max to pay for the A2-300 used?
post #15651 of 15652 Old 01-16-2016, 09:28 PM
PTAaron's Avatar
Quoted: 26 Post(s)
No clue, sorry. I've just been pondering the idea, haven't researched it much as the theater budget is $0 at the moment
-Aaron
PTAaron is offline
post #15652 of 15652 Old Yesterday, 07:55 PM
John Mauro's Avatar
A5-350 Replacement Driver
Is there a recommended upgraded 15" driver for the A5-350 that fits without modification?
John Mauro is offline
Subwoofers , Elemental Designs
