Anyone add veneer to their eD sub? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-21-2007, 08:21 AM - Thread Starter
iceperson's Avatar
I asked this over in the DIY forum, but adding veneer to a sub that hasn't been assembled is a bit different than adding veneer to an already completed, sub so I thought I'd ask here.
Anyway, has anyone ordered an unfinished sub from eD and added a veneer to it? What I'm most concerned with is how you went about the bottom and back of the sub. Did you just cut out holes for the woofer, ports, and amp and lay the veneer down, or did you remove those items from the box, lay and finish the veneer, then reattach those pieces? If anyone's done this and has pics that would be even better.
Tia
iceperson is offline
post #2 of 8 Old 12-21-2007, 09:09 AM
eRob's Avatar
Painting around the amp would be pretty easy. Just tape it off around the edges of the amp. I wouldn't even worry about the bottom since you wont be able to see.
-Nevermind. For some reason I thought you said paint and not veneer. Sorry, can't help you there.
eRob is offline
post #3 of 8 Old 12-21-2007, 11:49 AM
nebster's Avatar
mine is veneered but i can't post pictures until after its complete as it is a present for my father. its a sealed unit (a5s-350) but as soon as i can i'll post pics and my diy thread
nebster is offline
post #4 of 8 Old 12-21-2007, 12:47 PM
phatnogin5877's Avatar
cant wait to see the pics. Great gift by the way.
I got the pistol so I get the pesos
phatnogin5877 is offline
post #5 of 8 Old 12-21-2007, 01:51 PM
vitod's Avatar
Quoted: 272 Post(s)
Liked: 147
That's what great about eD is, you can tailor their sub offerings the way YOU want it. Unlike SVS, HSU where it's complete and that it. Not dissing them. Far from it. Just eD builds to suit.
Very nice.
Panasonic AE-8000, Carada BW 120", Paradigm Studio 40v3 x 2, Paradigm 690v4, Paradigm ADP 470v3 (rears), Micca M-8C x 4, Volt 6 x 2 (SR), SI DS4-18 in 12cuft X 2, Marantz 7702MKII, OPPO 103D, Emotiva XPA-3,
vitod is offline
post #6 of 8 Old 12-21-2007, 02:00 PM
sean_w_smith's Avatar
Very nice.
so you can buy an eD sub veneered?
That's news to me....
Sean
sean_w_smith is offline
post #7 of 8 Old 12-21-2007, 02:23 PM
sivadselim's Avatar
Quoted: 260 Post(s)
Liked: 220
NO. You can buy one unfinished, though, and veneer it yourself.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #8 of 8 Old 12-21-2007, 02:30 PM
vitod's Avatar
Quoted: 272 Post(s)
Liked: 147
Correct.
vitod is offline
