Want advice on what sub to purchase? Please read this before posting... - Page 12 - AVS Forum | Home Theater Discussions And Reviews
 10Likes
post #331 of 347 Old 07-09-2015, 12:02 PM
troyh4's Avatar
Quoted: 64 Post(s)
Hey everyone,
I've been out of the HT game for over 5 years. I'm hoping in the next year or so, I'll be able to get back into it. I recently bought a new house and it has an upstairs room that measures 13'x14' w/ 9' ceilings.
Carpeted, 1 window, sheet rock, and double French doors into it.
I will be piece mealing my equipment as I go along. For speakers, I really like the SVS Prime line. And their SB-13 sub. However, a sub of this magnitude, I'm wondering if it just plain and simple "too much sub" for a small room like mine. I don't plan on jacking my volume to ear bleed levels when watching movies or music. My neighbors are within 15 feet of me on both sides, yes, homes close to each other but I likey.
So having a loud volume probably won't be in my favor.
What are yall's thoughts on a sub like this for my room size? and or any other sub recommendations?
Troy
troyh4 is offline
post #332 of 347 Old 09-30-2015, 01:07 PM
therh86's Avatar
Quoted: 14 Post(s)
Hello,
I have recently bought a pair of Polk Audio Rti A7's, and are fantastic on their own. My room is 13'x15'x8' , and I would like to know what some recommendations on a sub to pair with them? I am looking only to emphasize the lows, but I do not want to "hear" the sub, just add to the lower end.
RH
therh86 is offline
post #333 of 347 Old 09-30-2015, 01:36 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1995
Originally Posted by therh86 View Post
Hello,
RH
What's your budget?
jbrown15 is offline
post #334 of 347 Old 09-30-2015, 08:02 PM
therh86's Avatar
Quoted: 14 Post(s)
I'd like to spend around $600 max.
therh86 is offline
post #335 of 347 Old 09-30-2015, 10:01 PM
jbrown15's Avatar
Liked: 1995
I've heard Rythmik Audio's LV12R and at under $600 its a pretty good sub. Outlaw Audio has their new Ultra-X12 for $639, so $40 over your budget but I've heard that's suppose to be a nice sub too!
jbrown15 is offline
post #336 of 347 Old 10-10-2015, 11:22 AM
therh86's Avatar
Quoted: 14 Post(s)
Any other suggestions?
therh86 is offline
post #337 of 347 Old 10-13-2015, 05:16 PM
kbuzz's Avatar
Quoted: 27 Post(s)
Hello All- I am working on a 3rd system in my basement and would appreciate recommendations to use with a vintage pair of A/D/S L300 mini monitors. The ADS --to my ear-- hit about 100hz maybe a tad lower as i believe there is some "bass bump" on these, but I can't confirm this as have not been able to find frequency range on the web. Anyway, given the small size I would think I need a sub that is more mid/upper bass proficient rather then hitting super lows but thats why im posting. Criteria is:
1. Budget. Id like to stay less then $500 all in and would no doubt consider used if shipping costs are "reasonable"
2. Size requirements/limits. I have some corner space so could probably accomadate up to a 15" but prefer a bit smaller.
3. Room dimensions. The room is l shaped and about 14 wide by 20 long, with another 6 x 10 off to the side.
4. Primary uses. 90 percent music.
5. Listening habits basic music and a bit of film....dont need to shake the foundation.
6. Appearance requirements. No issue, i dont even care if its veneered or plywood.
7. Timeframe. Next month or two.
So if anyone can chime in an models from the usual suspects, Hsu, SVS, etc it would be appreciated.
Thanks anyone for suggestions......
kbuzz is offline
post #338 of 347 Old 01-11-2016, 10:16 PM
Liked: 0
If not Rythmik LV12R then SVS PB/PC2000?
For a previous post I picked up the recommendation for Rythmik LV12R, however it is still out of stock and I'm getting impatient
Wanted some advise if I increased my budget and go for SVS PB2000 or PC2000, is there a difference that would justify the price difference from Rythmik?
1) 20 x 10 x8 space, with one side (20 feet) open to rest of the basement.
2) Currently have CM8 LR with HTM61 for center
3) using ML DYnamo 500, which is fine for the big sounds but I don't get the clarity and real low sounds ..
4) usage is 80% movies
Thank you!!
Bing2015 is offline
post #339 of 347 Old 02-07-2016, 12:12 PM
Liked: 0
Hello. I am currently trying to build up my home theater system. Currently using a kenwood 8" ported sub from a htib from 99 and it is definitely my weakest link. Using onkyo TX-NR626, JBL northridge surround speakers. Looking for good frequency range, especially for the lows in the music I listen to. EDM is primary music type, but also listen to pretty much everything else.
Criteria is:
1. Budget. Id like to stay less then $500 all in considering I will buy another one at some point.
2. Size requirements/limits. Would like to have a dual sub setup eventually, so nothing too large.
3. Room dimensions. The room is 15' x 25', window wall on left of system, open archway on right.
4. Primary uses. 60% home theater, 40% music
5. Listening habits: mostly home theater, but want enough to give a decent shake in the room. Music, mostly electronic, edm, dance with occasional country and classic rock.
6. Appearance requirements. Nicely finished, black.
scarfache is offline
post #340 of 347 Old 11-28-2016, 09:26 PM
the_r's Avatar
JL d110, SVS, or Paradigm?
Hi All,
I thought I knew a little bit about subwoofers, having spent countless hours in forums and reading hundreds of reviews, but after stopping by a JL audio store today, I feel more lost than I've ever been.
Just bought a new (old) semi-detached home, and working on a home theater in the basement. Problem is I live in Canada, and our selection of easily accessible subwoofers is limited. Here are the vitals:
1) ~1850 cubic feet basement (20' x 15' x 6'2)
2) Budget is $1400 CAD
3) 95% movies, TV, and video games, 5% music
4) Size isn't a huge factor
5) Setup includes Onkyo 747, KEF Q700 L/R, Q200c C, Q100 rears
6) Output probably not as important as the quality of the bass and the extension
So I went to a high-end audio store today, and the gentlemen that I spent an hour talking to was super helpful. He sold Paradigms, JL, Klipsch, Monitor Audio, among other pretty high end stuff, so he knows what he's talking about. I asked him about Paradigms as he was an authorized seller, and after a few minutes, he was directing me towards JL. He swears by it, and says they make the best stuff. I don't know enough about JL except that they make really expensive stuff that I feel I can't really afford. I can tell he was trying to sell me the best sub for the money, but the problem is the best sub for him may not be the best sub for me. It's like saying between a Porsche Boxster, BMW M2, and Corvette, he thinks the Porsche is the best car for my money. The Porsche might just be the most fun to drive and the most balanced car, but maybe I like the styling better in the M2, or sheer performance of a new Vette. He focused a lot on making sure the sub wasn't just big HT boom-boom-boom, and that it was fast and accurate, and that it blended well with my existing setup of KEFs (says they are very musical speakers).
Now, I don't have thousands of hours of subwoofer listening experience, and it's not like he had SVS and Paradigms to demo for me to compare which one I preferred, and I think that's the problem with subwoofer shopping. For cars, it feels so much easier, because you can literally test drive the cars, likely not on a track, but still, the test drive helps immensely. For subs, there are so many barriers - store HT-dedicated rooms are nothing like your actual setup; SVS is internet only so no demos, and I can't return an SVS since I'm from Canada; and no store will have the subs you're shopping for actually around for you to compare all at the same time.
In the end, my question is not just "what sub should I get" based on the above, but I'm looking for people with actual listening experience between ported and sealed subs that can maybe shed some insight. The store guy recommended only sealed subs, because ported ones just wouldn't be fast enough and accurate he said. I'm sure that's all well and true, but what if I don't appreciate that as much as he thinks I should? It's so hard because I really don't know what I like, and at my price point, some subs will do better at certain things than others. I don't have a $10K to spend on a sub that will do everything well. I feel like at my price point, some will go loud, some will go deep, and some will be fast/accurate - but I only get to choose 2.
Or perhaps I'm overthinking this as I usually do, because if I get either one of the 4 subs I'm considering, I'd be happy with any, which is not what the store owner thinks (says I gotta go sealed). Anyways, here are my top picks in no particular order:
- SVS PC2000
- JL d110
- SVS SB2000
- Paradigm SUB 12
Thoughts?
Thanks guys.
BarryDMartin likes this.
the_r is offline
post #341 of 347 Old 01-02-2017, 01:51 PM
Quoted: 38 Post(s)
Liked: 8
Hi - I have short listed two subs.
- BIC F12. New unit $225 with shipping and tax
- Klipsch SW110. 8 month old sub from craigslist for $180
I will be starting with Elac B6 and will be expanding to 5.1 as $ becomes available. My receiver is Denon avr-s510bt
1. My budget. ~225 with shipping and tax. I am in south eastern PA
2. Size requirements/limits. none
3. Room dimensions. 19x15 . TV will be moved to 19 ft wall. Height - half the room is 9 feet and the other half goes to rafters with the highest point being ~13.5 feet. Pic attachd.
4. Primary uses. 60% movies and 40% music
5. Listening habits. watching movies and listending to music at middle or middle+ volume. We never go high.
6. Appearance requirements. None.
7. Timeframe. 1 month.
Thank you for your time.
SM
smoideen1 is offline
post #342 of 347 Old 01-21-2017, 05:38 AM
Anji12305's Avatar
Quoted: 30 Post(s)
I would not consider a secondhand sub out of warranty. These are like sports cars or minivans - they get heavy use and little maintenance.
Have a browse of Monoprice and Emotiva.
Sent from my Nexus 6 using Tapatalk
Anji12305 is offline
post #343 of 347 Old 02-01-2017, 02:13 PM
Wheelhop's Avatar
Originally Posted by the_r View Post
Hi All,
- SVS PC2000
- JL d110
- SVS SB2000
- Paradigm SUB 12
Thoughts?
Thanks guys.
Hi The_R, I'm very happy with my SVS PC12 plus purchased several years ago. Like you I am in Canada(Alberta) and was nervous to buy before trying. At least they have free shipping in Canada now. And they will always let you upgrade if you were not satisfied. If I were you I'd call sonic boom audio and see what kind of deal you can get on the PC-2000 over the phone. I understand your reservations but it's really one of the best subs available in this price range.
I think you're smart to be going ported rather than sealed since it's mostly for movies, most music buffs are the ones to go sealed. We theater/gamer types need the added output and low impact from the ported subs. My HT is in a cement basement like you, I would encourage you to look into DIY bass traps in the corners as the bass can get boomy with the cement walls. Here's a picture of my theater, you can see my triangular bass trap floor to ceiling in the corner. I've loaned my speaker before for someone to sample, maybe you can find someone to do the same?
My system:
Samsung UN75F6300
Integra 40.2
SVS Prime towers/center/satilites
SVS PC-12 plus sub
Name:	old iphone pics 009.jpg
Wheelhop is offline
post #344 of 347 Old 02-07-2017, 12:21 PM
Quoted: 394 Post(s)
Liked: 280
Hi All,
- SVS PC2000
- JL d110
- SVS SB2000
- Paradigm SUB 12
Thoughts?
Thanks guys.
JL makes nice subs, but you are paying for the compactness more than anything. I would NOT go with the Paradigm, they make good speakers, but you can get better subs for the money. Of the options you listed, I PERSONALLY would probably go with the JL just cause I like tiny sealed subwoofers and just overall aesthetics, that said, of your list, I suspect you would be most happy with the SVS PC2000.
amnesia0287 is offline
post #345 of 347 Old 02-09-2017, 01:14 PM
Quoted: 30 Post(s)
Liked: 6
Looking for sub for big, open room
Hello all,
It’s been a while, but I’ve doing some upgrading and my subwoofer is suddenly the weak link. I have SF Venere S speakers, and a Mcintosh C2600 pre-amp, MC302 amp, and VPI Scout with 2M Black cartridge. Although I use the setup for movies, tv and 2-channel, I’m really only concerned with 2-channel stereo performance (hi-res music and vinyl). I live in a loft with 35 ft ceilings and the room where the equipment is is fairly large. I currently have a REL T9, which was great in my previous, smaller place, but it isn’t cutting it now. Also, I’d prefer one sub versus multiple, due to the way things are arranged. Bottom line is that I’m looking for a sealed sub that can handle the space.
I’m currently looking at a REL S/5, REL G2 and Revel B112. I’d love to hear from some folks with large rooms and high ceilings and whether any of the subs I’m considering worked or didn’t work … and any other suggestions for what DID work. I can probably demo one or some of these, which will help, but thought I’d reach out to this forum to get some advanced info.
Forty6&2 is offline
post #346 of 347 Old 02-18-2017, 07:36 PM
2 Stangs's Avatar
Quoted: 20 Post(s)
I currently have a SVS PB12-NSD which I bought right before they discontinued it. I am wondering if I would be better off switching to a sealed sub(s) given my room size. If so, which model would be the best to go with? I am partial to SVS.
1. Budget: anywhere up to 5K
2. Size requirements/limits. I am open to going dual if it will make a difference. Must be 22 Inch or less height so they fit under my screen.
3. Room dimensions. The room is a custom built closed off screening room with Klipsch RVX speakers.. 15L x 10W x 7H
4. Primary uses. 100% home theater
5. Listening habits: Movies, half volume.
6. Appearance requirements. Black, flat or piano
7. Timeframe. Early Summer
2 Stangs is offline
post #347 of 347 Old 10-15-2017, 04:05 PM
Alex solomon's Avatar
Quoted: 36 Post(s)
Looking for some advise for sub upgrade. My current setup:
Speakers: Polk LSiM 707, 706,703. Going 5.1.4 Atmos soon.
Receiver: Yamaha RX-A2070
Subwoofer SVS PB10 NSD .
Room size: 25 x 21 x 8'
Use: 100% HT
Listening habits: Never play louder than -10db, 0db being reference. Actually I listen at moderate volume almost of all the time, -15 to -20 on my old Onkyo 805 receiver, 0db being reference. Prefer extension and SQ over SPL output.
Budget: $1000, but might push to $1100.00 MAX!
Not sure if I should go for two 12" or one 15". Desired box size: would like to avoid fridge size boxes
Current list of subs I am looking at in no particular order:
1. Dual Rythmik LV12R Direct Servo
2. Dual Outlaw Ultra X12 (if I could get them on sale around Thanksgiving)
3. Dual HSU VTF-2 MK5
4. Single PSA S1500
5. Single HSU VTF-3 MK5 HP
6. Single HSU ULS-15 MK2
7. Single Rythmik FVX15
Help me narrow down to two possible choices. Also open to other suggestions up to my max budget of $1100.00. Thanks all.
Alex solomon is offline
