Best inexpensive Y splitter? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 02-13-2008, 12:32 AM - Thread Starter
MUCHO's Avatar
With all this talk of 2 subs, it seems the best way is to use a Y splitter.
Monoprice only seems to carry 1 version.
Anyone got a good reccomendation.
Also if I run three co-located subs, should I run with 2 Y splitters or is there s 3 way splitter?
MUCHO is offline
post #2 of 12 Old 02-13-2008, 12:56 AM
goneten's Avatar
Buy any Y-splitter.
--Regards,
goneten is offline
post #3 of 12 Old 02-13-2008, 02:06 AM
Jakeman02's Avatar
Next time you're around radio shack pick one up, you'll save on shipping and have it now, they aren't but a few bucks anyway, if you want to order online any of the options below would work.
http://www.partsexpress.com/pe/showd...number=189-300
Jakeman02 is offline
post #4 of 12 Old 02-13-2008, 03:56 AM
Jacksmyname's Avatar
Agree with the above posts.
I have two subs stacked, and just replaced the black cables with white ones (new house, and I'm a bit anal about how everything looks ).
I was using a "good" y splitter that's only about 6" long, but wanted to eliminate as much of the black color as possible (told ya I was anal ).
I just replaced it with this one:
http://www.radioshack.com/product/in...entPage=family
Works perfectly.
Jacksmyname is offline
post #5 of 12 Old 02-13-2008, 05:45 AM
John Ballentine's Avatar
I'm anal about how everything looks too - but I just changed out my white cables for black
John Ballentine is offline
post #6 of 12 Old 02-13-2008, 06:47 AM
Actually, the reason I switched to white is because the carpet is a neutral, sand color, and the wall paint is egg shell; white ceilings and trim.
While the cables for the subs aren't all that visible, some of it can be seen; hence the switch to white.
Did I really just use the word "hence"?
post #7 of 12 Old 02-13-2008, 09:28 PM
Vexthem's Avatar
If your subwoofer cable is (well) shielded, wouldn't it be a good idea to make sure that the splitter is shielded (well) too?
One that I found that seemed to be a good balance between price and confidence in the quality was an Acoustic Research Pro Series II PR142 (or PR142N). This is the 1F to 2M version, I think PR141 is 1M to 2F if you need that by chance.
I didn't purchase any yet because I am waiting to figure out what other cables and wires I need to save on shipping, but the best prices I found on this Y-cable was $12.70 at electotronics.com (but shipping is high for small orders) or $14.32 at homedecorworld.com (with lower shipping charges). The low price, high shipping place is probably only worth it if you order 3 or more cables (or other stuff). They are $30 at Partsexpress.com.
If anyone knows of quality shielded splitters for less, 1F to 3M splitters, or 1F to 4M splitters I'd love to know where to shop.
Vexthem is offline
post #8 of 12 Old 02-14-2008, 12:51 AM
Jakeman02's Avatar
Are you wanting a splitter or a Y cable, both accomplish the same thing. If a cable will work for you then check the link below, Dual shielding, 24k gold-plated connectors, Grooved finger grips and metal strain relief, Heavy-duty jacket, etc, for $1.88, PEs shipping isn't the cheapest in the world but it still comes out to just above 1/2 of the prices you listed. I would never pay $12.70 or $14.32 for a cable. I have less than that invested in all my cables, not including speaker wire of course.
As far as a splitter being non shielded I've used those also in the past, never had any issues or problems.
post #9 of 12 Old 02-14-2008, 01:29 AM
Vexthem's Avatar
I had been looking for a fairly short Y cable (several actually) for a sub and two Buttkicker Amps. That 13' Y-cable seems like an incredible deal (as long as the conductor is not super cheap/small). I ordered a few along with some 10 GA speaker wire and other stuff - so the shipping costs were spread pretty well.
I guess I subscribe to the chain/weakest link theory and prefer to have shielded splitters, Y-cables, whatever. But I am fairly new to much of this.
Vexthem is offline
post #10 of 12 Old 02-14-2008, 01:51 AM
Jakeman02's Avatar
It's a quality cable. I'm using 1 in my system now. I bought as many as I could at that price, kept a few and gave the rest to my needy friends who I've installed systems for.
post #11 of 12 Old 02-14-2008, 06:23 AM
weverb's Avatar
http://www.kongcable.com/products/13735.html
Analog: Pioneer SX-950, CT-F9191, AD797MCPS, PL-707, RH-65, RG-1, SR-202, Monitor 10/HE-500 hp's
Digital: Laptop, M2tech Young, Oppo 83, Simaudio i5.3, Dali Mentor
weverb is offline
post #12 of 12 Old 02-14-2008, 08:43 AM
mailiang's Avatar
Quoted: 842 Post(s)
Liked: 580
This is what I use for dual subs. It is specifically designed to split a line level output from your receiver. It's also great if your receiver is located in a tight spot, since it takes up the least amount of room. You can pick it up at your local Radio Shack or order it on line.
http://www.radioshack.com/product/in...entPage=search
Ian
The best way to succeed in life is to act on the advice you give to others
mailiang is offline
