Video pre-processing - Page 8 - AVS Forum | Home Theater Discussions And Reviews
post #211 of 212 Old 06-09-2010, 02:47 AM
yesgrey's Avatar
Originally Posted by JohnAd View Post
I probably felt that the exponent and transition point where more important than the other varaibles
Yes, I think you might be right and that would be preferable to keep the transition point and treat all values in the original regions with the same kind of formula. Of course this only makes sense if the standard formula was used for the encoding...
yesgrey is offline
post #212 of 212 Old 03-12-2012, 11:57 PM
ChuckZ's Avatar
I thought this little blurb might add something to the discussion:
What is super-resolution?
In a nutshell, motion-interpolated scaling!
ChuckZ is offline
Reply HDTV Software Media Discussion
